WS4622C-4/TR
WS4622C-4/TR
    WILLSEMI(韦尔)
    CSP-4L_0.97X0.97MM
    2A, 38 mΩ, 250nA静止电流和90nA备用电流负载开关
WS4622C-4/TR 数据手册
WS4622C WS4622C 2A, 38 mΩ, 250nA Quiescent current and 90nA Http://www.sh-willsemi.com Standby current Load Switch Descriptions The WS4622C is a single channel load switch with ultra-low on resistance MOSFET. It is designed for load switching applications with ultra-low quiescent current (250nA) and ultra-low standby current (90nA).The device is controlled by external logic pin, allowing CSP-4L optimization of battery life, and portable device autonomy. The WS4622C contains a P-channel MOSFET that can operate over an input voltage range of 1.2V to 5.5V and can support a maximum continuous current of 2A. Output discharge path is designed to reduce voltage on the output rail quickly. The WS4622C are available in a small 1 x 1mm Pin Configuration (Top View) CSP-4L Package. Standard products are Pb-free and Halogen-free. Features  Input Voltage Range :1.2V~5.5V  Main switch Ron : 38mΩ @ 4.2V  Maximum Output current : 2A.  Quiescent current : 250nA @ Typ  Standby current : 90nA @ Typ  Recommend capacitor : 1μF  Active High EN Pin Y : Year code  Output Auto-discharge W : Week code  CSP-4L 1 x 1 mm CSP-4L 22 : Device code Marking Applications  MP3/MP4 Players  Cellphones, radiophone, digital cameras  Bluetooth, wireless handsets  Others portable electronics device Will Semiconductor Ltd. Order information Device WS4622C-4/TR 1 Marking Package Shipping 22YW CSP-4L 3000/Reel&Tape Apr, 2019 – Rev 1.0 WS4622C Typical Application Pin Description PIN Symbol Description A1 OUT A2 IN Input pin B1 GND Ground B2 EN Output pin Enable (Active high) Block Diagram Will Semiconductor Ltd. 2 Apr, 2019 – Rev 1.0 WS4622C Absolute Maximum Ratings Parameter Value VIN Range -0.3~6.5 V VEN Range -0.3~6.5 V VOUT Range -0.3~6.5 V Storage Temperature Range -40 ~ 150 o Junction Temperature Range -40 ~ 125 oC Lead Temperature 260 o Moisture Sensitivity Level-1 ESD Ratings Unit C C HBM 8000 V MM 400 V Recommend Operating Ratings Parameter Value Operating Power voltage 1.2~5.5 V Enable Voltage 0~5.5 V Maximum DC current 2 A Operating ambient temperature -40~85 o Operating Junction temperature -40~125 o Decoupling input capacitor 1 uF 1 uF Power Dissipation Rating(25 C,WLCSP package) 0.5 W Power Dissipation Rating(85 C,WLCSP package) 0.2 Thermal Resistance, RθJA (CSP-4L) 100 Decoupling output capacitor o o Will Semiconductor Ltd. 3 Unit C C W C/W o Apr, 2019 – Rev 1.0 WS4622C Electronics Characteristics (Ta=25oC, VIN=5V, CIN=COUT=1μF, unless otherwise noted) Parameter Input Voltage Static drain-source on-state resistance Symbol Condition VIN RDSON Min. Typ. 1.2 Max. Unit 5.5 V VIN =5.5,IOUT =200mA 34 42 VIN =4.2,IOUT =200mA 38 47 VIN =3.3,IOUT =200mA 42 52 VIN =1.8,IOUT =200mA 62 88 VIN =1.2,IOUT =200mA 104 250 EN=Low,VIN=3.3V 65 120 mΩ Output discharge path RDIS EN logic high voltage VENH EN logic low voltage VENL EN pull down resistor RPD Standby current ISTD EN=Low, No load 90 500 nA Quiescent current IQ EN=High,No load 250 500 nA Enable time TEN VIN =3.6,RL=25ohm 40 μs Output rise time TR VIN =3.6,RL=25ohm 30 μs ON time(TEN+TR) TON VIN =3.6,RL=25ohm 70 μs Output fall time TF VIN =3.6,RL=25ohm 42 μs 0.9 V 0.5 4 4 V MΩ Enable, rise and fall time Will Semiconductor Ltd. Ω Apr, 2019 – Rev 1.0 WS4622C Typical characteristics (Ta=25oC, VIN=5V,IOUT=200mA, CIN=COUT=1μF, unless otherwise noted) Will Semiconductor Ltd. 5 Apr, 2019 – Rev 1.0 WS4622C Will Semiconductor Ltd. 6 Apr, 2019 – Rev 1.0 WS4622C Turn On & Turn Off (1)Start from VIN. VIN=VEN=3.6V,IOUT=100mA VIN=VEN=3.6V,IOUT=1A (2)Start from EN VIN=VEN=3.6V,IOUT=100mA VIN=VEN=3.6V,IOUT=1A (3)Shutdown from VIN VIN=VEN=3.6V,IOUT=100mA VIN=VEN=3.6V,IOUT=1A (4)Shutdown from EN VIN=VEN=3.6V,IOUT=100mA Will Semiconductor Ltd. VIN=VEN=3.6V,IOUT=1A 7 Apr, 2019 – Rev 1.0 WS4622C ACKAGE OUTLINE DIMENSIONS CSP-4L D e E e b TOP VIEW BOTTOM VIEW 0.50 Package Outline A2 A A1 0.50 A3 Φ0.30 SIDE VIEW RECOMMENDED LAND PATTERN (unit:mm) Symbol Dimensions in Millimeters Min. Typ. Max. A 0.55 0.58 0.62 A1 0.22 0.24 0.26 A2 0.30 0.32 0.34 A3 0.03 Ref. D 0.94 0.97 1.00 E 0.94 0.97 1.00 e b Will Semiconductor Ltd. 0.50BSC 0.30 0.32 8 0.34 Apr, 2019 – Rev 1.0 WS4622C TAPE AND REEL INFORMATION Reel Dimensions RD Reel Dimensions W Tape Dimensions P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 9 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 Q4 Apr, 2019 – Rev 1.0
WS4622C-4/TR 价格&库存
很抱歉,暂时无法提供与“WS4622C-4/TR”相匹配的价格&库存,您可以联系我们找货
WS4622C-4/TR
  • 5+0.99117
  • 50+0.77832
  • 150+0.68708
  • 500+0.57320
库存:500
