AIP74HC164DA.TB
AIP74HC164DA.TB
    I-CORE(中微爱芯)
    DIP14_19.2X6.6MM
    8位串行输入并行输出移位寄存器
AIP74HC164DA.TB 数据手册
Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN e Tab: 835-12 or AiP74HC/HCT164 8-bit Serial-in, Parallel-out Shift Register Specification i-c Product Specification Revision History: Version Date 2019-05-A1 2019-05 Description New Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 1、General Description The AiP74HC/HCT164 is an 8-bit serial-in/parallel-out shift register. The device features two serial data inputs (DSA and DSB), eight parallel data outputs (Q0 to Q7). Data is entered serially through DSA or DSB and either input can be used as an active HIGH enable for data entry through the other input. Data is shifted on the LOW-to-HIGH transitions of the clock (CP) input. A LOW on the master reset input (MR) clears the register and forces all outputs LOW, independently of other inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. i-c or e Features:  Input levels: For AiP74HC164: CMOS level For AiP74HCT164: TTL level  Gated serial data inputs  Asynchronous master reset  Specified from -40℃ to +85℃  Packaging information: DIP14/SOP14/TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN Ordering Information: Tube packing specifications: Type number Packaging form Marking code Tube quantity Boxed tube quantity Boxed quantity Packing box number Packing quantity DIP14 74HC164 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HCT164DA.TB DIP14 74HCT164 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HC164SA.TB SOP14 74HC164 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack or 50 PCS/tube SOP14 74HCT164 50 PCS/tube 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack AiP74HC164TA.TB TSSOP14 74HC164 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack i-c AiP74HCT164SA.TB AiP74HCT164TA.TB TSSOP14 Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC164DA.TB Notes 74HCT164 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Reel packing specifications: Packaging Type number Marking code form Number:AiP74HC/HCT164-AX-LJ-A015EN Reel quantity Boxed reel quantity Packing quantity SOP14 74HC164 2500 PCS/reel 5000 PCS/box 40000 PCS/pack AiP74HCT164SA.TR SOP14 74HCT164 2500 PCS/reel 5000 PCS/box 40000 PCS/pack AiP74HC164TA.TR TSSOP14 74HC164 4000 PCS/reel 8000 PCS/box 64000 PCS/pack AiP74HCT164TA.TR TSSOP14 74HCT164 4000 PCS/reel 8000 PCS/box 64000 PCS/pack Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm or e AiP74HC164SA.TR Notes i-c Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 2、Block Diagram And Pin Description e 2.1、Block Diagram i-c or Figure 1. Logic symbol Figure 2. IEC logic symbol Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 5/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN or e Figure 3. Logic diagram Figure 4. Functional diagram i-c 2.2、Pin Configurations 2.3、Pin Description Pin No. 1 2 3 4 5 6 7 Pin Name DSA DSB Q0 Q1 Q2 Q3 GND Description data input data input output output output output ground (0V) Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 8 CP clock input (LOW-to-HIGH, edge-triggered) 9 — MR master reset input (active LOW) 10 11 12 13 14 Q4 Q5 Q6 Q7 VCC output output output output supply voltage 2.4、Function Table Operating modes Input — MR DSA DSB Q0 Q1 to Q7 L to L q0 to q6 q0 to q6 q0 to q6 q0 to q6 e L X X X L H ↑ l l L H ↑ l h L Shift H ↑ h l L H ↑ h h H Note: H=HIGH voltage level; L=LOW voltage level; ↑=LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; q=lower case letters indicate the state of the referenced input one set-up time prior to the LOW-to-HIGH clock transition. or Reset (clear) CP Output 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) i-c Parameter Symbol Conditions Min. supply voltage VCC -0.5 input clamping IIK VI < -0.5V or VI > VCC+0.5V current output clamping IOK VO < -0.5V or VO > VCC+0.5V current output current IO -0.5V < VO < VCC+0.5V supply current ICC ground current IGND -50 total power Ptot dissipation storage Tstg -65 temperature DIP 245 Soldering TL 10s temperature SOP 250 Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Max. +7 Unit V ±20 mA ±20 mA ±25 50 - mA mA mA 500 mW +150 ℃ 7/ 19 VER:2019-05-A1 ℃ Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.2、Recommended Operating Conditions supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=6.0V AiP74HCT164 VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 2.0 0 0 - 5.0 1.67 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V -40 - +85 ℃ 4.5 0 0 - 5.0 1.67 - 5.5 VCC VCC 139 - V V V ns/V ns/V ns/V +85 ℃ Max. Unit 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V ±0.1 uA 8 uA e Symbol or Parameter - -40 - i-c 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. AiP74HC164 VCC=2.0V 1.5 1.2 HIGH-level VCC=4.5V 3.15 2.4 VIH input voltage VCC=6.0V 4.2 3.2 0.8 VCC=2.0V LOW-level VCC=4.5V 2.1 VIL input voltage VCC=6.0V 2.8 IO=-20uA; VCC=2.0V 1.9 2.0 IO=-20uA; VCC=4.5V 4.4 4.5 HIGH-level VOH VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 6.0 output voltage IO=-4.0mA; VCC=4.5V 3.98 4.32 IO=-5.2mA; VCC=6.0V 5.48 5.81 0 IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V 0 LOW-level VI = VIH or VIL IO=20uA; VCC=6.0V 0 VOL output voltage IO=4.0mA; VCC=4.5V 0.15 IO=5.2mA; VCC=6.0V 0.16 input leakage VI= VCC or GND; II current VCC=6.0V VI= VCC or GND; IO=0A; supply current ICC VCC=6.0V Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current CI Number:AiP74HC/HCT164-AX-LJ-A015EN - - 3.5 - pF AiP74HCT164 VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V IO=-20uA; VCC=4.5V IO=-4.0mA; VCC=4.5V IO=20uA; VCC=4.5V VI = VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; VI=VCC-2.1V; IO=0A; other inputs at VCC or GND; VCC=4.5V to 5.5V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V - - ±0.1 uA - - 8 uA - 100 360 uA - - 3.5 - pF VOH VOL II ICC additional supply current ΔICC input capacitance CI or supply current VI = VIH or VIL e input capacitance rev:B3 3.3.2、DC Characteristics 2 Unit V V V V V V V V V V V V V V V V i-c (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. AiP74HC164 1.5 VCC=2.0V HIGH-level VIH VCC=4.5V 3.15 input voltage VCC=6.0V 4.2 VCC=2.0V 0.5 LOW-level VIL VCC=4.5V 1.35 input voltage VCC=6.0V 1.8 IO=-20uA; VCC=2.0V 1.9 IO=-20uA; VCC=4.5V 4.4 HIGH-level VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 VOH output voltage IO=-4.0mA; VCC=4.5V 3.84 IO=-5.2mA; VCC=6.0V 5.34 IO=20uA; VCC=2.0V 0.1 IO=20uA; VCC=4.5V 0.1 LOW-level VOL VI = VIH or VIL IO=20uA; VCC=6.0V 0.1 output voltage IO=4.0mA; VCC=4.5V 0.33 IO=5.2mA; VCC=6.0V 0.33 input leakage VI=VCC or GND; II ±1 current VCC=6.0V VI=VCC or GND; IO=0A; supply current ICC 80 VCC=6.0V input CI capacitance Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 uA uA pF 9/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 LOW-level output voltage input leakage current Number:AiP74HC/HCT164-AX-LJ-A015EN AiP74HCT164 VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V IO=-20uA; VCC=4.5V IO=-4.0mA; VCC=4.5V IO=20uA; VCC=4.5V VI = VIH or VIL IO=5.2mA; VCC=6.0V VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; VI=VCC-2.1V; IO=0A; other inputs at VCC or GND; VCC=4.5V to 5.5V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1 uA - - 80 uA - - 450 uA - - - - pF VOH VOL II ICC additional supply current ΔICC input capacitance CI or supply current VI = VIH or VIL e HIGH-level input voltage LOW-level input voltage HIGH-level output voltage rev:B3 3.3.3、AC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter CP to Qn propagation delay — Symbol tpd see Figure 6 tPHL see Figure 7 transition time tt see Figure 6 CP pulse width tW see Figure 6 tW see Figure 7 MR to CP recovery time trec see Figure 7 DSA and DSB to CP set-up time tsu see Figure 8 i-c MR to Qn propagation delay Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V — MR pulse width — Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Min. Typ. Max. Unit 80 16 14 60 12 10 60 12 10 60 12 10 41 15 12 12 39 14 11 11 19 7 6 14 5 4 17 6 5 17 6 5 8 3 2 170 34 29 140 28 24 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 10/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 +4 +4 +4 6 30 35 -6 -2 -2 23 71 78 85 - ns ns ns MHz MHz MHz MHz - 40 - pF VCC=4.5V - 17 36 ns VCC=5.0V;CL=15pF - 14 - ns VCC=4.5V - 19 38 ns VCC=5.0V;CL=15pF - 16 - ns see Figure 6 VCC=4.5V - 7 15 ns tW see Figure 6 VCC=4.5V 18 7 - ns tW see Figure 7 VCC=4.5V 18 10 - ns 16 7 - ns 12 6 - ns +4 -2 - ns 27 55 - MHz - 61 - MHz - 40 - pF DSA and DSB to CP hold time th see Figure 8 CP maximum frequency fmax see Figure 6 power dissipation capacitance CPD CP to Qn propagation delay tpd see Figure 6 tPHL see Figure 7 tt VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V per package; VI= GND to VCC or e AiP74HCT164 — MR to Qn propagation delay transition time CP pulse width Number:AiP74HC/HCT164-AX-LJ-A015EN — MR pulse width — i-c MR to CP trec see Figure 7 VCC=4.5V recovery time DSA and DSB tsu to CP see Figure 7 VCC=4.5V set-up time DSA and DSB to CP th see Figure 8 VCC=4.5V hold time CP VCC=4.5V maximum fmax see Figure 8 VCC=5.0V;CL=15pF frequency power per package; dissipation CPD VI= GND to VCC-1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 3.3.4、AC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter CP to Qn propagation delay Symbol tpd see Figure 6 MR to Qn propagation delay tPHL see Figure 7 transition time tt see Figure 6 CP pulse width tW see Figure 6 Max. Unit 100 20 17 75 15 13 75 15 13 75 15 13 4 4 4 5 24 28 - 215 43 37 175 35 30 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz - - - pF VCC=4.5V - - 45 ns VCC=5.0V;CL=15pF - - - ns VCC=4.5V - - 48 ns VCC=5.0V;CL=15pF - - - ns or — MR pulse width tW see Figure 7 MR to CP recovery time trec see Figure 7 DSA and DSB to CP set-up time tsu see Figure 8 i-c — Typ. e — Min. Conditions AiP74HC164 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V DSA and DSB to CP hold time th see Figure 8 CP maximum frequency fmax see Figure 6 power dissipation capacitance CPD CP to Qn propagation delay tpd see Figure 6 tPHL see Figure 7 tt see Figure 6 VCC=4.5V - - 19 ns tW see Figure 6 VCC=4.5V 23 - - ns per package; VI= GND to VCC AiP74HCT164 — MR to Qn propagation delay transition time CP pulse width Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN — MR pulse width tW see Figure 7 VCC=4.5V 23 - - ns 20 - - ns 15 - - ns +4 - - ns 22 - - MHz - - - MHz - - - pF — or e MR to CP trec see Figure 7 VCC=4.5V recovery time DSA and DSB to CP tsu see Figure 8 VCC=4.5V set-up time DSA and DSB th to CP; see Figure 8 VCC=4.5V hold time CP VCC=4.5V maximum fmax see Figure 6 VCC=5.0V;CL=15pF frequency power per package; dissipation CPD VI= GND to VCC-1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. i-c 4、Testing Circuit 4.1、AC Testing Circuit Figure 5. Test circuit for measuring switching times Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. e 4.2、AC Testing Waveforms i-c or Figure 6. Waveforms showing the clock (CP) to output (Qn) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency Figure 7. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (CP) removal time Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN e Tab: 835-12 Figure 8. Waveforms showing the data set-up and hold times for Dn inputs 4.3、Measurement Points Input VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Output VX 0.1×VCC 0.1×VCC VY 0.9×VCC 0.9×VCC or Type AiP74HC164 AiP74HCT164 4.4、Test Data Type VI VCC 3.0V Load tr , tf 6.0ns 6.0ns i-c AiP74HC164 AiP74HCT164 Input CL 15pF, 50pF 15pF, 50pF Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Test tPLH, tPHL tPLH, tPHL 15/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 5、Package Information i-c or e 5.1、DIP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 16/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN i-c or e 5.2、SOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 17/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN i-c or e 5.3、TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 18/ 19 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT164-AX-LJ-A015EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Lead and lead compou nds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Lead frame ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ Chip ○ ○ ○ The lead ○ ○ ○ Plastic sheet installed ○ ○ ○ Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Polybro minated biphenyl s e Part name Hexaval ent chromiu m compoun ds ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard。 ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements。 or explanation 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 19/ 19 VER:2019-05-A1
AIP74HC164DA.TB 价格&库存
很抱歉,暂时无法提供与“AIP74HC164DA.TB”相匹配的价格&库存,您可以联系我们找货
AIP74HC164DA.TB
  • 5+0.66300
  • 20+0.60450
  • 100+0.54600
  • 500+0.48750
  • 1000+0.46020
  • 2000+0.44070
