APE 1F-5M-10-Z
APE 1F-5M-10-Z
    NIDEC(尼得科)
    SW5_16.7X9.5MM_TM
    微型按钮开关
APE 1F-5M-10-Z 数据手册
APE Washable RoHS Compliant Subminiature Pushbutton Switches UL ■Features ■ Specifications 1. Twin-contact clip mechanism for high reliability. 0.4VA AC、DC 2. Process sealed structure Rating Max:50mA 60VAC/DC Min:1μA 20mVAC/DC 3. Gold-plated contacts. Initial contact resistance 50mΩ max.  UL:48VAC/DC 50mA Dielectric strength 4. Terminal pin pitch: 2.54 mm. (1.5mA 200μVAC) 250VAC 1 minute (500VDC) Initial Insulation resistance 500MΩ min. 5. UL recognized Electrical life 10,000 operations at maximum rating. 30,000 operations at 0.4VA Operating force 0.78∼2.94N Operating temperature range Storage temperature range −20∼+85℃ −40∼+85℃ ■Part Numbering A Series code PE Actuator shape 2 F Number of poles Code Type Fig. Number of poles PE Push type 1 1 pole 2 2 poles 2 - Switching function Terminal style Code Switching function F ON -(ON) ■Optional Accessories………………………… Page 253. (ON) :Momentary. M - 10 - Z Actuator shape Clip contact mechanism Fig. Terminal style Code Actuator shape 2 PC Straight M Standard 5 Right angle (0.2 inch pitch) 6 Right angle (0.3 inch pitch) APE−M(Standard type) SPDT Switching function Part No. PC Straight APE1F−2M−10−Z ON (ON) Connecting terminals 2−3 2−1 ON 2−3 5−6 (ON) 2−1 5−4 ★APE1F−5M−10−Z ON (ON) Connecting terminals 2−3 2−1 APE1F−6M−10−Z ON (ON) Connecting terminals 2−3 2−1 ON 2−3 5−6 (ON) 2−1 5−4 Terminal numbers are not shown on the switch. DPDT Switching function Part No. APE2F−2M−10−Z Connecting terminals PC Straight Terminal numbers are not shown on the switch. SPDT Switching function Part No. 0.2R/A Terminal numbers are not shown on the switch. SPDT Switching function Part No. 0.3R/A Terminal numbers are not shown on the switch. DPDT Switching function Part No. ☆APE2F−6M−10−Z Connecting terminals 0.3R/A Terminal numbers are not shown on the switch. (ON) :Momentary. ☆:Semi-standard products. ★:Made to order products. APE ■Right angle terminals 1 pole ●The space between the terminal rows are available in two dimensions: 0.2 inches (5.08 mm) and 0.3 inches (7.62 mm).  [Example]  0.2-inch pitch : APE1F-5M-10-Z 0.3-inch pitch : APE1F-6M-10-Z 2 poles ■Button Shape ■Bracket Installation Procedure Standard(M) ■Mounting of Switch ●Use PC boards with hole diameter of 1mm. ●Do not bend the terminal pins before mounting the switch on the PC board. ●After mounting the switch, do not place the device in such a way that the device weight will be applied on to the actuator of the switch. ●Do not apply load exceeding 12.7 N to the actuator. If load exceeding 12.7 N is expected to be applied to the actuator, please use a Bracket (optional accessory sold separately). Maximum load will be 29.4 N when a Bracket is used. ●Use Bracket 140000640314 or 140000640318 for side-byside mounting. ● To i n c r e a s e m o u n t i n g s t r e n g t h , u s e B r a c k e t 140000640315. ●PC Hole Layouts will change depending on the Bracket. Please refer to P.245. :Optional Accessories. ■Color Cap Mounting Refer to P.249. APE ■ Soldering Specifications ⑴Manual Soldering Device:Soldering iron 380° C, Max.; 3 seconds, Max. ⑵Auto Soldering Device:Jet wave type or dip type 275° C, Max.; 6 seconds, Max. ・Pre-heating should be done at temperatures ranging from 80° C to 120° C and within 120 seconds. ■Flux Cleaning ⑴Solvent :Fluorine or Alcohol type. ⑵Cleaning after soldering should be done after the terminal temperature falls to 90℃ or below, or after leaving the switch for five minutes or longer at room temperature. ⑶Do not use ultrasonic cleaning. ■PC Hole Layouts(AP・APE)  PC Straight 2 poles APE 2 poles Terminal Type 1 pole AP-M AP-S APE 0.2−inch pitch 0.3−inch pitch FU 231 2 poles 140000640318 ■Packaging Specification ■Right-angle Terminal 15 AP-M KU 1 pole 140000640315 JI SO SO AP-M AP-S AP-H APE 140000640314 When optional Bracket is used. JI Type Without Bracket FU Mounting KU 196
APE 1F-5M-10-Z 价格&库存
很抱歉,暂时无法提供与“APE 1F-5M-10-Z”相匹配的价格&库存,您可以联系我们找货
