AS 2D-2M-10-Z
AS 2D-2M-10-Z
    NIDEC(尼得科)
    SW6_9.5X5MM_TM
    滑动开关 SW6_9.5X5MM_TM DPDT 50mA 60V 12.30mm
AS 2D-2M-10-Z 数据手册
AS Hyper-miniature Slide Switchess RoHS Compliant ■Features 1. High Contact Reliability Twin-contact clip mechanism for high contact reliability. 2. Gold-plated contacts suitable for low current applications 3. For PC board mounting 4. Improved operability The independent detent structure provides a light operating touch. ■ Specifications Voltagr range 20mV∼60V Current range 1μA∼50mA Rating Max. 50mA 60VAC/DC Min. 1μA 20mV AC/DC Initial contact resistance 50mΩ max. (1.5mA 200μVAC) Dielectric strength 250VAC 1 minute Initial insulation resistance 500MΩ min. (500VDC) 10,000 cycles at max. rating. Electrical life 50,000 cycles at min. rating or 0.4VA Operating force 0.69∼4.9N Operating temperature range −20℃∼+85℃ Storage temperature range −40℃∼+85℃ 0.4VA AC/DC ■Part Numbering A  S  2  D - 2  M - 10 - Z Series code Code Type S Slide type Fig. Numberof poles 1 1 pole 2 2 poles Code Switching function Fig. Terminal style D N ON ー ON E – ONーOFF ーON 2 PC terminal 5 Right angle(0.2inch pitch) 6 Right angle(0.3inch pitch) Code Actuator shape M Standard Distance between two terminal rows : 5.08mm (0.2") (Compact type) Terminal line for double poles are 2.54mm (0.1") ●Please refer to P.497 for soldering specifications, flux cleaning, and packaging specifications. Please refer to P.500 for PC hole layouts. Clip mechanism AS SPDT Switching function Viewed from part No. marking side Part No. PC DPDT  AS1D−2M−10−Z ☆AS1E−2M−10−Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 Distance between two terminal rows : 2.54 mm Switching function Viewed from part No. marking side Part No.  AS2D−2M−10−Z ★AS2E−2M−10−Z Connecting terminals PC DPDT ON ON 2−1 5−4 − OFF − ON ON 2−3 5−6 Distance between two terminal rows : 5.08 mm Switching function Viewed from part No. marking side Part No. ★AS2N−2M−10−Z Connecting terminals ON 2−1 5−4 − − ON 2−3 5−6 PC SPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No. 0.2R/A DPDT  AS1D−5M−10−Z  AS1E−5M−10−Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No.  AS2D−5M−10−Z Connecting terminals ON 2−1 5−4 − − ON 2−3 5−6 0.2R/A DPDT ※Mounting height : 5.15mm Switching function Viewed from part No. marking side Part No. ★AS2N−5M−10−Z Connecting terminals ON 2−1 5−4 − − 0.2R/A ☆:Semi-standard products. ★:Made to order products. Terminal numbers are not shown on the switch. Non-marking : standard stock items. ON 2−3 5−6 AS SPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No.  AS1D−6M−10−Z ON − ON Connecting terminals 2−1 − 2−3 0.3R/A DPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No. ☆AS2D−6M−10−Z ★AS2E−6M−10−Z Connecting terminals − OFF ON ON 2−1 5−4 ON ON 2−3 5−6 − 0.3R/A DPDT ※Mounting height : 5.15mm Switching function Viewed from part No. marking side Part No. ☆AS2N−6M−10−Z Connecting terminals − ON 2−1 5−4 ON 2−3 5−6 − 0.3R/A ■Actuator Shape ■Bracket Installation Procedure Standard (M) ■ Optional Accessories 《Sold separately》 Bracket 140000640324 6.3 3.4 Part Name Part No. 5 9.55 3.4 8.2 6.8 Dimensions 9.5 11.5 0.7 1.5 ■PC Hole Layouts Series P/C terminal Whithout bracket Right Angle terminal Whit bracket 0.2inch pitch ★:Made to order products. ☆:Semi-standard products. 0.3inch pitch AS1D AS1E AS2D AS2E AS2N :Optional Accessories.
AS 2D-2M-10-Z
物料型号:AS2D-2M-10-Z, AS1D-2M-10-Z, AS1E-2M-10-Z, AS2E-2M-10-Z, AS2N-2M-10-Z, AS1D-5M-10-Z, AS1E-5M-10-Z, AS2D-5M-5Z, AS2N-5M-10-Z, AS1D-6M-10-Z, AS2D-6M-10-Z, AS2E-6M-10-Z, AS2N-6M-10-Z。
器件简介:这些开关是超小型滑动开关,符合RoHS标准,具有高接触可靠性的双接触片机制,适合低电流应用,并为PCB板安装设计。
引脚分配:文档提供了不同型号的开关的引脚分配图,包括SPDT和DPDT配置。
参数特性:包括额定电压范围20mV至60V,电流范围从1A至50mA,初始接触电阻最大50mΩ,介质耐压250VAC持续1分钟,初始绝缘电阻最小500MΩ,电气寿命在最大额定值下为10,000次循环,在最小额定值或0.4VA下为50,000次循环,操作力0.69至4.9N,操作温度范围20°C至+85°C,存储温度范围-40°C至+85°C。
功能详解:独立凹槽结构提供轻触操作感,金镀接触适合低电流应用。
应用信息:文档提到了安装高度、操作形状和安装支架的安装程序。
封装信息:提供了PC孔位布局和支架的尺寸信息。
可选配件:包括支架,型号为140000640324。
AS 2D-2M-10-Z 价格&库存
很抱歉,暂时无法提供与“AS 2D-2M-10-Z”相匹配的价格&库存,您可以联系我们找货
AS2D-2M-10-Z
  • 25+21.94925
  • 50+21.15051
  • 100+20.15599
  • 250+19.15626
库存:49
AS2D-2M-10-Z
  • 1+23.03541
  • 5+22.07734
  • 10+21.34837
库存:49
