BCW29,235
BCW29,235
    NEXPERIA(安世)
    SOT-23
    PNP通用晶体管
BCW29,235 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET BCW29; BCW30 PNP general purpose transistors Product data sheet Supersedes data of 1999 Apr 13 2004 Jan 13 NXP Semiconductors Product data sheet PNP general purpose transistors BCW29; BCW30 FEATURES PINNING • Low current (max. 100 mA) PIN • Low voltage (max. 32 V). APPLICATIONS DESCRIPTION 1 base 2 emitter 3 collector • General purpose switching and amplification. DESCRIPTION PNP transistor in a SOT23 plastic package. NPN complements: BCW31 and BCW32. handbook, halfpage 3 3 MARKING 1 MARKING CODE(1) TYPE NUMBER BCW29 C1* BCW30 C2* 2 1 2 Top view MAM256 Note 1. * = p : Made in Hong Kong. * = t : Made in Malaysia. * = W : Made in China. Fig.1 Simplified outline SOT23 and symbol. ORDERING INFORMATION TYPE NUMBER BCW29 PACKAGE NAME − DESCRIPTION VERSION plastic surface mounted package; 3 leads SOT23 BCW30 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCBO collector-base voltage open emitter − −32 V VCEO collector-emitter voltage open base; IC = −2 mA − −32 V VEBO emitter-base voltage open collector − −5 V IC collector current (DC) − −100 mA ICM peak collector current − −200 mA IBM peak base current − −200 mA Ptot total power dissipation − 250 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb operating ambient temperature −65 +150 °C 2004 Jan 13 Tamb ≤ 25 °C 2 NXP Semiconductors Product data sheet PNP general purpose transistors BCW29; BCW30 THERMAL CHARACTERISTICS SYMBOL Rth(j-a) PARAMETER CONDITIONS thermal resistance from junction to ambient VALUE UNIT 500 K/W note 1 Note 1. Transistor mounted on an FR4 printed-circuit board. CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL ICBO PARAMETER MIN. TYP. MAX. UNIT IE = 0; VCB = −32 V − − −100 nA IE = 0; VCB = −32 V; Tj = 100 °C − − −10 μA − − −100 nA BCW29 − 90 − BCW30 − 150 − BCW29 120 − 260 BCW30 215 − 500 collector cut-off current CONDITIONS IEBO emitter cut-off current IC = 0; VEB = −5 V hFE DC current gain IC = −10 μA; VCE = −5 V DC current gain VCEsat VBEsat IC = −2 mA; VCE = −5 V collector-emitter saturation voltage IC = −10 mA; IB = −0.5 mA − −80 −300 mV IC = −50 mA; IB = −2.5 mA − −150 − mV base-emitter saturation voltage IC = −10 mA; IB = −0.5 mA − −720 − mV IC = −50 mA; IB = −2.5 mA − −810 − mV VBE base-emitter voltage IC = −2 mA; VCE = −5 V −600 − −750 mV Cc collector capacitance IE = Ie = 0; VCB = −10 V; f = 1 MHz − 4.5 − pF fT transition frequency IC = −10 mA; VCE = −5 V; f = 100 MHz 100 − − MHz F noise figure IC = −200 μA; VCE = −5 V; RS = 2 kΩ; f = 1 kHz; B = 200 Hz − 10 dB 2004 Jan 13 3 − NXP Semiconductors Product data sheet PNP general purpose transistors BCW29; BCW30 PACKAGE OUTLINE Plastic surface-mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 2004 Jan 13 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 TO-236AB 4 NXP Semiconductors Product data sheet PNP general purpose transistors BCW29; BCW30 DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings 2004 Jan 13 5 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R75/05/pp6 Date of release: 2004 Jan 13 Document order number: 9397 750 12403
BCW29,235 价格&库存
很抱歉,暂时无法提供与“BCW29,235”相匹配的价格&库存,您可以联系我们找货
BCW29,235
