5KP14A
5KP14A
    MDD(辰达半导体)
    R-6
    辰达行 R-6 5000W 17.2V
5KP14A 数据手册
5KP5.0 THRU 5KP110A Breakdown Voltage:5.0-110 Volts Peak Pulse Power:5000 Watts GLASS PASSIVATED JUNCTION TRANSIENT VOLTAGE SUPPRESSOR Features R-6  5000w peak pulse power capability  Excellent clamping capability  Low incremental surge resistance 1.0 (25.4) MIN.  Fast response time:typically less than 1.0ps from 0v to VBR for 0.360 (9.1) 0.340(8.6) unidirectional and 5.0ns ror bidirectional types. DIA.  High temperature soldering guaranteed: 265°C/10S/9.5mm lead length at 5 lbs tension 0.360(9.1) 0.340(8.6) 1.0 (25.4) MIN. Mechanical Data 0.052 (1.3) 0.048 (1.2) Case : JEDEC R-6 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.072 ounce, 2.05 grams DIA. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS VALUE UNITS Peak power dissipation sipation PPPM Minimum 5000 Watts Peak pulse reverse curr current IPPM See Table 1 Amps Steady state power dissapation (Note 2) PM(AV) 8.0 Watts Peak forward sur surge current IFSM 400 Amps VF 3.5 Volts TSTG,TJ -55 to + 175 C Maximum instantaneous forward voltage at 100A for unidirectional only (Note 3) Operating junction and storage temperature range Note: 1.10/1000µs waveform non-repetitive current pulse,per Fig.3 and derated above Ta=25°C per Fig.2 2.TL=75°C,lead lengths 9.5mm,Mounted on copper pad atea of (20x20mm)Fig.5 3.Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. DN:T20526A0 http://www.microdiode.com Rev:2020A0 Page :1 5KP5.0 THRU 5KP110A Breakdown Voltage:5.0-110 Volts Peak Pulse Power:5000 Watts ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device Type 5KP5.0 5KP5.0A 5KP6.0 5KP6.0A 5KP6.5 5KP6.5A 5KP7.0 5KP7.0A 5KP7.5 5KP7.5A 5KP8.0 5KP8.0A 5KP8.5 5KP8.5A 5KP9.0 5KP9.0A 5KP10 5KP10A 5KP11 5KP11A 5KP12 5KP12A 5KP13 5KP13A 5KP14 5KP14A 5KP15 5KP15A 5KP16 5KP16A 5KP17 5KP17A 5KP18 5KP18A 5KP20 5KP20A 5KP22 5KP22A 5KP24 5KP24A 5KP26 5KP26A 5KP28 5KP28A 5KP30 5KP30A 5KP33 5KP33A Maximum Breakdown Voltage Maximum Reverse V(BR) Test Stand-off Peak Pulse Leakage (Volts)(NOTES 1) Current Voltage Reverse Current VWM atVWM IT(mA) IPPM(NOTE2) (Volts) ID(NOTE3)(µA) MIN MAX (Amps) 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.00 10.00 11.10 11.10 12.20 12.20 13.30 13.30 14.40 14.40 15.60 15.60 16.70 16.70 17.80 17.80 18.90 18.90 20.00 20.00 22.20 22.20 24.40 24.40 26.70 26.70 28.90 28.90 31.10 31.10 33.30 33.30 36.70 36.70 http://www.microdiode.com 7.30 7.00 8.15 7.37 8.82 7.98 9.51 8.60 10.20 9.21 10.90 9.83 11.50 10.40 12.20 11.10 13.60 12.30 14.90 13.50 16.30 14.70 17.60 15.90 19.10 17.20 20.40 18.50 21.80 19.70 23.10 20.90 24.40 22.10 27.10 24.50 29.80 26.90 32.60 29.50 35.30 31.90 38.00 34.40 40.70 36.80 44.90 40.60 50 50 50 50 50 50 50 50 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5.0 5.0 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 8.0 8.0 8.5 8.5 9.0 9.0 10.00 10.00 11.00 11.00 12.00 12.00 13.00 13.00 14.00 14.00 15.00 15.00 16.00 16.00 17.00 17.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 33.00 33.00 5000 5000 5000 5000 2000 2000 1000 1000 250 250 150 150 50 50 20 20 15 15 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Maximum Clamping Voltage at IPPM Vc(Volts) Maximum Temperature Coefficient of V(BR) (%/ C) 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.1 45.4 53.5 48.4 59.0 53.3 0.057 0.057 0.061 0.061 0.065 0.065 0.068 0.068 0.073 0.073 0.075 0.075 0.078 0.078 0.081 0.081 0.084 0.084 0.086 0.086 0.088 0.088 0.090 0.090 0.092 0.092 0.094 0.094 0.096 0.096 0.097 0.097 0.098 0.098 0.099 0.099 0.100 0.100 0.101 0.101 0.101 0.101 0.102 0.102 0.103 0.103 0.104 0.104 522 544 439 486 407 447 377 417 350 388 334 368 315 348 296 325 266 295 249 275 228 252 210 233 194 216 186 205 174 193 164 181 155 172 140 154 127 141 116 129 107 119 100 110 93.6 103 84.8 93.9 Rev:2020A0 Page :2 5KP5.0 THRU 5KP110A Breakdown Voltage:5.0-110 Volts Peak Pulse Power:5000 Watts ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted) Device Type Breakdown Voltage V(BR) (Volts)(NOTES 1) Test Current IT(mA) Stand-off Voltage VWM (Volts) Maximum Reverse Leakage atVWM ID(NOTE3)(µA) Maximum Peak Pulse Reverse Current IPPM(NOTE2) (Amps) Maximum Clamping Voltage at IPPM Vc(Volts) Maximum Temperature Coefficient of V(BR) (%/ C) MIN MAX 5KP36 40.00 48.90 5.0 36.00 10 64.3 77.8 0.104 5KP36A 40.00 44.20 5.0 36.00 10 58.1 86.1 0.104 5KP40 44.40 54.30 5.0 40.00 10 71.4 70.1 0.105 5KP40A 44.40 49.10 5.0 40.00 10 64.5 77.6 0.105 5KP43 47.80 58.40 5.0 43.00 10 76.7 65.2 0.105 5KP43A 47.80 52.80 5.0 43.00 10 69.4 72.1 0.105 5KP45 50.00 61.10 5.0 45.00 10 80.3 62.3 0.106 5KP45A 50.00 55.30 5.0 45.00 10 72.7 68.8 0.106 5KP48 53.30 65.20 5.0 48.00 10 85.8 58.5 0.106 5KP48A 53.30 58.90 5.0 48.00 10 77.4 64.7 0.106 5KP51 56.70 69.30 5.0 51.00 10 91.1 54.9 0.107 5KP51A 56.70 62.70 5.0 51.00 10 82.4 60.7 0.107 5KP54 60.00 73.30 5.0 54.00 10 96.3 52.0 0.107 5KP54A 60.00 66.30 5.0 54.00 10 87.1 57.5 0.107 5KP58 64.40 78.70 5.0 58.00 10 103.0 48.6 0.107 5KP58A 64.40 71.20 5.0 58.00 10 93.6 53.5 0.107 5KP60 66.70 81.50 5.0 60.00 10 107.0 46.8 0.108 5KP60A 66.70 73.70 5.0 60.00 10 96.8 51.7 0.108 5KP64 71.10 86.90 5.0 64.00 10 114.0 43.9 0.108 5KP64A 71.10 78.60 5.0 64.00 10 103.0 48.6 0.108 5KP70 77.80 95.10 5.0 70.00 10 125.0 40.0 0.108 5KP70A 77.80 86.00 5.0 70.00 10 113.0 44.3 0.108 5KP75 83.30 102.00 5.0 75.00 10 134.0 37.4 0.108 5KP75A 83.30 92.10 5.0 75.00 10 121.0 41.4 0.108 5KP78 86.70 106.00 5.0 78.00 10 139.0 36.0 0.108 5KP78A 86.70 95.80 5.0 78.00 10 126.0 39.7 0.108 5KP85 94.40 115.00 5.0 85.00 10 151.0 33.2 0.108 5KP85A 94.40 104.00 5.0 85.00 10 137.0 36.5 0.108 5KP90 100.00 122.00 5.0 90.00 10 160.0 31.3 0.110 5KP90A 100.00 111.00 5.0 90.00 10 146.0 34.3 0.110 5KP100 111.00 136.00 5.0 100.00 10 179.0 28.0 0.110 5KP100A 111.00 123.00 5.0 100.00 10 162.0 30.9 0.110 5KP110 122.00 149.00 5.0 110.00 10 196.0 25.6 0.112 5KP110A 122.00 135.00 5.0 110.00 10 177.0 28.3 0.112 NOTES: 1. V(BR) measured after IT applied for 300µs IT=square wave pulse or equivalent 2. Surge current waveform per Fig.3 and derate per Fig.2 3. All items and symbols are consistent with ANSI/IEEE C62.35 http://www.microdiode.com Rev:2020A0 Page :2 5KP5.0 THRU 5KP110A Breakdown Voltage:5.0-110 Volts PppM,PEAK PULSE POWER,kw 10 NON-REPETITIVE PULSE WAVEFORM SHOWN in FIG.3 TA=25 C 1.0 0.1 0.1µs 1.0µs 10µs 100µs 1.0ms FIG. 2-PULSE DERATING CURVE PEAK PULSE POWER(PppM)or CURRENT(IppM) DERATING IN PERCENTAGE,% FIG. 1-PEAK PULSE POWER RATING CURVE 100 10ms td,PULSE WIDTH,sec. Peak Pulse Power:5000 Watts 100 75 50 25 0 0 25 50 75 100 125 150 175 200 TA, AMBIENT TEMPERATURE,( C) FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE FIG.3-PULSE WAVEFORM 100,000 f=1.0MHz Vsig=50mVp-p TJ=25 C PULSE WIDTH (td) is DEFINED as the POINT WHERE the PEAK CURRENT DECAYS to 50% of IppM tr=10µsec CJ,JINCTION CAPACITANCE,pF IppM,PEAK PULSE CURRENT,% 150 PEAK VALUE IppM 100 HALF VALUE IPPM 2 10/1000µsec WAVEFORM as DFINED by R.E.A. 50 MEASURED at ZERO BIAS 10,000 1,000 MEASURED at ATAND-OFF VOLTAGE,VWM td 0 0 1.0 2.0 3.0 4.0 t,TIME,ms 100 1 10 100 200 V(BR),BREAKDOWN VOLTAGE,VOLTS FIG.5-STEADY STATE POWER DERATING CURVE 60Hz RESISTIVE OR INDUCTIVE LOAD IFSM,PEAK FORWARD SURAGE CURRENT AMPERES PM(AV),STEADY STATE POWER DISSIPATION,WATTS 8 6 L=0.375” (9.5mm) lLEAD LENGTHS 4 2 1.6 1.6 0.040”(40 40 1mm) COPPER HEAT SINKS 0 0 25 50 75 100 125 150 TL,LEAD TEMPERATURE, C 175 FIG.6-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 400 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 350 300 250 200 150 100 1.0 10 100 200 NUMBER OF CYCLES AT 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2
5KP14A
1. 物料型号:5KP5.0 至 5KP110A 2. 器件简介:这些是玻璃钝化结瞬态电压抑制二极管,具有5000瓦的峰值脉冲功率能力,优秀的钳位能力,低增量浪涌电阻和快速响应时间(单向类型小于1.0皮秒,双向类型小于5.0纳秒)。 3. 引脚分配:JEDEC R-6塑封塑料体,引脚为可焊接的,符合MIL-STD-750标准。 4. 参数特性:包括峰值功率耗散(PPPM)、峰值脉冲反向电流(IPPM)、稳态功率耗散(PM(AV))、峰值正向浪涌电流(IFSM)和最大瞬态正向电压(VF)等。 5. 功能详解:器件具有高温焊接保证(265°C/10S/9.5mm引脚长度,5磅张力下),符合ROHS标准。 6. 应用信息:适用于需要高脉冲功率和快速响应的应用场合。 7. 封装信息:提供了详细的尺寸信息,包括最小和最大尺寸。
5KP14A 价格&库存
很抱歉,暂时无法提供与“5KP14A”相匹配的价格&库存,您可以联系我们找货
