WPM1485-6/TR
WPM1485-6/TR
    WILLSEMI(韦尔)
    DFN6L_2X2MM
    单p通道,-12V, -7.4A,功率MOSFET
WPM1485-6/TR 数据手册
WPM1485 WPM1485 Single P-Channel, -12V, -7.4A, Power MOSFET https://www.omnivision-group.com Rds(on) (Ω) VDS (V) 0.016@ VGS=-4.5V -12 0.022@ VGS=-2.5V 0.032@ VGS=-1.8V DFN2×2-6L Descriptions D 6 The WPM1485 is P-Channel enhancement MOS Field Effect Transistor. Uses advanced trench D 5 S 4 D technology and design to provide excellent RDS (ON) S with low gate charge. This device is suitable for use in DC-DC conversion, power switch and charging 1 D circuit. Standard Product WPM1485 is Pb-free and 2 D 3 G Halogen-free. Pin configuration (Top view) Features  Trench Technology  Supper high density cell design  Excellent ON resistance for higher DC current  Extremely Low Threshold Voltage  Small package DFN2×2-6L WLSI = Willsemi D = Device Code Y = Year WW = Week Marking Applications Order information  Driver for Relay, Solenoid, Motor, LED etc.  DC-DC converter circuit  Power Switch  Load Switch  Charging Will Semiconductor Ltd. Device Package Shipping WPM1485-6/TR DFN2×2-6L 3000/Reel&Tape 2022/04/22 - Rev.1.5 WPM1485 Absolute Maximum ratings Parameter Symbol 10 S Steady State Drain-Source Voltage VDS -12 Gate-Source Voltage VGS ±8 Continuous Drain Current TA=70°C Maximum Power Dissipation Continuous Drain Current TA=25°C a TA=25°C a TA=70°C TA=25°C b Maximum Power Dissipation TA=70°C TA=25°C b TA=70°C c ID PD ID PD Unit V -7.4 -6.4 -5.9 -5.1 1.8 1.3 1.1 0.8 -5.7 -4.6 -4.5 -3.6 1.0 0.6 0.6 0.4 A W A W IDM -30 A Operating Junction Temperature TJ -55~+150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Pulsed Drain Current Thermal resistance ratings Parameter Symbol Junction-to-Ambient Thermal Resistance a Junction-to-Ambient Thermal Resistance b Junction-to-Case Thermal Resistance t ≤ 10 s Steady State t ≤ 10 s Steady State Steady State RθJA RθJA RθJC Typical Maximum 55 69 70 91 88 115 125 179 34 44 a Surface mounted on FR-4 Board using 1 square inch pad size, 1oz copper b Surface mounted on FR-4 board using minimum pad size, 1oz copper c Pulse width
WPM1485-6/TR
物料型号:WPM1485 器件简介:WPM1485是一款单通道P型增强型MOS场效应晶体管,采用先进的沟槽技术和设计,具有出色的RDS(ON)和低栅极电荷。适用于DC-DC转换、电源开关和充电电路。标准产品WPM1485无铅和无卤素。 引脚分配:DFN2×2-6L封装,从上视图看,D为漏极,S为源极,G为栅极。 参数特性:包括阈值电压、导通电阻、输入电容、输出电容、反向传输电容、总栅极电荷等。 功能详解:WPM1485具有沟槽技术、超高密度单元设计、极低的阈值电压和小型DFN2×2-6L封装等特点。 应用信息:适用于继电器、电磁铁、电机、LED等的驱动器,DC-DC转换器电路,电源开关和负载开关,以及充电电路。 封装信息:DFN2×2-6L封装,提供3000/卷和胶带的发货方式。
WPM1485-6/TR 价格&库存
很抱歉,暂时无法提供与“WPM1485-6/TR”相匹配的价格&库存,您可以联系我们找货
WPM1485-6/TR
  • 5+0.77280
  • 20+0.75900
  • 100+0.73140
库存:688
