P6KE6.8 THRU P6KE440CA
Breakdown Voltage:6.8-440 Volts Peak Pulse P ower:600 Watts
GLASS PASSIVAED JUNCTION TRANSIENT VOLTAGE SUPPRESSOR
Features
DO-15
600w peak pulse power capability
Excellent clamping capability
Low incremental surge resistance
Fast response time:typically less than 1.0ps from 0v to
1.0(25.4)
MIN.
VBR for unidirectional and 5.0ns ror bidirectional types.
High temperature soldering guaranteed:
0.140 (3.6)
0.104(2.6)
DIA.
265°C/10S/9.5mm lead length at 5 lbs tension
0.300(7.6)
0.230(5.8)
Mechanical Data
0.034 (0.86)
0.028 (0.70)
DIA.
Case : JEDEC DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.014 ounce, 0.40 grams
1.0 (25.4)
MIN.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
VALUE
UNITS
Peak power dissipation
sipation
Pppm
Minimum 600
W
peak power dissipation (Note 1)
Ippm
See Table 1
A
Steady state power dissapation (Note 2)
PM(AV)
5.0
W
IFSM
100
A
VF
3.5/5.0
V
TSTG,TJ
-55 to + 175
C
Peak forward surPeak forward surge current(Note 3)
Maximum instantaneous forward voltage at 50A
for unidirectional only
(Note 4)
Operating junction and storage temperature range
Notes:
1.10/1000µs waveform non-repetitive current pulse,per Fig.3 and derated above Ta=25 C per Fig.2
2.TL=75 C,lead lengths 9.5mm,Mounted on copper pad atea of (40x40mm)Fig.5
3.Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
4.VF=3.5V max.for devices of V(BR)200V
DN:T20525A0
http://www.microdiode.com
Rev:2020A0
Page :1
ELECTRICAL CHARACTERISTICS (at TA=25°C unless otherwise noted)
Device Type
P6KE6.8
P6KE6.8A
P6KE7.5
P6KE7.5A
P6KE8.2
P6KE8.2A
P6KE9.1
P6KE9.1A
P6KE10
P6KE10A
P6KE11
P6KE11A
P6KE12
P6KE12A
P6KE13
P6KE13A
P6KE15
P6KE15A
P6KE16
P6KE16A
P6KE18
P6KE18A
P6KE20
P6KE20A
P6KE22
P6KE22A
P6KE24
P6KE24A
P6KE27
P6KE27A
P6KE30
P6KE30A
P6KE33
P6KE33A
P6KE36
P6KE36A
P6KE39
P6KE39A
P6KE43
P6KE43A
P6KE47
P6KE47A
P6KE51
P6KE51A
P6KE56
P6KE56A
Maximum
Breakdown Voltage
Maximum
Reverse
V(BR)
Test Stand-off
Peak Pulse
Leakage
(Volts)(NOTES 1)
Current Voltage
Reverse Current
VWM
atVWM
IT(mA)
IPPM(NOTE2)
(Volts) ID(NOTE3)(µA)
MIN
MAX
(Amps)
6.12
6.45
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.5
10.8
11.4
11.7
12.4
13.5
14.3
14.4
15.2
16.2
17.1
18.0
19.0
19.8
20.9
21.6
22.8
24.3
25.7
27.0
28.5
29.7
31.4
32.4
34.2
35.1
37.1
38.7
40.9
42.3
44.7
45.9
48.5
50.4
53.2
7.48
7.14
8.25
7.88
9.02
8.61
10.0
9.55
11.0
10.5
12.1
11.6
13.2
12.6
14.3
13.7
16.5
15.8
17.6
16.8
19.8
18.9
22.0
21.0
24.2
23.1
26.4
25.2
29.7
28.4
33.0
31.5
36.3
34.7
39.6
37.8
42.9
41.0
47.3
45.2
51.7
49.4
56.1
53.6
61.6
58.8
10.0
10.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
41.3
43.6
45.4
47.8
1000.0
1000.0
500.0
500.0
200.0
200.0
50.0
50.0
10.0
10.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
50.
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
55.6
57.1
51.3
53.1
48.0
49.6
43.5
44.8
40.0
41.4
37.0
38.5
34.7
35.9
31.6
33.0
27.3
28.3
25.5
26.7
22.6
23.8
20.6
21.7
18.8
19.6
17.3
18.1
15.3
16.0
13.8
14.5
12.6
13.1
11.5
12.0
10.6
11.1
9.7
10.1
8.8
9.3
8.2
8.6
7.5
7.8
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.2
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
80.5
77.0
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
0.102
0.102
0.103
0.103
The electrical characteristics above is for reference only.
Rev:2020A0
Page :2
Device Type
Breakdown Voltage
V(BR)
(Volts)(NOTES 1)
MIN
MAX
P6KE62
P6KE62A
P6KE68
P6KE68A
P6KE75
P6KE75A
P6KE82
P6KE82A
P6KE91
P6KE91A
P6KE100
P6KE100A
P6KE110
P6KE110A
P6KE120
P6KE120A
P6KE130
P6KE130A
P6KE150
P6KE150A
P6KE160
P6KE160A
P6KE170
P6KE170A
P6KE180
P6KE180A
P6KE200
P6KE200A
P6KE220
P6KE220A
P6KE250
P6KE250A
P6KE300
P6KE300A
P6KE350
P6KE350A
P6KE400
P6KE400A
P6KE440
P6KE440A
55.8
58.9
61.2
64.6
67.5
71.3
73.8
77.9
81.9
86.5
90.0
95.0
99.0
105
108
114
117
124
135
143
144
152
153
162
162
171
180
190
198
209
225
237
270
285
315
332
360
380
396
418
68.2
65.1
74.8
71.4
82.5
78.8
90.2
86.1
100
95.5
110
105
121
116
132
126
143
137
165
158
176
168
187
179
198
189
220
210
242
231
275
263
330
315
385
368
440
420
484
462
Test Stand-off
Current Voltage
VWM
IT(mA)
(Volts)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
50.2
53.0
55.1
58.1
60.7
64.1
66.4
70.1
73.7
77.8
81.0
85.5
89.2
94.0
97.2
102
105
111
121
128
130
136
138
145
146
154
162
171
175
185
202
214
243
256
284
300
324
342
356
376
Maximum
Reverse
Leakage
atVWM
ID(NOTE3)(µA)
Maximum
Peak Pulse
Reverse Current
IPPM(NOTE2)
(Amps)
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
6.7
7.1
6.1
6.5
5.6
5.8
5.1
5.3
4.6
4.8
4.2
4.4
3.8
3.9
3.5
3.6
3.2
3.4
2.8
2.9
2.6
2.7
2.5
2.6
2.3
2.4
2.1
2.2
1.7
1.8
1.7
1.7
1.4
1.4
1.2
1.2
1.0
1.1
0.95
1.0
89.0
85.0
98.0
92.0
108
103
118
113
131
125
144
137
158
152
173
165
187
179
215
207
230
219
244
234
258
246
287
274
344
328
360
344
430
414
504
482
574
548
631
602
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
0.104
0.104
0.104
0.104
0.105
0.105
0.105
0.105
0.106
0.106
0.106
0.106
0.107
0.107
0.107
0.107
0.107
0.107
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.110
0.110
0.110
0.110
0.110
0.110
0.110
0.110
0.110
0.110
NOTES:
1.V(BR)measured after IT applied for 300µs,IT=square wave pulse or equivalent
2. Surge current waveform per Fig.3 and derated per Fig.2
3.For bidirectional types having VWM of 10 volts and less,the ID limit is doubled
4.All items and symbols are consistent with ANSI/IEEE C62.35
Rev:2020A0
Page :2
PEAK PULSE POWER(PppM)or CURRENT(IppM)
DERATING IN PERCENTAGE,%
FIG. 1-PEAK PULSE POWER RATING CURVE
PppM,PEAK PULSE POWER,kw
100
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG.3
TA=25 C
10
1.0
0.1
0.1µs
1.0µs
10µs
100µs
1.0ms
10ms
td,PULSE WIDTH,sec.
FIG.3-PULSE WAVEFORM
FIG. 2-PULSE DERATING CURVE
100
75
50
25
150
IppM,PEAK PULSE CURRENT,%
tr=10µsec
100
125
150
175
200
10,000
100
HALF VALUE
MEASURED at
ZERO BIAS
IPPM
2
CJ,JINCTION CAPACITANCE,pF
10/1000µsec WAVEFORM
as DFINED by R.E.A
50
td
2.0
3.0
4.0
t,TIME,ms
FIG.5-STEADY STATE POWER DERATING CURVE
5.00
L=0.375” (9.5mm)
lLEAD LENGTHS
60Hz RESISTIVE
OR INDUCTIVE LOAD
TA=25 C
f=1.0MHz
Vsig=50mVp-p
1,000
MEASURED at
STAND-OFF
VOLTAGE,VwM
100
3.75
10
1.0
10
100
200
2.50
1.6 1.6 0.040”
(40 40 1mm)
COPPER HEAT SINKS
V(BR),BREAKDOWN VOLTAGE,VOLTS
1.25
IFSM,PEAK FORWARD SURAGE CURRENT
AMPERES
PM(AV),STEADY STATE POWER
DISSIPATION,WATTS
75
FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE
UNIDIRECTIONAL
PEAK VALUE IppM
50
75
100
125
150
175
200
TL,LEAD TEMPERATURE, C
FIG.7-TYPICAL REVERSE LEAKAGE CHARCTERISTICS
INSTANTANEOUS REVERSE LEAKAGE
CURRENT,MICROAMPERES
50
TA AMBIENT TEMPERATURE,( C)
PULSE WIDTH (td) is DEFINED
as the POINT WHERE the PEAK
CURRENT DECAYS to 50% of IppM
1000
100
MEASURED AT DEVICES
STAND-OFF
VOLTAGE,Vwm
10
1
TA=25 C
0.1
FIG.6-MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT UNIDIRECTIONAL ONLY
200
100
TJ=TJmax.
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
10
1.0
10
100
NUMBER OF CYCLES AT 60Hz
0.01
0.001
200
300
400
500
The curve characteristics above is for reference only.
https://www.microdiode.com
Rev:2020A0
Page :2
很抱歉,暂时无法提供与“P6KE100A”相匹配的价格&库存,您可以联系我们找货
