AIP74HC595SA.TR
AIP74HC595SA.TR
    I-CORE(中微爱芯)
    SOP-16
    带输出锁存器的8位串行输入、串行或并行输出移位寄存器;三态 SOP16_150MIL 2~6V
AIP74HC595SA.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN or e AiP74HC/HCT595 8-bit Serial-in, Serial or Parallel-out Shift Register with Output Latches; 3-state Specification i-c Product Specification Revision History: Version Date 2019-06-A1 2021-09-A2 2019-06 2021-09 Description New Modify Ordering Information Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 1、General Description The AiP74HC/HCT595 is an 8-bit serial-in/serial or parallel-out shift register with a storage register and 3-state outputs. Both the shift and storage register have separate clocks. The device features a serial input — — (DS) and a serial output (Q7S) to enable cascading and an asynchronous reset MR input. A LOW on MR will reset the shift register. Data is shifted on the LOW-to-HIGH transitions of the SHCP input. The data in the shift register is transferred to the storage register on a LOW-to-HIGH transition of the STCP input. If both clocks are connected together, the shift register will always be one clock pulse ahead of the storage — register. Data in the storage register appears at the output whenever the output enable input (OE) is LOW. — — A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Operation of the OE input e does not affect the state of the registers. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. i-c or Features:  Input levels: For AiP74HC595: CMOS level For AiP74HCT595: TTL level  8-bit serial input  8-bit serial or parallel output  Storage register with 3-state outputs  Shift register with direct clear  100 MHz (typical) shift out frequency  Specified from -40℃ to +85℃  Packaging information: DIP16/SOP16/TSSOP16 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN Ordering Information: Tube packing specifications: Packaging form Type number Marking code Tube quantity Boxed tube quantity Boxed quantity Packing box number Packing quantity DIP16 74HC595 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HCT595DA.TB DIP16 74HCT595 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HC595SA.TB SOP16 74HC595 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack or 50 PCS/tube SOP16 74HCT595 50 PCS/tube 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack AiP74HC595TA.TB TSSOP16 74HC595 92 PCS/tube 100 tube/box 9200 PCS/box 10 box/pack 92000 PCS/pack 92 PCS/tube 100 tube/box 9200 PCS/box 10 box/pack 92000 PCS/pack i-c AiP74HCT595SA.TB AiP74HCT595TA.TB TSSOP16 Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC595DA.TB Notes 74HCT595 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Reel packing specifications: Packaging Type number Marking code form Number:AiP74HC/HCT595-AX-LJ-A026EN Reel quantity Boxed reel quantity Packing quantity 5000 PCS/box 20000 PCS/pack SOP16(1) 74HC595 AiP74HCT595SA.TR SOP16(1) 74HCT595 2500 PCS/reel 5000 PCS/box 20000 PCS/pack AiP74HC595SA.TR SOP16(2) 74HC595 2500 PCS/reel 2500 PCS/box 40000 PCS/pack AiP74HCT595SA.TR SOP16(2) 74HCT595 2500 PCS/reel 2500 PCS/box 40000 PCS/pack AiP74HC595TA.TR TSSOP16 74HC595 2500 PCS/reel 5000 PCS/box 40000 PCS/pack AiP74HCT595TA.TR TSSOP16 74HCT595 2500 PCS/reel 5000 PCS/box 40000 PCS/pack Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing:0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing:0.65mm or e AiP74HC595SA.TR 2500 PCS/reel Notes i-c Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 2、Block Diagram And Pin Description 2.1、Block Diagram i-c or e Figure 1. Logic symbol Figure 2. IEC logic symbol Figure 3. Logic diagram Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 5/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN or 2.2、Pin Configurations e Figure 4. Functional diagram 2.3、Pin Description Pin Name Q1 Q2 Q3 Q4 Q5 Q6 Q7 GND Q7S 10 MR master reset (active LOW) 11 12 SHCP STCP shift register clock input storage register clock input 13 OE output enable input (active LOW) 14 15 16 DS Q0 VCC serial data input parallel data output supply voltage i-c Pin No. 1 2 3 4 5 6 7 8 9 — — Description parallel data output parallel data output parallel data output parallel data output parallel data output parallel data output parallel data output ground (0V) serial data output Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 2.4、Function Table Control SHCP STCP Input — — OE MR Output DS Q7S Function Qn — a LOW-level on MR only affects the shift registers empty shift register loaded into X ↑ L L X L L storage register shift register clear; parallel outputs in X X H L X L Z high-impedance OFF-state logic HIGH-level shifted into shift register stage 0. Contents of all shift register stages shifted through, e.g. ↑ X L H H Q6S NC previous state of stage 6 (internal Q6S) appears on the serial output (Q7S) contents of shift register stages (internal QnS) are transferred to the X ↑ L H X NC QnS storage register and parallel output stages contents of shift register shifted through; previous contents of the ↑ ↑ L H X Q6S QnS shift register is transferred to the storage register and the parallel output stages Note: H=HIGH voltage level; L=LOW voltage level; Z=high-impedance OFF-state; ↑=LOW-to-HIGH transition; X=don’t care; NC=no change. X L L X L NC or e X 3、Electrical Parameter i-c 3.1、Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Parameter supply voltage input clamping current output clamping current Symbol VCC Conditions - Min. -0.5 Max. +7.0 Unit V IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA output current IO -70 ±25 ±35 70 - mA mA mA mA +150 ℃ 500 mW VO= -0.5V to (VCC+0.5V) pin Q7S pins Qn supply current ICC ground current IGND storage Tstg -65 temperature total power Ptot dissipation DIP Soldering TL 10s temperature SOP Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 245 250 7/ 20 VER:2021-09-A2 ℃ ℃ Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. 3.2、Recommended Operating Conditions Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb AiP74HCT595 VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 2.0 0 0 - 5.0 1.67 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V -40 - +85 ℃ 4.5 0 0 - 5.0 1.67 - 5.5 VCC VCC 139 - V V V ns/V ns/V ns/V -40 - +85 ℃ or supply voltage input voltage output voltage Conditions AiP74HC595 VCC=2.0V VCC=4.5V VCC=6.0V e Parameter - Unit i-c 3.3、Electrical Characteristics 3.3.1、DC Characteristics (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. AiP74HC595 VCC=2.0V 1.5 1.2 HIGH-level VIH VCC=4.5V 3.15 2.4 input voltage VCC=6.0V 4.2 3.2 VCC=2.0V 0.8 0.5 LOW-level VIL VCC=4.5V 2.1 1.35 input voltage VCC=6.0V 2.8 1.8 all outputs; 1.9 2.0 IO=-20uA; VCC=2.0V all outputs; 4.4 4.5 IO=-20uA; VCC=4.5V all outputs; 5.9 6.0 IO=-20uA; VCC=6.0V HIGH-level Q7S output; VOH VI = VIH or VIL 3.84 4.32 output voltage IO=-4.0mA; VCC=4.5V Q7S output; 5.34 5.81 IO=-5.2mA; VCC=6.0V Qn bus driver outputs; 3.84 4.32 IO=-6.0mA; VCC=4.5V Qn bus driver outputs; 5.34 5.81 IO=-7.8mA; VCC=6.0V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 20 VER:2021-09-A2 V V V V V V V V V V V V V Wuxi I-CORE Electronics Co., Ltd. LOW-level output voltage VOL II Number:AiP74HC/HCT595-AX-LJ-A026EN all outputs; IO=20uA; VCC=2.0V all outputs; IO=20uA; VCC=4.5V all outputs; IO=20uA; VCC=6.0V Q7S output; IO=4.0mA; VCC=4.5V Q7S output; IO=5.2mA; VCC=6.0V Qn bus driver outputs; IO=6.0mA; VCC=4.5V Qn bus driver outputs; IO=7.8mA; VCC=6.0V VI = VIH or VIL VI=VCC or GND; VCC=6.0V ICC VI=VIH or VIL; VCC=6.0V; VO=VCC or GND VI=VCC or GND; IO=0A; VCC=6.0V CI - IOZ - 0 0.1 V - 0 0.1 V - 0 0.1 V - 0.15 0.33 V - 0.16 0.33 V - 0.15 0.33 V - 0.16 0.33 V - - ±1.0 uA - - ±5.0 uA - - 80 uA - 3.5 - pF or input leakage current OFF-state output current supply current input capacitance rev:B3 e Tab: 835-12 AiP74HCT595 HIGH-level input voltage LOW-level input voltage VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.84 4.5 4.32 - V V 3.7 4.32 - V - 0 0.15 0.1 0.33 V V - 0.16 0.33 V - - ±1.0 uA - - ±5.0 uA - - 80 uA - 150 675 uA - 25 113 uA - 3.5 - pF VOH VI = VIH or VIL; VCC=4.5V all outputs; IO=-20uA Q7S output; IO=-4.0mA Qn bus driver outputs; IO=-6.0mA all outputs; IO=20uA Q7S output; IO=4.0mA Qn bus driver outputs; IO=6.0mA i-c HIGH-level output voltage VIH LOW-level output voltage input leakage current OFF-state output current supply current additional supply current input capacitance VOL II IOZ ICC ΔICC CI VI = VIH or VIL; VCC=4.5V VI=VCC or GND; VCC=5.5V VI=VIH or VIL; VCC=5.5V; VO=VCC or GND VI=VCC or GND; IO=0A; VCC=5.5V — per input pin; pins MR, SHCP, — VI=VCC-2.1V; STCP, OE other inputs at VCC or GND; IO=0A; pin DS VCC=4.5V to 5.5V - Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 9/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 3.3.2、AC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol propagation delay tpd HIGH to LOW propagation delay tPHL — OE to Qn enable time ten — tdis pulse width tW Min. Typ. Max. Unit 75 15 13 75 15 13 75 15 13 50 10 9 75 15 13 3 3 3 50 10 9 9 30 35 52 19 15 55 20 16 47 17 14 47 17 14 41 15 12 17 6 5 11 4 3 17 6 5 11 4 3 22 8 7 -6 -2 -2 -19 -7 -6 30 91 108 160 32 27 175 35 30 175 35 30 150 30 26 150 30 27 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - 115 - pF i-c or OE to Qn disable time Conditions AiP74HC595 VCC=2.0V SHCP to Q7S; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V STCP to Qn; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — MR to Q7S; VCC=4.5V see Figure 9 VCC=6.0V VCC=2.0V see Figure 10 VCC=4.5V VCC=6.0V VCC=2.0V see Figure 10 VCC=4.5V VCC=6.0V VCC=2.0V SHCP HIGH or LOW; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V STCP HIGH or LOW; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — MR LOW; VCC=4.5V see Figure 9 VCC=6.0V VCC=2.0V DS to SHCP; VCC=4.5V see Figure 8 VCC=6.0V VCC=2.0V SHCP to STCP; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V see Figure 8 VCC=4.5V VCC=6.0V VCC=2.0V see Figure 9 VCC=4.5V VCC=6.0V VCC=2.0V SHCP or STCP; see Figure 6 VCC=4.5V and Figure 7 VCC=6.0V e Parameter set-up time tsu DS to SHCP hold time th — MR to SHCP recovery time trec maximum frequency fmax power dissipation capacitance CPD all 9 outputs switching; fi=1MHz; VI=GND to VCC Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 10/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN AiP74HCT595; VCC=4.5V to 5.5V SHCP to Q7S; see Figure 6 - 25 42 ns STCP to Qn; see Figure 7 - 24 40 ns MR to Q7S; see Figure 9 - 23 40 ns ten see Figure 10 - 21 35 ns tdis see Figure 10 - 18 30 ns tW SHCP HIGH or LOW; see Figure 6 STCP HIGH or LOW; see Figure 7 MR LOW; see Figure 9 DS to SHCP; see Figure 8 SHCP to STCP; see Figure 7 16 16 20 16 16 6 5 8 5 8 - ns ns ns ns ns see Figure 8 3 -2 - ns 10 -7 - ns 30 52 - MHz - 130 - pF propagation delay tpd HIGH to LOW propagation delay tPHL — — OE to Qn enable time — OE to Qn disable time pulse width set-up time tsu DS to SHCP hold time th — e — i-c or MR to SHCP trec see Figure 9 recovery time maximum fmax SHCP or STCP; see Figure 6 and Figure 7 frequency power all 9 outputs switching; fi=1MHz; dissipation CPD VI=GND to VCC-1.5V capacitance Note: [1] Typical values are measured at nominal supply voltage. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 3.3.3、AC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol propagation delay tpd HIGH to LOW propagation delay tPHL — OE to Qn enable time ten — tdis pulse width tW Min. Typ. Max. Unit 95 19 16 95 19 16 95 19 16 65 13 11 95 19 16 3 3 3 65 13 11 4.8 24 28 - 200 40 34 220 44 37 220 44 37 190 38 33 190 38 33 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - - - pF i-c or OE to Qn disable time Conditions AiP74HC595 VCC=2.0V SHCP to Q7S; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V STCP to Qn; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — MR to Q7S; VCC=4.5V see Figure 9 VCC=6.0V VCC=2.0V see Figure 10 VCC=4.5V VCC=6.0V VCC=2.0V see Figure 10 VCC=4.5V VCC=6.0V VCC=2.0V SHCP HIGH or LOW; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V STCP HIGH or LOW; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — MR LOW; VCC=4.5V see Figure 9 VCC=6.0V VCC=2.0V DS to SHCP; VCC=4.5V see Figure 8 VCC=6.0V VCC=2.0V SHCP to STCP; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V see Figure 8 VCC=4.5V VCC=6.0V VCC=2.0V see Figure 9 VCC=4.5V VCC=6.0V VCC=2.0V SHCP or STCP; see Figure 6 VCC=4.5V and Figure 7 VCC=6.0V e Parameter set-up time tsu DS to SHCP hold time th — MR to SHCP recovery time trec maximum frequency fmax power dissipation capacitance CPD all 9 outputs switching; fi=1MHz; VI=GND to VCC Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN AiP74HCT595; VCC=4.5V to 5.5V SHCP to Q7S; see Figure 6 - - 53 ns STCP to Qn; see Figure 7 - - 50 ns MR to Q7S; see Figure 9 - - 50 ns ten see Figure 10 - - 44 ns tdis see Figure 10 - - 38 ns tW SHCP HIGH or LOW; see Figure 6 STCP HIGH or LOW; see Figure 7 MR LOW; see Figure 9 DS to SHCP; see Figure 8 SHCP to STCP; see Figure 7 20 20 25 20 20 - - ns ns ns ns ns see Figure 8 3 - - ns 13 - - ns 24 - - MHz - - - pF propagation delay tpd HIGH to LOW propagation delay tPHL — — OE to Qn enable time — OE to Qn disable time pulse width set-up time tsu DS to SHCP hold time th — e — i-c or MR to SHCP trec see Figure 9 recovery time maximum fmax SHCP or STCP; see Figure 6 and Figure 7 frequency power all 9 outputs switching; fi=1MHz; dissipation CPD VI=GND to VCC-1.5V capacitance Note: [1] Typical values are measured at nominal supply voltage. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 4、Testing Circuit e 4.1、AC Testing Circuit or Figure 5. Test circuit for measuring switching times i-c Definitions for test circuit: RL=Load resistance. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. S1=Test selection switch. 4.2、AC Testing Waveforms Figure 6. Shift clock pulse, maximum frequency and input to output propagation delays Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN or e Figure 7. Storage clock to output propagation delays i-c Figure 8. Data set-up and hold times Figure 9. Master reset to output propagation delays Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 15/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN e Tab: 835-12 Figure 10. Enable and disable times or 4.3、Measurement Points Type AiP74HC595 AiP74HCT595 Input Output VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V 4.4、Test Data Input VI tr , tf CL RL tPHL, tPLH S1 position tPZH, tPHZ VCC 3V 6ns 6ns 50pF 50pF 1kΩ 1kΩ open open GND GND i-c Type Load AiP74HC595 AiP74HCT595 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 tPZL, tPLZ VCC VCC 16/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 5、Package Information i-c or e 5.1、DIP16 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 17/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN i-c or e 5.2、SOP16 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 18/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN i-c or e 5.3、TSSOP16 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 19/ 20 VER:2021-09-A2 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT595-AX-LJ-A026EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Lead and lead compou nds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Lead frame ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ Chip ○ ○ ○ The lead ○ ○ ○ Plastic sheet installed ○ ○ ○ Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Polybro minated biphenyl s e Part name Hexaval ent chromiu m compoun ds ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit explanation of the following the SJ/T11363-2006 standard. or ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 20/ 20 VER:2021-09-A2
AIP74HC595SA.TR 价格&库存
很抱歉,暂时无法提供与“AIP74HC595SA.TR”相匹配的价格&库存,您可以联系我们找货
