ESDA0505CT6
ESDA0505CT6
    LEIDITECH(雷卯电子)
    SOT563
    雷卯 SOT-563 100W 5V
ESDA0505CT6 数据手册
SDA0505T6 5 Line ESD Priotection Array Features ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) Dimensions SOT-563 RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-563 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 100 W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/3 www.leiditech.com SDA0505T6 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A U5 5 6 1 9.8 SDA0505T6 (Max) (@A) 12 IR μA (Max) C (Pf) (Typ.) 1 30 5 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2018 2/3 www.leiditech.com SDA0505T6 SOT-563 Package Outline & Dimensions Inches Symbol Min. Nom. Max. Min. Nom. Max. A 0.020 0.021 0.023 0.50 0.55 0.60 b 0.007 0.009 0.011 0.17 0.22 0.27 C 0.003 0.005 0.007 0.08 0.12 0.18 D 0.059 0.062 0.066 1.50 1.60 1.70 E 0.043 0.047 0.051 1.10 1.20 1.30 e Soldering Footprint Millimeters 0.02 BSC 0.5 BSC L 0.004 0.008 0.012 0.10 0.20 0.30 HE 0.059 0.062 0.067 1.50 1.60 1.70 Symbol Inches Millimeters C 0.0531 1.35 G 0.0354 0.90 P 0.0197 0.50 X 0.0118 0.30 Y 0.0177 0.45 Z 0.0709 1.80 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 2/3 www.leiditech.com
ESDA0505CT6
物料型号:SDA0505T6
器件简介:5线ESD保护阵列,具有超低漏电(nA级别)、5V工作电压、低钳位电压,符合IEC 61000-4-2(ESD)和IEC61000-4-4(EFT)标准,符合RoHS标准。
引脚分配:文档中未明确提供引脚分配图或表。
参数特性:包括最大脉冲功率、ESD保护级别、工作温度范围、存储温度范围等。
功能详解:文档中未提供详细的功能解释,但提供了特性曲线图,包括8/20μs脉冲波形和ESD脉冲波形。
应用信息:适用于USB 2.0电源和数据线、机顶盒和数字电视、数字视频接口(DVI)、笔记本电脑、SIM卡端口、10/100以太网等。
封装信息:SOT-563封装,无铅引脚,UL阻燃等级94V-0,每卷3000件,卷径7英寸。
ESDA0505CT6 价格&库存
很抱歉,暂时无法提供与“ESDA0505CT6”相匹配的价格&库存,您可以联系我们找货
