ESD56231L24
ESD56231L24
1 Line, Bi-directional, Transient Voltage Suppressor
http//:www.sh-willsemi.com
Descriptions
The ESD56231L24 is a Bi-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components which are connected to power lines,
from over-stress caused by ESD (Electrostatic Discharge),
EFT (Electrical Fast Transient) and Lightning.
SOD-123FL
The ESD56231L24 may be used to provide ESD protection up
to
±30kV
(contact
and
air
discharge)
according
to
IEC61000-4-2, and withstand peak pulse current up to 170A
(8/20μs) according to IEC61000-4-5.
Pin 2
Pin 1
The ESD56231L24 is available in SOD-123FL package.
Standard products are Pb-free and Halogen-free.
Circuit diagram
Features
Reverse stand-off voltage: ±24V Max.
Transient protection for each line according to
IEC61000-4-2 (ESD): ±30kV (contact and air discharge)
Pin1
IEC61000-4-4 (EFT): 80A (5/50ns)
TDYW
Pin2
IEC61000-4-5 (surge): 170A (8/20μs)
Capacitance: CJ = 400pF typ.
Low leakage current
Low clamping voltage
Solid-state silicon technology
TD = Device code
Y = Year code
W = Week code
Marking (Top View)
Applications
Power lines
Cellular handsets
Tablets
Microprocessors
Portable Electronics
Order information
Device
Package
Shipping
ESD56231L24-2/TR SOD-123FL 3000/Tape&Reel
Will Semiconductor Ltd.
1
Revision 0.94, 2017/06/15
ESD56231L24
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
5000
W
Peak pulse current (tp = 8/20μs)
IPP
170
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
kV
±30
TSTG
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
VRWM
Reverse leakage current
IR
Reverse breakdown voltage
Condition
VBR
IBR = 1mA
1)
VCL
VESD = 8kV
Clamping voltage
2)
VCL
IPP = 170A, tp = 8/20μs
CJ
Typ.
VRWM = 24V
Clamping voltage
Junction capacitance
Min.
Max.
Unit
±24
V
1
µA
24.4
V
28
V
32
V
VR = 0V, f = 1MHz
400
560
pF
VR = 24V, f = 1MHz
200
280
pF
Notes:
1)
Contact discharge mode, according to IEC61000-4-2.
2)
Non-repetitive current pulse, according to IEC61000-4-5.
2
ESD56231L24
o
100
90
Front time: T1= 1.25 T = 8μs
100
90
Time to half-value: T2= 20μs
Current (%)
Peak pulse current (%)
Typical characteristics (TA=25 C, unless otherwise noted)
50
T2
10
10
T
5
10
T1
15
Time (μs)
tr = 0.7~1ns
500
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
36
Pulse waveform: tp = 8/20μs
32
30
28
26
24
f = 1MHz
VAC = 50mV
450
400
350
300
250
200
150
22
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
34
t
60ns
30ns
30
60
100
-24 -20 -16 -12 -8 -4
80 100 120 140 160 180
8
12 16 20 24
IPP - Peak pulse current (A)
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
10
% of Rated power
Peak pulse power (kW)
100
1
80
60
40
10
100
Pulse time (s)
1000
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
3
ESD56231L24
PACKAGE OUTLINE DIMENSIONS
SOD-123FL
D1
E
D
E1
L
Side View
A
A1
Bottom View
Side View
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.88
1.04
1.2
A1
0.1
0.15
0.2
D
2.5
2.7
2.9
D1
3.4
3.675
3.95
E
1.4
1.675
1.95
E1
0.5
0.8
1.1
L
0.7
0.8
0.9
Recommend land pattern (Unit: mm)
2.2
4
1.2
0.9
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
4
ESD56231L24
TAPE AND REEL INFORMATION
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
5
Q4
很抱歉,暂时无法提供与“ESD56231L24-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.39600
- 20+0.36000
- 100+0.32400
- 500+0.28800
- 1000+0.27120
- 2000+0.25920
- 国内价格
- 1+0.37070
- 200+0.23870
- 1500+0.20790
- 3000+0.18370
