WSB5507W
WSB5507W
Middle Power Schottky Barrier Diode
Http://www.sh-willsemi.com
Features
0.5 A Average rectified forward current
Low forward voltage, low leakage current
Small package SOD-323
SOD-323
Applications
Circuit
Switching circuit
Middle current rectification
Absolute maximum ratings
Marking
Parameter
Symbol
Value
Unit
VRRM
40
V
VR
40
V
IO
0.5
A
IFSM
7
Reverse voltage (repetitive peak)
Reverse voltage (DC)
Peak forward surge current
(1)
Junction temperature
125
C
-40 ~ 85
O
C
-55 ~ 150
O
C
TJ
Operating temperature
Topr
Storage temperature
Tstg
A
O
Electronics characteristics (TA=25oC)
Parameter
Forward voltage
Symbol
(2)
Min.
Typ.
Max.
Unit
IF=0.2A
0.38
0.45
V
IF=0.5A
0.5
0.55
V
IR
VR=40V
2
100
uA
CJ
VR=4V, F=1MHz
27
RθJL
Junction to lead
VF
Reverse current
Junction capacitance
Thermal resistance
Condition
(3)
112
pF
140
K/W
Order Informations
Device
WSB5507W-2/TR
Package
Marking
*7
SOD-323
(4)
Shipping
3000/Reel&Tape
Note 1
: Pulse Width=8.3ms, Single Pulse;
Note 2
: Single Pulse test tp=380us;
Note 3
: Device mounted on an FR4 PCB,single-sided copper, tin-plated and standard footprint.
Note 4
: * = Month code (A~Z); 7 = Device code;
Will Semiconductor Ltd.
1
Sep, 2018 - Rev. 1.1
WSB5507W
o
Typical characteristics (Ta=25 C, unless otherwise noted)
Reverse Current Leakage (A)
Forward Current (A)
1
0.1
O
120 C
0.01
O
85 C
1E-3
0.0
O
25 C
0.2
O
-50 C
0.4
0.6
0.01
O
O
85 C
1E-6
O
25 C
1E-8
O
-50 C
1E-10
Forward Voltage (V)
5
10
15
25
30
35
40
45
Fig.2 Reverse current vs. Reverse voltage
600
120
C-CAPACITANCE (pF)
100
400
200
Reverse voltage (V)
Fig.1 Forward voltage vs. Forward current
Average Forward Current (mA)
120 C
1E-4
80
60
40
100
10
15
VR-REVERSE VOLTAGE (V)
o
Lead Temperature( C)
Fig.3 Forward Current Derating
O
T=25 C f=1MHz
Fig.4 Junction capacitance vs. Reverse voltage
2
25
WSB5507W
Package outline dimensions
SOD-323
D
A2
A1
b
E
D1
A
Side View
Top View
L1
c
θ
L
Side View
Symbol
Dimensions in Millimeters
Min.
Typ.
Max.
1.10
A
A1
0.85Ref
A2
0.00
0.10
b
0.25
0.40
c
0.08
0.18
D1
1.60
1.70
1.80
D
2.30
2.55
2.80
E
1.15
1.40
L
0.48Ref.
L1
0.10
0.50
θ
0°
8°
Recommended land pattern (Unit: mm)
0.80
1.40
Notes:
0.80
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
3
WSB5507W
TAPE AND REEL INFORMATION
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
4
Q4
很抱歉,暂时无法提供与“WSB5507W-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 30+0.28094
- 3000+0.21422
- 国内价格
- 1+0.19140
- 3000+0.16940
- 国内价格
- 20+0.22954
- 300+0.12057
- 1200+0.11876
