PBLS6021D,115
PBLS6021D,115
    NEXPERIA(安世)
    SOT457
    60 V,1.5 A PNP BISS负载开关
PBLS6021D,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBLS6021D 60 V, 1.5 A PNP BISS loadswitch Rev. 01 — 12 August 2009 Product data sheet 1. Product profile 1.1 General description PNP low VCEsat Breakthrough In Small Signal (BISS) transistor and NPN ResistorEquipped Transistor (RET) in a SOT457 (SC-74) small Surface-Mounted Device (SMD) plastic package. 1.2 Features n n n n n Low VCEsat (BISS) and resistor-equipped transistor in one package Low threshold voltage (
PBLS6021D,115
1. 物料型号: - 型号名称:PBLS6021D - 封装类型:SC-74 (SOT457)
2. 器件简介: - 这是一款PNP低VCEsat(Breakthrough In Small Signal, BISS)负载开关,集成了NPN电阻器装备晶体管(Resistor-Equipped Transistor, RET)。
3. 引脚分配: - 1号引脚:TR1的基极 - 2号引脚:TR2的输入(基极) - 3号引脚:TR2的输出(集电极) - 4号引脚:TR2的地(发射极) - 5号引脚:TR1的集电极 - 6号引脚:TR1的发射极
4. 参数特性: - 包括工作电压、电流、饱和电阻、偏置电阻等参数,例如: - VCEO:集电极-发射极电压,开路基极时为-60V - Ic:集电极电流,最大为-1.5A - RcEsat:集电极-发射极饱和电阻,在特定条件下的最小值为110mΩ,典型值为175mΩ
5. 功能详解: - 该器件适用于供电线路开关、电池充电器开关、LED、驱动器和背光的高端开关,以及便携设备。
6. 应用信息: - 适用于汽车、工业、计算、消费和可穿戴应用市场。
7. 封装信息: - 塑料表面贴装包(TSOP6),6个引脚。
PBLS6021D,115 价格&库存
很抱歉,暂时无法提供与“PBLS6021D,115”相匹配的价格&库存,您可以联系我们找货
PBLS6021D,115
    • 1153+4.088501153+0.52950
    • 10000+3.6448010000+0.47200
    • 100000+3.05410100000+0.39550
    库存:103950
    PBLS6021D,115
