SA130A
SA130A
    MDD(辰达半导体)
    DO-15
    辰达行 DO-15 500W 159V
SA130A 数据手册
SA5.0(C)A THRU SA170(C)A Breakdown Voltage:5.0-170CA Volts Pesk Pulse Power:500 Watts GLASS PASSIVAED JUNCTION TRANSIENT VOLTAGE SUPPRESSOR Features DO-15  500w peak pulse power capability  Excellent clamping capability  Low incremental surge resistance  Fast response time:typically less than 1.0ps from 0v 1.0(25.4) MIN. to VBR for unidirectional and 5.0ns ror bidirectional  types. High temperature soldering guaranteed: 0.140(3.6) 0.104(2.6) DIA. 265°C /10S/9.5mm lead length at 5 lbs tension 0.300(7.6) 0.230(5.8) Mechanical Data 0.034 (0.86) 0.028 (0.70) DIA. Case : JEDEC DO-15 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.014 ounce, 0.40 grams 1.0 (25.4) MIN. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS VALUE UNITS Pppm Minimum 500 W Peak pulse reverse curr current IPPM See Table 1 A Steady state power dissapation (Note 2) PM(AV) 1.6 W Peak forward sur surge current IFSM 70 A VF 3.5 V TSTG,TJ -55 to + 175 Peak power dissipation sipation Maximum instantaneous forward voltage at 35A for unidirectional only (Note 3) Operating junction and storage temperature range C Notes: 1.10/1000µs waveform non-repetitive current pulse,per Fig.3 and derated above Ta=25 C per Fig.2 2.TL=75 C,lead lengths 9.5mm,Mounted on copper pad atea of (40x40mm)Fig.5 3.Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. DN:T20525A0 http://www.microdiode.com Rev:2020A0 Page :1 SA5.0 THRU SA170CA Breakdown Voltage:5.0-170CA Volts Pesk Pulse Power:500 Watts ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device Type SA5.0 SA5.0A SA6.0 SA6.0A SA6.5 SA6.5A SA7.0 SA7.0A SA7.5 SA7.5A SA8.0 SA8.0A SA8.5 SA8.5A SA9.0 SA9.0A SA10 SA10A SA11 SA11A SA12 SA12A SA13 SA13A SA14 SA14A SA15 SA15A SA16 SA16A SA17 SA17A SA18 SA18A SA20 SA20A SA22 SA22A SA24 SA24A SA26 SA26A SA28 SA28A SA30 SA30A SA33 SA33A Breakdown Voltage V(BR) (Volts)(NOTES 1) MIN MAX 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.00 10.00 11.10 11.10 12.20 12.20 13.30 13.30 14.40 14.40 15.60 15.60 16.70 16.70 17.80 17.80 18.90 18.90 20.00 20.00 22.20 22.20 24.40 24.40 26.70 26.70 28.90 28.90 31.10 31.10 33.30 33.30 36.70 36.70 7.30 7.00 8.15 7.37 8.82 7.98 9.51 8.60 10.20 9.21 10.90 9.83 11.50 10.40 12.20 11.10 13.60 12.30 14.90 13.50 16.30 14.70 17.60 15.90 19.10 17.20 20.40 18.50 21.80 19.70 23.10 20.90 24.40 22.10 27.10 24.50 29.80 26.90 32.60 29.50 35.30 31.90 38.00 34.40 40.70 36.80 44.90 40.60 Test Stand-off Current Voltage VWM IT(mA) (Volts) 10 10 10 10 10 10 10 10 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 5.0 5.0 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 8.0 8.0 8.5 8.5 9.0 9.0 10.00 10.00 11.00 11.00 12.00 12.00 13.00 13.00 14.00 14.00 15.00 15.00 16.00 16.00 17.00 17.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 33.00 33.00 Maximum Reverse Leakage atVWM ID(NOTE3)(µA) 600 600 600 600 400 400 150 150 50 50 25 25 10 10 5.0 5.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Maximum Peak Pulse Reverse Current IPPM(NOTE2) (Amps) 52.1 54.3 43.9 48.5 40.7 44.7 37.6 41.7 35.0 38.8 33.3 36.8 31.4 34.7 29.6 32.5 26.6 29.4 24.9 27.5 22.7 25.1 21.0 23.3 19.4 21.6 18.6 20.5 17.4 19.2 16.4 18.1 15.5 17.1 14.0 15.4 22.7 14.1 11.6 12.9 10.7 11.9 10.0 11.0 9.3 10.0 8.5 9.4 Maximum Clamping Voltage at IPPM Vc(Volts) Maximum Temperature Coefficient of V(BR) (mv/ C) 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.1 45.4 53.5 48.4 59.0 53.3 5.0 5.0 5.0 5.0 5.0 5.0 6.0 6.0 7.0 7.0 7.0 7.0 8.0 8.0 9.0 9.0 10.0 10.0 11.0 11.0 12.0 12.0 13.0 13.0 14.0 14.0 16.0 16.0 19.0 17.0 20.0 19.0 21.0 20.0 25.0 23.0 28.0 25.0 31.0 28.0 31.0 30.0 35.0 31.0 39.0 36.0 42.0 39.0 The electrical characteristics above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2 SA5.0 THRU SA170CA Breakdown Voltage:5.0-170CA Volts Pesk Pulse Power:500 Watts ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device Type SA36 SA36A SA40 SA40A SA43 SA43A SA45 SA45A SA48 SA48A SA51 SA51A SA54 SA54A SA58 SA58A SA60 SA60A SA64 SA64A SA70 SA70A SA75 SA75A SA78 SA78A SA85 SA85A SA90 SA90A SA100 SA100A SA110 SA110A SA120 SA120A SA130 SA130A SA150 SA150A SA160 SA160A SA170 SA170A Maximum Breakdown Voltage Maximum Reverse V(BR) Test Stand-off Peak Pulse Leakage (Volts)(NOTES 1) Current Voltage Reverse Current VWM atVWM IT(mA) IPPM(NOTE2) (Volts) ID(NOTE3)(µA) MIN MAX (Amps) 40.00 40.00 44.40 44.40 47.80 47.80 50.00 50.00 53.30 53.30 56.70 56.70 60.00 60.00 64.40 64.40 66.70 66.70 71.10 71.10 77.80 77.80 83.30 83.30 86.70 86.70 94.40 94.40 100.00 100.00 111.00 111.00 122.00 122.00 133.00 133.00 144.00 144.00 167.00 167.00 178.00 178.00 189.00 189.00 48.90 44.20 54.30 49.10 58.40 52.80 61.10 55.30 65.20 58.90 69.30 62.70 73.30 66.30 78.70 71.20 81.50 73.70 86.90 78.60 95.10 86.00 102.00 92.10 106.00 95.80 115.00 104.00 122.00 111.00 136.00 123.00 149.00 135.00 163.00 147.00 176.00 159.00 204.00 185.00 218.00 197.00 231.00 209.00 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 36.00 36.00 40.00 40.00 43.00 43.00 45.00 45.00 48.00 48.00 51.00 51.00 54.00 54.00 58.00 58.00 60.00 60.00 64.00 64.00 70.00 70.00 75.00 75.00 78.00 78.00 85.00 85.00 90.00 90.00 100.00 100.00 110.00 110.00 120.00 120.00 130.00 130.00 150.00 150.00 160.00 160.00 170.00 170.00 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.8 77.4 91.1 82.4 96.3 87.1 103.0 93.6 107.0 96.8 114.0 103.0 125.0 113.0 134.0 121.0 139.0 126.0 151.0 137.0 160.0 146.0 179.0 162.0 196.0 177.0 214.0 193.0 230.0 209.0 268.0 243.0 287.0 259.0 304.0 275.0 Maximum Clamping Voltage at IPPM Vc(Volts) 7.8 8.6 7.0 7.8 6.5 7.2 6.2 6.9 5.8 6.5 5.5 6.1 5.2 5.7 4.9 5.3 4.7 5.2 4.4 4.9 4.0 4.4 3.7 4.1 3.6 4.0 3.3 3.6 3.1 3.4 2.8 3.1 2.6 2.8 2.3 2.6 2.2 2.4 1.9 2.1 1.7 1.9 1.6 1.8 Maximum Temperature Coefficient of V(BR) (mv/ C) 46.0 41.0 51.0 46.0 55.0 50.0 58.0 52.0 63.0 56.0 66.0 61.0 71.0 65.0 78.0 70.0 80.0 71.0 86.0 76.0 94.0 85.0 101 91.0 105 95.0 114 103 121 111 135 123 148 133 162 146 175 158 203 184 217 196 230 208 NOTES: 1.V(BR)measured after IT applied for 300µs,IT=square wave pulse or equivalent 2.Surge current waveform per Fig.3 and derated per Fig.2 3.For bidirectional types having VWM of 10 volts and less,the ID limit is doubled 4.All items and symbols are consistent with ANSI/IEEE C62.35 The electrical characteristics above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2 SA5.0 THRU SA170CA Breakdown Voltage:5.0-170CA Volts PEAK PULSE POWER(PppM)or CURRENT(IppM) DERATING IN PERCENTAGE,% FIG. 1-PEAK PULSE POWER RATING CURVE PppM,PEAK PULSE POWER,kw 100 NON-REPETITIVE PULSE WAVEFORM SHOWN inFIG.3 TA=25 C 10 1.0 0.1 0.1µs 1.0µs 10µs 100µs 1.0ms 10ms td,PULSE WIDTH,sec. FIG.3-PULSE WAVEFORM FIG. 2-PULSE DERATING CURVE 100 75 50 25 0 0 25 150 IppM,PEAK PULSE CURRENT,% tr=10µsec 50 75 125 150 175 200 FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE UNIDIRECTIONAL 10,000 100 IPPM HALF VALUE 2 TJ=25 C f=1.0MHz Vsig=50mVp-p CJ,JINCTION CAPACITANCE,pF 10/1000µsec WAVEFORM as DFINED by R.E.A 50 td 0 1.0 2.0 3.0 4.0 t,TIME,ms FIG.5-STEADY STATE POWER DERATING CURVE 1.6 L=0.375” (9.5mm) lLEAD LENGTHS 60Hz RESISTIVE OR INDUCTIVE LOAD MEASURED at ZERO BIAS 1,000 100 MEASURED at STAND-OFF VOLTAGE,VwM 1.2 10 1.0 10 100 200 0.8 1.6 1.6 0.040” (40 40 1mm) COPPER HEAT SINKS V(BR),BREAKDOWN VOLTAGE,VOLTS 0.4 IFSM,PEAK FORWARD SURAGE CURRENT AMPERES PM(AV),STEADY STATE POWER DISSIPATION,WATTS 100 TA, AMBIENT TEMPERATURE,( C) PULSE WIDTH (td) is DEFINED as the POINT WHERE the PEAK CURRENT DECAYS to 50% of IppM PEAK VALUE IppM 0 0 0 25 50 75 100 125 150 175 200 TL,LEAD TEMPERATURE, C FIG.7-TYPICAL REVERSE LEAKAGE CHARCTERISTICS INSTANTANEOUS REVERSE LEAKAGE CURRENT,MICROAMPERES Pesk Pulse Power:500 Watts 100 MEASURED AT DEVICES STAND-OFF VOLTAGE,Vwm 10 1 TA=25 C 0.1 FIG.6-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT UNIDIRECTIONAL ONLY 70 60 TJ=TJmax. 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 50 40 30 20 1.0 10 100 NUMBER OF CYCLES AT 60Hz 0.01 0 100 200 300 400 500 V(BR),BREAKDOWN VOLTAGE,VOLTS The curve characteristics above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2
SA130A
1. 物料型号:SA5.0至SA170CA 2. 器件简介:这些是玻璃钝化结瞬态电压抑制二极管,具有500瓦的峰值脉冲功率能力,优秀的钳位能力,低增量浪涌电阻,快速响应时间(单向类型小于1.0皮秒,双向类型小于5.0纳秒)。 3. 引脚分配:JEDEC DO-15封装,引脚为可焊接的,符合MIL-STD-750标准。 4. 参数特性: - 峰值脉冲功率:最小500瓦 - 峰值脉冲反向电流:见表1 - 稳态功率耗散:1.6瓦 - 峰值正向浪涌电流:70安培 - 单向类型在35安培下的最大瞬态正向电压:3.5伏特 - 工作结和存储温度范围:-55至+175摄氏度 5. 功能详解:文档提供了详细的电气特性表,包括但不限于击穿电压、测试电流、待机电压、最大反向漏电流、最大峰值脉冲反向电流、最大钳位电压和最大温度系数。 6. 应用信息:文档未明确提供应用信息,但通常TVS二极管用于保护电子设备免受电压浪涌的影响。 7. 封装信息:JEDEC DO-15封装,重量为0.014盎司或0.40克。
SA130A 价格&库存
很抱歉,暂时无法提供与“SA130A”相匹配的价格&库存,您可以联系我们找货
