MMBZ18VCL/DG,215
MMBZ18VCL/DG,215
    NEXPERIA(安世)
    SOT-23
    安世 SOT-23 Cd: 90 pF Ptot: 350 mW Pppm: 40 W
MMBZ18VCL/DG,215 数据手册
MMBZxVCL; MMBZxVDL series Double ESD protection diodes for transient overvoltage suppression Rev. 01 — 3 September 2008 Product data sheet 1. Product profile 1.1 General description Unidirectional double ElectroStatic Discharge (ESD) protection diodes in a common cathode configuration, encapsulated in a SOT23 (TO-236AB) small Surface-Mounted Device (SMD) plastic package. The devices are designed for ESD and transient overvoltage protection of up to two signal lines. Table 1. Product overview Type number[1] MMBZ12VDL Package Configuration Nexperia JEDEC SOT23 TO-236AB dual common cathode MMBZ15VDL MMBZ18VCL MMBZ20VCL MMBZ27VCL MMBZ33VCL [1] All types available as /DG halogen-free version. 1.2 Features n Unidirectional ESD protection of two lines n Bidirectional ESD protection of one line n Low diode capacitance: Cd ≤ 140 pF n Rated peak pulse power: PPPM ≤ 40 W n Ultra low leakage current: IRM ≤ 5 nA n ESD protection up to 30 kV (contact discharge) n IEC 61000-4-2; level 4 (ESD) n IEC 61643-321 n AEC-Q101 qualified 1.3 Applications n Computers and peripherals n Audio and video equipment n Cellular handsets and accessories n Automotive electronic control units n Portable electronics MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit MMBZ12VDL MMBZ12VDL/DG - - 8.5 V MMBZ15VDL MMBZ15VDL/DG - - 12.8 V MMBZ18VCL MMBZ18VCL/DG - - 14.5 V MMBZ20VCL MMBZ20VCL/DG - - 17 V MMBZ27VCL MMBZ27VCL/DG - - 22 V MMBZ33VCL MMBZ33VCL/DG - - 26 V MMBZ12VDL MMBZ12VDL/DG - 110 140 pF MMBZ15VDL MMBZ15VDL/DG - 85 105 pF MMBZ18VCL MMBZ18VCL/DG - 70 90 pF MMBZ20VCL MMBZ20VCL/DG - 65 80 pF MMBZ27VCL MMBZ27VCL/DG - 48 60 pF MMBZ33VCL MMBZ33VCL/DG - 45 55 pF Per diode VRWM Cd reverse standoff voltage diode capacitance f = 1 MHz; VR = 0 V 2. Pinning information Table 3. Pinning Pin Description 1 anode (diode 1) 2 anode (diode 2) 3 common cathode Simplified outline Graphic symbol 3 1 3 2 1 2 006aaa150 © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 2 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 3. Ordering information Table 4. Ordering information Type number MMBZ12VDL Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 - plastic surface-mounted package; 3 leads SOT23 MMBZ15VDL MMBZ18VCL MMBZ20VCL MMBZ27VCL MMBZ33VCL MMBZ12VDL/DG MMBZ15VDL/DG MMBZ18VCL/DG MMBZ20VCL/DG MMBZ27VCL/DG MMBZ33VCL/DG 4. Marking Table 5. Marking codes Type number Marking code[1] Type number Marking code[1] MMBZ12VDL *MA MMBZ12VDL/DG TJ* MMBZ15VDL *MB MMBZ15VDL/DG TL* MMBZ18VCL *MC MMBZ18VCL/DG TN* MMBZ20VCL *MD MMBZ20VCL/DG TQ* MMBZ27VCL *ME MMBZ27VCL/DG TS* MMBZ33VCL *MF MMBZ33VCL/DG TU* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 3 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit PPPM rated peak pulse power tp = 10/1000 µs [1][2] IPPM rated peak pulse current tp = 10/1000 µs [1][2] - 40 W MMBZ12VDL MMBZ12VDL/DG - 2.35 A MMBZ15VDL MMBZ15VDL/DG - 1.9 A MMBZ18VCL MMBZ18VCL/DG - 1.6 A MMBZ20VCL MMBZ20VCL/DG - 1.4 A MMBZ27VCL MMBZ27VCL/DG - 1 A MMBZ33VCL MMBZ33VCL/DG - 0.87 A [3] - 350 mW [4] Per diode Per device total power dissipation Ptot Tamb ≤ 25 °C - 440 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] In accordance with IEC 61643-321 (10/1000 µs current waveform). [2] Measured from pin 1 or 2 to pin 3. [3] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [4] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. Table 7. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Max Unit IEC 61000-4-2 (contact discharge) - 30 kV machine model - 2 kV Per diode VESD [1][2] electrostatic discharge voltage [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 or 2 to pin 3. © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 4 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression Table 8. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 8 kV 001aaa631 IPP 006aab319 150 100 % 90 % IPP (%) 100 % IPP; 10 µs 100 50 % IPP; 1000 µs 50 10 % 0 1.0 2.0 3.0 30 ns 4.0 tp (ms) Fig 1. t tr = 0.7 ns to 1 ns 0 10/1000 µs pulse waveform according to IEC 61643-321 60 ns Fig 2. ESD pulse waveform according to IEC 61000-4-2 6. Thermal characteristics Table 9. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Per device Rth(j-a) Rth(j-sp) thermal resistance from junction in free air to ambient [1] - - 350 K/W [2] - - 280 K/W thermal resistance from junction to solder point [3] - - 60 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [3] Soldering point at pin 3. © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 5 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 7. Characteristics Table 10. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit MMBZ12VDL MMBZ12VDL/DG IF = 10 mA - - 0.9 V MMBZ15VDL MMBZ15VDL/DG IF = 10 mA - - 0.9 V MMBZ18VCL MMBZ18VCL/DG IF = 10 mA - - 0.9 V MMBZ20VCL MMBZ20VCL/DG IF = 10 mA - - 0.9 V MMBZ27VCL MMBZ27VCL/DG IF = 200 mA - - 1.1 V MMBZ33VCL MMBZ33VCL/DG IF = 10 mA - - 0.9 V MMBZ12VDL MMBZ12VDL/DG - - 8.5 V MMBZ15VDL MMBZ15VDL/DG - - 12.8 V MMBZ18VCL MMBZ18VCL/DG - - 14.5 V MMBZ20VCL MMBZ20VCL/DG - - 17 V MMBZ27VCL MMBZ27VCL/DG - - 22 V MMBZ33VCL MMBZ33VCL/DG - - 26 V Per diode VF VRWM IRM forward voltage reverse standoff voltage reverse leakage current MMBZ12VDL MMBZ12VDL/DG VRWM = 8.5 V - 0.1 5 nA MMBZ15VDL MMBZ15VDL/DG VRWM = 12.8 V - 0.1 5 nA MMBZ18VCL MMBZ18VCL/DG VRWM = 14.5 V - 0.1 5 nA MMBZ20VCL MMBZ20VCL/DG VRWM = 17 V - 0.1 5 nA MMBZ27VCL MMBZ27VCL/DG VRWM = 22 V - 0.1 5 nA MMBZ33VCL MMBZ33VCL/DG VRWM = 26 V - 0.1 5 nA © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 6 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression Table 10. Characteristics …continued Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions VBR IR = 1 mA Cd VCL Min Typ Max Unit MMBZ12VDL MMBZ12VDL/DG 11.4 12 12.6 V MMBZ15VDL MMBZ15VDL/DG 14.3 15 15.8 V MMBZ18VCL MMBZ18VCL/DG 17.1 18 18.9 V MMBZ20VCL MMBZ20VCL/DG 19 20 21 V MMBZ27VCL MMBZ27VCL/DG 25.65 27 28.35 V MMBZ33VCL MMBZ33VCL/DG 31.35 33 34.65 V MMBZ12VDL MMBZ12VDL/DG - 110 140 pF MMBZ15VDL MMBZ15VDL/DG - 85 105 pF MMBZ18VCL MMBZ18VCL/DG - 70 90 pF MMBZ20VCL MMBZ20VCL/DG - 65 80 pF MMBZ27VCL MMBZ27VCL/DG - 48 60 pF MMBZ33VCL MMBZ33VCL/DG - 45 55 pF breakdown voltage diode capacitance f = 1 MHz; VR = 0 V [1][2] clamping voltage MMBZ12VDL MMBZ12VDL/DG IPPM = 2.35 A - - 17 V MMBZ15VDL MMBZ15VDL/DG IPPM = 1.9 A - - 21.2 V MMBZ18VCL MMBZ18VCL/DG IPPM = 1.6 A - - 25 V MMBZ20VCL MMBZ20VCL/DG IPPM = 1.4 A - - 28 V MMBZ27VCL MMBZ27VCL/DG IPPM = 1 A - - 38 V MMBZ33VCL MMBZ33VCL/DG IPPM = 0.87 A - - 46 V © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 7 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression Table 10. Characteristics …continued Tamb = 25 °C unless otherwise specified. Symbol Parameter SZ Conditions Min Typ Max Unit MMBZ12VDL MMBZ12VDL/DG - 8.1 - mV/K MMBZ15VDL MMBZ15VDL/DG - 11 - mV/K MMBZ18VCL MMBZ18VCL/DG - 14 - mV/K MMBZ20VCL MMBZ20VCL/DG - 15.8 - mV/K MMBZ27VCL MMBZ27VCL/DG - 23 - mV/K MMBZ33VCL MMBZ33VCL/DG - 29.4 - mV/K temperature coefficient IZ = 1 mA [1] In accordance with IEC 61643-321 (10/1000 µs current waveform). [2] Measured from pin 1 or 2 to pin 3. 006aab327 103 006aab321 1.2 PPPM PPPM (W) PPPM(25°C) 102 0.8 10 0.4 1 10−2 10−1 1 10 102 0 103 tp (ms) 0 50 100 150 200 Tj (°C) MMBZ27VCL: unidirectional and bidirectional Tamb = 25 °C Fig 3. Rated peak pulse power as a function of exponential pulse duration (rectangular waveform); typical values Fig 4. Relative variation of rated peak pulse power as a function of junction temperature; typical values © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 8 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 006aab328 100 006aab329 102 IRM (nA) Cd (pF) 80 10 1 60 10−1 40 (1) (2) 10−2 (3) 20 (4) 10−3 −75 0 0 5 10 15 20 25 VR (V) f = 1 MHz; Tamb = 25 °C −25 25 75 125 175 Tamb (°C) MMBZ27VCL: VRWM = 22 V (1) MMBZ15VDL: unidirectional (2) MMBZ15VDL: bidirectional (3) MMBZ27VCL: unidirectional (4) MMBZ27VCL: bidirectional Fig 5. Diode capacitance as a function of reverse voltage; typical values Fig 6. Reverse leakage current as a function of junction temperature; typical values I IPPM IPP −VCL −VBR −VRWM V −IRM −IR − −VCL −VBR −VRWM IR IRM −IRM −IR + P-N − −IPP −IPPM Fig 7. + −IPP −IPPM 006aab324 V-I characteristics for a unidirectional ESD protection diode Fig 8. 006aab325 V-I characteristics for a bidirectional ESD protection diode © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet VRWM VBR VCL Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 9 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 8. Application information The MMBZxVCL series and the MMBZxVDL series are designed for the protection of up to two unidirectional data or signal lines from the damage caused by ESD and surge pulses. The devices may be used on lines where the signal polarities are either positive or negative with respect to ground. The devices provide a surge capability of 40 W per line for a 10/1000 µs waveform. line 1 to be protected line 1 to be protected line 2 to be protected MMBZxVCL/VDL GND unidirectional protection of two lines MMBZxVCL/VDL GND bidirectional protection of one line 006aab330 Fig 9. Typical application: ESD and transient voltage protection of data lines Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the devices as close to the input terminal or connector as possible. 2. The path length between the device and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. 9. Test information 9.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 10 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 10. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 04-11-04 Fig 10. Package outline SOT23 (TO-236AB) 11. Packing information Table 11. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number MMBZ12VDL Package Description Packing quantity 3000 10000 SOT23 4 mm pitch, 8 mm tape and reel -215 -235 SOT23 4 mm pitch, 8 mm tape and reel -215 -235 MMBZ15VDL MMBZ18VCL MMBZ20VCL MMBZ27VCL MMBZ33VCL MMBZ12VDL/DG MMBZ15VDL/DG MMBZ18VCL/DG MMBZ20VCL/DG MMBZ27VCL/DG MMBZ33VCL/DG [1] For further information and the availability of packing methods, see Section 15. © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 11 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 12. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig 11. Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig 12. Wave soldering footprint SOT23 (TO-236AB) © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 12 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 13. Revision history Table 12. Revision history Document ID Release date MMBZXVCL_MMBZXVDL_SER_1 20080903 Data sheet status Change notice Supersedes Product data sheet - - © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 13 of 15 MMBZxVCL; MMBZxVDL series Nexperia Double ESD protection diodes for transient overvoltage suppression 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 14.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. ESD protection devices — These products are only intended for protection against ElectroStatic Discharge (ESD) pulses and are not intended for any other usage including, without limitation, voltage regulation applications. Nexperia accepts no liability for use in such applications and therefore such use is at the customer’s own risk. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © MMBZXVCL_MMBZXVDL_SER_1 Product data sheet Rev. 01 — 3 September 2008 Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia MMBZxVCL; MMBZxVDL series Double ESD protection diodes for transient overvoltage suppression 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Thermal characteristics. . . . . . . . . . . . . . . . . . . 5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Application information. . . . . . . . . . . . . . . . . . 10 Test information . . . . . . . . . . . . . . . . . . . . . . . . 10 Quality information . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Packing information. . . . . . . . . . . . . . . . . . . . . 11 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 September 2008
MMBZ18VCL/DG,215 价格&库存
很抱歉,暂时无法提供与“MMBZ18VCL/DG,215”相匹配的价格&库存,您可以联系我们找货
