S-34TS04A0B-A8T3U5
S-34TS04A0B-A8T3U5
    ABLIC(艾普凌科)
    UFDFN8
    IC EEPROM 8DFN
S-34TS04A0B-A8T3U5 数据手册
S-34TS04A 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT www.ablic.com Rev.2.0_00_U © ABLIC Inc., 2013-2019 This IC is a 2-wire serial E2PROM with temperature sensor for DIMM serial presence detect which operates in 2.2 V to 3.6 V voltage ranges. This IC has the capacity of 4 K-bit and the organization of 2 pages × 256-word × 8-bit. Page write and sequential read are available. This IC operates with the I2C-bus at 1.0 MHz maximum. A substantial reduction in current consumption may be achieved by using the software programmed shutdown mode which can be set by the I2C-bus. Caution This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, it is imperative to contact our sales representatives.  Features  Package E2PROM block • • • • • • • • • DFN-8(2030)B Page write: 16 bytes / page Sequential read Write protect function during low power supply voltage Write protect: Individual software data protection for each of four 128-byte blocks Endurance: 106 cycle / word*1 (Ta = +25°C) Data retention: 100 years (Ta = +25°C) Memory capacity: 4 K-bit Initial delivery state: FFh 5 8 4 1 (3.0 × 2.0 × t0.8 mm) Temperature sensor block • Temperature accuracy: • Temperature sample rate: • Selectable hysteresis width: 0.5°C typ. (Ta = +75°C to +95°C) 1.0°C typ. (Ta = +40°C to +125°C) 8 samples / s min. No hysteresis, 1.5°C, 3.0°C, 6.0°C Overall • JEDEC standard compliant: TSE2004B2 • Current consumption: E2PROM in standby mode and temperature sensor in shutdown mode: 3.0 μA max. E2PROM in standby mode and temperature sensor in active mode: 0.1 mA max. E2PROM in read operation mode and temperature sensor in active mode: 0.4 mA max. E2PROM in write operation mode and temperature sensor in active mode: 2.0 mA max. • Operation voltage range: 2.2 V to 3.6 V • Operation frequency: 1.0 MHz max. (VDD = 2.2 V to 3.6 V) • Noise suppression: Schmitt trigger and noise filter on input pins (SCL, SDA) • Operation temperature range: Ta = −20°C to +125°C • Lead-free (Sn 100%), halogen-free *1. For each address (Word: 8-bit) 1 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Block Diagram Capabilities register Configuration register HIGH limit register Temperature sensor ΔΣ A/D converter LOW limit register TCRIT limit register Ambient temperature register Timeout circuit VDD VSS Power-on reset SCL Start / stop detector SDA Manufacture ID register Device ID / revision register Resolution register Pointer register Serial clock controller Voltage detector High-voltage generator Device address comparator Address counter SA2 SA1 SA0 Data register Xdecoder E2PROM High-voltage detector Y-decoder Selector Data output ACK output controller 2 Temperature controller EVENT 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Product Name Structure 1. Product name S-34TS04A 0 B - A8T5 U 5 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 A8T5: DFN-8(2030)B, Tape Operation temperature B: Ta = −20°C to +125°C Product name S-34TS04A: 4 K-bit *1. 2. Refer to the tape drawing. Package Package Name DFN-8(2030)B 3. Dimension PQ008-B-P-SD Tape PQ008-B-C-SD Reel PQ008-B-R-SD Land PQ008-B-L-SD Product name list Product Name S-34TS04A0B-A8T5U5 Capacity 4 K-bit Package Name DFN-8(2030)B  Pin Configuration 1. DFN-8(2030)B Top view Pin No. 1 8 2 7 3 6 4 5 *1. 1 2 3 4 5 6 7 8 Symbol SA0 SA1 SA2 VSS SDA*1 SCL*1 ___________ EVENT VDD Description Select address input Select address input Select address input Ground Serial data I/O Serial clock input Temperature event output Power supply Do not use it in "High-Z". Remark For DFN-8(2030)B package, connect the heatsink of back side to the board, and set electric potential open or VSS. However, do not use it as the function of electrode. 3 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Absolute Maximum Ratings Table 1 Item Power supply voltage Input voltage (SCL, SA1, SA2) SA0 pin high level input voltage I/O voltage (SDA) ___________ Output voltage (EVENT) Operation ambient temperature Storage temperature Symbol Absolute Maximum Rating −0.3 to +4.3 −0.3 to +4.3 −0.3 to +10.0 −0.3 to +4.3 −0.3 to +4.3 −20 to +125 −65 to +150 VDD VIN VHV VIO VOUT Topr Tstg Unit V V V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Recommended Operation Conditions Table 2 Item Power supply voltage Operation ambient temperature High level input voltage Low level input voltage SA0 pin high level input voltage Symbol VDD Topr VIH VIL VHV Condition TSE2004B2 compliant TSE2004B2 compliant − − VHV − VDD ≥ 4.8 V Min. 2.2 −20 0.7 × VDD −0.3 7.0 Max. 3.6 +125 VDD + 0.5 0.3 × VDD 10.0 Unit V °C V V V  Pin Capacitance Table 3 Item Input capacitance I/O capacitance Output capacitance Symbol CIN CI/O COUT Condition VIN = 0 V (SCL, SA0, SA1, SA2) VI/O = 0 V (SDA) ___________ VOUT = 0 V (EVENT) (Ta = +25°C, f = 1.0 MHz, VDD = 2.5 V) Min. Max. Unit − 6 pF − 8 pF − 8 pF  Endurance Table 4 Item Symbol Operation Ambient Temperature Endurance NW Ta = +25°C *1. For each address (Word: 8-bit) Min. 106 Max. − Unit cycle / word*1 Min. Max. Unit 100 − year  Data Retention Table 5 Item Data retention 4 Symbol − Operation Ambient Temperature Ta = +25°C 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  DC Electrical Characteristics Table 6 Item Symbol Shutdown current consumption ISD Standby current consumption IDD1 Current consumption (READ) IDDR Current consumption (WRITE) IDDW Input leakage current ILI Output leakage current ILO Input current 1 IIL Input current 2 IIH Input impedance 1 ZIL Input impedance 2 ZIH Low level output voltage VOL Low level output current 1 IOL1 Low level output current 2 IOL2 Power-on reset threshold voltage Power-off threshold voltage VPON VPOFF Condition E2PROM: standby mode Temperature sensor: shutdown mode E2PROM: standby mode Temperature sensor: active mode E2PROM: read mode Temperature sensor: active mode f = 1.0 MHz E2PROM: write mode Temperature sensor: active mode f = 1.0 MHz SCL, SDA VIN = V___________ SS to VDD SDA, EVENT VOUT = VSS to VDD SA0, SA1, SA2 VIN < 0.3 × VDD SA0, SA1, SA2 VIN > 0.7 × VDD SA0, SA1, SA2 VIN = 0.3 × VDD SA0, SA1, SA2 VIN = 0.7 × VDD ___________ SDA, EVENT IOL = 3.0 mA ___________ SDA, EVENT VOL = 0.4 V ___________ SDA, EVENT VOL = 0.6 V, f ≤ 400 kHz − − Ta = −20°C to +125°C VDD = 2.2 V to 3.6 V Min. Max. Unit − 3.0 μA − 0.1 mA − 0.4 mA − 2.0 mA − 1.0 μA − 1.0 μA − 50.0 μA − 2.0 μA 30 − kΩ 800 − kΩ − 0.4 V 20 − mA 6 − mA 1.6 − − 0.9 V V 5 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  AC Electrical Characteristics Table 7 Measurement Conditions Input pulse voltage 0.2 × VDD to 0.8 × VDD 20 ns or less 0.3 × VDD to 0.7 × VDD 100 pF Input pulse voltage Input pulse rising / falling time Output reference voltage Output load Output reference voltage 0.8 × VDD 0.7 × VDD 0.3 × VDD 0.2 × VDD Figure 1 Input / Output Waveform during AC Measurement Table 8 Item Symbol SCL clock frequency SCL clock time "L" SCL clock time "H" SCL clock "L" timeout SCL, SDA rising time SCL, SDA falling time Data input setup time Data input hold time Data output hold time Start condition setup time Start condition hold time Stop condition setup time Bus release time Noise suppression time Power-off time Initialize time Min. 10 1.3 0.6 25 0.02 0.02 100 0 200 0.6 0.6 0.6 1.3 − 1 0.2 fSCL tLOW tHIGH tTIMEOUT tR tF tSU.DAT tHD.DI tHD.DAT tSU.STA tHD.STA tSU.STO tBUF tI tPOFF tINIT tF tHIGH Ta = −20°C to +125°C VDD = 2.2 V to 3.6 V 400 kHz 1000 kHz Max. Min. Max. 400 10 1000 − 0.5 − − 0.26 − 35 25 35 0.3 − 0.12 0.3 − 0.12 − 50 − − 0 − 900 0 350 − 0.26 − − 0.26 − − 0.26 − − 0.5 − 50 − 50 − 1 − − 0.2 − tLOW tR SCL tHD.STA tSU.STA tHD.DI tSU.DAT tSU.STO SDA (Input) tHD.DAT SDA (Output) Figure 2 6 Bus Timing tBUF Unit kHz μs μs ms μs μs ns ns ns μs μs μs μs ns ms ms 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A Table 9 Item Symbol Write time Start condition tWR Ta = −20°C to +125°C VDD = 2.2 V to 3.6 V Min. Max. − 5.0 Acknowledge Write data Stop condition Unit ms tWR Start condition SCL D0 SDA Figure 3 Write Cycle Timing  Temperature Characteristics Table 10 Item Temperature sensor accuracy Resolution Temperature conversion time Symbol TACC1 TACC2 TACC3 TRES tCONV Condition Ta = +75°C to +95°C Ta = +40°C to +125°C Ta = −20°C to +125°C Default value All TRES [1:0] settings Min. − − − − − VDD = 2.2 V to 3.6 V Typ. ±0.5 ±1.0 ±2.0 0.25 − Max. ±1.0 ±2.0 ±3.0 − 125 Unit °C °C °C °C ms 7 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Pin Functions 1. VDD (Power supply) pin The VDD pin is used to apply positive supply voltage. Regarding the applied voltage value, refer to " Recommended Operation Conditions". Set a bypass capacitor of about 0.1 μF between the VDD pin and the VSS pin for stabilization as close to IC as possible. 2. SA0, SA1 and SA2 (Select address input) pins In this IC, to set the slave address, connect each of the SA0 pin, SA1 pin and SA2 pin to the VSS pin or the VDD pin. Therefore the users can set 8 types of slave address by a combination of the SA0 pin, SA1 pin, SA2 pin. Comparing the slave address transmitted from the master device and one that you set, makes possible to select one slave address from other devices connected onto the bus. Each of the SA0 pin, SA1 pin and SA2 pin has a built-in pull-down resistor. In open, the pin is set to the same status as it connected to the VSS pin. The SA0 pin is used to detect the VHV voltage, when decoding an SWPn or CWP instruction. Refer to Table 11 for pin setting and device select code. 3. SDA (Serial data I/O) pin The SDA pin is used for the bi-directional transmission of serial data. This pin is a signal input pin, and an Nch open-drain output pin. In use, generally, connect the SDA line to any other device which has the open-drain or open-collector output with Wired-OR connection by pulling up to VDD by a resistor. 4. SCL (Serial clock input) pin The SCL pin is used for the serial clock input. Since the signals are processed at a rising or falling edge of the SCL clock, pay attention to the rising and falling time and comply with the specification. 5. ___________ EVENT (Temperature event output) pin ___________ The EVENT pin is an open-drain output that requires a pull-up resistor to VDD on the system motherboard or ___________ integrated into the master controller. EVENT pin has three operating modes, depending on the configuration register settings, and the output status is defined by the measured temperature and the temperature limit register setting. These modes are interrupt, comparator, or TCRIT only. Figure 4 shows an example of the measured temperature versus time, with the corresponding behavior of the ___________ EVENT pin in each of these three modes. 5. 1 Interrupt mode ___________ In interrupt mode, the EVENT pin will be asserted when the measured temperature crosses any temperature limit setting. Once the pin has been asserted, the pin will remain asserted until it is released by writing "1" to the CLEAR bit in the configuration register. After the pin is de-asserted, the pin will be re-asserted when the measured temperature crosses any temperature limit setting. 5. 2 Comparator mode ___________ In comparator mode, the EVENT pin will be asserted when the measured temperature is above the high limit or below "the low limit − hysteresis width". The pin will clear itself when the measured temperature is below "the high limit − hysteresis width" and above the low limit. 5. 3 TCRIT only mode ___________ In TCRIT only mode, the EVENT pin will only be asserted if the measured temperature exceeds the critical temperature. Once the pin has been asserted, it will remain asserted until the temperature drops below "the critical temperature − hysteresis width". 8 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A TTCRIT TTCRIT − THYS THIGH THIGH − THYS TLOW TLOW − THYS Comparator mode EVENT pin TCRIT only mode EVENT pin Interrupt mode EVENT pin Interrupt clear Interrupt clear Figure 4 Interrupt clear Interrupt clear ___________ EVENT pin (Active "L") 9 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Initial Delivery State Initial delivery state of all address E2PROM is "FFh". All write protects are cleared.  Operation This IC behaves as a slave device in the I2C-bus protocol. This IC has unrelated two functions as 4 K-bit E2PROM with software write protection and temperature sensor measuring ambient temperature. All operations are synchronized by the serial clock. Read and write operations are initiated by a start condition, generated by the master device. The start condition is followed by a device select code and read / write bit, and this IC generates an acknowledge bit. The 7-bit device select code is constructed of 4-bit device type identifier code (DTIC) and 3-bit code which shows the state of the SA0 pin, SA1 pin, and SA2 pin. DTIC is a code to define functions. When writing data to this IC, this IC generates an acknowledge bit during the 9th bit time, following the master device's 8-bit transmission. When data is read by the master device, the master device acknowledges the receipt of the data byte in the same way. Data transfers are terminated by a master device which generates stop condition after an acknowledge for write, and after no acknowledge for read. This IC has the timeout function. This IC shall not initiate clock stretching, which is an optional I2C-bus feature. 1. Setting of DTIC Operation function is identified by DTIC. There are three types of DTIC of which two are used for E2PROM and one is used for temperature sensor. The E2PROM memory may be accessed using a DTIC of "1010b", and to perform the software write protection or the E2PROM page address operations a DTIC of "0110b" is required. The temperature sensor registers are accessed using a DTIC of "0011b". 2. E2PROM function This IC has a 4 K-bit E2PROM array. The E2PROM array is devided into two pages consisting of a lower 256-byte page and an upper 256-byte page, which change over by the set E2PROM page address order. Each page has two 128-byte blocks. Each block can be set to write-protected by software write protect function. Page write operation up to 16 bytes and sequential read operation are available. All operations of the E2PROM section are inhibited to be performed during E2PROM write time. For more detail, refer to " E2PROM Operation". 3. Temperature sensor function This IC has a digital temperature sensor. With the nine types of temperature sensor registers, this IC can be performed to read measured ambient temperature from register and to write configration data to register. This IC can ___________ output comparison result of ambient temperature and specified limit value from EVENT pin. Temperature sensor regularly refresh temperature register value after power-on, and can go into shutdown condition when SHDN bit is set. During shutdown condition, temperature sensor circuit is stopped and holds temperature sensor register value, reducing current consumption. All operations of the temperature sensor section are performed anytime. For more detail, refer to " Temperature Sensor Operation". 10 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 4. Initialization operation after power-on By a power-on reset circuit, this IC initializes the internal circuit at the time of power-on. Perform the beginning (start condition) of the instruction transmission to this IC after the initialization by the power-on reset circuit. Regarding the datails of power-on reset, refer to " Reset and Initialization". 5. Start condition Start is identified by a "H" to "L" transition of the SDA line while the SCL line is stable at "H". Every operation begins from a start condition. 6. Stop condition Stop is identified by a "L" to "H" transition of the SDA line while the SCL line is stable at "H". When a device receives a stop condition during a read sequence, the read operation is interrupted, and the device enters standby mode. When a device receives a stop condition during an E2PROM write sequence, the reception of the write data is halted, and this IC initiates an E2PROM write cycle. tINIT VDD VDD min. tSU.STA tHD.STA tSU.STO SCL SDA Start condition Figure 5 Stop condition Start / Stop Conditions after Power-on 11 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 7. Data transmission Changing the SDA line while the SCL line is "L", data is transmitted. Changing the SDA line while the SCL line is "H", a start or stop condition is recognized. tHD.DI tSU.DAT SCL SDA (Input) Figure 6 8. Data Transmission Timing Acknowledge The unit of data transmission is 8 bits. During the 9th clock cycle period the receiver on the bus pulls down the SDA line to acknowledge the receipt of the 8-bit data. When an E2PROM write cycle is in progress, this IC does not generate an acknowledge for DTIC of "1010b" and "0110b". SCL (Input) 1 8 9 SDA (Input) Acknowledge output SDA (Output) Start condition tHD.DAT Figure 7 12 Acknowledge Output Timing 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 9. Device addressing To start communication, the master device on the system generates a start condition to the slave device. Following this, the master device sends the device select code. Table 11 Device Select Code ____ SA Pin Device Type Identifier Select Address Signal R/ W Instruction B7 B6 B5 B4 B3 B2 B1 B0 SA2 SA1 SA0 ____ 2 *1 Read / write E PROM 1 0 1 0 SA2 SA1 SA0 R/ W SA2 SA1 SA0 −*2 −*2 VHV Set write protection, block 0 (SWP0) 0 1 1 0 0 0 1 0 *2 − −*2 VHV Set write protection, block 1 (SWP1) 0 1 1 0 1 0 0 0 −*2 −*2 VHV Set write protection, block 2 (SWP2) 0 1 1 0 1 0 1 0 *2 − −*2 VHV Set write protection, block 3 (SWP3) 0 1 1 0 0 0 0 0 *2 − −*2 VHV Clear write protection for all blocks (CWP) 0 1 1 0 0 1 1 0 *2 − −*2 −*2 Read SWP0 status (RPS0) 0 1 1 0 0 0 1 1 *2 *2 − − −*2 Read SWP1 status (RPS1) 0 1 1 0 1 0 0 1 −*2 −*2 −*2 Read SWP2 status (RPS2) 0 1 1 0 1 0 1 1 −*2 −*2 −*2 Read SWP3 status (RPS3) 0 1 1 0 0 0 0 1 *2 *2 − − −*2 Set page address to 0 (SPA0) 0 1 1 0 1 1 0 0 *2 *2 − − −*2 Set page address to 1 (SPA1) 0 1 1 0 1 1 1 0 *2 *2 − −*2 Read page address (RPA) 0 1 1 0 1 1 0 1____ − Read / write temperature register*1 0 0 1 1 SA2 SA1 SA0 R/ W SA2 SA1 SA0 *1. Slave addresses (SA2, SA1, SA0) are compared by the select address input pins (SA2, SA1, SA0) of a memory device with the address value which is set beforehand. *2. Connected to the VSS pin or VDD pin. The device select code consists of a 4-bit device type identifier, and 3-bit select signals (SA2 pin, SA1 pin, SA0 pin). To address the memory array, the 4-bit device type identifier is "1010b"; to access the write-protection settings and the page address settings, it is "0110b"; and to access the temperature sensor settings is "0011b". Up to eight devices can be connected on a single I2C-bus. Address select signals (SA2 pin, SA1 pin, SA0 pin) should be set on each device, respectively. The device continues the operation only when the received device select code matches the address select signal. The SWPn, CWP, RPSn write protect commands and SPAn, RPA E2PROM page address commands do not use the select address, therefore all devices____ on the I2C-bus will act on these commands simultaneously. The 8th bit is the read / write bit (R/ W ). This bit is set to "1" for read and "0" for write operations. If a match occurs on the device select code, the corresponding device gives an acknowledge on serial data (SDA) during the 9th bit time. If the device does not match the device select code, this IC goes into standby mode automatically. Table 12 Operating Modes ____ E2PROM Mode current address read E2PROM random read E2PROM sequential read E2PROM byte write E2PROM page write SWPn and CWP Set E2PROM page address Read E2PROM page address Temperature sensor read Temperature sensor write *1. X: Don't care R/ W 1 0 1 1 0 0 0 0 1 1 0 Byte 1 1 ≥1 1 ≤ 16 2 2 2 2 2 I/O Sequence ____ Start, device select, R/____ W = 1, data, stop = 0, address Start, device select, R/ W____ Restart, device select, R/ W = 1, data, stop address read or E2PROM random read Similar to E2PROM current ____ Start, device select, R/____ W = 0, address, data, stop Start, device select, R/____ W = 0, address, data, stop Start, device select, R/____ W = 0, X*1, X*1, stop Start, device select, R/____ W = 0, X*1, X*1, stop Start, device select, R/____ W = 1, X*1, X*1, stop Start, device select, R/____ W = 1, data, stop Start, device select, R/ W = 0, pointer, data, stop 13 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 10. Timeout This IC has the timeout function. If the SCL stays "L" for the SCL clock "L" timeout (tTIMEOUT) or more, this IC resets the serial interface and returns to standby mode. If the SCL stays "L" for less than the tTIMEOUT, this IC does not reset the serial interface. The tTIMEOUT is 30 ms typ. tTIMEOUT.MIN CASE 1 SCL CASE 2 SCL CASE 3 SCL tTIMEOUT.MAX CASE 1: SCL clock time "L" (tLOW) ≥ tTIMEOUT.MAX, this IC will reset the bus communication and return to standby mode. CASE 2: tLOW < tTIMEOUT.MIN, this IC will not reset the bus communication. CASE 3: tTIMEOUT.MIN ≤ tLOW < tTIMEOUT.MAX, this IC may or may not reset the bus communication. Figure 8 The Examples of the Timeout Timing When this IC is not in the range of the clock frequency specified by AC characteristics, it may not perform communication normally. 14 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  E2PROM Operation 1. Write 1. 1 Byte write When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, this IC generates an acknowledge. This IC then receives an 8-bit word address and responds with an acknowledge. After this IC receives 8-bit write data and responds with an acknowledge, it receives a stop condition and that initiates the write cycle at the designated memory address. When the certain word address is protected by the write instruction, this IC does not generate an acknowledge after data byte coding, and write operation is not performed. During the write operation to this IC, access to the temperature sensor section of this IC are permitted, but all operations of the E2PROM section are inhibited to be performed and the E2PROM section does not send back an acknowledge. S T A R T DEVICE SELECT CODE 1 SDA LINE W R I T E 0 1 0 SA2 SA1 SA0 0 M S B WORD ADDRESS DATA W7 W6 W5 W4 W3 W2 W1 W0 D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C B W K AA C C KK Figure 9 1. 2 S T O P A C K Byte Write Page write The page write mode allows up to 16 bytes to be written in a single write operation in this IC. Its basic process to transmit data is as same as byte write, but it operates page write by sequentially receiving 8-bit write data as much data as the page size has. When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, it generates an acknowledge. Then this IC receives an 8-bit word address, and responds with an acknowledge. After this IC receives 8-bit write data and responds with an acknowledge, it receives 8-bit write data corresponding to the next word address, and generates an acknowledge. This IC repeats reception of 8-bit write data and generation of acknowledge in succession. This IC can receive as many write data as the maximum page size. Receiving a stop condition initiates a write cycle of the area starting from the designated memory address and having the page size equal to the received write data. S W T R A I R T DEVICE T SELECT CODE E SDA LINE 1 0 1 0 SA2 SA1 SA0 0 M S B L R A S / C BWK WORD ADDRESS (n) DATA (n) W7W6 W5W4 W3 W2 W1W0 D7 D6 D5 D4 D3 D2 D1 D0 A C K Figure 10 DATA (n + 1) D7 A C K S T O P DATA (n + x) D0 D7 A C K D0 A C K Page Write The lower 4 bits of the word address are automatically incremented every time when it receives 8-bit write data. If the size of the write data exceeds 16 bytes, the higher 4 bits (W7 to W4) of the word address remain unchanged, and the lower 4 bits are rolled over and the last 16-byte data that this IC received will be overwritten. 15 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 1. 3 Software write protect This IC has set write protection for block n (SWPn), clear write protection for all blocks (CWP) and read protection status for block n (RPSn). There are four independent memory blocks, and each block may be independently protected. The memory blocks are: • • • • Block 0 = word addresses 00h to 7Fh, page address = 0 Block 1 = word addresses 80h to FFh, page address = 0 Block 2 = word addresses 00h to 7Fh, page address = 1 Block 3 = word addresses 80h to FFh, page address = 1 1. 3. 1 Set write protect (SWPn) and clear write protect (CWP) If the software write protect has been set with the SWPn instruction, the block n in memory is write-protected. The four independent blocks are protected by SWPn instructions. The write-protected block can be cleared with the CWP instruction. The CWP instruction clears write protection for all blocks, therefore the CWP instruction can not clear write protection for each block. The SWPn and CWP instructions have the same format as a byte write instruction, but have a different device select code. Like the byte write instruction, it is followed by an address byte and a data byte, but in this case the contents can be set in all "Don't care". In the instructions of SWPn and CWP, be sure to apply the high voltage of VHV to the SA0 pin, and input "H" or "L" to the SA1 pin and SA2 pin. The device select code for each block is shown in Table 11. S T A R T SDA LINE DEVICE SELECT CODE Address 0 1 1 0 Select 0 Signals M S B Remark W R I T E DATA X X X X X X X X X X X X X X X X L R A S / C B W K A C K A C K X: Don't care Figure 11 1. 3. 2 WORD ADDRESS S T O P Software Write Protect Read protection status (RPSn) The RPSn are the instructions to find the write protection status in block n. If a certain block is not protected by SWPn instruction, this IC generates an acknowledge after the device receives the device select code of the block. If a certain block is protected by SWPn instruction, this IC does not generate an acknowledge after the device receives the device select code of the block. 1. 3. 3 Set E2PROM page address (SPAn) The SPAn are the instructions to select the lower 256-byte page (SPA0) or the higher 256-byte page (SPA1). The E2PROM page address selects the lower 256 bytes (SPA0) after power-on reset. 1. 3. 4 Read E2PROM page address (RPA) The RPA are the instructions to find the current page address status. If the current page address is "0", this IC generates an acknowledge after the device receives the device select code. If the current page address is "1", this IC does not generate an acknowledge. 16 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A Table 13 Status Software Write Protect (SWPn) No Software Write Protect Instruction SWPn in protected block SWPn in no protected block CWP Page write or byte write in protected block Page write or byte write in no protected block SWPn or CWP Page write or byte write Table 14 Status Software Write Protect (SWPn) No Software Write Protect ____ Acknowledge for Write Instruction (R/ W bit = 0) ACK Output No Yes Yes Word Address Don't care Don't care Don't care ACK Output No Yes Yes Don't care Don't care Don't care ACK Output No Yes Yes No Yes Yes Yes Word address Yes Don't care No No Yes Word address Yes Data Yes Yes Yes Yes Don't care Word address Yes Yes Don't care Data Yes Yes Yes Yes Data Write ____ Acknowledge for Read Instruction (R/ W bit = 1) ACK Output Instruction Word Address ACK Output Data ACK Output RPSn No Don't care No Don't care No RPSn Yes Don't care No Don't care No 17 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 1. 4 Acknowledge polling Acknowledge polling is used to know the completion of the write cycle in this IC. After this IC receives a stop condition and once starts the write cycle, E2PROM operations are forbidden and no response is made to the signal transmitted by the master device. Accordingly the master device can recognize the completion of the write cycle in this IC (slave device) by detecting a response from the slave device after transmitting the start condition, the device address and the read / write instruction code to this IC, namely to the slave devices. That is, if this IC does not generate an acknowledge, the write cycle is in progress and if this IC generates an acknowledge, the write cycle has been completed. It is recommended to use the read instruction "1" as the read / write instruction code transmitted by the master device. Acknowledge polling during write DATA SDA LINE D2 D1 D0 S T O P W R I T E S T A R T S T A R T DEVICE SELECT CODE 0 W R I T E DEVICE SELECT CODE 0 R N / A W C K WORD ADDRESS A C K R A / C WK tWR Acknowledge polling during read S S T T A O R P DATA T SDA DEVICE D2 D1 D0 SELECT CODE LINE S T A R T R E A D NO ACK from R Master Device E A D DEVICE SELECTCODE 1 1 R N / A W C K DATA R A / C WK S T O P S T A R T DEVICE SELECT CODE R A / C WK tWR Remark Users are able to input data after acknowledge output in acknowledge polling during write. Users are able to read data after acknowledge output in acknowledge polling during read. However, after that users input the write instruction, a start condition may not be input during data output. Input a stop condition and the next instruction after acknowledge output and data output. Figure 12 18 Usage Example of Acknowledge Polling 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 2. Read 2. 1 Current address read Either in writing or in reading this IC holds the last accessed memory address. The memory address is maintained when the instruction transmission is not interrupted, and the memory address is maintained as long as the power voltage does not decrease less than the power-on reset threshold voltage (VPON). The master device can read the data at the memory address of the current address pointer without assigning the word address as a result, when it recognizes the position of the address pointer in this IC. This is called "current address read". In the following the address counter in this IC is assumed to be "n". When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1" following a start condition, it responds with an acknowledge. Next an 8-bit data at the address "n" is sent from this IC synchronous to the SCL clock. The address counter is incremented and the content of the address counter becomes n + 1. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. S T A R T SDA LINE DEVICE SELECT CODE 1 0 1 NO ACK from Master Device R E A D DATA 0 SA2 SA1 SA0 1 M S B L R S / B W Figure 13 S T O P D7 D6 D5 D4 D3 D2 D1 D0 A C K ADR INC Current Address Read Attention should be paid to the following point on the recognition of the address pointer in this IC. In read, the memory address counter in this IC is automatically incremented after output of the 8th bit of the data. In write, on the other hand, the higher bits of the memory address (the higher 4 bits of the word address) are left unchanged and are not incremented. 19 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 2. 2 Random read Random read is used to read the data at an arbitrary memory address. A dummy write is performed to load the memory address into the address counter. When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "0" following a start condition, it responds with an acknowledge. This IC then receives an 8-bit word address and responds with an acknowledge. The memory address is loaded to the address counter in this IC by these operations. Reception of write data does not follow in a dummy write whereas reception of write data follows in byte write and in page write. Since the memory address is loaded into the memory address counter by dummy write, the master device can read the data starting from the arbitrary memory address by transmitting a new start condition and performing the same operation in the current address read. That is, when this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1", following a start condition signal, it responds with an acknowledge. Next, 8-bit data is transmitted from this IC synchronously with the SCL clock. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. S T A R T SDA LINE DEVICE SELECT CODE W R I T E WORD ADDRESS (n) 1 0 1 0 SA2 SA1 SA0 0 M S B S T A R T NO ACK from Master Device R E A D DEVICE SELECT CODE DATA 1 0 1 0 SA2 SA1 SA0 1 W7 W6 W5 W4 W3 W2 W1 W0 L R A S / C B W K A C K M S B S T O P D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C B W K ADR INC DUMMY WRITE Figure 14 2. 3 Random Read Sequential read When this IC receives a 7-bit device address and a 1-bit read / write instruction code set to "1" following a start condition both in current address read and random read, it responds with an acknowledge. When an 8-bit data is output from this IC synchronously with the SCL clock, the address counter is automatically incremented. When the master device responds with an acknowledge, the data at the next memory address is transmitted. Response with an acknowledge by the master device has the memory address counter in this IC incremented and makes it possible to read data in succession. This is called sequential read. The master device outputs stop condition not an acknowledge, the reading of this IC is ended. Data can be read in succession in the sequential read mode. When the memory address counter reaches the last word address, it rolls over to the first word address of same page address. NO ACK from Master Device R E DEVICE A SELECT CODE D SDA LINE 1 R A / C W K A C K D7 D0 A C K D7 D0 ADR INC Figure 15 20 D7 DATA (n + 1) DATA (n) S T O P A C K D0 D7 DATA (n + 2) ADR INC Sequential Read ADR INC D0 DATA (n + x) ADR INC 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Temperature Sensor Operation Temperature sensor goes into active condition and regularly refresh ambient temperature register value by ambient temperature and the comparison value between ambient temperature and temperature limit after power-on. The Temperature registers store the ambient temperature data, limits, and configuration values. All registers in the address space from "00h" through "08h" are 16-bit registers, accessed through block read and write commands. Temperature sensor goes into shutdown condition by setting SHDN bit of configuration register. Temperature sensor circuit including temperature sensor device and A/D converter circuit are stopped to control the current consumption during shutdown mode. Ambient temperature register value is held during shutdown condition. Temperature sensor goes into active condition again by clearing SHDN bit of configuration register. 1. Temperature sensor register write operation Writing to the temperature registers are accomplished through continuous write operations for 2-byte data. After the write operation of the device select code, the master device writes data to the pointer register, then it writes the 16-bit data every 8 bits. The 16-bit data is stored internally at the time when this IC generates an acknowledge after receiving the 16-bit data. W R I DEVICE T SELECT CODE E POINTER REGISTER MSB DATA LSB DATA 0 0 1 1 SA2 SA1 SA0 0 0 0 0 0 P3 P2 P1 P0 B15 B14 B13 B12 B11 B10 B9 B8 B7 B6 B5 B4 B3 B2 B1 B0 S T A R T SDA LINE M S B L R A S / C B W K Figure 16 A C K A C K S T O P A C K Temperature Sensor Register Write 21 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 2. Temperature sensor register read operation Reading data from temperature sensor register may be accomplished in the following ways: (1) If the location latched in the pointer register is correct, the read sequence may consist of an operation in which R/W bit of device select code is set to "1", and a following operation in which the 2-byte data is output every 8 bits from this IC. This way is used to read data from the ambient teperature register repeatedly. (2) The master device transfers the device select code and the R/W bit "0" and it is followed by the pointer register. The current location latched in the pointer register becomes clear by sending stop condition after this IC generates an acknowledge. After that, reading data from the temperature sensor will be accomplished in the way of (1). The master device is able to transfer the reading instrcution by sending start condition instead of stop condition after the pointer regiser is set in the way of (2). S T A R T SDA LINE DEVICE SELECT CODE 0 0 1 1 SA2 SA1 SA0 1 M S B ACK from Master Device R E A D LSB DATA B15 B14 B13 B12 B11 B10 B9 B8 B7 B6 B5 B4 B3 B2 B1 B0 A C K SDA LINE 0 0 1 1 SA2 SA1 SA0 0 M S B SDA LINE 0 0 1 1 SA2 SA1 SA0 0 M S B L R A S / C B W K Figure 19 22 0 0 0 0 0 P3 P2 P1 P0 AA CC KK Pointer Register Write S T A R T POINTER REGISTER 0 0 POINTER REGISTER L R A S / C BW K Figure 18 W R I DEVICE T SELECT CODE E N A C K Temperature Sensor Register Read W R I DEVICE T SELECT CODE E S T A R T S T O P MSB DATA L R A S / C BW K Figure 17 S T A R T NO ACK from Master Device DEVICE SELECT CODE R E A D 0 0 1 1 SA2 SA1 SA0 1 0 P3 P2 P1 P0 AA C C KK M S B L R A S / C B W K ACK from Master Device NO ACK from Master Device MSB DATA LSB DATA B15 B14 B13 B12 B11 B10 B9 B8 B7 B6 B5 B4 B3 B2 B1 B0 A C K Pointer Register Write and Temperature Sensor Register Read S T O P N A C K 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. Temperature sensor register The register addresses are shown in Table 15. Table 15 Address Not applicable R/W W Address pointer 00h R Capabilities register Pointer Register Mapping Name Function Default Address storage for subsequent operations Undefined Indicates the functions and capabilities of the temperature sensor Controls the operation of the temperature sensor Temperature high limit Temperature low limit Critical temperature R/W*1 R/W R/W R/W Configuration register HIGH limit register LOW limit register TCRIT limit register Ambient temperature 05h R Current ambient temperature register 06h R Manufacturer ID register PCI-SIG manufacturer ID 07h R Device / revision register Device ID and revision number 08h R/W Resolution register Sets temperature resolution −*2 Undefined register Undefined 09h to FFh *1. There are read-only bits, write-only bits, and readable and writable bits in configuration register. *2. Behavior on accesses to invalid pointer register locations is not assured. 01h 02h 03h 04h B7 0 B6 0 B5 0 Fixed 0 Figure 20 B4 0 B3 P3 B2 B1 P2 P1 Pointer register bits 00EFh 0000h 0000h 0000h 0000h Not applicable 1C85h 2221h 0001h Undefined B0 P0 Pointer Register Structure 23 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. 1 Capabilities register The capabitilies register indicates the supported features of the temperature sensor. B15 RFU B14 RFU B7 B6 EVSD TMOUT Address : 00h R/W : Read only Default : 00EFh B13 RFU B5 VHV Figure 21 B12 RFU B11 RFU B4 B3 TRES[1:0] B10 RFU B9 RFU B8 RFU B2 RANGE B1 ACC B0 EVENT Capabilities Register Structure Bit 15 to 8 : RFU Reserved for future use. These bits are always "0". Bit 7 : EVSD ___________ EVENT pin operation during shutdown mode. ___________ "1": EVENT pin output de-asserts during shutdown. Bit 6 : TMOUT Bus timeout period access during normal operation. "1": tTIMEOUT is supported within the range of 25 ms to 35 ms. Bit 5 : VHV Support SA0 high level input voltage (VHV) for SA0 pin. "1": A voltage up to 10 V is supported on the SA0 pin. Bit 4 to 3 : TRES[1:0] Indicates the temperature resolution. Temperature resolution is set on the resolution register. Refer to "3. 7 Resolution Register" for resolution register. "00": 9-bit temperature resolution (0.5°C resolution) "01" (default): 10-bit temperature resolution (0.25°C resolution) "10": 11-bit temperature resolution (0.125°C resolution) "11": 12-bit temperature resolution (0.0625°C resolution) Bit 2 : RANGE Indicates the supported temperature range. "1": Lower than 0°C can be read and the sign bit will be set appropriately. Bit 1 : ACC Indicates the supported temperature accuracy. ±1.0°C max. (+75°C to +95°C) "1": Bit 0 : EVENT Indicates whether interrupt mode is supported. "1": Interrupt mode is supported. 24 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. 2 Configuration register ___________ The configuration register holds the status bits and setting data of the EVENT pin, as well as temperature hysteresis width setting data. B15 RFU B14 RFU B13 RFU B7 B6 B5 TCRIT EVENT CLEAR _LOCK _LOCK Address : 01h R/W : Readable and Writable Default : 0000h Figure 22 B12 RFU B11 RFU B4 EVENT _STS B3 EVENT _CTRL B10 B9 HYST[1:0] B2 TCRIT _ONLY B1 EVENT _POL B8 SHDN B0 EVENT _MODE Configuration Register Structure Bit 15 to 11 : RFU Reserved for future use. These bits are always "0". Bit 10 to 9: HYST[1:0] Control the hysteresis width shown in Table 16. This hysteresis width applies to temperature high limit, temperature low limit and critical temperature. Once the ambient temperature is above a given threshold, it must drop below the threshold minus the hysteresis width___________ in order to be flagged as an interrupt event. Note that hysteresis width is also applied to the EVENT pin functionality. When either of the lock bits is set, these bits HYST[1:0] cannot be altered. HYST1 0 0 1 1 Table 16 Hysteresis Width Setting HYST0 0 1 0 1 Hysteresis Width No hysteresis 1.5°C 3.0°C 6.0°C Bit 8 : SHDN Shutdown setting. The temperature sensing device and A/D converter are disabled to save power, no events will be generated. When either of the lock bits is set, this bit cannot be set until unlocked. However it can be cleared at any time. "0" (default): The temperature sensor is active and converting. "1": The temperature sensor is disabled and will not generate interrupts or update the temperature data. Bit 7 : TCRIT_LOCK Locks the TCRIT limit register from being updated. "0" (default): The TCRIT limit register can be updated normally. "1": The TCRIT limit register is locked and cannot be updated. Once this bit has been set, it cannot be cleared until an internal power-on reset. Bit 6 : EVENT_LOCK Locks the HIGH and LOW limit registers from being updated. "0" (default): The HIGH and LOW limit registers can be updated normally. "1": The HIGH and LOW limit registers are locked and cannot be updated. Once this bit has been set, it cannot be cleared until an internal power-on reset. 25 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A Bit 5 : CLEAR ___________ Clears the EVENT pin when it has been asserted. This bit is write-only and will always be read "0". "0": Nothing happens. ___________ "1": In interrupt mode, the EVENT pin is reset and will not be asserted until a new interrupt condition occurs. This bit is ignored if the device is operating in comparator mode and when detecting the critical temprature. This bit is self clearing. The read value is fixed to "0". Bit 4 : EVENT_STS ___________ Indicates if the EVENT pin is asserted. This bit is read only. ___________ "0" (default): The EVENT pin is not being asserted. ___________ "1": The EVENT pin is being asserted. Bit 3 : EVENT_CTRL ___________ Controls the asserted state of the EVENT pin. If either of the lock bits are set (bit 7 and bit 6), then this bit cannot be altered. ___________ "0" (default): The EVENT pin can not be asserted. ___________ "1": The EVENT pin can be asserted. Bit 2 : TCRIT_ONLY ___________ Controls whether the EVENT pin will be asserted from a high / low out-of-limit condition. When the EVENT_LOCK bit is___________ set, this bit cannot be altered. "0" (default): The EVENT pin will be asserted if the measured temperature is above the temperature high limit or below the temperature low limit in addition to if the temperature is above the critical temperature. ___________ "1": The EVENT pin will only be asserted if the measured temperature is above the critical temperature. Bit 1 : EVENT_POL ___________ ___________ Controls the active "H" state of the EVENT pin. The EVENT pin is driven to this state when it is asserted. If either of the lock bits___________ are set (bit 7 and bit 6), then this bit cannot be altered. "0" (default): The EVENT pin is active "L". The active "L" state of the pin will be logical "0". ___________ "1": The EVENT pin is active "H". The active "H" state of the pin will be logical "1". Bit 0 : EVENT_MODE ___________ ___________ Controls the behavior of the EVENT pin. The EVENT pin may function in either comparator or interrupt mode. If either of the lock bits are set (bit 7 and bit 6), then this bit cannot be altered. ___________ "0" (default): The EVENT pin will function in comparator mode. ___________ "1": The EVENT pin will function in interrupt mode. 26 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. 3 Temperature limit register (HIGH limit / LOW limit / TCRIT limit) Temperature in the HIGH limit register, LOW limit register and TCRIT limit register are set and described in 2's complement format of Sign bit + 10-bit. Examples of temperature limit register are shown in Table 17. B15 − B14 − B13 − B7 B6 B5 23°C 22°C 21°C HIGH limit register Address : 02h R/W : Readable and writable Default : 0000h LOW limit register Address : 03h R/W : Readable and writable Default : 0000h TCRIT limit register Address : 04h R/W : Readable and writable Default : 0000h Figure 23 B12 Sign B11 27°C B10 26°C B9 25°C B8 24°C B4 20°C B3 2-1°C B2 2-2°C B1 − B0 − Temperature Limit Register Structure 27 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. 4 Ambient temperature register 3 status bits of TCRIT, HIGH and LOW and ambient temperature data described in 2's complement format of Sign bit + 12-bit can be read. Examples of ambient temperature register are shown in Table 17. B15 TCRIT B13 LOW B12 Sign B11 27°C B10 26°C B9 25°C B8 24°C B7 B6 B5 23°C 22°C 21°C Address : 05h R/W : Read-only Default : Not applicable (0000h) B4 20°C B3 2-1°C B2 2-2°C*1 B1 2-3°C*1 B0 2-4°C*1 *1. B14 HIGH The bits may not be used according to the resolution defined based on value of TRES[1:0] bit of the capabilties register. Unused/unsupported bits will read as 0. Figure 24 Ambient Temperature Register Structure Bit 15 : TCRIT When set, the ambient temperature is above the critical temperature. This bit will remain set so long as the ambient temperature is above the critical temperature and will automatically clear once the ambient temperature has dropped below the limit minus the hysteresis width. Bit 14 : HIGH When set, the ambient temperature is above the high limit. This bit will remain set so long as the ambient temperature is above the high limit. Once set, it will only be cleared when the ambient temperature drops below or equal to the high limit minus the hysteresis width. Bit 13 : LOW When set, the ambient temperature is below the low limit. This bit will remain set so long as the ambient temperature is below the low limit minus the hysteresis. Once set, it will only be cleared when the ambient temperature meets or exceeds the low limit. Bit 12 to 0 : TAMB Ambient temperature data in 2's complement format of Sign bit + 12-bit. Table 17 Examples of Temperature B15 to B0 (binary) xxx0 0111 1101 00xx xxx0 0101 0101 00xx xxx0 0001 1001 00xx xxx0 0000 0010 11xx xxx0 0000 0001 00xx xxx0 0000 0000 01xx xxx0 0000 0000 00xx xxx1 1111 1111 11xx xxx1 1111 1111 00xx xxx1 1111 1101 01xx xxx1 1110 1100 00xx 28 Value +125.00 +85.00 +25.00 +2.75 +1.00 +0.25 +0.00 −0.25 −1.00 −2.75 −20.00 Unit °C °C °C °C °C °C °C °C °C °C °C 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 3. 5 Manufacturer ID register PCI-SIG ID number of ABLIC Inc. can be read. B15 0 B14 0 B7 B6 1 0 Address : 06h R/W : Read-only Default : 1C85h B13 0 B12 1 B11 1 B10 1 B9 0 B8 0 B5 0 B4 0 B3 0 B2 1 B1 0 B0 1 Figure 25 3. 6 Manufacturer ID Register Structure Device ID / revision register Device ID and revision number of product can be read. B15 0 B14 0 B7 B6 0 0 Address : 07h R/W : Read-only Default : 2221h B13 1 B12 0 B11 0 B10 0 B9 1 B8 0 B5 1 B4 0 B3 0 B2 0 B1 0 B0 1 Figure 26 3. 7 Device ID / Revision Register Structure Resolution register Resolution register defines temperature sensor resolution. B15 0 B14 0 B13 0 B12 0 B11 0 B10 0 B9 0 B8 0 B7 B6 B5 0 0 0 Address : 08h R/W : Readable and writable Default : 0001h B4 0 B3 0 B2 0 B1 B0 Figure 27 RES[1:0] Resolution Register Structure Bit 15 to 2 : − Unimplemented bit. These bits are always "0". Bit 1 to 0 : RES[1:0] These bits define resolution. The resolution here is reflected by TRES[1:0] value of capacities register. "00": LSB = 0.5°C (tCONV ≤ 30 ms max.) "01" (default): LSB = 0.25°C (tCONV ≤ 60 ms max.) "10": LSB = 0.125°C (tCONV ≤ 125 ms max.) "11": LSB = 0.0625°C (tCONV ≤ 125 ms max.) 29 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Reset and Initialization This IC has a power-on reset circuit which prevents malfunction, cancels write at power-on. At power-on status, the master device should not transfer the data from the time that the power supply voltage reaches VDD min. to tINIT. And at power-off, all registers are reset when the power supply voltage drops below VPOFF. Therefore if the power supply voltage remains below VPOFF for tPOFF, all operations of this IC are reset. Operating this IC will be required to apply the stable power supply voltage (VDD). The power supply voltage must remain stable until the end of the transmission of the data and, for a write instruction and temperature conversion time. tINIT tPOFF tINIT VDD min. VPON VPOFF VDD Reset status Figure 28 30 Normal operation Reset status Operation when Power Supply Voltage Drops and Power-on Normal operation 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Usage 1. A pull-up resistor to SDA I/O pin and SCL input pin In consideration of I2C-bus protocol function, the SDA I/O pin and SCL input pin should be connected with a pull-up resistor. This IC cannot transmit normally without using a pull-up resistor. In case that the SCL input pin of this IC is connected to the Nch open-drain output pin of the master device, connect the SCL pin with a pull-up resistor. As well, in case the SCL input pin of this IC is connected to the tri-state output pin of the master device, connect the SCL pin with a pull-up resistor in order not to set it in "High-Z". This prevents this IC from error caused by an uncertain output (High-Z) from the tri-state pin when resetting the master device during the voltage drop. ___________ ___________ Pull-up resistor of the EVENT pin is also required to transmit EVENT behavior. 2. Equivalent circuits of input pin and I/O pin The SCL pin and the SDA pin of this IC do not have a built-in pull-down or pull-up resistor. Each of the SA0 pin, SA1 pin and SA2 pin has a built-in pull-down resistor. The SDA pin is an open-drain output. The followings are equivalent circuits of the pins. SDA SCL Figure 29 SCL Pin Figure 30 EVENT Figure 31 3. ___________ EVENT Pin SDA Pin SA0, SA1, SA2 Figure 32 SA0, SA1, SA2 Pin Acknowledge check The I2C-bus protocol includes an acknowledge check function as a handshake function to prevent a communication error. This function allows detection of a communication failure during data communication between the master device and this IC. This function is effective to prevent malfunction, so it is recommended to perform an acknowledge check with the master device. 31 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A 4. SDA pin and SCL pin noise suppression time This IC includes a built-in low-pass filter at the SDA pin and the SCL pin to suppress noise. If the power supply voltage is 2.2 V, noise with a pulse width of 75 ns or less can be suppressed. For details of the assurable value, refer to noise suppression time (tl) in Table 8 in " AC Electrical Characteristics". 400 300 Noise suppression time 200 (tI) max. [ns] 100 0 2.0 2.5 3.0 4.0 3.5 Power supply voltage (VDD) [V] Figure 33 5. Noise Suppression Time for SDA Pin and SCL Pin Operation when inputting stop condition during write This IC does the E2PROM write operation only when it receives data of 1 byte or more and receives a stop condition immediately after an acknowledge output. Refer to Figure 34 for details. Write valid by stop condition Write invalid by stop condition S T A DEVICE R T SELECT CODE SDA LINE WORD ADDRESS (n) DATA (n) 1 0 1 0 SA2 SA1 SA0 0 W7W6 W5W4 W3 W2 W1W0 D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C BWK Figure 34 6. Write invalid by stop condition W R I T E M S B A C K Write valid by stop condition Write invalid by stop condition DATA (n + 1) D7 A C K Write valid by stop condition S T O P DATA (n + x) D0 D7 A C K D0 A C K Write Operation by Inputting Stop Condition during Write Command cancel by start condition By a start condition, users are able to cancel command which is being input. However, users are not able to input a start condition when this IC is outputting "L". When users cancel the command, there may be a case that the address will not be identified. Use random read for the read operation, not current address read. 32 2-WIRE SERIAL E2PROM WITH TEMPERATURE SENSOR FOR DIMM SERIAL PRESENCE DETECT Rev.2.0_00_U S-34TS04A  Precautions • Do not operate these ICs in excess of the absolute maximum ratings. Attention should be paid to the power supply voltage, especially. The surge voltage which exceeds the absolute maximum ratings can cause latch-up and malfunction. Perform operations after confirming the detailed operation condition in the data sheet. • Operations with moisture on this IC's pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking this IC up from low temperature tank during the evaluation. Be sure that not remain frost on this IC's pin to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 33 2.0±0.1 (1.60) 0.5 0.25±0.1 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PQ008-B-P-SD-1.0 TITLE DFN-8-B-PKG Dimensions No. PQ008-B-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. ø1.5 +0.1 -0 2.0±0.05 4.0±0.1 0.2±0.05 0.9±0.1 +0.1 ø1.0 - 0 4.0±0.1 2.3±0.1 4 3 21 5 6 78 Feed direction No. PQ008-B-C-SD-1.0 TITLE DFN-8- B - C a r r i e r T a p e PQ008-B-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 12.5max. 9.2±0.5 Enlarged drawing in the central part ø13±0.2 No. PQ008-B-R-SD-1.0 DFN-8- B - R e e l TITLE PQ008-B-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 1.6 0.30 0.50 No. PQ008-B-L-SD-1.0 TITLE DFN-8-B-Land Recommendation PQ008-B-L-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-34TS04A0B-A8T3U5 价格&库存
很抱歉,暂时无法提供与“S-34TS04A0B-A8T3U5”相匹配的价格&库存,您可以联系我们找货
