PBLS2024D,115
PBLS2024D,115
    NEXPERIA(安世)
    SOT457
    20 V,1.8 A PNP BISS负载开关
PBLS2024D,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBLS2024D 20 V, 1.8 A PNP BISS loadswitch Rev. 02 — 6 September 2009 Product data sheet 1. Product profile 1.1 General description PNP low VCEsat Breakthrough In Small Signal (BISS) transistor and NPN ResistorEquipped Transistor (RET) in a SOT457 (SC-74) small Surface-Mounted Device (SMD) plastic package. 1.2 Features n n n n n Low VCEsat (BISS) and resistor-equipped transistor in one package Low threshold voltage (
PBLS2024D,115
物料型号:PBLS2024D
器件简介:PBLS2024D是一款20V、1.8A的PNP BISS(Breakthrough In Small Signal)负载开关,采用SOT457(SC-74)小型表面贴装塑料封装。它集成了低VCEsat(BISS)的PNP小信号晶体管和带有电阻的NPN晶体管(RET),具有低阈值电压(小于1V),相比MOSFET具有更低的导通电压,是节省空间的解决方案。
引脚分配: - 引脚1:TR1的基极 - 引脚2:TR2的输入(基极) - 引脚3:TR2的输出(集电极) - 引脚4:TR2的地(发射极) - 引脚5:TR1的集电极 - 引脚6:TR1的发射极
参数特性: - VCEO:集电极-发射极电压,开基极条件下,最大值为-20V。 - Ic:集电极电流,最大值为-1.8A。 - ICM:峰值集电极电流,单脉冲条件下,最大值为-3A。 - RcEsat:集电极-发射极饱和电阻,特定条件下,范围在78mΩ至117mΩ之间。
功能详解: - 该器件适用于供电线路开关、电池充电器开关、LED、驱动器和背光的高端开关,以及便携设备。
应用信息: - 器件适用于汽车、工业、计算、消费和可穿戴应用市场。
封装信息: - 封装类型:SC-74塑料表面贴装封装(TSOP6),共6个引脚。
PBLS2024D,115 价格&库存
很抱歉,暂时无法提供与“PBLS2024D,115”相匹配的价格&库存,您可以联系我们找货
