PESD1442U005
Ultal Low Capacitance ESD Protection Diode in 0402
Features
䕔 (6'SURWHFWLRQIRUKLJKVSHHGGDWDOLQHVWR
䕔 (6'FRQWDFWGLVFKDUJHW\SLFDO.9PD[.9
䕔 (6'DLUGLVFKDUJHW\SLFDO.9PD[.9
1
2
䕔 6XUIDFHPRXQW
䕔 ([WUHPHO\ORZFDSDFLWDQFH
䕔 9HU\ORZOHDNDJHFXUUHQW
䕔 )DVWUHVSRQVHWLPH
䕔 %LGLUHFWLRQDO(6'SURWHFWLRQ
䕔 /HDGIUHHVROGHUWHUPLQDWLRQ
䕔 7KHEHVW(6'SURWHFWLRQIRUKLJKIUHTXHQF\ORZYROWDJHDSSOLFDWLRQV
Mechanical Data
Applications
(plastic package).
Lead free; RoHS compliant
䕔 Case:
䕔 USB3.0, Firewire, DVI, HDMI, S-ATA
䕔 Thunderbolt, Display Port
䕔 Molding
Compound Flammability Rating:
UL 94 V-0
䕔 Mobile HDMI Link, MDDI, MIPI, SWP / NFC
䕔 Terminals:
High temperature soldering guaranteed:
260 °C/10 sec. at terminals
Absolute Maximum Ratings
Ratings at 25 °C, ambient temperature unless otherwise specified
3DUDPHWHU
6\PERO
9DOXH
8QLW
0D[LPXP&RQWDFWGLVFKDUJHYROWDJH3HU,(&
.9
9
0D[LPXP$LUGLVFKDUJHYROWDJH3HU,(&
.9
9
0D[LPXP2SHUDWLQJWHPSHUDWXUH
723(5
WR
Я
0D[LPXP6WRUDJHWHPSHUDWXUH
767*
WR
Я
0D[LPXPOHDGWHPSHUDWXUHIRUVROGHULQJGXULQJV
7/
Я
Electrical Characteristics
(TA = 25 °C unless otherwise specified)
3DUDPHWHU
6\PERO
7HVW&RQGLWLRQV
5DWHG9ROWDJH
95
14
9
7ULJJHUYROWDJH
97
,(&.9FRQWDFWGLVFKDUJH
9
&ODPSLQJYROWDJH
9&
9
/HDNDJHFXUUHQW
'&9VKDOOEHDSSOLHGRQFRPSRQHQW
X$
&DSDFLWDQFH
&3
95 9I 0+]
Note:
0LQ
7\S
0D[
8QLWV
S)
1 Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method.
2 After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the maximum leakage current is less than 10uA.
Rev : 01.06.2015
1/3
www.leiditech.com
PESD1442U005
(6'&ODPSLQJ7HVW
(6'7(67(5
5=
ȍ
*+]',*,7$/
5*8
ȍFRD[
î
26&,//26&23(
$77(18$725
ȍ
'87'(9,&(81'(57(67
,(&QHWZRUN
&= S)5= ȍ
450
400
350
300
250
200
150
100
50
Typical Device Capacitance VS. Frequency
0.06
0.05
Capacitance(pF)
Voltage ( V )
Typical ESD Response
(IEC 61000-4-2, 8KV contact discharge)
0 10
40
50
60 70
0.04
0.03
0.02
0.01
1.0E+07
80 90
Time(ns)
1.0E+08
1.0E+09
1.0E+10
Frequency(Hz)
Eye Diagram Measurement
USB3.0 Mask at 5.0 Gbps
HDMI Mask at 3.4 Gbps
Rev : 01.06.2015
2/3
www.leiditech.com
PESD1442U005
ESD Protection for Signal Line
The CESD is designed for the protection of one bidirectional data line from ESD damage.
Place the CESD as close to the input terminal or connector as possible.
Minimize the path length between the CESD and the protected signal line.
Use ground planes whenever possible.
USB Port
Signal line to be protected
Vbus
DD+
GND
USB 3.0
Host/
Controller
RXRX+
GND
TXTX+
GND
GND
3URGXFW'LPHQVLRQ
'LP
PLOOPHWHUV
PLQ PD[
5()
%6&
Ordering inormation
Order code
PESD1442U005
Package
Packaging option
Base quantity
Packaging specification
Tape and reel
1000pcs / reel
EIA STD RS-481
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
3/3
www.leiditech.com
很抱歉,暂时无法提供与“PESD1442U005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28588
- 100+0.23884
- 300+0.21527
- 1000+0.19759
- 5000+0.18343
- 10000+0.17630
