AIP74HC74SA.TR
AIP74HC74SA.TR
    I-CORE(中微爱芯)
    SOP-14
    具有设置和复位功能的双D型触发器;正边缘触发器
AIP74HC74SA.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN or e AiP74HC/HCT74 Dual D-type flip-flop with set and reset; positive-edge trigger Specification i-c Product Specification Revision History: Version Date 2019-05-A1 2019-05 2021-11-A2 2021-11 Description New Modify Ordering Information; Modify ambient temperature to -40℃ ~+105℃ and add electrical characteristics of -40℃~+105℃ Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 1、General Description The AiP74HC/HCT74 are dual positive edge triggered D-type flip-flop. They have individual data (nD), — — — clock (nCP), set (nSD) and reset (nRD) inputs, and complementary nQ and nQ outputs. Data at the nD-input, that meets the set-up and hold time requirements on the LOW-to-HIGH clock transition, is stored in the flip-flop and appears at the nQ output. Schmitt-trigger action in the clock input, makes the circuit highly tolerant to slower clock rise and fall times. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. i-c or e Features:  Input levels: For AiP74HC74: CMOS level For AiP74HCT74: TTL level  Symmetrical output impedance  Low power dissipation  Balanced propagation delays  Specified from -40℃ to +105℃  Packaging information: DIP14/SOP14/TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN Ordering Information: Tube packing specifications: Type number Packaging form Marking code Tube quantity Boxed tube quantity Boxed quantity Packing box number Packing quantity DIP14 74HC74 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HCT74DA.TB DIP14 74HCT74 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HC74SA.TB SOP14 74HC74 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack or 50 PCS/tube SOP14 74HCT74 50 PCS/tube 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack AiP74HC74TA.TB TSSOP14 74HC74 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack i-c AiP74HCT74SA.TB AiP74HCT74TA.TB TSSOP14 74HCT74 Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC74DA.TB Notes Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Reel packing specifications: Packaging Type number Marking code form Number:AiP74HC/HCT74-AX-LJ-A009EN Reel quantity Boxed reel quantity Packing quantity 8000 PCS/box 64000 PCS/pack SOP14 74HC74 AiP74HCT74SA.TR SOP14 74HCT74 4000 PCS/reel 8000 PCS/box 64000 PCS/pack AiP74HC74TA.TR TSSOP14 74HC74 5000 PCS/reel 10000 PCS/box 80000 PCS/pack AiP74HCT74TA.TR TSSOP14 74HCT74 Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC74SA.TR 4000 PCS/reel Notes 5000 PCS/reel 10000 PCS/box 80000 PCS/pack i-c or Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 2、Block Diagram And Pin Description 2.1、Block Diagram 4 1SD 10 2SD SD 2 1D D Q 1Q 12 2D 2Q 3 1CP CP 11 2CP FF Q 1Q 2Q RD 5 9 6 8 e 1RD 2RD 1 13 Figure 1. Logic symbol S 5 or 4 3 2 1 10 11 12 1D 6 R S 9 C1 1D 8 R i-c 13 C1 Figure 2. IEC logic symbol Q C C C C C C D C Q C RD SD CP C C Figure 3. Logic diagram for one flip-flop Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 5/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 4 Number:AiP74HC/HCT74-AX-LJ-A009EN 1SD SD 2 3 1D D Q 1Q Q 1Q Q 2Q Q 2Q 5 1CP CP FF 6 RD 1 1RD 10 2SD SD 2D D 9 e 12 11 2CP CP FF 8 or RD 13 2RD Figure 4. Functional diagram 2.2、Pin Configurations 1RD 1 14 VCC 1D 2 13 2RD 1CP 3 12 2D 4 11 2CP 1Q 5 10 2SD 1Q 6 9 2Q GND 7 8 2Q i-c 1SD Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 2.3、Pin Description Pin Name Description asynchronous reset-direct input (active LOW) data input clock input (LOW-to-HIGH, edge-triggered) asynchronous set-direct input (active LOW) output complement output ground (0V) complement output output asynchronous set-direct input (active LOW) clock input (LOW-to-HIGH, edge-triggered) data input asynchronous reset-direct input (active LOW) supply voltage — 1RD 1D 1CP — 1SD 1Q — 1Q GND — 2Q 2Q — 2RD VCC e — 2SD 2CP 2D or Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 2.4、Function Table Input — — nSD L H L nRD H L L — — Output nCP X X X nD X X X Input nQ H L H Output i-c nCP nD nQn+1 nSD nRD H H ↑ L L H H ↑ H H Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH transition; Qn+1=state after the next LOW-to-HIGH CP transition. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 — nQ L H H — nQn+1 H L 7/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol VCC IIK IOK IO ICC IGND Ptot Tstg soldering temperature TL Conditions VI < -0.5V or VI > VCC+0.5V VO < -0.5V or VO > VCC+0.5V -0.5V < VO < VCC+0.5V DIP 10s SOP Min. -0.5 -100 -65 Max. +7 ±20 ±20 ±25 100 500 +150 245 250 Unit V mA mA mA mA mA mW ℃ ℃ e Parameter supply voltage input clamping current output clamping current output current supply current ground current total power dissipation storage temperature or Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. 3.2、Recommended Operating Conditions Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb Conditions AiP74HC74 VCC=2.0V VCC=4.5V VCC=6.0V AiP74HCT74 VCC=2.0V VCC=4.5V VCC=6.0V - i-c Parameter Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +105 V V V ns/V ns/V ns/V ℃ 4.5 0 0 -40 5.0 1.67 - 5.5 VCC VCC 139 +105 V V V ns/V ns/V ns/V ℃ Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH LOW-level output voltage input leakage current VOL II ICC input capacitance CI Min. Typ. Max. Unit 1.5 3.15 4.2 3.84 5.34 - 1.2 2.4 3.2 0.8 2.1 2.8 4.32 5.81 0.15 0.16 0.5 1.35 1.8 0.33 0.33 V V V V V V V V V V - - ±1.0 uA - - 40 uA - - 3.5 - pF or supply current Conditions AiP74HC74 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-4.0mA; VCC=4.5V VI=VIH or VIL IO=-5.2mA; VCC=6.0V IO=4.0mA; VCC=4.5V VI=VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=6.0V VI=VCC or GND; IO=0A; VCC=6.0V e Parameter AiP74HCT74 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current VOH supply current ICC VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 3.84 4.32 - V - 0.15 0.33 V - - ±1.0 uA - - 40 uA - 70 315 uA - 80 360 uA - 3.5 - pF IO=-4.0mA; VCC=4.5V i-c VI=VIH or VIL additional supply current input capacitance VOL II ΔICC CI VI=VIH or VIL IO=5.2mA; VCC=4.5V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; per input pin; nD, VI=VCC-2.1V; nRD inputs IO=0A; other inputs per input pin; nSD, at VCC or GND; nCP input VCC=4.5V to 5.5V - Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 9/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol Conditions AiP74HC74 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-4.0mA; VCC=4.5V VI=VIH or VIL IO=-5.2mA; VCC=6.0V IO=4.0mA; VCC=4.5V VI=VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=6.0V VI=VCC or GND; IO=0A; VCC=6.0V AiP74HCT74 Min. Typ. Max. Unit 1.5 3.15 4.2 3.7 5.2 - - 0.5 1.35 1.8 0.4 0.4 V V V V V V V V V V - - ±1.0 uA - - 80 uA VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH LOW-level output voltage input leakage current II ICC or supply current VOL e Parameter HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current VOH VI=VIH or VIL IO=-4.0mA; VCC=4.5V 3.7 - - V VOL VI=VIH or VIL IO=5.2mA; VCC=4.5V - - 0.4 V - - ±1.0 uA supply current ICC - - 80 uA - - 343 uA - - 392 uA VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; per input pin; nD, VI=VCC-2.1V; nRD inputs IO=0A; other inputs per input pin; nSD, at VCC or GND; nCP input VCC=4.5V to 5.5V i-c II additional supply current ΔICC Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 10/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 3.3.3、AC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol — nCP to nQ,nQ propagation delay tpd see Figure 6[1] tpd see Figure 7[1] tpd see Figure 7[1] nQ,nQ transition time tt see Figure 6[2] CP pulse width tW see Figure 6 tW see Figure 7 nSD, nRD recovery time trec see Figure 7 nD to nCP set-up time tsu see Figure 6 nD to nCP hold time th see Figure 6 nCP maximum frequency fmax see Figure 6 power dissipation capacitance CPD — — nSD to nQ,nQ propagation delay — — — nSD, nRD pulse width Max. Unit 100 20 17 100 20 17 40 8 7 75 15 13 3 3 3 4.8 24 28 47 17 14 14 50 18 15 14 52 19 16 15 19 7 6 19 7 6 19 7 6 3 1 1 6 2 2 -6 -2 -2 23 69 76 82 220 44 37 250 50 43 250 50 43 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz — - 24 - pF VCC=4.5V - 18 44 ns VCC=5.0V;CL=15pF - 15 - ns i-c — Typ. or — Min. e — nRD to nQ,nQ propagation delay Conditions AiP74HC74 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V CL=50pF;f=1 MHz; VI= GND to VCC[3] AiP74HCT74 — nCP to nQ,nQ propagation delay tpd see Figure 6[1] Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 — rev:B3 — nSD to nQ,nQ propagation delay — Number:AiP74HC/HCT74-AX-LJ-A009EN VCC=4.5V - 23 50 ns VCC=5.0V;CL=15pF - 18 - ns VCC=4.5V - 24 50 ns VCC=5.0V;CL=15pF - 18 - ns see Figure 6[2] VCC=4.5V - 7 19 ns tW see Figure 6 VCC=4.5V 23 9 - ns tW see Figure 7 VCC=4.5V 20 9 - ns 8 1 - ns tpd see Figure 7[1] tpd see Figure 7[1] tt — nRD to nQ,nQ propagation delay — nQ,nQ transition time CP pulse width — — nSD, nRD pulse width — — e nSD, nRD trec see Figure 7 VCC=4.5V recovery time nD to nCP tsu see Figure 6 VCC=4.5V set-up time nD to nCP th see Figure 6 VCC=4.5V hold time CP VCC=4.5V maximum fmax see Figure 6 VCC=5.0V;CL=15pF frequency power CL=50pF;f=1 MHz; dissipation CPD VI= GND to VCC-1.5V[3] capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. 5 - ns 3 -3 - ns 22 54 - MHz or 15 59 - MHz - 29 - pF i-c - Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 3.3.4、AC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol — nCP to nQ,nQ propagation delay [1] Conditions AiP74HC74 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V AiP74HCT74 Min. Typ. Max. Unit 120 24 20 120 24 20 45 9 8 90 18 15 3 3 3 4.0 20 24 - 265 53 45 300 60 51 300 60 51 110 22 19 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz tpd see Figure 6 tpd see Figure 7[1] tpd see Figure 7[1] nQ,nQ transition time tt see Figure 6[2] CP pulse width tW see Figure 6 tW see Figure 7 nSD, nRD recovery time trec see Figure 7 nD to nCP set-up time tsu see Figure 6 nD to nCP hold time th see Figure 6 nCP maximum frequency fmax see Figure 6 tpd see Figure 6[1] VCC=4.5V - - 53 ns tpd see Figure 7[1] VCC=4.5V - - 60 ns tpd see Figure 7[1] VCC=4.5V - - 60 ns tt see Figure 6[2] VCC=4.5V - - 22 ns — — nSD to nQ,nQ propagation delay — — or — — nSD, nRD pulse width — i-c — e — nRD to nQ,nQ propagation delay — nCP to nQ,nQ propagation delay — — nSD to nQ,nQ propagation delay — — nRD to nQ,nQ propagation delay — nQ,nQ transition time Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 CP pulse width rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN tW see Figure 6 VCC=4.5V 27 - - ns tW see Figure 7 VCC=4.5V 24 - - ns nSD, nRD trec see Figure 7 recovery time nD to nCP tsu see Figure 6 set-up time nD to nCP th see Figure 6 hold time CP maximum fmax see Figure 6 frequency Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. VCC=4.5V 9 - - ns VCC=4.5V 18 - - ns VCC=4.5V 3 - - ns VCC=4.5V 18 - - MHz — — — e — nSD, nRD pulse width 4、Testing Circuit or 4.1、AC Testing Circuit VI tW 90% negative pulse VM GND tf tr tr tf VI 90% positive pulse VM VM 10% i-c GND VM 10% tW VCC G VI VO DUT RT CL Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 4.2、AC Testing Waveforms VI VM nD input GND th th tsu tsu 1/fmax VI VM nCP input GND tW tPHL tPLH VOH VOL e VM nQ ouput tPLH VOH tPHL 90% 90% VM nQ ouput 10% 10% or VOL tTLH tTHL Figure 6. Input to output propagation delays VI nCP input VM GND trec VI nSD input i-c VM GND tW VI nRD input tW VM GND VOH nQ ouput tPLH tPHL VM VOL VOH VM nQ ouput VOL tPHL tPLH Figure 7. Set and reset propogation delays, pulse widths and recovery time Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 15/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 4.3、Measurement Points Input VM 0.5×VCC 1.3V Type AiP74HC74 AiP74HCT74 Output VM 0.5×VCC 1.3V 4.4、Test Data Type VI VCC 3.0V Load tr , tf 6.0ns 6.0ns CL 15pF, 50pF 15pF, 50pF Test RL 1kΩ 1kΩ tPLH, tPHL tPLH, tPHL i-c or e AiP74HC74 AiP74HCT74 Input Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 16/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 5、Package Information i-c or e 5.1、DIP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 17/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN i-c or e 5.2、SOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 18/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN i-c or e 5.3、TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 19/ 20 VER:2021-11-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT74-AX-LJ-A009EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Lead and lead compou nds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Lead frame ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ Chip ○ ○ ○ The lead ○ ○ ○ Plastic sheet installed ○ ○ ○ Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Polybro minated biphenyl s e Part name Hexaval ent chromiu m compoun ds ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit explanation of the following the SJ/T11363-2006 standard. or ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 20/ 20 VER:2021-11-A2
AIP74HC74SA.TR 价格&库存
很抱歉,暂时无法提供与“AIP74HC74SA.TR”相匹配的价格&库存,您可以联系我们找货
