717 SERIES
Press-Fit Card Edge Connectors 0.156” (3.96mm) Pitch
Features:
0.156” (3.96mm) contact spacing x 0.200” (5.08mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
Low profile insulator body, 0.550”(13.97mm)
Contact termination options include P.C. tail, and 0.025” (0.64mm) square wire wrap
Press-fit compliant section for gas tight reliable connection in plated through holes eliminates soldering
operations
Single or dual row configurations
Accepts between contact and in-contact polarizing keys (special features if requested)
Tools available for insulator and contact removal. Simple “flat rock” tooling is used for connector installation
RoHS Compliant & UL Certified
Specifications:
Insulator Material
UL 94V-0 Thermoplastic Polyester, Black
Contact Material
Copper Alloy
Contact Plating
30µ” Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
Current Rating
3 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1200 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-40°C to +105°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
Contact insertion into Hole
20 lbs (89 N) maximum
Contact Retention in Hole
10 lbs (44 N) minimum
Re-Insertability in same Hole
3 Times minimum
Example Part Number:
717-044-520-201
Series
Total Number of Contacts
Contact Code
Contact Rows
Series:
Insulator Color:
717
Thermoplastic Polyester, Green
Total Number of Contacts:
Contact Rows:
005, 006, . . . . 043
Single Row
010, 012, . . . . 086
Dual Row
Contact Code:
Description:
Contact Point:
Tail Length "G":
520
P.C. Tail
Regular Point
.190 (4.83)
522
P.C. Tail
Regular Point
.375 (9.53)
525
P.C. Tail
High Point
.190 (4.83)
540
Wire Wrap
Regular Point
.560 (14.22)
541
Wire Wrap
Regular Point
.750 (19.05)
545
Wire Wrap
High Point
.560 (14.22)
560
Make Before Break (MBB) Contacts
Contact Rows:
Description:
101
Single Row
201
Dual Row
www.edac.net
BETWEEN CONTACT
POLARIZING KEY
P/N 306-240-318
PROPOSED
IN-CONTACT
POLARIZING KEY
P/N 725-240-328
.190 (4.83)
Ordering Code Notes:
1) All connector sizes up to 43 contacts single row / 86
contacts dual row are available upon request.
2) Make-Before-Break switching contacts, assembled in
specific contact positions, are available upon request.
customerservice@edac.net
717 SERIES
SECTIONS
"Y"
"Y"
CONTACT ROWS & INSULATOR OPTIONS
"C"
"D"
.420
(10.67)
CARD
SLOT
.350
(8.89)
CARD SLOT ACCEPTS .054(1.37) TO
.070 (1.78)THICK P.C. BOARD
Single Row Versions May Require
Backup Springs Depending upon
the Application.
.230 (5.84)
CONTACT POINT
CODE 101
CODE 201
the Application.
"Y"
.550
(13.97)
"Y"
"G"
MAKE BEFORE BREAK
(M.B.B) POINT CONTACTS
.025 (0.64) SQUARE
P.C. & WIRE WRAP TAILS
.156 (3.96)
"E"
.535
(13.59) .440
(11.18)
.200 (5.08) ROW SPACING
.080 (2.03) CUT OUT
FOR IN-CONTACT
POLARIZING KEY
.156 (3.96)
"E"
.040 (1.02) DIA ± .003 (0.08)
SEE NOTE BELOW
.008 (0.20) DIA
.050 (1.27)
CUT OUT FOR
BETWEEN CONTACT
POLARIZING KEY
+.000
( "D" MINUS .012 (0.30) -.015 (0.38)
TO OBTAIN OPTIMUM COMPLIANT SECTION PERFORMANCE,
DRILL HOLES .0453 ± .001 (1.15 ± 0.03) DIAMETER
COPPER PLATE, .001 (25.4 MICRONS) MINIMUM THICKNESS,
FOLLOWED BY TIN PLATE TO PROVIDE FINISHED
HOLES .040 ± .003 (1.02 ± 0.08) DIAMETER
www.edac.net
很抱歉,暂时无法提供与“717-076-560-201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+105.8168425+13.72965
