BF620,115
BF620,115
    NEXPERIA(安世)
    SOT89-3
    三极管 NPN Ic=50mA Vceo=300V hfe=50 P=1.1W SOT89-3
BF620,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET dbook, halfpage M3D109 BF620; BF622 NPN high-voltage transistors Product data sheet Supersedes data of 1999 Apr 21 2004 Dec 14 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 FEATURES PINNING • Low current (max. 50 mA) PIN • High voltage (max. 300 V). 1 emitter 2 collector 3 base APPLICATIONS DESCRIPTION • Video output stages. DESCRIPTION NPN high-voltage transistor in a SOT89 plastic package. PNP complements: BF621 and BF623. 2 MARKING 3 TYPE NUMBER MARKING CODE BF620 DC BF622 DA 3 2 1 1 sym042 Fig.1 Simplified outline (SOT89) and symbol. ORDERING INFORMATION PACKAGE TYPE NUMBER NAME BF620 BF622 2004 Dec 14 SC-62 DESCRIPTION plastic surface mounted package; collector pad for good heat transfer; 3 leads 2 VERSION SOT89 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL VCBO PARAMETER collector-base voltage CONDITIONS MAX. UNIT open emitter − 300 V − 250 V BF620 − 300 V BF622 − 250 V BF620 BF622 VCEO MIN. collector-emitter voltage open base VEBO emitter-base voltage − 5 V IC collector current (DC) − 50 mA ICM peak collector current − 100 mA IBM peak base current − 50 mA Ptot total power dissipation note 1 − 0.5 W note 2 − 0.8 W note 3 − 1.1 W open collector Tamb ≤ 25 °C Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb ambient temperature −65 +150 °C Notes 1. Device mounted on a printed-circuit board, single-sided copper, tin-plated and standard footprint. 2. Device mounted on a printed-circuit board, single-sided copper, tin-plated and mounting pad for collector 1 cm2. 3. Device mounted on a printed-circuit board, single-sided copper, tin-plated and mounting pad for collector 6 cm2. 2004 Dec 14 3 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 006aaa238 1600 Ptot (mW) 1200 800 (1) (2) (3) 400 0 −75 −25 25 75 125 175 Tamb (°C) (1) FR4 PCB; 6 cm2 mounting pad for collector. (2) FR4 PCB; 1 cm2 mounting pad for collector. (3) FR4 PCB; standard footprint. Fig.2 Power derating curves. 2004 Dec 14 4 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 THERMAL CHARACTERISTICS SYMBOL PARAMETER Rth(j-a) CONDITIONS thermal resistance from junction to ambient Rth(j-s) VALUE UNIT note 1 250 K/W note 2 156 K/W note 3 113 K/W 30 K/W in free air thermal resistance from junction to soldering point Notes 1. Device mounted on a printed-circuit board, single-sided copper, tin-plated and standard footprint. 2. Device mounted on a printed-circuit board, single-sided copper, tin-plated and mounting pad for collector 1 cm2. 3. Device mounted on a printed-circuit board, single-sided copper, tin-plated and mounting pad for collector 6 cm2. 006aaa235 103 Zth (K/W) 102 (1) (3) (2) (4) (5) (6) (7) 10 (8) (9) (10) 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Mounted on FR4 printed-circuit board; standard footprint. (1) δ = 1. (2) δ = 0.75. (3) δ = 0.5. (4) δ = 0.33. (5) δ = 0.2. (6) δ = 0.1. (7) δ = 0.05. (8) δ = 0.02. (9) δ = 0.01. (10) δ = 0. Fig.3 Transient thermal impedance as a function of pulse time; typical values. 2004 Dec 14 5 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 006aaa236 103 Zth (K/W) (1) 102 (2) (3) (4) (5) (6) 10 (7) (8) (9) (10) 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Mounted on FR4 printed-circuit board; mounting pad for collector 1 cm2. (1) δ = 1. (2) δ = 0.75. (3) δ = 0.5. (4) δ = 0.33. (5) δ = 0.2. (6) δ = 0.1. (7) δ = 0.05. (8) δ = 0.02. (9) δ = 0.01. (10) δ = 0. Fig.4 Transient thermal impedance as a function of pulse time; typical values. 006aaa237 103 Zth (K/W) 102 (1) (3) (2) (4) (5) (6) 10 (7) (8) (9) (10) 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Mounted on FR4 printed-circuit board; mounting pad for collector 6 cm2. (1) δ = 1. (2) δ = 0.75. (3) δ = 0.5. (4) δ = 0.33. (5) δ = 0.2. (6) δ = 0.1. (7) δ = 0.05. (8) δ = 0.02. (9) δ = 0.01. (10) δ = 0. Fig.5 Transient thermal impedance as a function of pulse time; typical values. 2004 Dec 14 6 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 CHARACTERISTICS Tamb = 25 °C unless otherwise specified. SYMBOL ICBO PARAMETER collector-base cut-off current CONDITIONS MIN. MAX. UNIT IE = 0 A; VCB = 200 V − 10 nA IE = 0 A; VCB = 200 V; Tj = 150 °C − 10 µA nA IEBO emitter-base cut-off current IC = 0 A; VEB = 5 V − 50 hFE DC current gain IC = 25 mA; VCE = 20 V 50 − VCEsat collector-emitter saturation voltage IC = 30 mA; IB = 5 mA − 600 mV Cre feedback capacitance IC = ic = 0 A; VCE = 30 V; f = 1 MHz − 1.6 pF fT transition frequency IC = −10 mA; VCE = 10 V; f = 100 MHz 60 − MHz 2004 Dec 14 7 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 PACKAGE OUTLINE Plastic surface-mounted package; collector pad for good heat transfer; 3 leads SOT89 B D A bp3 E HE Lp 1 2 3 c bp2 w M bp1 e1 e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A bp1 bp2 bp3 c D E e e1 HE Lp w mm 1.6 1.4 0.48 0.35 0.53 0.40 1.8 1.4 0.44 0.23 4.6 4.4 2.6 2.4 3.0 1.5 4.25 3.75 1.2 0.8 0.13 OUTLINE VERSION SOT89 2004 Dec 14 REFERENCES IEC JEDEC JEITA TO-243 SC-62 8 EUROPEAN PROJECTION ISSUE DATE 04-08-03 06-03-16 NXP Semiconductors Product data sheet NPN high-voltage transistors BF620; BF622 DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DISCLAIMERS above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 2004 Dec 14 9 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R75/04/pp10 Date of release: 2004 Dec 14 Document order number: 9397 750 13867
BF620,115 价格&库存
很抱歉,暂时无法提供与“BF620,115”相匹配的价格&库存,您可以联系我们找货
BF620,115
    BF620,115
    • 1+6.02640
    • 10+4.87080
    • 30+4.29840
    • 100+3.67805
    • 500+3.33591
    • 1000+3.16484
    库存:909
    BF620,115
    • 1+4.95618
    • 5+4.28665
    • 10+3.82941
    BF620,115
      • 1000+1.853941000+0.23962
      • 2000+1.677992000+0.21688
      • 3000+1.588323000+0.20529
      • 5000+1.487485000+0.19226
      • 7000+1.427747000+0.18454
      • 10000+1.3696810000+0.17703
      库存:2
      BF620,115
      • 1+6.418151+0.82954
      库存:2
