PBHV9540Z,115
PBHV9540Z,115
    NEXPERIA(安世)
    SOT-223
    通用三极管 PNP Ic=500mA Vceo=400V hfe=65 P=1.45W SOT223
PBHV9540Z,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBHV9540Z 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor Rev. 01 — 11 December 2009 Product data sheet 1. Product profile 1.1 General description PNP high-voltage low VCEsat Breakthrough In Small Signal (BISS) transistor in a medium power SOT223 (SC-73) Surface-Mounted Device (SMD) plastic package. NPN complement: PBHV8140Z. 1.2 Features „ „ „ „ „ „ High voltage Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain (hFE) at high IC AEC-Q101 qualified Medium power SMD plastic package 1.3 Applications „ „ „ „ LED driver for LED chain module LCD backlighting Automotive motor management Switch Mode Power Supply (SMPS) 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCESM collector-emitter peak voltage VBE = 0 V - - −500 V VCEO collector-emitter voltage open base - - −400 V IC collector current - - −0.5 A 100 155 - hFE [1] DC current gain Pulse test: tp ≤ 300 μs; δ ≤ 0.02. VCE = −10 V; IC = −50 mA [1] PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 base 2 collector 3 emitter 4 collector Simplified outline Graphic symbol 4 2, 4 1 1 2 3 3 sym028 3. Ordering information Table 3. Ordering information Type number PBHV9540Z Package Name Description Version SC-73 plastic surface-mounted package with increased heat sink; 4 leads SOT223 4. Marking Table 4. Marking codes Type number Marking code PBHV9540Z V9540Z PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 2 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage VCEO collector-emitter voltage open emitter - −500 V open base - −400 V VCESM collector-emitter peak voltage VBE = 0 V - −500 V VEBO emitter-base voltage IC collector current open collector - −6 V - −0.5 A ICM peak collector current single pulse; tp ≤ 1 ms - −1 A IBM peak base current single pulse; tp ≤ 1 ms - −200 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 0.73 W [2] - 1.45 W Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for collector 6 cm2. 006aab764 2.0 Ptot (W) 1.5 (1) 1.0 (2) 0.5 0.0 −75 −25 25 75 125 175 Tamb (°C) (1) FR4 PCB, mounting pad for collector 6 cm2 (2) FR4 PCB, standard footprint Fig 1. Power derating curves PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 3 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air thermal resistance from junction to solder point Rth(j-sp) Min Typ Max Unit [1] - - 170 K/W [2] - - 85 K/W - - 15 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for collector 6 cm2. 006aab765 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aab766 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 4 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = −320 V; IE = 0 A - - −100 nA VCB = −320 V; IE = 0 A; Tj = 150 °C - - −10 μA - - −100 nA - - −100 nA ICES collector-emitter cut-off VCE = −320 V; VBE = 0 V current IEBO emitter-base cut-off current VEB = −4 V; IC = 0 A hFE DC current gain VCE = −10 V VCEsat collector-emitter saturation voltage IC = −50 mA [1] 100 155 - IC = −100 mA [1] 100 155 - IC = −300 mA [1] 80 145 - IC = −500 mA [1] 65 130 - - −100 −190 mV IC = −100 mA; IB = −10 mA IC = −100 mA; IB = −20 mA [1] - −65 −110 mV IC = − 300 mA; IB = −60 mA [1] - −110 −210 mV IC = −500 mA; IB = −100 mA [1] - −180 −320 mV 640 mΩ RCEsat collector-emitter saturation resistance IC = −500 mA; IB = −100 mA [1] - 360 VBEsat base-emitter saturation IC = −100 mA; voltage IB = −20 mA [1] - −0.75 −0.9 V - 55 - ns - 1775 - ns - 1830 - ns - 1545 - ns VCC = −2 V; IC = −0.15 A; IBon = −0.03 A; IBoff = 0.03 A td delay time tr rise time ton turn-on time ts storage time tf fall time - 920 - ns toff turn-off time - 2465 - ns fT transition frequency VCE = −10 V; IC = −10 mA; f = 100 MHz - 30 - MHz Cc collector capacitance VCB = −20 V; IE = ie = 0 A; f = 1 MHz - 20 - pF Ce emitter capacitance VEB = −0.5 V; IC = ic = 0 A; f = 1 MHz - 540 - pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 5 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 006aab911 300 006aab912 −1.0 IC (A) hFE IB (mA) = −200 −180 −160 −140 −120 −100 −80 −60 −0.8 (1) 200 −0.6 (2) −40 −20 −0.4 100 (3) −0.2 0 −10−1 −1 −10 −102 IC (mA) 0.0 −103 0 VCE = −10 V −1 −2 −3 −4 −5 VCE (V) Tamb = 25 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 4. DC current gain as a function of collector current; typical values 006aab913 −1.2 Fig 5. Collector current as a function of collector-emitter voltage; typical values 006aab914 −1.2 VBEsat (V) VBE (V) −1.0 (1) −0.8 (1) −0.8 (2) (2) −0.6 (3) −0.4 (3) −0.4 −0.0 −10−1 −1 −10 −102 IC (mA) −103 −0.2 −10−1 VCE = −10 V −1 (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C IC (mA) −103 (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values Fig 7. Base-emitter saturation voltage as a function of collector current; typical values PBHV9540Z_1 Product data sheet −102 IC/IB = 5 (1) Tamb = −55 °C Fig 6. −10 © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 6 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 006aab915 −1 006aab916 −1 VCEsat (V) VCEsat (V) −10−1 −10−1 (1) (2) (1) (3) (2) (3) −10−2 −10−1 −1 −10 −102 IC (mA) −103 −10−2 −10−1 −10 −102 IC (mA) −103 Tamb = 25 °C IC/IB = 5 (1) Tamb = 100 °C (1) IC/IB = 20 (2) Tamb = 25 °C (2) IC/IB = 10 (3) Tamb = −55 °C (3) IC/IB = 5 Fig 8. −1 Collector-emitter saturation voltage as a function of collector current; typical values 006aab917 103 Fig 9. Collector-emitter saturation voltage as a function of collector current; typical values 006aab918 104 RCEsat (Ω) RCEsat (Ω) 103 102 102 10 10 (1) (1) (2) 1 (2) 1 (3) 10−1 −10−1 −1 −10 −102 (3) IC (mA) −103 10−1 −10−1 −10 −102 IC (mA) −103 Tamb = 25 °C IC/IB = 5 (1) Tamb = 100 °C (1) IC/IB = 20 (2) Tamb = 25 °C (2) IC/IB = 10 (3) Tamb = −55 °C (3) IC/IB = 5 Fig 10. Collector-emitter saturation resistance as a function of collector current; typical values Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values PBHV9540Z_1 Product data sheet −1 © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 7 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 8. Test information VBB RB oscilloscope VCC RC Vo (probe) (probe) 450 Ω oscilloscope 450 Ω R2 VI DUT R1 mgd624 Fig 12. Test circuit for switching times 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 6.7 6.3 3.1 2.9 1.8 1.5 4 1.1 0.7 7.3 6.7 3.7 3.3 1 2 2.3 4.6 3 0.8 0.6 Dimensions in mm 0.32 0.22 04-11-10 Fig 13. Package outline SOT223 (SC-73) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PBHV9540Z [1] Package SOT223 Description 8 mm pitch, 12 mm tape and reel 1000 4000 -115 -135 For further information and the availability of packing methods, see Section 14. PBHV9540Z_1 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 8 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 11. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig 14. Reflow soldering footprint SOT223 (SC-73) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 8.7 occupied area Dimensions in mm 1 2 3 1.9 (3×) 2.7 preferred transport direction during soldering 2.7 1.1 1.9 (2×) sot223_fw Fig 15. Wave soldering footprint SOT223 (SC-73) PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 9 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBHV9540Z_1 20091211 Product data sheet - - PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 10 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PBHV9540Z_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 December 2009 11 of 12 PBHV9540Z NXP Semiconductors 500 V, 0.5 A PNP high-voltage low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Quality information . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 December 2009 Document identifier: PBHV9540Z_1
PBHV9540Z,115 价格&库存
很抱歉,暂时无法提供与“PBHV9540Z,115”相匹配的价格&库存,您可以联系我们找货
PBHV9540Z,115
  • 1+7.562141+0.94926
  • 10+4.7053310+0.59065
  • 100+3.04666100+0.38244
  • 500+2.33376500+0.29295
库存:1501
PBHV9540Z,115
