IP4233CZ6,125
IP4233CZ6,125
    NEXPERIA(安世)
    SOT363-6
    以太网端口的超低电容ESD保护 SOT363 双向 VBR:6~9.5V
IP4233CZ6,125 数据手册
IP4233CZ6 Ultra low capacitance ESD protection for Ethernet ports Rev. 3 — 17 June 2010 Product data sheet 1. Product profile 1.1 General description The IP4233CZ6 is designed to protect Input/Output (I/O) ports that are sensitive to capacitive loads, such as Ethernet, from destruction by ElectroStatic Discharge (ESD). The IP4233CZ6 incorporates two pairs of ultra low capacitance back-to-back diodes which protect components from ESD voltages as high as ±8 kV contact discharge according to IEC 61000-4-2, level 4. The back-to-back diodes prevent negative clipping of AC signals and voltages below zero. The IP4233CZ6 is fabricated using monolithic silicon technology integrating two ultra low capacitance back-to-back ESD protection diodes in a very small 6-lead SOT363 package. 1.2 Features and benefits „ „ „ „ Pb-free and Restriction of Hazardous Substances (RoHS) compliant ESD protection compliant to IEC 61000-4-2 level 4, ±8 kV contact discharge Two low input capacitance (0.9 pF typical) back-to-back ESD protection diodes Very small 6-lead SOT363 package 1.3 Applications „ ESD protection high-frequency AC-coupled Ethernet ports 1.4 Quick reference data Table 1. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VESD electrostatic discharge voltage all pins; IEC 61000-4-2, level 4; contact discharge - - ±8 kV - 0.9 1.3 pF C(I/O-GND) input/output to ground capacitance [1] Guaranteed by design. [2] Pins 2 to 6 and pins 3 to 5. VI = 0 V; f = 1 MHz [1][2] IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 2. Pinning information Table 2. Pinning Pin Description Simplified outline 1 not connected 2 ESD protection I/O channel 1 3 ESD protection I/O channel 2 4 not connected 5 ESD protection I/O channel 2 6 ESD protection I/O channel 1 6 1 5 Graphic symbol 4 2 1 6 2 5 3 4 3 018aaa013 3. Ordering information Table 3. Ordering information Type number Package IP4233CZ6 Name Description Version SC-88 plastic surface-mounted package; 6 leads SOT363 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VI input voltage - ±5.5 V VESD electrostatic discharge voltage - ±8 kV Tstg storage temperature −55 +125 °C Tamb ambient temperature −40 +85 °C all pins; IEC 61000-4-2, level 4; contact discharge 5. Characteristics Table 5. Characteristics Tamb = 25 °C unless otherwise specified. IP4233CZ6 Product data sheet Symbol Parameter Conditions C(I/O-GND) input/output to ground capacitance VI = 0 V; f = 1 MHz IRM reverse leakage current VI = 3.0 V VBR breakdown voltage [1] Guaranteed by design. [2] Pins 2 to 6 and pins 3 to 5. back-to-back diode; I = 5 mA Min Typ Max Unit [1][2] - 0.9 1.3 pF [2] - - 100 nA 6 - 9.5 V All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 2 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 6. Application information A typical application for protecting a 10/100 Mbit/s Ethernet transceiver against ESD is shown in Figure 1. not used not used PTC TX+ TX+ PTC TX− 1 6 2 5 3 4 TX− 10/100 BASE-T ETHERNET IP4233CZ6 Primary-Secondary Coordinating Elements (Opt) RJ45 PTC RX+ RX+ PTC RX− not used RX− not used REMI VCC REMI REMI REMI VCC GND 018aaa014 Fig 1. IP4233CZ6 Product data sheet Typical application for ESD protection of a 10/100 Mbit/s Ethernet transceiver All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 3 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 7. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 Fig 2. JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Package outline SOT363 (SC-88) IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 4 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 8. Soldering of SMD packages This text provides a very brief insight into a complex technology. A more in-depth account of soldering ICs can be found in Application Note AN10365 “Surface mount reflow soldering description”. 8.1 Introduction to soldering Soldering is one of the most common methods through which packages are attached to Printed Circuit Boards (PCBs), to form electrical circuits. The soldered joint provides both the mechanical and the electrical connection. There is no single soldering method that is ideal for all IC packages. Wave soldering is often preferred when through-hole and Surface Mount Devices (SMDs) are mixed on one printed wiring board; however, it is not suitable for fine pitch SMDs. Reflow soldering is ideal for the small pitches and high densities that come with increased miniaturization. 8.2 Wave and reflow soldering Wave soldering is a joining technology in which the joints are made by solder coming from a standing wave of liquid solder. The wave soldering process is suitable for the following: • Through-hole components • Leaded or leadless SMDs, which are glued to the surface of the printed circuit board Not all SMDs can be wave soldered. Packages with solder balls, and some leadless packages which have solder lands underneath the body, cannot be wave soldered. Also, leaded SMDs with leads having a pitch smaller than ~0.6 mm cannot be wave soldered, due to an increased probability of bridging. The reflow soldering process involves applying solder paste to a board, followed by component placement and exposure to a temperature profile. Leaded packages, packages with solder balls, and leadless packages are all reflow solderable. Key characteristics in both wave and reflow soldering are: • • • • • • Board specifications, including the board finish, solder masks and vias Package footprints, including solder thieves and orientation The moisture sensitivity level of the packages Package placement Inspection and repair Lead-free soldering versus SnPb soldering 8.3 Wave soldering Key characteristics in wave soldering are: • Process issues, such as application of adhesive and flux, clinching of leads, board transport, the solder wave parameters, and the time during which components are exposed to the wave • Solder bath specifications, including temperature and impurities IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 5 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 8.4 Reflow soldering Key characteristics in reflow soldering are: • Lead-free versus SnPb soldering; note that a lead-free reflow process usually leads to higher minimum peak temperatures (see Figure 3) than a SnPb process, thus reducing the process window • Solder paste printing issues including smearing, release, and adjusting the process window for a mix of large and small components on one board • Reflow temperature profile; this profile includes preheat, reflow (in which the board is heated to the peak temperature) and cooling down. It is imperative that the peak temperature is high enough for the solder to make reliable solder joints (a solder paste characteristic). In addition, the peak temperature must be low enough that the packages and/or boards are not damaged. The peak temperature of the package depends on package thickness and volume and is classified in accordance with Table 6 and 7 Table 6. SnPb eutectic process (from J-STD-020C) Package thickness (mm) Package reflow temperature (°C) Volume (mm3) < 350 ≥ 350 < 2.5 235 220 ≥ 2.5 220 220 Table 7. Lead-free process (from J-STD-020C) Package thickness (mm) Package reflow temperature (°C) Volume (mm3) < 350 350 to 2000 > 2000 < 1.6 260 260 260 1.6 to 2.5 260 250 245 > 2.5 250 245 245 Moisture sensitivity precautions, as indicated on the packing, must be respected at all times. Studies have shown that small packages reach higher temperatures during reflow soldering, see Figure 3. IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 6 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports temperature maximum peak temperature = MSL limit, damage level minimum peak temperature = minimum soldering temperature peak temperature time 001aac844 MSL: Moisture Sensitivity Level Fig 3. Temperature profiles for large and small components For further information on temperature profiles, refer to Application Note AN10365 “Surface mount reflow soldering description”. IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 7 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 9. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes IP4233CZ6 v.3 20100617 Product data sheet - IP4233CZ6 v.2 Modifications: • • Figure 1: corrected Section 10 “Legal information”: updated IP4233CZ6 v.2 20100506 Preliminary data sheet - IP4233CZ6_1 IP4233CZ6_1 20090330 Objective data sheet - - IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 8 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 10. Legal information 10.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 10.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 10.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 9 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 11. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com IP4233CZ6 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 3 — 17 June 2010 10 of 11 © Nexperia B.V. 2017. All rights reserved IP4233CZ6 Nexperia Ultra low capacitance ESD protection for Ethernet ports 12. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 8.2 8.3 8.4 9 10 10.1 10.2 10.3 10.4 11 12 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Application information. . . . . . . . . . . . . . . . . . . 3 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 4 Soldering of SMD packages . . . . . . . . . . . . . . . 5 Introduction to soldering . . . . . . . . . . . . . . . . . . 5 Wave and reflow soldering . . . . . . . . . . . . . . . . 5 Wave soldering . . . . . . . . . . . . . . . . . . . . . . . . . 5 Reflow soldering . . . . . . . . . . . . . . . . . . . . . . . . 6 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 June 2010
IP4233CZ6,125 价格&库存
很抱歉,暂时无法提供与“IP4233CZ6,125”相匹配的价格&库存,您可以联系我们找货
