WPM3012
WPM3012
Single P-Channel, -30V, -4.6A, Power MOSFET
VDS (V)
https://www.omnivision-group.com
Max. RDS(on) (mΩ)
-30
53@ VGS=-10V
93@ VGS=-4.5V
Descriptions
SOT-23
The WPM3012 is P-Channel enhancement MOS
Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS (ON)
with low gate charge. This device is suitable for use in
DC-DC conversion, power switch and charging circuit.
Standard Product WPM3012 is Pb-free.
Features
Trench Technology
Supper high density cell design
Excellent ON resistance for higher DC current
Small package SOT-23
Pin configuration (Top view)
W32 = Device Code
Applications
Driver for Relay, Solenoid, Motor, LED etc.
DC-DC converter circuit
Power Switch
Load Switch
Charging
Will Semiconductor Ltd.
= Month(A~Z)
Marking
Order information
1
Device
Package
Shipping
WPM3012-3/TR
SOT-23
3000/Reel&Tape
2022/4/22-Rev.1.5
WPM3012
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
-30
Gate-Source Voltage
VGS
±20
Continuous Drain Current
Maximum Power Dissipation b
TA=25°C
ID
TA=70°C
TA=25°C
PD
TA=70°C
Unit
V
-4.6
-3.8
-3.7
-3.0
1.7
1.1
1.1
0.7
A
W
Pulsed Drain Current c
IDM
-16
A
Operating Junction Temperature
TJ
-55 to 150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Lead Thermal Resistance
Symbol
t ≤ 10 s
Steady State
Steady State
RθJA
RθJL
Typical
Maximum
62
74
91
109
39
47
Unit
°C/W
Note:
a. FR-4 board (38mm X 38mm X t1.6mm, 70um Copper) partially covered with copper (645mm 2 area)
b. The power dissipation PD is based on Junction-to-Ambient thermal resistance RθJA t ≤ 10 s value and the
TJ(MAX)=150°C.
c.
Repetitive rating, ~10us pulse width, duty cycle ~1%, keep initial TJ =25°C, the maximum allowed
junction temperature of 150°C.
d. The static characteristics are obtained using ~380us pulses, duty cycle ~1%.
2
2022/4/22-Rev.1.5
WPM3012
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = -250uA
-30
V
Zero Gate Voltage Drain Current
IDSS
VDS =-24 V, VGS = 0V
-1
uA
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS = ±20V
±100
nA
Gate Threshold Voltage
VGS(TH)
VGS = VDS, ID = -250uA
-1.9
-2.5
V
Drain-to-source On-resistance
RDS(on)
VGS = -10V, ID = -4A
42
53
VGS = -4.5V, ID = -3A
64
93
ON CHARACTERISTICS
-1.4
mΩ
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
Total Gate Charge
QG(TOT)
Threshold Gate Charge
QG(TH)
VGS = -10 V, VDS = -15 V,
1.24
Gate-to-Source Charge
QGS
ID = -3.1A
1.96
Gate-to-Drain Charge
QGD
2.37
Turn-On Delay Time
td(ON)
5.6
Rise Time
tr
12.7
Turn-Off Delay Time
td(OFF)
RL=5 Ω, RG=15 Ω
31.9
Fall Time
tf
VGS = 0 V, f = 1.0 MHz, VDS =
-20 V
366
62
pF
54
12
nC
SWITCHING CHARACTERISTICS
ns
18.7
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = -1.0A
3
-0.8
-1.2
V
2022/4/22-Rev.1.5
WPM3012
10
15
Typical Characteristics (Ta=25oC, unless otherwise noted)
5.0
7
VDS=5V
4.5
6
VGS=-10V
-IDS -Drain to Source Current(A)
5
VDS-Drain-to-Source Voltage(V)
5
VGS=-4.5V
4
VGS=-4V
3
VGS=-3V
2
1
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
3.5
3.0
2.5
o
150 C
2.0
1.5
o
-50 C
0.5
0.0
0.0
4.0
o
25 C
1.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
-VGS -Gate to Source Voltage(V)
-VDS-Drain-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
200
90
ID=-3.1A
180
80
VGS=-4.5V
RDS(ON)-On Resistance(m)
60
VGS=-10V
50
40
160
140
120
100
80
60
40
30
2
4
6
8
10
12
3
4
-IDS-Drain to Source Current(A)
On-Resistance vs. Drain Current
1.4
7
8
9
10
1.2
VGS=-10V
ID=-3.1A
1.3
1.2
1.1
1.0
0.9
0.8
0.7
-50
6
On-Resistance vs. Gate-to-Source Voltage
1.6
1.5
5
-VGS-Gate to Source Voltage (V)
Gate Threshold Voltage Normalized
VGS=6V
VGS=5.5V
-ID -Drain-to-Source Current (A)
=8V
GS
2
VGS=10VV
4
RDS(ON)-On Resistance Normalized
IDS-Drain-to-Source Current (A)
6
-25
50
75
100
125
1.0
0.9
0.8
0.7
0.6
-50
150
Temperature ( C)
o
-25
50
75
100
125
150
Temperature ( C)
o
On-Resistance vs. Junction Temperature
ID=-250uA
1.1
Threshold Voltage vs. Temperature
4
2022/4/22-Rev.1.5
WPM3012
1.0
600
VGS=0
IS-Source to Drain Current (A)
C-Capacitance(pF)
0.9
f=1MHz
500
400
300
200
100
4
6
8
10
12
14
16
18
0.8
0.7
0.6
0.5
o
25 C
0.3
0.2
o
0.1
0.0
0.0
o
150 C
0.4
-50 C
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
VSD-Source to Drain Voltage (V)
-VDS-Source to Drain Voltage(V)
Capacitance
Body Diode Forward Voltage
350
T
O
=150 C
J(Max)
10
O
300
T =25 C
A
100us
Limit by Rdson
250
I D -Drain Current (A)
1ms
Power(W)
200
150
100
1
10ms
T
DC
o
=150 C
100ms
J(MAX)
o
T =25 C
0.1
1s
A
Single Pulse
10s
50
1E-4
1E-3
0.01
0.1
1
10
100
0.01
0.01
1000
0.1
Pulse Width(s)
1
V
10
100
-Drain to Source Voltage(V)
DS
Single pulse power
Safe operating power
10
V
DS
-V GS -Gate to Source Voltage (V)
=-15V
I =-3.1A
8
D
6
4
2
4
6
8
10
12
Gate Charge Characteristics (nC)
5
2022/4/22-Rev.1.5
10
In Descending Order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pluse
Normalized Effective Transient
Thermal Impedance
1
0.1
0.01
1E-3
1E-5
single pulse
1E-4
1E-3
0.01
0.1
1
10
Square Wave Pulse Duration (s)
Transient thermal response (Junction-to-Ambient)
100
1000
PACKAGE OUTLINE DIMENSIONS
SOT-23
D
Ⅰ
1.
L
L1
b
K
E
E1
2.(N/A)
θ
M
e
Ⅰ
c
e1
SIDE VIEW
TOP VIEW
2.90
0.90
0.80
0.90
A
A1
0.80
SIDE VIEW
0.95
RECOMMENDED LAND PATTERN(unit:mm)
Symbol
Dimensions in Millimeters
Min.
Typ.
Max.
A
0.89
1.10
1.30
A1
0.00
0.10
b
0.30
0.43
0.55
c
0.05
0.20
D
2.70
2.90
3.10
E
1.15
1.33
1.50
E1
2.10
2.40
2.70
e
0.95 Typ.
e1
1.70
1.90
2.10
L
0.45
0.55
0.65
L1
0.20
0.35
0.60
M
0.10
0.15
0.25
K
0.00
0.25
θ
0︒
8︒
WPM3012
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
Tape Dimensions
W
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pin1
User Direction of Feed
7inch
13inch
8mm
12mm
16mm
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1 Quadrant
Q1
Q2
Q3
1
Q4
很抱歉,暂时无法提供与“WPM3012-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.68756
- 100+0.56480
- 600+0.40234
- 国内价格
- 1+0.60500
- 200+0.39050
- 1500+0.33880
- 3000+0.30030
- 国内价格
- 5+0.75006
- 50+0.61614
- 150+0.51905
- 500+0.43892
- 2500+0.42531
