ESD56131W-2/TR
ESD56131W-2/TR
    WILLSEMI(韦尔)
    SOD323F
    TVS二极管 VRWM=4.6V VBR(Min)=4.8V VC=14V IPP=100A Ppk=1400W SOD323F
ESD56131W-2/TR 数据手册
ESD56131W ESD56131W 1-Line, Bi-directional, Transient Voltage Suppressor www.omnivision-group.com Descriptions The ESD56131W is a Bi-directional TVS (Transient Voltage Suppressor). It is specifically designed to protect sensitive electronic components which are connected to power lines from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lightning. The ESD56131W may be used to provide ESD protection up to ±30kV (contact and air discharge) according SOD-323F (Bottom View) to IEC61000-4-2, and with high surge capability used to protect USB voltage bus pin according to IEC61000-4-5. The ESD56131W is available in SOD-323F package. Pin1 Pin2 Standard products are Pb-free and Halogen-free. Circuit diagram Features ⚫ Reverse stand-off voltage: ±4.6V ⚫ Transient protection according to IEC61000-4-2 (ESD): ±30kV (contact and air discharge) Pin1 IEC61000-4-4 (EFT): 80A (5/50ns) TH * Pin2 IEC61000-4-5 (surge): 100A (8/20μs) ⚫ Capacitance: CJ = 250pF typ. ⚫ Low clamping voltage ⚫ Solid-state silicon technology TH = Device code * Marking (Top View) Applications ⚫ Power supply protection ⚫ Power management = Month code Order information Device Package Shipping ESD56131W-2/TR SOD-323F 3000/Tape&Reel Will Semiconductor Ltd. 1 Revision 1.2, 2022/04/24 ESD56131W Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp=8/20μs) Ppk 1400 W Peak pulse current (tp = 8/20μs) IPP 100 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge ±30 kV ±30 TJ 125 oC Operating temperature TOP -40~85 oC Lead temperature TL 260 oC TSTG -55~150 oC Junction temperature Storage temperature Electrical characteristics (TA = 25oC, unless otherwise noted) I VRWM Reverse stand-off voltage IR Reverse leakage current VCL Clamping voltage IPP Peak pulse current IPP IHOLD VHOLD VCL VTRIG VRWM ITRIG IR IR ITRIG VRWM VTRIG VHOLD VCL V IHOLD VTRIG Reverse trigger voltage ITRIG Reverse trigger current VHOLD Reverse holding voltage IHOLD Reverse holding current IPP Definitions of electrical characteristics Will Semiconductor Ltd. 2 Revision 1.2, 2022/04/24 ESD56131W Electrical characteristics (TA = 25oC, unless otherwise noted) Parameter Symbol Reverse maximum working voltage VRWM Reverse leakage current Reverse breakdown voltage Reverse holding voltage Clamping voltage 1) Clamping voltage 2) Junction capacitance IR VBR VHOLD VCL VCL CJ Condition Min. Typ. VRWM = 4.6V Max. Unit ±4.6 V 1 μA IBR = 1mA 4.8 V IHOLD = 50mA 4.8 V VESD = 8kV 8.0 V IPP = 1A, tp = 8/20μs 6 V IPP = 50A, tp = 8/20μs 10 V IPP = 100A, tp = 8/20μs 14 V 300 pF VR = 0V, f = 1MHz 250 Notes: 1) Contact discharge mode, according to IEC61000-4-2. 2) Non-repetitive current pulse, according to IEC61000-4-5. Will Semiconductor Ltd. 3 Revision 1.2, 2022/04/24 ESD56131W Time to half-value: T2= 20s 50 T2 10 10 0 0 Time (s) tr = 0.7~1ns 8/20μs waveform per IEC61000-4-5 Time (ns) Contact discharge current waveform per IEC61000-4-2 CJ - Junction capacitance (pF) 14 Pulse waveform: tp = 8/20μs 12 pin2 to pin1 10 pin1 to pin2 8 t 60ns 30ns 20 T T1 VC - Clamping voltage (V) 100 90 Front time: T1= 1.25  T = 8s 100 90 Current (%) Peak pulse current (%) Typical characteristics (TA = 25oC, unless otherwise noted) 6 270 f = 1MHz VAC = 50mV 260 250 240 230 220 210 200 190 180 170 4 0 20 40 60 80 160 -5 100 -4 -3 -2 -1 0 1 2 3 IPP - Peak pulse current (A) VR - Reverse voltage (V) Clamping voltage vs. Peak pulse current Capacitance vs. Reverse voltage 4 5 10V/div 10V/div 20ns/div 20ns/div ESD clamping ESD clamping (+8kV contact discharge per IEC61000-4-2) (-8kV contact discharge per IEC61000-4-2) Will Semiconductor Ltd. 4 Revision 1.2, 2022/04/24 PACKAGE OUTLINE DIMENSIONS SOD-323F D E b D1 TOP VIEW SIDE VIEW 1.40 0.80 0.80 A 0.80 c 2.20 SIDE VIEW Symbol RECOMMEND LAND PATTERN(unit:mm) Dimensions in Millimeters Min. Typ. Max. A 0.60 - 1.10 c 0.08 0.13 0.18 b 0.25 - 0.40 D1 1.60 1.70 1.80 E 1.15 1.25 1.35 D 2.30 2.50 2.80 Will Semiconductor Ltd. 5 Revision 1.2, 2022/04/24 TAPE AND REEL INFORMATION Reel Dimensions RD Reel Dimensions W Tape Dimensions P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 6 Q4 Revision 1.2, 2022/04/24
