SMPJ6.0CA
SMPJ6.0CA
    MDD(辰达半导体)
    SMP
    辰达行 SMP 5000W 6V
SMPJ6.0CA 数据手册
SMPJ5.0 THRU SMPJ100CA Stand-off Voltage - 5.0 to 100 Volts Peak Pulse Power: 5000 Watts TRANSIENT VTAGE SUPPRESSOR Features SMP ƹ Excellent clamping capability ◆ Low dynamic impedance ◆ Solder dip 260 °C max. 10 s, per JESD 22-B106 Mechanical Data Case : JEDEC SMP Molded plastic body Terminals : Tin plated leads, solderable per J-STD- 002 and JESD22-B102 Mounting Position : Any 0D[LPXP5DWLQJV (OHFWULFDO&KDUDFWHULVWLFV Ratings at TA = 25°C unless otherwise specified PARAMETER Peak power dissipation, with a 10/1000us waveform(1)(2 ) Power dissipation, on infinite heat sink at TL=75℃(2) Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (3) Operating junction and storage temperature range Maximum instantaneous forward voltage at 100A for unidirectional only(4) Junction to ambient Junction to lead Notes: (1) (2) (3) (4) (5) Dimensions in inches and (millimeters) SYMBOL UNIT Max PPPM W 5000 PD W 8.0 IFSM A 400 TJ,TST G ℃ -55 to +150 VFM V 3.5 RθJ-A ℃/W 75 RθJ-L ℃/W 15 Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤220v,and VF=5.0v Max for devices of VBR>220v. Mounted on minimum recommended pad layout. DN:T20519A0 http://www.microdiode.com Rev:2020A0 Page :1 SMPJ5.0 THRU SMPJ100CA Stand-off Voltage - 5.0 to 100 Volts Peak Pulse Power: 5000 Watts ELECTRICAL CHARACTERISTICS(TA=25°C unless otherwise noted) Part No. Peak Power Dissipation 10/1000μ sec(W) Reverse Stand-Off Voltage VRWM(V) Breakdown Voltage VBR (V) Min @ IT Breakdown Voltage VBR (V) Max @ IT Test Current IT (mA) Max Clamping Voltage VC (V)@ IPP Peak Pulse Current IPP (A) Reverse Leakage IR (μA) @ VRWM SMPJ5.0A SMPJ5.0CA 5000 5.0 6.40 7.00 10 9.20 543.48 1000 SMPJ6.0A SMPJ6.0CA 5000 6.0 6.67 7.37 10 10.30 485.44 1000 SMPJ6.5A SMPJ6.5CA 5000 6.5 7.22 7.98 10 11.20 446.43 500 SMPJ7.0A SMPJ7.0CA 5000 7.0 7.78 8.60 10 12.00 416.67 200 SMPJ7.5A SMPJ7.5CA 5000 7.5 8.33 9.21 1 12.90 387.60 100 SMPJ8.0A SMPJ8.0CA 5000 8.0 8.89 9.83 1 13.60 367.65 50 SMPJ8.5A SMPJ8.5CA 5000 8.5 9.44 10.40 1 14.40 347.22 25 SMPJ9.0A SMPJ9.0CA 5000 9.0 10.00 11.10 1 15.40 324.68 10 SMPJ10A SMPJ10CA 5000 10.0 11.10 12.30 1 17.00 294.12 5 SMPJ11A SMPJ11CA 5000 11.0 12.20 13.50 1 18.20 274.73 5 SMPJ12A SMPJ12CA 5000 12.0 13.30 14.70 1 19.90 251.26 5 SMPJ13A SMPJ13CA 5000 13.0 14.40 15.90 1 21.50 232.56 5 SMPJ14A SMPJ14CA 5000 14.0 15.60 17.20 1 23.20 215.52 5 SMPJ15A SMPJ15CA 5000 15.0 16.70 18.50 1 24.40 204.92 5 SMPJ16A SMPJ16CA 5000 16.0 17.80 19.70 1 26.00 192.31 5 SMPJ17A SMPJ17CA 5000 17.0 18.90 20.90 1 27.60 181.16 5 SMPJ18A SMPJ18CA 5000 18.0 20.00 22.10 1 29.20 171.23 5 SMPJ19A SMPJ19CA 5000 19.0 21.10 23.30 1 30.80 162.44 5 SMPJ20A SMPJ20CA 5000 20.0 22.20 24.50 1 32.40 154.32 5 SMPJ22A SMPJ22CA 5000 22.0 24.40 26.90 1 35.50 140.85 5 SMPJ24A SMPJ24CA 5000 24.0 26.70 29.50 1 38.90 128.53 5 SMPJ26A SMPJ26CA 5000 26.0 28.90 31.90 1 42.10 118.76 5 SMPJ28A SMPJ28CA 5000 28.0 31.10 34.40 1 45.40 110.13 5 SMPJ30A SMPJ30CA 5000 30.0 33.30 36.80 1 48.40 103.31 5 SMPJ33A SMPJ33CA 5000 33.0 36.70 40.60 1 53.30 93.81 5 SMPJ36A SMPJ36CA 5000 36.0 40.00 44.20 1 58.10 86.06 5 SMPJ40A SMPJ40CA 5000 40.0 44.40 49.10 1 64.50 77.52 5 SMPJ43A SMPJ43CA 5000 43.0 47.80 52.80 1 69.40 72.05 5 SMPJ45A SMPJ45CA 5000 45.0 50.00 55.30 1 72.70 68.78 5 SMPJ48A SMPJ48CA 5000 48.0 53.30 58.90 1 77.40 64.60 5 SMPJ51A SMPJ51CA 5000 51.0 56.70 62.70 1 82.40 60.68 5 SMPJ54A SMPJ54CA 5000 54.0 60.00 66.30 1 87.10 57.41 5 SMPJ58A SMPJ58CA 5000 58.0 64.40 71.20 1 93.60 53.42 5 SMPJ60A SMPJ60CA 5000 60.0 66.70 73.70 1 96.80 51.65 5 SMPJ64A SMPJ64CA 5000 64.0 71.10 78.60 1 103.0 48.54 5 SMPJ70A SMPJ70CA 5000 70.0 77.80 86.00 1 113.0 44.25 5 SMPJ75A SMPJ75CA 5000 75.0 83.30 92.10 1 121.0 41.32 5 SMPJ78A SMPJ78CA 5000 78.0 86.70 95.80 1 126.0 39.68 5 SMPJ80A SMPJ80CA 5000 80.0 88.80 97.60 1 129.6 38.58 5 SMPJ85A SMPJ85CA 5000 85.0 94.40 104.00 1 137.0 36.50 5 SMPJ90A SMPJ90CA 5000 90.0 100.00 111.00 1 146.0 34.25 5 SMPJ100A SMPJ100CA 5000 100.0 111.00 123.00 1 162.0 30.86 5 http://www.microdiode.com Rev:2020A0 Page :2 SMPJ5.0 THRU SMPJ100CA Stand-off Voltage - 5.0 to 100 Volts Peak Pulse Power: 5000 Watts  Typical Characteristics 100 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ PPP or IPP(%) 75 PPPM(KW) 10 50 1.0 25 0.1 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1μs 1μs 0 10μs 100μs td(μs) 1.0ms 0 10ms FIG1:Peak Pulse Power Rating Curve 150 75 50 100 125 TJ(℃) 150 175 200 FIG2: Pulse Power or Current vs. Initial Junction Temperature 100 tr=10μs TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM Peak Value IPPM IPPM(%) 25 Rth(℃/W) 100 Half Value - IPP 2 IPPM 50 10 1 10/1000μs Waveform as Defined by R.E.A. td 0 0 1.0 2.0 3.0 4.0 T(ms) 0.1 0.001 0.01 0.1 1 tp(s) 10 100 1000 FIG4:Typical Transient Thermal Impedance FIG3: Pulse Waveform 10.5 TJ=TJMax. 8.3ms Single Half Sine-Wave 9.0 400 8.0 PD(W) IFSM(A) 7.5 6.0 4.5 3.0 1.5 0 0 0 10 Number of Cycles FIG5: Maximum Non-Repetitive Surge Current http://www.microdiode.com 100 0 25 50 75 100 125 150 175 200 TL(℃) FIG6:Steady State Power Dissipation Rev:2020A0 Page :3 SMPJ5.0 THRU SMPJ100CA Stand-off Voltage - 5.0 to 100 Volts Peak Pulse Power: 5000 Watts 0RXQWLQJ3DG/D\RXW(unit:mm) B A C Dim Millimeters A 5.40 B 5.90 C 2.10 D 1.90 E 4.00 D E Note: based on the center of the small pad,Maximum Displacement 0.3mm。 Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2020A0 Page :4
SMPJ6.0CA
物料型号:SMPJ5.0至SMPJ100CA
器件简介:这些是瞬态电压抑制器,具有5.0至100伏特的隔离电压和高达5000瓦特的峰值脉冲功率。
引脚分配:文档中未明确列出引脚分配,但提到了JEDEC SMP塑封体和锡镀引脚,可按照J-STD-002和JESD22-B102标准进行焊接。
参数特性: - 峰值功率耗散:5000瓦特 - 无限热沉上的功率耗散:8.0瓦特 - 峰值正向浪涌电流:400安培 - 工作和存储结温范围:-55至+150摄氏度 - 最大瞬态正向电压:3.5伏特(VBR≤220伏特)或5.0伏特(VBR>220伏特)
功能详解:文档提供了详细的电气特性表,包括峰值功率耗散、反向隔离电压、击穿电压、测试电流、最大钳位电压和峰值脉冲电流等参数。
应用信息:虽然文档没有直接提供应用信息,但瞬态电压抑制器通常用于保护电子设备免受电压浪涌和瞬态电压的影响。
封装信息:封装为JEDEC SMP塑封体,尺寸数据以英寸和毫米提供。
SMPJ6.0CA 价格&库存
很抱歉,暂时无法提供与“SMPJ6.0CA”相匹配的价格&库存,您可以联系我们找货
