S-85V1AB30-I6T1U
S-85V1AB30-I6T1U
    ABLIC(艾普凌科)
    SMD6
    S-85V1A系列是一款5.5V输入、200mA异步降压开关稳压器,具有10uA静态电流。该IC采用独特的COT(恒定导通时间)控制,实现快速瞬态响应和高效率。适用于移动设备和电池供电设备。采用超小型...
S-85V1AB30-I6T1U 数据手册
S-85V1A Series 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 A QUIESCENT CURRENT www.ablic.com Rev.1.2_00 © ABLIC Inc., 2017-2018 The S-85V1A Series is a step-down switching regulator which features high efficiency and fast transient response. Since PWM / PFM switching control automatically switches to PFM control when under light load, high efficiency is realized. This IC is suitable for mobile devices and battery powered devices due to introduction of own distinctive COT (Constant On-Time) control. Also, high-density mounting is realized by adopting super-small, thin SNT-6A package. Therefore, the occupancy area including a coil, an input capacitor and an output capacitor can be reduced to 2.0 mm  4.5 mm = 9.0 mm2, and it contributes to miniaturization of electronic equipment.  Features  Applications 10 A quiescent current 93% COT control 2.2 V to 5.5 V 0.7 V to 2.5 V, in 0.05 V step 2.6 V to 3.9 V, in 0.1 V step  Output voltage accuracy: 1.5% (1.0 V VOUT 3.9 V) 15 mV (0.7 V VOUT  1.0 V)  Switching frequency: 1.0 MHz (at PWM operation)  High side power MOS FET on-resistance: 450 m  Low side power MOS FET on-resistance: 350 m  Soft-start function: 1 ms typ.  Under voltage lockout function (UVLO): 1.8 V typ. (detection voltage) 135°C typ. (detection temperature)  Thermal shutdown function:  Overcurrent protection function: 450 mA (at L = 2.2 H)  Automatic recovery type short-circuit protection function:Hiccup control  Input and output capacitors: Ceramic capacitor compatible  Operation temperature range: Ta = 40°C to 85°C  Lead-free (Sn 100%), halogen-free  Current consumption:  Efficiency:  Fast transient response:  Input voltage:  Output voltage:  Typical Application Circuit VIN CIN 10 F L 2.2 H SW VIN PVSS VOUT  SNT-6A (1.80 mm 1.57 mmt0.5 mm max.) VOUT(S) = 1.8 V VOUT COUT 10 F 100 80 60 VIN = 2.5 V VIN = 3.6 V 20 VSS  Package  Efficiency 40 EN  Bluetooth device  Wireless sensor network device  Healthcare equipment  Smart meter  Portable game device  Remote control 0 VIN = 4.2 V 0.1 1 10 IOUT [mA] 100 1000 1 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Block Diagram CIN VIN VOUT Ripple generation circuit Error amplifier − ON time generation + circuit + Reference voltage circuit EN Enable circuit SW Output control circuit − UVP circuit + Soft-start cicuit SW Reverse current detection circuit + − Thermal shutdown circuit Overcurrent protection circuit UVLO circuit VSS Figure 1 2 VIN L PVSS VOUT COUT 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Product Name Structure Users can select output voltage for the S-85V1A Series. Refer to "1. Product name" regarding the contents of product name, "2. Package" regarding the package, "3. Product name list" regarding details of the product name. 1. Product name S-85V1A B xx - I6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free *1 Package name abbreviation and packing specification I6T1: SNT-6A, Tape *2, *3 Output voltage 07 to 39 (e.g., when the output voltage is 0.7 V, it is expressed as 07.) *1. *2. *3. 2. Refer to the tape drawing. Refer to "3. Product name list". In the range from 0.7 V to 2.5 V, the products which have 0.05 V step are also available. Contact our sales office when the product is necessary. Package Table 1 Package Name SNT-6A Package Drawing Codes Dimension Tape Reel Land PG006-A-P-SD PG006-A-C-SD PG006-A-R-SD PG006-A-L-SD 3 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 3. Product name list Table 2 Output Voltage (VOUT) 0.7 V ± 15 mV 0.8 V ± 15 mV 0.9 V ± 15 mV 1.0 V ± 1.5% 1.1 V ± 1.5% 1.2 V ± 1.5% 1.3 V ± 1.5% 1.4 V ± 1.5% 1.5 V ± 1.5% 1.6 V ± 1.5% 1.7 V ± 1.5% 1.8 V ± 1.5% 1.9 V ± 1.5% 2.0 V ± 1.5% 2.1 V ± 1.5% 2.2 V ± 1.5% 2.3 V ± 1.5% 2.4 V ± 1.5% 2.5 V ± 1.5% 2.6 V ± 1.5% 2.7 V ± 1.5% 2.8 V ± 1.5% 2.9 V ± 1.5% 3.0 V ± 1.5% 3.1 V ± 1.5% 3.2 V ± 1.5% 3.3 V ± 1.5% 3.4 V ± 1.5% 3.5 V ± 1.5% 3.6 V ± 1.5% 3.7 V ± 1.5% 3.8 V ± 1.5% 3.9 V ± 1.5% Remark 4 S-85V1A Series S-85V1AB07-I6T1U S-85V1AB08-I6T1U S-85V1AB09-I6T1U S-85V1AB10-I6T1U S-85V1AB11-I6T1U S-85V1AB12-I6T1U S-85V1AB13-I6T1U S-85V1AB14-I6T1U S-85V1AB15-I6T1U S-85V1AB16-I6T1U S-85V1AB17-I6T1U S-85V1AB18-I6T1U S-85V1AB19-I6T1U S-85V1AB20-I6T1U S-85V1AB21-I6T1U S-85V1AB22-I6T1U S-85V1AB23-I6T1U S-85V1AB24-I6T1U S-85V1AB25-I6T1U S-85V1AB26-I6T1U S-85V1AB27-I6T1U S-85V1AB28-I6T1U S-85V1AB29-I6T1U S-85V1AB30-I6T1U S-85V1AB31-I6T1U S-85V1AB32-I6T1U S-85V1AB33-I6T1U S-85V1AB34-I6T1U S-85V1AB35-I6T1U S-85V1AB36-I6T1U S-85V1AB37-I6T1U S-85V1AB38-I6T1U S-85V1AB39-I6T1U Please contact our sales office for products with specifications other than the above. 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Pin Configuration 1. SNT-6A Table 3 Top view 1 2 3 Pin No. 6 5 4 Figure 2 Symbol 1 2 3 4 5 VOUT VSS SW PVSS VIN 6 EN Description Voltage output pin GND pin External inductor connection pin Power GND pin Power supply pin Enable pin "H" : Enable (normal operation) "L" : Disable (standby) 5 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Absolute Maximum Ratings Table 4 (Unless otherwise specified: Ta = +25°C, VSS = 0 V) Item VIN pin voltage EN pin voltage VOUT pin voltage SW pin voltage PVSS pin voltage Operation temperature Storage temperature Symbol VIN VEN VOUT VSW VPVSS Topr Tstg Absolute Maximum Rating Unit VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VIN + 0.3 ≤ VSS + 6.0 VSS − 0.3 to VIN + 0.3 ≤ VSS + 6.0 VSS − 0.3 to VIN + 0.3 ≤ VSS + 6.0 VSS − 0.3 to VSS + 0.3 ≤ VSS + 6.0 −40 to +85 −40 to +125 V V V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 5 Item Symbol Condition Board A Board B Junction-to-ambient thermal resistance*1 θJA SNT-6A Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark Refer to " Power Dissipation" and "Test Board" for details. 6 Min. − − − − − Typ. 224 176 − − − Max. − − − − − Unit °C/W °C/W °C/W °C/W °C/W 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Electrical Characteristics Table 6 (VIN = 3.6 V*1, Ta = +25°C unless otherwise specified) Item Operating input voltage Output voltage*2 Symbol VIN Condition Min. Typ. Max. Unit − 2.2 VOUT(S) × 0.985 VOUT(S) − 0.015 3.6 5.5 VOUT(S) × 1.015 VOUT(S) + 0.015 V 1.0 V ≤ VOUT ≤ 3.9 V, no external parts VOUT 0.7 V ≤ VOUT < 1.0 V, no external parts Current consumption during shutdown ISSS Current consumption duringt switching off ISS1 VEN = 0 V VOUT(S) VOUT(S) V V − − 1 μA − 10 20 μA 1.1 − −0.1 −0.1 − − − − − 0.3 0.1 0.1 V V μA μA High level input voltage Low level input voltage High level input current Low level input current High side power MOS FET on-resistance Low side power MOS FET on-resistance High side power MOS FET leakage current Low side power MOS FET leakage current Current limit*3 VSH VSL ISH ISL VOUT = VOUT(S) + 0.1 V, VEN = VIN, no external parts, no switching operation VIN = 2.2 V to 5.5 V, EN pin VIN = 2.2 V to 5.5 V, EN pin VIN = 2.2 V to 5.5 V, EN pin, VEN = VIN VIN = 2.2 V to 5.5 V, EN pin, VEN = 0 V RHFET ISW = 100 mA − 450 − mΩ RLFET ISW = −100 mA − 350 − mΩ IHSW VIN = 2.2 V to 5.5 V, VEN = 0 V, VSW = 0 V − − 0.5 μA ILSW VIN = 2.2 V to 5.5 V, VEN = 0 V, VSW = VIN −0.5 − − μA ILIM − 450 − mA ON time*4 tON tON(S)/1.3 tON(S) tON(S)/0.7 ns Minimum OFF time UVLO detection voltage UVLO release voltage tOFF(MIN) VUVLO− VUVLO+ L = 2.2 μH *5 tON(S) = 1/fSW × VOUT/VIN, VOUT = VOUT(S) × 0.9 − When VIN falls When VIN rises − 1.7 1.9 − 1.9 2.1 ns V V UVP detection voltage VUVP − V Soft-start wait time tSSW − ms Soft-start time tSS Thermal shutdown detection temperature Thermal shutdown release temperature Time until VOUT starts rising Time until VOUT reaches 90% after it starts rising − 100 1.8 2.0 VOUT(S) × 0.7 1.5 − 1.0 − ms TSD Junction temperature − 135 − °C TSR Junction temperature − 115 − °C − − *1. VIN = VOUT(S) + 1.0 V (VOUT(S) ≥ 2.6 V) *2. VOUT: Actual output voltage VOUT(S): Set output voltage *3. The current limit changes according to the L value for the inductor to be used, input voltage, and output voltage. Refer to " Operation" for details. *4. tON: Actual ON time tON(S): Set ON time *5. fSW : Switching frequency (1 MHz) 7 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Operation 1. Fast transient response Distinctive COT (Constant On-Time) control is used for DC-DC converter control. The S-85V1A Series monitors the output voltage (VOUT) using a comparator and if VOUT falls below the targeted value, the high side power MOS FET will turn on for a certain amount of time. Since the high side power MOS FET turns on and VOUT rises immediately after the load current fluctuates rapidly and VOUT falls, the fast transient response is realized. The S-85V1A Series outputs ON time in proportion to VOUT and in inverse proportion to power supply voltage. Therefore, when in continuous mode, even if the power supply voltage or VOUT settings would change, it always operates at a quasi-fixed frequency of 1 MHz. 2. PWM / PFM switching control The S-85V1A Series automatically switches between the pulse width modulation method (PWM) and pulse frequency modulation method (PFM) according to the load current. If the output current (IOUT) is large, the IC will operate at PWM control. If IOUT is small, the IC will operate at PFM control and the pulse will skip according to the load current. This reduces switching loss and improves efficiency when under light load. The S-85V1A Series has a built-in reverse current detection circuit. The reverse current detection circuit monitors the current flowing through the inductor. If the bottom of ripple current in the inductor falls to 0 mA, the high side power MOS FET and low side power MOS FET will turn off and switching operation will stop. Switching frequency will fall from 1.0 MHz by skipping a pulse. This means that the smaller IOUT is, the more the switching frequency (fSW ) will drop, and it reduces switching loss. 3. EN pin This pin starts and stops switching operation. When the EN pin is set to "L", the operation of all internal circuits, including the high side power MOS FET, is stopped, reducing current consumption. Current consumption increases when a voltage of 0.3 V to VIN − 0.3 V is applied to the EN pin. When not using the EN pin, connect it to the VIN pin. Since the EN pin is neither pulled down nor pulled up internally, do not use it in the floating status. The structure of the EN pin is shown in Figure 3. Table 7 Internal Circuit VOUT Pin Voltage VOUT*1 "H" Enable (normal operation) "L" Disable (standby) "High-Z" *1. Refer to *2 in Table 6 in " Electrical Characteristics". EN Pin VIN EN VSS Figure 3 4. Under voltage lockout function (UVLO) The S-85V1A Series has a built-in UVLO circuit to prevent the IC from malfunctioning due to a transient status at power-on or a momentary drop in the supply voltage. When UVLO status is detected, the high side power MOS FET and low side power MOS FET will turn off, and the SW pin will change to "High-Z". For this reason, switching operation will stop. The soft-start function is reset if UVLO status is detected once, and is restarted by releasing the UVLO status. Note that the other internal circuits operate normally and the status is different from the disabled status. Also, there is a hysteresis width for avoiding malfunctions due to generation of noise etc. in the input voltage. 8 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 5. Thermal shutdown function The S-85V1A Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 135°C typ., the thermal shutdown circuit becomes the detection status, and the switching operation is stopped. When the junction temperature decreases to 115°C typ., the thermal shutdown circuit becomes the release status, and the switching operation is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the switching operation is stopped and output voltage (VOUT) decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the switching operation is restarted, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. Switching operation stopping and starting can be stopped by either setting the EN pin to "L", lowering the output current (IOUT) to reduce internal power consumption, or decreasing the ambient temperature. Table 8 Thermal Shutdown Circuit *1 Release: 115°C typ. Detection: 135°C typ.*1 *1. Junction temperature 6. VOUT Pin Voltage VOUT "High-Z" Overcurrent protection function The S-85V1A Series has a built-in current limit circuit. The overcurrent protection circuit monitors the current that flows through the low side power MOS FET and limits current to prevent thermal destruction of the IC due to an overload, magnetic saturation in the inductor, etc. When a current exceeding the current limit (ILIM) flows through the low side power MOS FET, the current limit circuit operates and prohibits turning on the high side power MOS FET until the current falls below the low side current limit (ILIMDET). If the value of the current that flows through the low side power MOS FET falls to the ILIMDET or lower, the S-85V1A Series returns to normal operation. ILIMDET is fixed at 270 mA typ. in the IC, and ILIM will vary depending on the external parts to be used. The relation between ILIM, the inductor value (L), the input voltage (VIN), and the output voltage (VOUT) are shown in the following expression. ILIM = ILIMDET + 1 (VIN − VOUT) × VOUT × VIN 2 × L × fSW 9 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 7. Automatic recovery type short-circuit protection function (Hiccup control) The S-85V1A Series has a built-in automatic recovery type short-circuit protection function for Hiccup control. Hiccup control is a method for periodically carrying out automatic recovery when the IC detects overcurrent and stops the switching operation. 7. 1 When over load status is released Overcurrent detection Under voltage protection circuit (UVP circuit) detects a drop in the output voltage (VOUT). 220 μs elapse Switching operation stop (for 9 ms typ.) Overload status release The IC restarts, soft-start function starts. In this case, it is unnecessary to input an external reset signal for restart. VOUT reaches VOUT(S) after 1.0 ms typ. elapses. Overload status Normal load status ILIMDET = 270 mA typ. *1 IL IOUT = 200 mA max. 0A VSW 0V VOUT(S) VOUT VUVP typ. 0V 220 s 9.0 ms typ. 1.0 ms typ. *1. Inductor current Figure 4 7. 2 When over load status continues Overcurrent detection The UVP circuit detects a drop in VOUT. 220 μs elapse Switching operation stop (for 9 ms typ.) The IC restarts, soft-start function starts. The status returns to when over load status continues after 1.25 ms typ. elapses. Overload status ILIMDET = 270 mA typ. *1 IL IOUT = 200 mA max. 0A VSW 0V VOUT(S) VOUT VUVP typ. 220 s 9.0 ms typ. 1.25 ms typ. 220 s *1. Inductor current Figure 5 10 0V 9.0 ms typ. 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 8. Pre-bias compatible soft-start function The S-85V1A Series has a built-in pre-bias compatible soft-start circuit. If the pre-bias compatible soft-start circuit starts when electrical charge remains in the output voltage (VOUT) as a result of power supply restart, etc., or when VOUT is biased beforehand (pre-bias status), switching operation is stopped until the soft-start voltage exceeds the internal feedback voltage, and then VOUT is maintained. If the soft-start voltage exceeds the internal feedback voltage, switching operation will restart and VOUT will rise to the output voltage setting value (VOUT(S)). This allows VOUT(S) to be reached without lowering the pre-biased VOUT. In soft-start circuits which are not pre-bias compatible, a large current flows as a result of the discharge of the residual electric charge through the low side power MOS FET when switching operation starts, which could cause damage, however in a pre-bias compatible soft-start circuit, the IC is protected from the large current when switching operation starts, and it makes power supply design for the application circuit simpler. In the S-85V1A Series, VOUT reaches VOUT(S) gradually due to the soft-start circuit. In the following cases, rush current and VOUT overshoot are reduced. • At power-on • When the EN pin changes from "L" to "H". • When UVLO operation is released. • When thermal shutdown is released. • At short-circuit recovery In addition, the soft-start circuit operates under the following conditions. The soft-start circuit starts operating after "H" is input to the EN pin and the soft-start wait time (tSSW) = 1.5 ms typ. elapses. The soft-start time (tSS) is set to 1.0 ms typ. • At power supply restart (the IC restart) • At UVLO detection (after UVLO release) • At thermal shutdown detection (after thermal shutdown release) • After Hiccup control Soft-start wait time (tSSW) Soft-start time (tSS) Soft-start operation during pre-bias VEN VOUT VSW Figure 6 11 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Typical Circuit VIN VOUT Ripple generation circuit Error amplifier − ON time generation + circuit + SS SW CIN 10 μF Output control circuit − UVP circuit + Reference voltage circuit EN Soft-start cicuit SW L VIN VOUT 2.2 μH Reverse current detection circuit + − COUT 10 μF PVSS Thermal shutdown circuit UVLO cicuit Overcurrent protection circuit VSS Figure 7 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants. 12 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  External Parts Selection Selectable values and recommended values for external parts are shown in Table 9. Use ceramic capacitors for CIN and COUT. Table 9 Input Capacitor (CIN) 2.2 μF or larger 10 μF Item Selectable value Recommended value 1. Output Capacitor (COUT) 4.7 μF to 100 μF 10 μF Inductor (L) 1.5 μH to 10 μH 2.2 μH Input capacitor (CIN) CIN can lower the power supply impedance, average the input current, improve the efficiency and noise tolerance. Select a capacitor according to the impedance of the power supply to be used. Also take into consideration the DC bias characteristics of the capacitor to be used. 2. Output capacitor (COUT) COUT is used to smooth output voltage. If the capacitance is large, the overshoot and undershoot during load transient and output ripple voltage can be improved even more. Select a proper capacitor after the sufficient evaluation under actual conditions. Table 10 Recommended Capacitors (CIN, COUT) List (at VOUT(S) ≤ 3.3 V) Manufacturer Part Number Capacitance Withstanding Voltage Dimensions (L × W × H) Murata Manufacturing Co., Ltd. TDK Corporation Murata Manufacturing Co., Ltd. GRM155R60J106ME15 C1608X5R0J106K080AB GRM185R60J106ME15 10 μF 10 μF 10 μF 6.3 V 6.3 V 6.3 V 1.0 mm × 0.5 mm × 0.5 mm 1.6 mm × 0.8 mm × 0.8 mm 1.6 mm × 0.8 mm × 0.5 mm Table 11 Recommended Capacitors (CIN, COUT) List (at VOUT(S) > 3.3 V) Manufacturer Part Number Capacitance Withstanding Voltage Dimensions (L × W × H) TDK Corporation Murata Manufacturing Co., Ltd. C1608X5R0J106K080AB GRM185R60J106ME15 10 μF 10 μF 6.3 V 6.3 V 1.6 mm × 0.8 mm × 0.8 mm 1.6 mm × 0.8 mm × 0.5 mm 3. Inductor (L) When selecting L, note the allowable current. If a current exceeding this allowable current flows through the inductor, magnetic saturation may occur, and there may be risks which substantially lower efficiency and damage the IC as a result of large current. Therefore, select an inductor so that peak current value (IPK), even during overcurrent detection, does not exceed the allowable current. When prioritizing the load response, select an inductor with a small L value such as 2.2 μH. When prioritizing the efficiency, select an inductor with a large L value such as 10 μH. IPK is calculated using the following expression. IPK = IOUT + 1 (VIN − VOUT) × VOUT × VIN 2 × L × fSW Table 12 Recommended Inductors (L) List Manufacturer Part Number Inductance Rated Current Dimensions (L × W × H) ALPS ELECTRIC CO., LTD. Murata Manufacturing Co., Ltd. Würth Elektronik GmbH & Co. KG Murata Manufacturing Co., Ltd. TDK Corporation Coilcraft, Inc. GLUHK2R201A DFE201210S-2R2M=P2 74438343022 LQM2MPN2R2MGH MLP2016G2R2M PFL2015-222ME 2.2 μH 2.2 μH 2.2 μH 2.2 μH 2.2 μH 2.2 μH 1700 mA 2000 mA 1100 mA 1300 mA 850 mA 1050 mA 2.0 mm × 1.6 mm × 1.0 mm 2.0 mm × 1.2 mm × 1.0 mm 2.0 mm × 1.6 mm × 1.0 mm 2.0 mm × 1.6 mm × 0.9 mm 2.0 mm × 1.6 mm × 1.0 mm 2.2 mm × 1.45 mm × 1.5 mm 13 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Board Layout Guidelines Note the following cautions when determining the board layout for the S-85V1A Series. • Place CIN as close to the VIN pin and the PVSS pin as possible. • Make the VIN pattern and GND pattern as wide as possible. • Place thermal vias in the GND pattern to ensure sufficient heat dissipation. • Keep thermal vias near CIN and COUT approximately 3 mm to 4 mm away from capacitor pins. • Large current flows through the SW pin. Make the wiring area of the pattern to be connected to the SW pin small to minimize parasitic capacitance and emission noise. • Do not wire the SW pin pattern under the IC. Total size Figure 8 2.0 mm × 4.5 mm = 9.0 mm2 Reference Board Pattern Caution The above pattern diagram does not guarantee successful operation. Perform thorough evaluation using the actual application to determine the pattern. Remark 14 Refer to the land drawing of SNT-6A and "SNT Package User's Guide". 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Precautions • Mount external capacitors and inductors as close as possible to the IC, and make single GND. • Characteristic ripple voltage and spike noise occur in the IC containing switching regulators. Moreover rush current flows at the time of a power supply injection. Because these largely depend on the inductor, the capacitor and impedance of power supply to be used, fully check them using an actually mounted model. • The 10 μF capacitor connected between the VIN pin and the VSS pin is a bypass capacitor. It stabilizes the power supply in the IC when application is used with a heavy load, and thus effectively works for stable switching regulator operation. Allocate the bypass capacitor as close to the IC as possible, prioritized over other parts. • Although the IC contains a static electricity protection circuit, static electricity or voltage that exceeds the limit of the protection circuit should not be applied. • The power dissipation of the IC greatly varies depending on the size and material of the board to be connected. Perform sufficient evaluation using an actual application before designing. • ABLIC Inc. assumes no responsibility for the way in which this IC is used on products created using this IC or for the specifications of that product, nor does ABLIC Inc. assume any responsibility for any infringement of patents or copyrights by products that include this IC either in Japan or in other countries. 15 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Characteristics (Typical Data) Example of major power supply dependence characteristics (Ta = +25°C) ISS1 [μA] 1. 1 Current consumption during switching off (ISS1) vs. Input voltage (VIN) 1. 2 100 15 80 10 5 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 40 0 5.5 1. 3 Output voltage (VOUT) vs. Input voltage (VIN) VOUT(S) = 1.2 V 1.230 2.0 1. 4 1.220 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 Output voltage (VOUT) vs. Input voltage (VIN) VOUT(S) = 1.8 V 1.840 1.820 VOUT [V] 1.210 1.200 1.190 1.800 1.780 1.180 1.170 60 20 0 VOUT [V] Current consumption during shutdown (ISSS) vs. Input voltage (VIN) 20 ISSS [nA] 1. 1.760 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 1. 5 Output voltage (VOUT) vs. Input voltage (VIN) VOUT(S) = 2.5 V 2.600 VOUT [V] 2.400 2.200 2.000 1.800 2.0 1. 6 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 ON time (tON) vs. Input voltage (VIN) VOUT(S) = 1.8 V 1.0 1. 7 fSW [MHz] tON [s] 0.8 0.6 0.4 0.2 1.2 1.0 0.8 0.6 0.0 2.0 16 Switching frequency (fSW) vs. Input voltage (VIN) VOUT(S) = 1.8 V 1.4 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series Soft-start wait time (tSSW) vs. Input voltage (VIN) 1. 9 2.50 2.00 2.00 1.50 1.00 0.50 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 2.0 800 700 600 500 400 300 200 100 0 RHFET [m] RHFET [m] 2.5 High side power MOS FET on-resistance (RHFET) 1. 11 vs. Input voltage (VIN) 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 2.0 80 ILSW [nA] 80 20 4.5 5.0 5.5 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 60 40 20 0 0 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 1. 14 High level input voltage (VSH) vs. Input voltage (VIN) 2.0 1.0 1.0 0.8 0.8 VSL [V] 1.2 0.6 0.4 0.2 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 1. 15 Low level input voltage (VSL) vs. Input voltage (VIN) 1.2 0.0 3.5 4.0 VIN [V] 1. 13 Low side power MOS FET leakage current (ILSW) vs. Input voltage (VIN) 100 40 3.0 800 700 600 500 400 300 200 100 0 100 60 2.5 Low side power MOS FET on-resistance (RLFET) vs. Input voltage (VIN) 5.5 1. 12 High side power MOS FET leakage current (IHSW) vs. Input voltage (VIN) IHSW [nA] 1.00 0.00 2.0 1. 10 1.50 0.50 0.00 VSH [V] Soft-start time (tSS) vs. Input voltage (VIN) 2.50 tSS [ms] tSSW [ms] 1. 8 0.6 0.4 0.2 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 0.0 2.0 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 5.5 17 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 2. Example of major temperature characteristics (Ta = −40°C to +85°C) 2. 1 Current consumption during switching off (ISS1) vs. Temperature (Ta) 2. 2 20 200 VDD = 5.5 V 150 VDD = 3.6 V ISSS [nA] ISS1 [μA] 15 10 5 2. 3 −40 −25 0 VDD = 2.2 V 100 VDD = 3.6 V VDD = 5.5 V 50 VDD = 2.2 V 0 Current consumption during shutdown (ISSS) vs. Temperature (Ta) 25 Ta [°C] 50 0 75 85 Output voltage (VOUT) vs. Temperature (Ta) 2. 4 −40 −25 0 25 Ta [C] VOUT(S) = 1.8 V 1.840 1.210 1.200 1.190 VDD = 3.6 V 2. 5 −40 −25 1.800 1.760 0 25 Ta [C] 50 VDD = 5.5 V 1.780 1.180 1.170 VDD = 2.2 V VDD = 3.6 V 1.820 VOUT [V] VOUT [V] VDD = 2.2 V VDD = 5.5 V 75 85 Output voltage (VOUT) vs. Temperature (Ta) VOUT(S) = 1.2 V 1.230 1.220 50 75 85 −40 −25 0 25 Ta [C] 50 75 85 Output voltage (VOUT) vs. Temperature (Ta) VOUT(S) = 2.5 V 2.560 VOUT [V] 2.540 VDD = 5.5 V 2.520 2.500 2.480 VDD = 3.6 V 2.460 2.440 2. 6 40 25 0 25 Ta [C] 50 75 85 ON time (tON) vs. Temperature (Ta) 2. 7 1.2 1.4 0.8 VDD = 3.6 V 0.6 VDD = 2.2 V 0.4 0.2 18 fSW [MHz] tON [s] 1.0 0.0 Switching frequency (fSW) vs. Temperature (Ta) VDD = 5.5 V −40 −25 0 25 Ta [C] 1.2 1.0 0.8 0.6 50 75 85 VDD = 3.6 V VDD = 5.5 V −40 −25 0 VDD = 2.2 V 25 Ta [C] 50 75 85 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series Soft-start wait time (tSSW) vs. Temperature (Ta) 2.00 2.00 1.50 VDD = 5.5 V 1.00 VDD = 3.6 V 40 25 VDD = 2.2 V 25 Ta [C] 50 2. 11 RLFET [m] RHFET [m] 0.50 VDD = 2.2 V VDD = 5.5 V 40 25 1.00 75 85 VDD = 3.6 V 0 25 Ta [C] 50 250 200 200 100 50 0 −40 −25 0 25 Ta [C] 50 0.6 0.2 0.0 VDD = 2.2 V −40 −25 VDD = 3.6 V 25 Ta [C] 25 0 VDD = 3.6 V 25 Ta [C] 50 75 85 VDD = 5.5 V VDD = 3.6 V 100 VDD = 2.2 V 50 0 25 Ta [C] 50 75 85 VDD = 5.5 V 1.0 0.8 0.6 0.4 0.2 75 85 −40 −25 1.2 0.0 0 75 85 2. 15 Low level input voltage (VSL) vs. Temperature (Ta) VSL [V] 0.8 0.4 VDD = 5.5 V 150 0 75 85 VDD = 5.5 V 1.0 50 50 2. 14 High level input voltage (VSH) vs. Temperature (Ta) 1.2 25 Ta [C] 2. 13 Low side power MOS FET leakage current (ILSW) vs. Temperature (Ta) 250 VDD = 5.5 V 0 VDD = 2.2 V 40 300 VDD = 3.6 V VDD = 2.2 V 40 25 800 700 600 500 400 300 200 100 0 300 150 VDD = 3.6 V VDD = 5.5 V Low side power MOS FET on-resistance (RLFET) vs. Temperature (Ta) 75 85 2. 12 High side power MOS FET leakage current (IHSW) vs. Temperature (Ta) VDD = 2.2 V 1.50 0.00 0 2. 10 High side power MOS FET on-resistance (RHFET) vs. Temperature (Ta) 800 700 600 500 400 300 200 100 0 tSS [ms] 2.50 0.00 IHSW [nA] Soft-start time (tSS) vs. Temperature (Ta) 2.50 0.50 VSH [V] 2. 9 ILSW [nA] tSSW [ms] 2. 8 VDD = 2.2 V 40 25 0 VDD = 3.6 V 25 Ta [C] 50 75 85 19 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series 2.2 2.2 2.1 2.1 2.0 2.0 1.9 1.8 1.7 1.6 20 2. 17 UVLO release voltage (VUVLO+) vs. Temperature (Ta) VUVLO [V] VUVLO [V] 2. 16 UVLO detection voltage (VUVLO−) vs. Temperature (Ta) 1.9 1.8 1.7 40 25 0 25 Ta [C] 50 75 85 1.6 40 25 0 25 Ta [C] 50 75 85 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series Transient response characteristics The external parts shown in Table 13 are used in "3. Transient response characteristics". Table 13 Element Name Inductor Input capacitor Output capacitor Part Number GLUHK2R201A C1608X5R0J106K080AB C1608X5R0J106K080AB Power-on (VOUT = 1.8 V, VIN = 0 V → 3.6 V, Ta = +25°C) VIN VOUT IL 4 3. 1. 2 4 3 2 1 0 1 2 3 4 IOUT = 200 mA 5 700 600 500 400 300 200 100 0 100 VIN VOUT IL 0 1 2 3 Time [ms] 4 IL [mA] 700 600 500 400 300 200 100 0 100 VIN [V], VOUT [V] 3. 1. 1 IOUT = 0.1 mA 4 3 2 1 0 1 2 3 4 0 1 2 3 Time [ms] 3. 2 Manufacturer ALPS ELECTRIC CO., LTD. TDK Corporation TDK Corporation IL [mA] VIN [V], VOUT [V] 3. 1 Constant 2.2 μH 10 μF 10 μF 5 Transient response characteristics of EN pin VOUT IL 1 2 3 Time [ms] 4 IOUT = 200 mA 5 700 600 500 400 300 200 100 0 100 VEN VOUT IL [mA] VEN 3. 2. 2 4 3 2 1 0 1 2 3 4 IL 0 1 2 3 Time [ms] 4 5 Power supply fluctuation (VOUT = 1.8 V, Ta = +25°C) IOUT = 0.1 mA 5 3. 3. 2 VIN = 3.6 V → 4.2 V → 3.6 V 2.10 5 2.00 4 4 VIN 3 VOUT 2 1 0 10 20 30 Time [ms] 40 50 1.90 IOUT = 200 mA VIN = 3.6 V → 4.2 V → 3.6 V 2.10 2.00 VIN 1.90 3 1.80 2 1.70 1 VOUT VOUT [V] 3. 3. 1 VIN [V] 700 600 500 400 300 200 100 0 100 VIN [V] 3. 3 IOUT = 0.1 mA VEN [V], VOUT [V] 3. 2. 1 4 3 2 1 0 1 2 3 4 0 IL [mA] VEN [V], VOUT [V] (VOUT = 1.8 V, VIN = 3.6 V, VEN = 0 V → 3.6 V, Ta = +25°C) VOUT [V] 3. 1.80 1.70 0 10 20 30 Time [ms] 40 50 21 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series Load fluctuation (VOUT = 1.8 V, VIN = 3.6 V, Ta = +25°C) IOUT [mA] 20 10 IOUT 0 10 30 0.0 0.2 0.4 0.6 Time [ms] 0.8 3. 4. 2 300 1.95 200 1.90 100 1.85 VOUT 20 2.00 1.80 1.75 1.70 1.0 IOUT = 0.1 mA → 200 mA → 0.1 mA 2.00 1.95 IOUT 0 100 1.90 1.85 1.80 VOUT 1.75 200 300 0.0 0.2 0.4 0.6 Time [ms] 0.8 VOUT [V] IOUT = 0.1 mA → 10 mA → 0.1 mA IOUT [mA] 3. 4. 1 30 VOUT [V] 3. 4 1.70 1.0  Reference Data The external parts shown in Table 14 are used in " Reference Data". Table 14 Condition Input Capacitor (CIN) C1005X5R0J106M050BC (10 μF) TDK Corporation C1005X5R0J106M050BC (10 μF) TDK Corporation η [%] 1. 1 Efficiency (η) vs. Output current (IOUT) 1. 2 1.5 80 1.4 60 VIN = 3.6 V 40 VIN = 5.5 V 0.01 0.1 VIN = 5.5 V 1.3 1.2 1.1 0 1 10 IOUT [mA] 1.0 0.001 100 VIN = 3.6 V 0.01 0.1 1 IOUT [mA] 10 100 VOUT = 1.8 V (External parts: Condition) Efficiency (η) vs. Output current (IOUT) 2. 2 Output voltage (VOUT) vs. Output current (IOUT) 100 2.0 80 1.9 60 VOUT [V] η [%] 2. 1 VIN = 3.6 V 40 VIN = 5.5 V 20 0.01 0.1 1 IOUT [mA] VIN = 5.5 V 1.8 1.7 VIN = 3.6 V 1.6 0 22 Output voltage (VOUT) vs. Output current (IOUT) 100 20 2. Output Capacitor (COUT) C1005X5R0J106M050BC (10 μF) TDK Corporation C1005X5R0J106M050BC (10 μF) TDK Corporation VOUT = 1.2 V (External parts: Condition) VOUT [V] 1. Inductor (L) GLUHK2R201A (2.2 μH) ALPS ELECTRIC CO., LTD DFE201210S (2.2 μH) Toko Ink. 10 100 1.5 0.001 0.01 0.1 1 IOUT [mA] 10 100 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series VOUT = 1.2 V (External parts: Condition) η [%] 3. 1 Efficiency (η) vs. Output current (IOUT) 3. 2 Output voltage (VOUT) vs. Output current (IOUT) 100 1.5 80 1.4 60 VOUT [V] 3. VIN = 3.6 V 40 VIN = 5.5 V 20 0.1 1 1.2 1.1 0 0.01 VIN = 5.5 V 1.3 10 1.0 0.001 100 VIN = 3.6 V 0.01 IOUT [mA] 10 100 VOUT = 1.8 V (External parts: Condition) Efficiency (η) vs. Output current (IOUT) 4. 2 Output voltage (VOUT) vs. Output current (IOUT) 100 2.0 80 1.9 60 VOUT [V] 4. 1 η [%] 4. 0.1 1 IOUT [mA] VIN = 3.6 V 40 VIN = 5.5 V 20 0.1 1 IOUT [mA] 1.8 1.7 VIN = 3.6 V 1.6 0 0.01 VIN = 5.5 V 10 100 1.5 0.001 0.01 0.1 1 IOUT [mA] 10 100 23 5.5 V INPUT, 200 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR WITH 10 μA QUIESCENT CURRENT Rev.1.2_00 S-85V1A Series  Power Dissipation SNT-6A Tj = 125C max. Power dissipation (PD) [W] 1.0 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 Ambient temperature (Ta) [C] 24 Board Power Dissipation (PD) A 0.45 W B C 0.57 W − D − E − 175 SNT-6A Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SNT6A-A-Board-SD-1.0 ABLIC Inc. 1.57±0.03 6 1 5 4 2 3 +0.05 0.08 -0.02 0.5 0.48±0.02 0.2±0.05 No. PG006-A-P-SD-2.1 TITLE SNT-6A-A-PKG Dimensions No. PG006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.85±0.05 ø0.5 -0 4.0±0.1 0.65±0.05 3 2 1 4 5 6 Feed direction No. PG006-A-C-SD-2.0 TITLE SNT-6A-A-Carrier Tape No. PG006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PG006-A-R-SD-1.0 SNT-6A-A-Reel TITLE No. PG006-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 0.52 1.36 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package ( 1.30 mm ~ 1.40 mm ). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) No. PG006-A-L-SD-4.1 TITLE SNT-6A-A -Land Recommendation No. PG006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-85V1AB30-I6T1U 价格&库存
很抱歉,暂时无法提供与“S-85V1AB30-I6T1U”相匹配的价格&库存,您可以联系我们找货
