AIP74HC04SA.TB
AIP74HC04SA.TB
    I-CORE(中微爱芯)
    SOP14_150MIL
    通用逻辑门芯片 SOP-14 -0.5V 7V
AIP74HC04SA.TB 数据手册
Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN or e AiP74HC/HCT04 Hex Inverter Specification i-c Product Specification Revision History: Version Date 2019-05-A1 2019-05 Description New Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 1、General Description The AiP74HC/HCT04 is a hex inverter. The inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. i-c or e Features:  Input levels: For AiP74HC04: CMOS level For AiP74HCT04: TTL level  Specified from -40℃ to +85℃  Packaging information: DIP14/SOP14/TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN Ordering Information: Tube packing specifications: Type number Packaging form Marking code Tube quantity Boxed tube quantity Boxed quantity Packing box number Packing quantity DIP14 74HC04 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HCT04DA.TB DIP14 74HCT04 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack AiP74HC04SA.TB SOP14 74HC04 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack or 50 PCS/tube SOP14 74HCT04 50 PCS/tube 200 tube/box 10000 PCS/box 5 box/pack 50000 PCS/pack AiP74HC04TA.TB TSSOP14 74HC04 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack 94 PCS/tube 200 tube/box 18800 PCS/box 10 box/pack 188000 PCS/pack i-c AiP74HCT04SA.TB AiP74HCT04TA.TB TSSOP14 74HCT04 Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC04DA.TB Notes Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Reel packing specifications: Packaging Marking code Type number form Number:AiP74HC/HCT04-AX-LJ-A003EN Reel quantity Boxed reel quantity Packing quantity 5000 PCS/box 40000 PCS/pack SOP14 74HC04 AiP74HCT04SA.TR SOP14 74HCT04 2500 PCS/reel 5000 PCS/box 40000 PCS/pack AiP74HC04TA.TR TSSOP14 74HC04 3000 PCS/reel 6000 PCS/box 48000 PCS/pack AiP74HCT04TA.TR TSSOP14 74HCT04 Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e AiP74HC04SA.TR 2500 PCS/reel Notes 3000 PCS/reel 6000 PCS/box 48000 PCS/pack i-c or Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 2、Block Diagram And Pin Description e 2.1、Block Diagram i-c or Figure 1. Logic symbol Figure 2. IEC logic symbol Figure 3. Logic diagram for one gate Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 5/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 2.3、Pin Description Pin Name 1A 1Y 2A 2Y 3A 3Y GND 4Y 4A 5Y 5A 6Y 6A VCC Description data input data output data input data output data input data output ground (0V) data output data input data output data input data output data input supply voltage i-c or Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 e 2.2、Pin Configurations 2.4、Function Table Input nA L H Note: H=HIGH voltage level; L=LOW voltage level. Output nY H L Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Unit V mA mA mA mA mA mW or e Parameter Symbol Conditions Min. Max. supply voltage VCC -0.5 +7 input clamping IIK VI < -0.5V or VI > VCC+0.5V ±20 current output clamping IOK VO < -0.5V or VO > VCC+0.5V ±20 current output current IO -0.5V < VO < VCC+0.5V ±25 supply current ICC 50 ground current IGND -50 total power Ptot 500 dissipation storage -65 +150 Tstg temperature DIP 245 Soldering 10s TL temperature SOP 250 Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. ℃ ℃ 3.2、Recommended Operating Conditions Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb Conditions AiP74HC04 VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 2.0 0 0 - 5.0 1.67 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V - -40 - +85 ℃ 4.5 0 0 - 5.0 1.67 - 5.5 VCC VCC 139 - V V V ns/V ns/V ns/V -40 - +85 ℃ i-c Parameter AiP74HCT04 VCC=2.0V VCC=4.5V VCC=6.0V - Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 7/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN Max. Unit 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V ±0.1 uA 2.0 uA - pF - V 0.8 V 0.1 0.26 V V V V ±0.1 uA 2.0 uA 432 uA - pF i-c or e 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. AiP74HC04 VCC=2.0V 1.5 1.2 HIGH-level VCC=4.5V 3.15 2.4 VIH input voltage VCC=6.0V 4.2 3.2 VCC=2.0V 0.8 LOW-level VIL VCC=4.5V 2.1 input voltage VCC=6.0V 2.8 IO=-20uA; VCC=2.0V 1.9 2.0 IO=-20uA; VCC=4.5V 4.4 4.5 HIGH-level VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 6.0 VOH output voltage IO=-4.0mA; VCC=4.5V 3.98 4.32 IO=-5.2mA; VCC=6.0V 5.48 5.81 IO=20uA; VCC=2.0V 0 IO=20uA; VCC=4.5V 0 LOW-level VI = VIH or VIL IO=20uA; VCC=6.0V 0 VOL output voltage IO=4.0mA; VCC=4.5V 0.15 IO=5.2mA; VCC=6.0V 0.16 input leakage VI= VCC or GND; II current VCC=6.0V VI= VCC or GND; IO=0A; supply current ICC VCC=6.0V input CI 3.5 capacitance AiP74HCT04 HIGH-level VIH VCC=4.5V to 5.5V 2.0 1.6 input voltage LOW-level VIL VCC=4.5V to 5.5V 1.2 input voltage 4.4 4.5 IO=-20uA; VCC=4.5V HIGH-level VOH VI = VIH or VIL output voltage IO=-4.0mA; VCC=4.5V 3.98 4.32 0 IO=20uA; VCC=4.5V LOW-level VI = VIH or VIL VOL output voltage IO=5.2mA; VCC=4.5V 0.15 input leakage VI= VCC or GND; II current VCC=6.0V VI= VCC or GND; IO=0A; supply current ICC VCC=5.5V per input pin; VI=VCC-2.1V; additional IO=0A; other inputs at VCC or GND; 120 ΔICC supply current VCC=4.5V to 5.5V input CI 3.5 capacitance Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN Unit V V V V V V V V V V V V V V V V i-c or e 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. AiP74HC04 1.5 VCC=2.0V HIGH-level VCC=4.5V 3.15 VIH input voltage VCC=6.0V 4.2 0.5 VCC=2.0V LOW-level VIL VCC=4.5V 1.35 input voltage VCC=6.0V 1.8 1.9 IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V 4.4 HIGH-level VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 VOH output voltage IO=-4.0mA; VCC=4.5V 3.84 IO=-5.2mA; VCC=6.0V 5.34 IO=20uA; VCC=2.0V 0.1 IO=20uA; VCC=4.5V 0.1 LOW-level VI = VIH or VIL IO=20uA; VCC=6.0V 0.1 VOL output voltage IO=4.0mA; VCC=4.5V 0.33 IO=5.2mA; VCC=6.0V 0.33 input leakage VI= VCC or GND; II ±1 current VCC=6.0V VI= VCC or GND; IO=0A; supply current ICC 20 VCC=6.0V input CI capacitance AiP74HCT04 HIGH-level VIH VCC=4.5V to 5.5V 2.0 input voltage LOW-level VIL VCC=4.5V to 5.5V 0.8 input voltage 4.4 IO=-20uA; VCC=4.5V HIGH-level VI = VIH or VIL VOH output voltage IO=-4.0mA; VCC=4.5V 3.84 IO=20uA; VCC=4.5V 0.1 LOW-level VI = VIH or VIL VOL output voltage IO=5.2mA; VCC=4.5V 0.33 input leakage VI= VCC or GND; II ±1 current VCC=6.0V VI= VCC or GND; IO=0A; supply current ICC 20 VCC=5.5V per input pin; VI=VCC-2.1V; additional IO=0A; other inputs at VCC or GND; 540 ΔICC supply current VCC=4.5V to 5.5V input CI capacitance Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 uA uA pF V V V V V V uA uA uA pF 9/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 3.3.3、AC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol nA, nB to nY propagation delay tpd transition time tt power dissipation capacitance CPD Conditions AiP74HC04 VCC=2.0V VCC=4.5V see Figure 5 VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V see Figure 5 VCC=4.5V VCC=6.0V per package; VI= GND to VCC Min. Typ. Max. Unit - 25 9 7 7 19 7 6 85 17 14 75 15 13 ns ns ns ns ns ns ns - 21 - pF e Parameter AiP74HCT04 - 10 19 ns - 8 - ns - 7 15 ns - 24 - pF i-c or nA, nB to nY VCC=4.5V propagation tpd see Figure 5 VCC=5.0V;CL=15pF delay transition time tt see Figure 5 VCC=4.5V power per package; dissipation CPD VI= GND to VCC–1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 10/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 3.3.4、AC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol nA, nB to nY propagation delay tpd transition time tt power dissipation capacitance CPD Conditions AiP74HC04 VCC=2.0V VCC=4.5V see Figure 5 VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V see Figure 5 VCC=4.5V VCC=6.0V per package; VI= GND to VCC Min. Typ. Max. Unit - - 105 21 18 95 19 16 ns ns ns ns ns ns ns - - - pF e Parameter AiP74HCT04 - - 24 ns - - - ns - - 19 ns - - - pF i-c or nA, nB to nY VCC=4.5V propagation tpd see Figure 5 VCC=5.0V;CL=15pF delay transition time tt see Figure 5 VCC=4.5V power per package; dissipation CPD VI= GND to VCC–1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 4、Testing Circuit e 4.1、AC Testing Circuit or Figure 4. Test circuit for measuring switching times Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. i-c 4.2、AC Testing Waveforms Figure 5. The input (nA) to output (nY) propagation delay times Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 4.3、Measurement Points Input VM 0.5×VCC 1.3V Type AiP74HC04 AiP74HCT04 Output VM 0.5×VCC 1.3V 4.4、Test Data Type VI VCC 3.0V Load tr , tf 6.0ns 6.0ns CL 15pF, 50pF 15pF, 50pF Test tPLH, tPHL tPLH, tPHL i-c or e AiP74HC04 AiP74HCT04 Input Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 5、Package Information i-c or e 5.1、DIP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN i-c or e 5.2、SOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 15/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN i-c or e 5.3、TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 16/ 17 VER:2019-05-A1 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74HC/HCT04-AX-LJ-A003EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Part name Lead and lead compo unds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Hexaval ent chromiu m compoun ds Polybro minated biphenyl s Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ e Lead frame ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard。 ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements。 or explanation 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; This information is using to the reference only, the company is not responsible for any loss; i-c The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 17/ 17 VER:2019-05-A1
AIP74HC04SA.TB 价格&库存
很抱歉,暂时无法提供与“AIP74HC04SA.TB”相匹配的价格&库存,您可以联系我们找货
AIP74HC04SA.TB
  • 5+0.47600
  • 20+0.43400
  • 100+0.39200
  • 500+0.35000
  • 1000+0.33040
  • 2000+0.31640
