RVC Series
Stackpole Electronics, Inc.
Medium Voltage Thick Film Chip Resistor
Resistive Product Solutions
Features:
Voltage ratings 2 times or more compared to standard chip resistors
Values up to 100MΩ
Lower resistance values may be available - contact Stackpole
Proportionally higher pulse power capability
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Type/Code
Power Rating (W)
@ 70ºC
Max Working
Voltage (V)
Max Overload
Voltage (V)
TCR (ppm/ºC)
RVC0402
0.063
100
200
±100
±200
±400
RVC0603
0.1
200
400
±100
±200
±400
RVC0805
0.125
400
800
±100
±200
±400
RVC1206
0.25
500
1000
±100
±200
±400
RVC2010
0.5
2000
3000
±100
±200
±400
RVC2512
1
3000
4000
±100
±200
±400
Ohmic Range (Ω) and Tolerance
1%
5%
39K - 1M
1.02M - 10M
1.1M - 20M
22M - 100M
56K - 1M
1.02M - 10M
1.1M - 20M
22M - 100M
100K - 1M
1.02M - 10M
1.1M - 20M
22M - 100M
100K - 1M
1.02M - 10M
1.1M - 20M
22M - 100M
51K- 1M
1.02M - 20M
1.1M - 20M
22M - 100M
30K - 1M
1.02M - 20M
1.1M - 20M
22M - 100M
Working Voltage = √ P*R or maximum working voltage listed above, whichever is lower.
Overload Voltage = 2.5* √ P*R or maximum overload voltage listed above, whichever is lower.
Mechanical Specifications
Type/Code
Weight (g)
(1000 pc)
L
Body Length
W
Body Width
H
Body Height
a
Top Termination
b
Bottom Termination
Unit
RVC0402
0.620
0.039 ± 0.002
1.00 ± 0.05
0.020 ± 0.002
0.50 ± 0.05
0.014 ± 0.002
0.35 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.008 ± 0.004
0.20 ± 0.10
inches
mm
RVC0603
2.042
0.063 ± 0.004
1.60 ± 0.10
0.031 ± 0.004
0.80 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
inches
mm
RVC0805
4.368
0.079 ± 0.004
2.00 ± 0.10
0.049 ± 0.004
1.25 ± 0.10
0.020 ± 0.004
0.50 ± 0.10
0.014 ± 0.008
0.35 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
inches
mm
RVC1206
8.947
0.122 ± 0.004
3.10 ± 0.10
0.061 ± 0.004
1.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.020 ± 0.010
0.50 ± 0.25
0.020 ± 0.008
0.50 ± 0.20
inches
mm
Rev Date: 01/23/2019
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RVC Series
Mechanical Specifications (cont.)
Type/Code
Weight (g)
(1000 pc)
L
Body Length
W
Body Width
H
Body Height
a
Top Termination
b
Bottom Termination
Unit
RVC2010
24.241
0.197 ± 0.008
5.00 ± 0.20
0.098 ± 0.006
2.50 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.024 ± 0.010
0.60 ± 0.25
0.020 ± 0.008
0.50 ± 0.20
inches
mm
RVC2512
39.448
0.250 ± 0.008
6.35 ± 0.20
0.126 ± 0.006
3.20 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.024 ± 0.010
0.60 ± 0.25
0.020 ± 0.008
0.50 ± 0.20
inches
mm
Performance Characteristics
Test
Test Method
Temperature Coefficient of
Resistance (TCR)
JIS-C-5201-1 4.8
IEC-60115-1 4.8
JIS-C-5201-1 4.13
IEC-60115-1 4.13
JIS-C-5201-1 4.6
IEC-60115-1 4.6
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
JIS-C-5201- 4.24
IEC-60115-1 4.24
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
JIS-C-5201-1 4.33
IEC-60115-1 4.33
JIS-C-5201-1 4.17
IEC-60115-1 4.17
JIS-C-5201-1 4.18
IEC-60115-1 4.18
JIS-C-5201-1 4.7
IEC-60115-1 4.7
Short Time Overload
Insulation Resistance
Endurance
Damp Heat with Load
Dry Heat
Bending Strength
Solderability
Resistance to
Soldering Heat
Voltage Proof
Test Specification
± 1%
± 5%
As specified by
Electrical Specification Table
±(1% + 0.05Ω)
Test Method
-55°C ~ +125°C, 25°C is the reference temperature
RCWV * 2.5 or Max. Overload Voltage
whichever is lower for 5 seconds
±(2% + 0.05Ω)
≥ 10G
Max. Overload voltage for 1 minute
70ºC ± 2°C, RCWV for 1000 hours with
1.5 hour "ON" and 0.5 hour "OFF"
40ºC ± 2°C, 90% ~ 95% R.H., RCWV for 1000 hours
with 1.5 hour "ON" and 0.5 hour "OFF"
±(2% + 0. 1Ω)
±(3% + 0.1Ω)
±(2% + 0. 1Ω)
±(3% + 0.1Ω)
±(1% + 0.05Ω)
±(1.5% + 0.1Ω)
at +155°C for 1000 hours
±(1% + 0.05Ω)
±(1% + 0.05Ω)
Bending once for 5 seconds
2010, 2512 sizes: 2 mm; other sizes: 3 mm
95% min. coverage
±(0.5% + 0.05Ω)
245ºC ± 5°C for 3 seconds
±(1% + 0.05Ω)
No breakdown or flashover
260ºC ± 5°C for 10 seconds
0402: 150V for 1 minute
0603: 300V for 1 minute
0805, 1206, 2010, 2512: 500V for 1 minute
Individual leaching area ≤ 5%
JIS-C-5201-1 4.18
Total leaching area ≤ 10%
IEC-60068-2-58 8.2.1
Rapid Change of
JIS-C-5201-1 4.19
±(0.5% + 0.05Ω)
±(1% + 0.05Ω)
Temperature
IEC-60115-1 4.19
RCWV (Rated continuous working voltage) = √ P*R or Max. Operating Voltage whichever is lower.
Storage temperature: 25ºC ± 3°C; humidity < 80% RH
Operating temperature range is -55°C to 155°C
Leaching
260ºC ± 5°C for 30 seconds
-55°C to +155°C, 5 cycles
Power Derating Curve:
2
www.seielect.com
RVC Series
Recommended Pad Layout
Type/Code
RVC0402
RVC0603
RVC0805
RVC1206
RVC2010
RVC2512
a
b
c
Unit
0.020
0.50
0.035
0.90
0.047
1.20
0.079
2.00
0.150
3.80
0.193
4.90
0.018
0.45
0.024
0.60
0.028
0.70
0.035
0.90
0.035
0.90
0.063
1.60
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Soldering Conditions
(1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds
(2) Time of wave soldering at maximum temperature point 260°C: 10 seconds
(3) Time of soldering iron at maximum temperature point 410°C: 5 seconds
3
www.seielect.com
RVC Series
Reel Specifications
Type/Code
Tape Width Reel Diameter
(mm)
(inches)
A
B
C
W
T
Unit
RVC0402, RVC0603
RVC0805, RVC1206
8 mm
7"
7.028 ± 0.059
178.50 ± 1.50
2.362 ± 0.039
60.00 ± 1.00
0.512 ± 0.008
13.00 ± 0.20
0.354 ± 0.020
9.00 ± 0.50
0.492 ± 0.020
12.50 ± 0.50
inches
mm
RVC2010, RVC2512
12 mm
7"
7.028 ± 0.059
178.50 ± 1.50
2.362 ± 0.039
60.00 ± 1.00
0.512 ± 0.020
13.00 ± 0.50
0.512 ± 0.020
13.00 ± 0.50
0.610 ± 0.020
15.50 ± 0.50
inches
mm
Paper Tape Specifications
Type/Code
RVC0402
RVC0603
RVC0805
RVC1206
A
0.026
0.65
0.043
1.10
0.063
1.60
0.075
1.90
Type/Code
RVC0402
RVC0603
RVC0805
RVC1206
B
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.045
1.15
0.075
1.90
0.094
2.40
0.138
3.50
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
P0
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
W
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P1
E
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
P2
4
F
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.018
0.45
0.028
0.70
0.031
0.80
0.033
0.85
D
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
T
Unit
www.seielect.com
RVC Series
Embossed Plastic Tape Specifications
Type/Code
RVC2010
RVC2512
A
0.110
2.80
0.138
3.50
Type/Code
RVC2010
RVC2512
B
0.004
0.10
0.004
0.10
0.217
5.50
0.264
6.70
0.004
0.10
0.004
0.10
0.157
4.00
0.157
4.00
P0
0.157
4.00
0.157
4.00
W
0.004
0.10
0.004
0.10
0.472
12.00
0.472
12.00
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
E
0.012
0.30
0.012
0.30
0.069
1.75
0.069
1.75
0.002
0.05
0.002
0.05
0.059
1.50
0.059
1.50
P2
F
0.004
0.10
0.004
0.10
0.217
5.50
0.217
5.50
D
0.004
0.10
0.004
0.10
Unit
0.002
0.05
0.002
0.05
inches
mm
inches
mm
T
Unit
0.047
1.20
0.047
1.20
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Standard
Termination Series RoHS
Type
Compliant
SMD
Surface Mount Chip Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
RVC
YES(1)
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
100% Matte Sn over Ni
Jan-03
03/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
5
www.seielect.com
RVC Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
R
Product Series
RVC Medium Voltage
V
C
Size
Code
W
0402 0.063
0603
0.1
0805 0.125
1206 0.25
2010
0.5
2512
1
Tolerance
Code Tol
Value
F
1% E96, E24
J
5%
E24
J
T
1
M
Packaging
Code
T
6
Description
Size
Quantity
0402
10000
7" Reel - Paper Tape
0603, 0805, 1206 5000
7" Reel - Plastic Tape
2010, 2512
4000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
10 ohm = 10R0
10 Kohm = 10K0
1 Mohm = 1M00
100 Mohm = 100M
www.seielect.com
很抱歉,暂时无法提供与“RVC0805FT221R”相匹配的价格&库存,您可以联系我们找货
