PBSS302NX,115
PBSS302NX,115
    NEXPERIA(安世)
    SOT89-3
    通用三极管 NPN Ic=5.3A Vceo=20V hfe=200 P=2.1W SOT89-3
PBSS302NX,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBSS302NX 20 V, 5.3 A NPN low VCEsat (BISS) transistor Rev. 02 — 20 November 2009 Product data sheet 1. Product profile 1.1 General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT89 (SC-62/TO-243) small and flat lead Surface-Mounted Device (SMD) plastic package. PNP complement: PBSS302PX. 1.2 Features „ „ „ „ „ Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain (hFE) at high IC High efficiency due to less heat generation Smaller required Printed-Circuit Board (PCB) area than for conventional transistors 1.3 Applications „ „ „ „ „ DC-to-DC conversion MOSFET gate driving Motor control Charging circuits Power switches (e.g. motors, fans) 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - 20 V - - 5.3 A - - 10.6 A - 28 40 mΩ VCEO collector-emitter voltage IC collector current ICM peak collector current single pulse; tp ≤ 1 ms RCEsat collector-emitter saturation resistance IC = 4 A; IB = 200 mA [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 emitter 2 collector 3 base Simplified outline Symbol 2 3 3 2 1 1 sym042 3. Ordering information Table 3. Ordering information Type number PBSS302NX Package Name Description Version SC-62 plastic surface-mounted package; collector pad for good heat transfer; 3 leads SOT89 4. Marking Table 4. Marking codes Type number Marking code[1] PBSS302NX *5C [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 2 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 20 V VCEO collector-emitter voltage open base - 20 V VEBO emitter-base voltage open collector - 5 V IC collector current - 5.3 A ICM peak collector current single pulse; tp ≤ 1 ms - 10.6 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 0.6 W [2] - 1.65 W [3] - 2.1 W Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aaa556 2.5 Ptot (W) (1) 2.0 (2) 1.5 1.0 (3) 0.5 0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, standard footprint Fig 1. Power derating curves PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 3 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air Min Typ Max Unit [1] - - 208 K/W [2] - - 76 K/W [3] - - 60 K/W - - 20 K/W thermal resistance from junction to solder point Rth(j-sp) [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aaa557 103 Zth(j-a) (K/W) δ=1 0.75 102 0.50 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 4 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 006aaa558 102 δ=1 0.75 Zth(j-a) (K/W) 0.50 0.33 0.20 10 0.10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aaa559 102 δ=1 0.75 Zth(j-a) (K/W) 0.50 0.33 0.20 10 0.10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 5 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Min Typ Max Unit collector-base cut-off VCB = 20 V; IE = 0 A current VCB = 20 V; IE = 0 A; Tj = 150 °C - - 100 nA - - 50 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 2 V; IC = 0.5 A [1] 300 570 - VCE = 2 V; IC = 1 A [1] 300 550 - VCE = 2 V; IC = 2 A [1] 250 520 - VCE = 2 V; IC = 4 A [1] 200 450 - VCE = 2 V; IC = 6 A [1] 200 380 - IC = 0.5 A; IB = 50 mA [1] - 20 25 mV IC = 1 A; IB = 50 mA [1] - 35 50 mV IC = 1 A; IB = 10 mA [1] - 50 70 mV IC = 2 A; IB = 40 mA [1] - 70 100 mV IC = 4 A; IB = 200 mA [1] - 110 160 mV IC = 4 A; IB = 400 mA [1] - 100 140 mV IC = 4 A; IB = 40 mA [1] - 140 220 mV IC = 5.3 A; IB = 265 mA [1] - 140 200 mV collector-emitter IC = 4 A; IB = 200 mA saturation resistance I = 4 A; I = 40 mA C B [1] - 28 40 mΩ [1] - 35 55 mΩ base-emitter saturation voltage IC = 1 A; IB = 100 mA [1] - 0.82 0.9 V IC = 4 A; IB = 400 mA [1] - 0.92 1.05 V VBEon base-emitter turn-on voltage VCE = 2 V; IC = 2 A [1] - 0.75 0.85 V td delay time tr rise time ton turn-on time VCC = 12.5 V; IC = 3 A; IBon = 0.15 A; IBoff = −0.15 A ts storage time tf fall time - 85 - ns toff turn-off time - 355 - ns fT transition frequency - 140 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 95 150 pF ICBO VCEsat RCEsat VBEsat [1] Conditions collector-emitter saturation voltage VCE = 10 V; IC = 0.1 A; f = 100 MHz 15 - ns 40 - ns - 55 - ns - 270 - ns Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PBSS302NX_2 Product data sheet - © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 6 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 006aaa572 1000 hFE (1) 006aaa578 14 IC (A) 12 IB (mA) = 50 45 40 35 30 25 20 800 10 600 (2) 8 15 6 400 10 (3) 4 5 200 2 0 10−1 1 10 102 0 103 104 IC (mA) 0 1 2 3 4 5 VCE (V) Tamb = 25 °C VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values Fig 6. 006aaa573 1.2 VBE (V) Collector current as a function of collector-emitter voltage; typical values 006aaa576 1.2 VBEsat (V) 0.8 0.8 (1) (1) (2) (2) 0.4 0.4 (3) (3) 0 10−1 1 10 102 0 10−1 103 104 IC (mA) 1 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig 7. 102 103 104 IC (mA) (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values Fig 8. Base-emitter saturation voltage as a function of collector current; typical values PBSS302NX_2 Product data sheet 10 © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 7 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 006aaa574 1 006aaa575 1 VCEsat (V) VCEsat (V) 10−1 10−1 (1) (2) (3) (1) 10−2 10−2 10−3 10−1 10−3 10−1 (2) (3) 1 10 102 103 104 IC (mA) 1 102 103 104 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C Fig 9. 10 (3) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values 006aaa577 103 Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values 006aaa579 103 RCEsat (Ω) RCEsat (Ω) 102 102 (1) (2) 10 10 1 1 (1) (2) (3) 10−1 10−2 10−1 1 10 102 (3) 10−1 103 104 IC (mA) 10−2 10−1 1 102 103 104 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values PBSS302NX_2 Product data sheet 10 © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 8 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 VCC = 12.5 V; IC = 3 A; IBon = 0.15 A; IBoff = −0.15 A Fig 14. Test circuit for switching times PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 9 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 9. Package outline 4.6 4.4 1.8 1.4 1.6 1.4 2.6 2.4 4.25 3.75 1 2 1.2 0.8 3 0.53 0.40 1.5 0.48 0.35 0.44 0.23 3 Dimensions in mm 06-08-29 Fig 15. Package outline SOT89 (SC-62/TO-243) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PBSS302NX [1] Package SOT89 Description 8 mm pitch, 12 mm tape and reel 1000 4000 -115 -135 For further information and the availability of packing methods, see Section 15. PBSS302NX_2 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 10 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 11. Soldering 4.75 2.25 2.00 1.90 1.20 solder lands 0.85 0.20 solder resist occupied area 1.70 1.20 solder paste 4.60 4.85 0.50 1.20 Dimensions in mm 1.20 1.00 (3x) 3 2 1 msa442 0.60 (3x) 0.70 (3x) 3.70 3.95 Fig 16. Reflow soldering footprint SOT89 (SC-62) 6.60 2.40 3.50 2 7.60 0.50 3 1 1.20 3.00 solder lands solder resist occupied area Dimensions in mm preferred transport direction during soldering 1.50 0.70 5.30 msa423 Not recommended for wave soldering Fig 17. Wave soldering footprint SOT89 (SC-62) PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 11 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 12. Mounting 32 mm 30 mm 32 mm 40 mm 2.5 mm 20 mm 40 mm 1 mm 3 mm 2.5 mm 2.5 mm 1 mm 1 mm 0.5 mm 0.5 mm 5 mm 3.96 mm 5 mm 3.96 mm 1.6 mm 001aaa234 PCB thickness: 1.6 mm 001aaa235 PCB thickness = 1.6 mm FR4 PCB = 1.6 mm ceramic PCB = 0.635 mm Fig 18. FR4 PCB, standard footprint; ceramic PCB, Al2O3, standard footprint SOT89 (SC-62) PBSS302NX_2 Product data sheet Fig 19. FR4 PCB, mounting pad for collector 6 cm2 SOT89 (SC-62) © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 12 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 13. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS302NX_2 20091120 Product data sheet - PBSS302NX_1 Modifications: PBSS302NX_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • • • Figure 15 “Package outline SOT89 (SC-62/TO-243)”: updated Figure 16 “Reflow soldering footprint SOT89 (SC-62)”: updated Figure 17 “Wave soldering footprint SOT89 (SC-62)”: updated 20060824 Product data sheet PBSS302NX_2 Product data sheet - - © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 13 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 14.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PBSS302NX_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 20 November 2009 14 of 15 PBSS302NX NXP Semiconductors 20 V, 5.3 A NPN low VCEsat (BISS) transistor 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Mounting. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 20 November 2009 Document identifier: PBSS302NX_2
PBSS302NX,115
物料型号:PBSS302NX
器件简介:Nexperia公司生产的NPN低VCEsat(BISS)晶体管,采用SOT89(SC-62/TO-243)小型、扁平的表面贴装设备(SMD)塑料封装。PNP互补型号为PBSS302PX。
引脚分配:共有3个引脚,1号引脚为发射极(emitter),2号引脚为集电极(collector),3号引脚为基极(base)。
参数特性: - 集电极-发射极电压(VCEO):20V - 集电极电流(Ic):5.3A - 峰值集电极电流(ICM):10.6A(单脉冲,tp≤1ms) - 集电极-发射极饱和电阻(RcEsat):在Ic=4A,IB=200mA条件下,范围为28mΩ至40mΩ
功能详解: - 低VCEsat有助于提高效率,减少热产生 - 高IC和ICM表明该晶体管可以承受较大的电流 - 高hFE表明在高集电极电流下具有较高的电流增益 - 与传统晶体管相比,所需的PCB面积更小
应用信息: - DC-DC转换 - MOSFET门驱动 - 电机控制 - 充电电路 - 电源开关(例如电机、风扇)
封装信息:SC-62塑料表面贴装封装,集电极焊盘有助于良好的热传递,共有3个引脚。
PBSS302NX,115 价格&库存
很抱歉,暂时无法提供与“PBSS302NX,115”相匹配的价格&库存,您可以联系我们找货
PBSS302NX,115
  • 1+7.003381+0.90287
  • 10+5.1101010+0.65879
  • 100+3.31324100+0.42714
