SURFACE MOUNT CERMET TRIMMERS (14 TURNS)
ST-5 構造図
RoHS compliant
ST-5
INTERNAL STRUCTURE
①
⑩
②
⑨
③
④
⑤
Part name
■ FEATURES
RoHS compliant
Precise adjustment is possible
Automatic mounting is possible (Taping)
Flow/reflow soldering is possible
Sealed construction (Washable: Refer to page 698.)
Resin material is UL Recognized 94V-0
⑥
⑦
⑧
Material
①
Housing
②
Shaft
③
Terminal pin
④
Base element
⑤
Electrode
Ag-Pd cermet
⑥
Resistive element
RuO2 cermet
⑦
Wiper
⑧
Adhesive
⑨
Rubber cushion
⑩
Rotor gear
Polyphenylenesulphide
Brass, Nickel-plated
Copper, Tin-plated
Ceramic
Multi metal alloy
Epoxy
Silicone rubber
Polyamide
■ PART NUMBER DESIGNATION
S T - 5 E T W 5 0 0 Ω ( 5 0 1 )
Series name
Terminal pin
E:Sn (Lead-free)
Resistance code
Resistance value
Product shape (Shape of terminal)
Form of packaging
T:Taping (Reel)
M:Magazine (Stick)
Blank:Bulk in plastic bag
※ Please refer to the LIST OF PART NUMBERS when placing orders.
W:Gull wing (Top adjustment)
X:Gull wing (Side adjustment)
P:Gull wing (Side adjustment)
R:Gull wing (Side adjustment)
ST-5
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Form of packaging
Adjustment Shape of terminal
position
Taping (reel)
Magazine (stick)
( Gull wing ) ST-5ETW
X ( Gull wing ) ST-5ETX
P ( Gull wing ) ST-5ETP
R ( Gull wing ) ST-5ETR
Top adjustment W
Side
adjustment
Pieces in package
〈Nominal resistance values〉
500 pcs./reel
Plastic bag
ST-5EMW
ST-5EW
ST-5EMX
ST-5EX
ST-5EMP
ST-5EP
ST-5EMR
ST-5ER
50 pcs./stick
→ 10 Ω → 20 Ω
50 Ω
1 kΩ
2 kΩ
10 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
20 kΩ
100 Ω
200 Ω
500 Ω
5 kΩ
Fig. 1
※ The above part numbers are all available with the respective combination of
(Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping and magazine specifications are not sold separately and must be purchased in reel or stick units.
50 pcs./pack
The products indicated by → mark are manufactured upon receipt of order basis.
■ MECHANICAL CHARACTERISTICS
■ ELECTRICAL CHARACTERISTICS
10 Ω ~ 2 MΩ
Nominal resistance range
± 10 %
Resistance tolerance
Power ratings
0.25 W (85 °C) 0 W (120 °C)
Resistance law
Linear law
Maximum input voltage
DC200 V or power rating, whichever is smaller
Maximum wiper current
100 mA or power rating, whichever is smaller
Effective electrical turn
11 turns
End resistance
1 % or 2 Ω, whichever is greater
C.R.V.
1 % or 3 Ω, whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
− 55 ~ 120 °C
10 Ω ~ 50 Ω : ± 250 10-6/°C maximum
100 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
1000 MΩ minimum (DC500 V)
Dielectric strength
AC600 V, 60 s
Net weight
Approx. 0.35 g
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
150 ℃
14 turns
Operating torque
20 mN·m {204 gf·cm} maximum
Mechanical stop
Clutch action
Rotational life
200 cycles
10 Ω ~ 200 Ω [ Δ R/R ≦ ± (0.5 Ω +3 %)]
500 Ω ~ 2 MΩ [ Δ R/R ≦ ± (0.5 Ω +2 %)]
Thrust to shaft
5 N {0.51 kgf} minimum
Solderability
245 ± 3 °C, 2 ~ 3 s
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Pull-off strength
5 N {0.51 kgf} 10 s
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
− 65 ~ 125 °C (0.5 h), 5
Thermal shock
cycles
− 10 ~ 65 °C (80 ~ 98 %),
Humidity
10 cycles, 240 h
981
m/s2, 6 ms
Shock
6 directions for 3 times each
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times
each
Load life
85 °C, 0.25 W, 1000 h
Specifications
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 1 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
Peak : 250 0 ℃
Low temp. operation
− 55 °C, 2 h
Over 230 ℃
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
No leaks (No continuous bubbles)
Soldering heat
Flow : 260 ± 3 °C as the temperature in a pot of
molten solder, immersion from head of terminal to
backside of board, 5 ~ 6 s, two times maximum
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
手はんだ Manual soldering:350 ± 10 °C, 3 ~ 4 s
[ Δ R/R ≦ 1 %]
+5
180 ℃
Mechanical turn
Pre Heating Zone
90±30 s
30±10 s
Heating time
Soldering Zone
Reflow : two times maximum
Δ R/R:Change in total resistance
S.S. :Setting stability
ST-5
■ MAXIMUM INPUT RATINGS
(Ω)
Resistance code
Maximum input voltage (V) Maximum wiper current (mA)
10
100
200
500
100 1.00 100
200 2.00 100
500
3.53
70.7
101
5.00
50.0
201
7.07
35.4
501
11.2
22.4
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
15.8
22.4
35.4
50.0
70.7
112
15.8
11.2
7.07
5.00
3.54
2.24
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
158
200
200
200
200
1.58
1.00
0.40
0.20
0.10
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
1.4
(Unit: mm)
1.4
2
● ST-5EX
2
● ST-5EW
3.3
2
3.3
1.4
1.4
5
● ST-5EP
1.4
5
● ST-5ER
1.4
2
2
1.4
5.75
2
5.75
1.4
5
Note) The zero point is the center of mounting.
1.4
1.4
5
ST-5
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit: mm)
● ST-5EW
Top adjustment
①
③
CW rotation
Resistance code & Production date code
1
6.3
6.75
1
Resistance code, Production date code
& Lead free Identification mark
1
φ 1.6, Slot 0.6 W × 0.8 D
0.9
3
6
2.5 2.5
1
2
1
1
1
1
4.3
6.75
● ST-5EP
Side adjustment
1
1
1
6.3
Resistance code &
8.75
3
Note the terminal position.
3 – 0.5
● ST-5EX
Side adjustment
3 – 0.5
2.5 2.5
1
4.3
②
3
0.9
6
2
1
6.75
1
4.3
1
● ST-5ER
Side adjustment
0.9
1
1
1
1
1
3 – 0.5
2.5 2.5
6
8.75
3
3 – 0.5
0.9
2.5 2.5
6
2
2
6.75
4.3
ST-5
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the dia- grams below.
● EMBOSSED TAPE DIMENSIONS
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
(Unit: mm)
Filled
TR Taping
Empty
17.4±1
Head
ST-5TW/TX Taping
End
40 mm min.
21±0.8
2±0.5
50 min.
Empty
20 pitches min.
Leader
13±0.2
400 mm min.
Direction of feed
254±2 (ST-5ETP/ETR)
330±2 (ST-5ETW/ETX)
2±0.1
7.5±0.1
12±0.1
4±0.1
0.5±0.1
Installation example
(ST-5EW)
16
7.5±0.1
+0.1
(ST-5EP)
16
2±0.1
0.4±0.1
.5
4±0.1
φ1
+0.1
Φ1
12±0.1
1.75±0.1
● ST-5ETW/ETX
1.75±0.1
● ST-5ETP/ETR
21.4±1
5
Direction of feed
8.5
Direction of feed
ST-5
● Magazine is packed 50 pcs. per stick.
Orders will be accepted for units of 50 pcs., i.e., 50, 100, 150 pcs., etc.
● Magazines are packed 2000 pcs. per box.
ST-5 マガジン寸法図
● Magazine dimensions
(Unit: mm)
8.5
3±1
380±2
3±1
11
Installation example (ST-5EW)
Stopper
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
ST-5EW 20K ohm(203) 价格&库存
很抱歉,暂时无法提供与“ST-5EW 20K ohm(203)”相匹配的价格&库存,您可以联系我们找货
