Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
SO
T8
9
PBHV9040X
500 V, 0.25 A PNP high-voltage low VCEsat (BISS) transistor
9 December 2013
Product data sheet
1. General description
PNP high-voltage low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT89
(SC-62) medium power and flat lead Surface-Mounted Device (SMD) plastic package.
NPN complement: PBHV8540X.
2. Features and benefits
High voltage
Low collector-emitter saturation voltage VCEsat
High collector current capability IC and ICM
High collector current gain (hFE) at high IC
AEC-Q101 qualified
3. Applications
Electronic ballast for fluorescent lighting
LED driver for LED chain module
LCD backlighting
High Intensity Discharge (HID) front lighting
Automotive motor management
Hook switch for wired telecom
Switch mode power supply
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCESM
collector-emitter peak
voltage
VBE = 0 V
-500
V
VCEO
collector-emitter
voltage
open base
-400
V
IC
collector current
-0.25
A
hFE
DC current gain
100
200
VCE = -10 V; IC = -50 mA; Tamb = 25 °C
Scan or click this QR code to view the latest information for this product
PBHV9040X
NXP Semiconductors
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
E
emitter
2
C
collector
3
B
base
Simplified outline
Graphic symbol
2
3
3
2
1
SOT89
1
sym079
6. Ordering information
Table 3.
Type number
PBHV9040X
Package
Name
Description
Version
SOT89
plastic surface-mounted package; die pad for good heat transfer; SOT89
3 leads
7. Marking
Table 4.
Marking codes
Type number
Marking code
[1]
PBHV9040X
%4E
[1]
PBHV9040X
Product data sheet
% = placeholder for manufacturing site code
All information provided in this document is subject to legal disclaimers.
9 December 2013
© NXP N.V. 2013. All rights reserved
2 / 14
PBHV9040X
NXP Semiconductors
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
-500
V
VCEO
collector-emitter voltage
open base
-400
V
VCESM
collector-emitter peak voltage
VBE = 0 V
-500
V
VEBO
emitter-base voltage
open collector
-6
V
IC
collector current
-0.25
A
ICM
peak collector current
-0.5
A
IBM
peak base current
-200
mA
Ptot
total power dissipation
[1]
0.52
W
[2]
1.5
W
single pulse; tp ≤ 1 ms
Tamb ≤ 25 °C
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm .
006aab846
2.0
Ptot
(W)
1.6
(1)
1.2
0.8
(2)
0.4
0.0
- 75
- 25
25
(1) FR4 PCB, mounting pad for collector 6 cm
(2) FR4 PCB, standard footprint
Fig. 1.
75
125
175
Tamb (°C)
2
Power derating curves
PBHV9040X
Product data sheet
9 December 2013
3 / 14
PBHV9040X
NXP Semiconductors
9. Thermal characteristics
Table 6.
Symbol
Parameter
Rth(j-a)
thermal resistance
from junction to
ambient
Rth(j-sp)
Conditions
in free air
Min
Typ
Max
Unit
[1]
240
K/W
[2]
83
K/W
K/W
thermal resistance
from junction to solder
point
[1]
[2]
006aab847
103
Zth(j-a)
(K/W)
2
duty cycle = 1
102
0.75
0.33
0.5
0.2
0.1
10
1
0.05
0.02
0.01
10- 5
10- 4
10- 3
10- 2
10- 1
1
10
102
tp (s)
103
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
006aab848
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.5
0.2
10
0.75
0.33
0.1
0.05
1
10- 5
0.02
0.01
10- 4
10- 3
10- 2
Fig. 3.
10- 1
1
10
102
tp (s)
103
2
PBHV9040X
Product data sheet
9 December 2013
4 / 14
PBHV9040X
NXP Semiconductors
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = -320 V; IE = 0 A; Tamb = 25 °C
-100
nA
VCB = -320 V; IE = 0 A; Tj = 150 °C
-10
µA
ICES
collector-emitter cut-off VCE = -320 V; VBE = 0 V; Tamb = 25 °C
current
-100
nA
IEBO
emitter-base cut-off
current
VEB = -4 V; IC = 0 A; Tamb = 25 °C
-100
nA
hFE
DC current gain
100
200
VCE = -10 V; IC = -100 mA;
80
200
10
25
-110
-200
mV
Tamb = 25 °C
VCE = -10 V; IC = -250 mA; pulsed;
tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C
VCEsat
collector-emitter
saturation voltage
IC = -100 mA; IB = -20 mA;
Tamb = 25 °C
VBEsat
base-emitter saturation IC = -100 mA; IB = -20 mA; pulsed;
voltage
-1
-1.1
V
td
delay time
VCC = -2 V; IC = -0.15 A; IBon = -0.03 A;
9
ns
tr
rise time
IBoff = 0.03 A; Tamb = 25 °C
1810
ns
ton
turn-on time
1819
ns
ts
storage time
715
ns
tf
fall time
1085
ns
toff
turn-off time
1800
ns
fT
transition frequency
55
MHz
7
pF
150
pF
VCE = -10 V; IC = -10 mA; f = 100 MHz;
Tamb = 25 °C
Cc
collector capacitance
VCB = -20 V; IE = 0 A; ie = 0 A;
f = 1 MHz; Tamb = 25 °C
Ce
emitter capacitance
VEB = -0.5 V; IC = 0 A; ic = 0 A;
PBHV9040X
Product data sheet
9 December 2013
5 / 14
PBHV9040X
NXP Semiconductors
006aab182
400
006aab183
- 0.5
IB (mA) = - 140
IC
(A)
hFE
- 126
- 0.4
300
- 112
(1)
- 84
- 0.3
- 42
- 28
- 0.2
- 14
(3)
100
- 0.1
-1
- 10
- 102
IC (mA)
VCE = -10 V
-2
Fig. 5.
(2) Tamb = 25 °C
(3) Tamb = -55 °C
-4
VCE (V)
-5
Collector current as a function of collectoremitter voltage; typical values
DC current gain as a function of collector
current; typical values
006aab184
- 1.2
006aab185
- 1.3
VBE
(V)
VBEsat
(V)
(1)
- 0.8
- 0.9
(1)
(2)
(2)
(3)
(3)
- 0.4
Fig. 6.
-3
Tamb = 25 °C
(1) Tamb = 100 °C
Fig. 4.
- 70
- 56
(2)
200
- 98
- 0.5
-1
- 10
- 102
IC (mA)
- 0.1
- 10- 1
- 103
-1
- 10
VCE = -10 V
IC/IB = 5
(1) Tamb = -55 °C
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
PBHV9040X
Product data sheet
Fig. 7.
- 103
- 104
IC (mA)
Base-emitter saturation voltage as a function of
collector current; typical values
9 December 2013
- 102
6 / 14
PBHV9040X
NXP Semiconductors
006aab186
- 10
VCEsat
(V)
VCEsat
(V)
-1
-1
- 10- 1
- 10- 2
- 10- 1
Fig. 8.
(1)
(2)
(3)
-1
006aab187
- 10
(1)
- 10- 1
(2)
(3)
- 10
- 102
IC (mA)
- 10- 2
- 10- 1
- 103
-1
IC/IB = 5
Tamb = 25 °C
(1) Tamb = 100 °C
(1) IC/IB = 20
(2) Tamb = 25 °C
(2) IC/IB = 10
(3) Tamb = -55 °C
(3) IC/IB = 5
Collector-emitter saturation voltage as a
function of collector current; typical values
006aab188
104
Fig. 9.
RCEsat
(Ω)
103
103
102
102
10
(1)
(2)
1
10- 1
10- 1
(3)
1
-1
- 10
- 102
IC (mA)
10- 1
10- 1
- 103
-1
IC/IB = 5
Tamb = 25 °C
(1) Tamb = 100 °C
(1) IC/IB = 20
(2) Tamb = 25 °C
(2) IC/IB = 10
(3) Tamb = -55 °C
(3) IC/IB = 5
Fig. 10. Collector-emitter saturation resistance as a
PBHV9040X
Product data sheet
- 103
006aab189
104
(1)
(2)
(3)
IC (mA)
RCEsat
(Ω)
10
- 102
- 10
- 10
- 102
IC (mA)
- 103
Fig. 11. Collector-emitter saturation resistance as a
9 December 2013
7 / 14
PBHV9040X
NXP Semiconductors
11. Test information
- IB
input pulse
(idealized waveform)
90 %
- I Bon (100 %)
10 %
- I Boff
output pulse
- IC
90 %
- I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig. 12. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mgd624
Fig. 13. Test circuit for switching times
11.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PBHV9040X
Product data sheet
9 December 2013
8 / 14
PBHV9040X
NXP Semiconductors
12. Package outline
Plastic surface-mounted package; exposed die pad for good heat transfer; 3 leads
SOT89
B
D
A
bp3
E
1
2
HE
Lp
3
c
bp2
w M B
bp1
e1
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
bp1
bp2
bp3
c
D
E
e
e1
HE
Lp
w
mm
1.6
1.4
0.48
0.35
0.53
0.40
1.8
1.4
0.44
0.23
4.6
4.4
2.6
2.4
3.0
1.5
4.25
3.75
1.2
0.8
0.13
OUTLINE
VERSION
REFERENCES
IEC
SOT89
JEDEC
JEITA
TO-243
SC-62
EUROPEAN
PROJECTION
ISSUE DATE
06-03-16
06-08-29
Fig. 14. Package outline SOT89
PBHV9040X
Product data sheet
9 December 2013
9 / 14
PBHV9040X
NXP Semiconductors
13. Soldering
4.75
2.25
2
1.9
1.2
0.2
0.85
solder lands
1.7
1.2
4.6
solder resist
0.5
1
(3×)
4.85
occupied area
1.1
(2×)
1.5
solder paste
Dimensions in mm
1.5
0.6
(3×)
0.7
(3×)
3.95
sot089_fr
Fig. 15. Reflow soldering footprint for SOT89
6.6
2.4
3.5
solder lands
7.6
0.5
solder resist
occupied area
1.8
(2×)
Dimensions in mm
preferred transport direction during soldering
1.9
1.5
(2×)
1.9
0.7
5.3
sot089_fw
Fig. 16. Wave soldering footprint for SOT89
PBHV9040X
Product data sheet
9 December 2013
10 / 14
PBHV9040X
NXP Semiconductors
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PBHV9040X v.1
20131209
Product data sheet
PBHV9040X
Product data sheet
9 December 2013
11 / 14
PBHV9040X
NXP Semiconductors
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nxp.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
NXP Semiconductors does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local NXP
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, NXP Semiconductors does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
PBHV9040X
Product data sheet
Right to make changes — NXP Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This NXP
Semiconductors product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using NXP Semiconductors products, and NXP
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the NXP Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
9 December 2013
12 / 14
PBHV9040X
NXP Semiconductors
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV,
FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE,
ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse,
QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET,
TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
PBHV9040X
Product data sheet
9 December 2013
13 / 14
PBHV9040X
NXP Semiconductors
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
11.1
Test information ..................................................... 8
Quality information ............................................... 8
12
Package outline ..................................................... 9
13
Soldering .............................................................. 10
14
Revision history ................................................... 11
15
15.1
15.2
15.3
15.4
Legal information .................................................12
Data sheet status ............................................... 12
Definitions ...........................................................12
Disclaimers .........................................................12
Trademarks ........................................................ 13
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 9 December 2013
PBHV9040X
Product data sheet
9 December 2013
14 / 14
