SMDJ9.0A
SMDJ9.0A
    MDD(辰达半导体)
    SMD
    辰达行 SMD 3000W 9V
SMDJ9.0A 数据手册
SMDJ5.0(C)A THRU SMDJ170(C)A Stand-off Voltage - 5.0 to 170 Volts Peak Pulse Power: 3000 Watts TRANSIENT VTAGE SUPPRESSOR Features DO-214AB/SMC  For surface mounted applications in order to optimize board  space Low profile package  Built-in strain relief  Glass passivated junction 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90)  Low inductance  Excellent clamping capability  3000W peak pulse power capability at 10/1000μs waveform, 0.280(7.11) 0.260(6.60)  repetition rate (duty cycle): 0.01%  Fast response time 0.012(0.305) 0.006(0.152)  Typical IR less than 1μA above 10V  High Temperature soldering: 260℃/10 seconds at terminals  Plastic package has underwriters laboratory flammability 94V-0 0.103(2.62) 0.079(2.06) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Mechanical Data Case : JEDEC SMC molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.095 grams Standard Packaging: 12mm tape (EIA STD RS-481) Dimensions in inches and (millimeters) Applications I/O interface AC/DC power supply Low frequency signal transmission line (RS232, RS485, etc.) MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2 ) Maximum Instantaneous Forward Voltage at 100A for Unidirectional only Steady state power dissipation at TA=50℃ Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (N ote3 ) Operating junction and Storage Temperature Range. Typical thermal resistance junction to lead PPPM VF PM(AV) 3000 W 3.5 V 6.5 W IFSM 300 A TJ,TSTG -65 to +150 ℃ RθJL 15 ℃/W RθJA 75 ℃/W Typical thermal resistance junction to ambient Notes: 1. Non-repetitive current pulse , per Fig. 3 and derated above T = 25OC p e r F i g . 2 . A 2. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only,duty cycle=4 per minute maximum. DN:T20519A0 http://www.microdiode.com Rev:2020A0 Page :1 SMDJ5.0(C)A THRU SMDJ170(C)A Stand-off Voltage - 5.0 to 170 Volts Peak Pulse Power: 3000 Watts Electrical Characteristics (TA=25℃ ℃) Part Number (Uni) Part Number (Bi) SMDJ5.0A SMDJ6.0A SMDJ6.5A SMDJ7.0A SMDJ7.5A SMDJ8.0A SMDJ8.5A SMDJ9.0A SMDJ10A SMDJ11A SMDJ12A SMDJ13A SMDJ14A SMDJ15A SMDJ16A SMDJ17A SMDJ18A SMDJ20A SMDJ22A SMDJ24A SMDJ26A SMDJ28A SMDJ30A SMDJ33A SMDJ36A SMDJ40A SMDJ43A SMDJ45A SMDJ48A SMDJ51A SMDJ54A SMDJ58A SMDJ60A SMDJ64A SMDJ70A SMDJ75A SMDJ78A SMDJ85A SMDJ90A SMDJ100A SMDJ110A SMDJ120A SMDJ130A SMDJ150A SMDJ160A SMDJ170A SMDJ5.0CA SMDJ6.0CA SMDJ6.5CA SMDJ7.0CA SMDJ7.5CA SMDJ8.0CA SMDJ8.5CA SMDJ9.0CA SMDJ10CA SMDJ11CA SMDJ12CA SMDJ13CA SMDJ14CA SMDJ15CA SMDJ16CA SMDJ17CA SMDJ18CA SMDJ20CA SMDJ22CA SMDJ24CA SMDJ26CA SMDJ28CA SMDJ30CA SMDJ33CA SMDJ36CA SMDJ40CA SMDJ43CA SMDJ45CA SMDJ48CA SMDJ51CA SMDJ54CA SMDJ58CA SMDJ60CA SMDJ64CA SMDJ70CA SMDJ75CA SMDJ78CA SMDJ85CA SMDJ90CA SMDJ100CA SMDJ110CA SMDJ120CA SMDJ130CA SMDJ150CA SMDJ160CA SMDJ170CA UNI BI Reverse Stand off Voltage VR (Volts) RDE RDG RDK PDM PDP PDR PDT PDV PDX PDZ PEE PEG PEK PEM PEP PER PET PEV PEX PEZ PFE PFG PFK PFM PFP PFR PFT PFV PFX PFZ RGE PGG PGK PGM PGP PGR PGT PGV PGX PGZ PHE PHG PHK PHM PHP PHR DDE DDG DDK DDM DDP DDR DDT DDV DDX DDZ DEE DEG DEK DEM DEP DER DET DEV DEX DEZ DFE DFG DFK DFM DFP DFR DFT DFV DFX DFZ DGE DGG DGK DGM DGP DGR DGT DGV DGX DGZ DHE DHG DHK DHM DHP DHR 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 33.0 36.0 40.0 43.0 45.0 48.0 51.0 54.0 58.0 60.0 64.0 70.0 75.0 78.0 85.0 90.0 100.0 110.0 120.0 130.0 150.0 160.0 170.0 Marking Breakdown Voltage VBR (Volts) @ IT MIN MAX 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.00 11.10 12.20 13.30 14.40 15.60 16.70 17.80 18.90 20.00 22.20 24.40 26.70 28.90 31.10 33.30 36.70 40.00 44.40 47.80 50.00 53.30 56.70 60.00 64.40 66.70 71.10 77.80 83.30 86.70 94.40 100.00 111.00 122.00 133.00 144.00 167.00 178.00 189.00 7.00 7.37 7.98 8.60 9.21 9.83 10.40 11.10 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 49.10 52.80 55.30 58.90 62.70 66.30 71.20 73.70 78.60 86.00 92.10 95.80 104.00 111.00 123.00 135.00 147.00 159.00 185.00 197.00 209.00 Maximum Maximum Maximum Test Agency Peak Reverse Current Clamping Approval Voltage VC Pulse Leakage IR IT @ Ipp Current Ipp @ VR (mA) (V) (A) (μA) 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 113.0 121.0 126.0 137.0 146.0 162.0 177.0 193.0 209.0 243.0 259.0 275.0 326.1 291.3 267.9 250.0 232.6 220.6 208.3 194.8 176.5 164.8 150.8 139.5 129.3 123.0 115.4 108.7 102.7 92.6 84.5 77.1 71.3 66.1 62.0 56.3 51.6 46.5 43.2 41.3 38.8 36.4 34.4 32.1 31.0 29.1 26.5 24.8 23.8 21.9 20.5 18.5 16.9 15.5 14.4 12.3 11.6 10.9 800 800 500 200 100 50 20 10 5 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X For parts without A , the VBR is ± 10%, and VC is 5% higher than A parts. For bidirectional type having VR of 10 volts and less, the IR limit is double. http://www.microdiode.com Rev:2020A0 Page :2 SMDJ5.0(C)A THRU SMDJ170(C)A Stand-off Voltage - 5.0 to 170 Volts Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % 1000 PPPM-Peak Pulse Power (KW) Peak Pulse Power: 3000 Watts 100 10 1 80 60 40 20 0.31x0.31" (8.0x8.0mm) Copper Pad Area 0.1 0 0.0000001 0.000001 0.00001 0.0001 0 0.001 Figure 3 - Pulse Waveform 75 100 125 150 175 100000 tr=10μsec TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM Peak Value IPPM 100 Bi-directional V= OV 10000 Uni-directional V= OV Cj (pF) IPPM- Peak Pulse Current, % IRSM 50 Figure 4 - Typical Junction Capacitance 150 Half Value IPPM IPPM ( ) 2 50 1000 Uni-directional @ VR 100 10/1000μsec. Waveform as defined by R.E.A Bi-directional @ VR 10 0 td 1.0 0 2.0 3.0 1 1.0 4.0 10.0 100.0 1000.0 VBR - Reverse Breakdown Voltage (V) t-Time (ms) Figure 6 - Maximum Non-Repetitive Peak Forward Surge Current Uni-Directional only Figure 5 - Steady State Power Derating Curve 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 350 IFSM - Peak Forward Surge Current (A) PM(AV), Steady Sate Power Dissipation (W) 25 TA - Ambient temperature (ºC) td-Pulse Width (Sec.) 0 25 50 75 100 125 TA - Ambient Temperature(ºC) http://www.microdiode.com 150 175 300 250 200 150 100 50 0 1 10 100 Number of Cycles at 60 Hz Rev:2020A0 Page :3 SMDJ5.0(C)A THRU SMDJ170(C)A Stand-off Voltage - 5.0 to 170 Volts Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only PM(AV), Steady State Power Dissipation (W) Figure 5. Steady State Power Dissipation Derating Curve Peak Pulse Power: 3000 Watts Reflow Soldering Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :4 SMDJ5.0(C)A THRU SMDJ170(C)A Stand-off Voltage - 5.0 to 170 Volts Peak Pulse Power: 3000 Watts Packing information unit:mm P0 P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 BOX (pcs) 6000 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout Symbol Unit (mm) A 4.3 Unit (inch) 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2020A0 Page :5
SMDJ9.0A
物料型号:SMDJ5.0(C)A 至 SMDJ170(C)A
器件简介:瞬态电压抑制器,适用于表面贴装应用,优化板空间,低轮廓封装,内置缓释装置,玻璃钝化结,低电感,优秀的钳位能力,3000W峰值脉冲功率能力。
引脚分配:文档中没有明确指出具体的引脚分配,但提到了极性符号标记在封装上。
参数特性:包括最大脉冲功率耗散、最大瞬态正向电压、稳态功率耗散、峰值正向浪涌电流、工作结温和存储温度范围等。
功能详解:器件具有快速响应时间,典型IR小于1μA在10V以上,高温焊接能力,塑料封装具有UL94V-0可燃性等级。
应用信息:适用于I/O接口、交流/直流电源供应、低频信号传输线(如RS232、RS485等)。
封装信息:JEDEC SMC模塑塑料封装,尺寸以英寸和毫米为单位提供,重量为0.003盎司或0.095克,标准包装为12mm胶带。
SMDJ9.0A 价格&库存
很抱歉,暂时无法提供与“SMDJ9.0A”相匹配的价格&库存,您可以联系我们找货
