NJU77232RB1-TE1
NJU77232RB1-TE1
    JRC(⽇本无线)
    LSSOP8
    RAIL-TO-RAIL INPUT PUSH-PULL OUT
NJU77232RB1-TE1 数据手册
NJU77230/NJU77231/NJU77232 Rail-to-Rail Input,Push-Pull Output Low power CMOS Comparators + - ■FEATURES(V =3V, V =0V, Ta=25°C) ●Rail-to-Rail Input ●Push Pull Output ●Supply Current ●Propagation Delay ●Operating Voltage ●Input Offset Voltage ●Operating Temperature ●Integrated EMI filter ●Package NJU77230 NJU77231 ■GENERAL DESCRIPTION The NJU77230/NJU77231/NJU77232 are Rail-to-Rail Input CMOS comparators featuring Low-power and Push-Pull output. These comparators operate from 1.8V to 5.5V and low supply current of 6µA/ch.typ. This feature is suitable for battery powered application. The NJU77231/NJU77232 are available in small size Package, DFN6-G1(1616), DFN8-U1(2020), significantly reducing the required portable application's board area. 6µA/ch typ. 780ns typ. 1.8 to 5.5V 6mV max. -40 to 125℃ SOT-23-5, SC88A SOT-23-5, SC88A, DFN6-G1(ESON6-G1) NJU77232 MSOP8(TVSP8)* *meet JEDEC MO-187-DA / thin type, DFN8-U1(ESON8-U1) ■APPLICATION ■RELATED PRODUCTS Features Rail-to-Rail Input Open-Drain Output Low power CMOS Comparators ●Portable and Battery-Powered Applications ●Alarm and Surveillance Circuits ●Industrial Instruments ●Sensor Applications ■PIN CONFIGURATION Parts NJU77230F Number Package SOT-23-5 Outline Pin Function NJU77242 NJU77231F NJU77231F3 SC-88A SOT-23-5 SC-88A -INPUT 1 V+ V- 2 5 V+ V- 2 4 OUTPUT +INPUT 3 4 OUTPUT NJU77231KG1 NJU77232RB1 NJU77232KU1 DFN6-G1(ESON6-G1)(*) MSOP8(TVSP8) DFN8-U1(ESON8-U1) (*) (Top View) Pin Function NJU77240 NJU77241 (Top View) 5 -INPUT 3 Parts Number Package Outline Dual NJU77230F3 (Top View) +INPUT 1 Single V+ 1 NC 2 OUTPUT 3 Exposed Pad on Underside (Top View) (Top View) 6 V- 5 -INPUT 4 +INPUT A OUTPUT 1 8 V+ A OUTPUT 1 A -INPUT 2 7 B OUTPUT A -INPUT 2 A +INPUT 3 6 B -INPUT A +INPUT 3 V- 4 5 B +INPUT V- 4 Exposed Pad on Underside 8 V+ 7 B OUTPUT 6 B -INPUT 5 B +INPUT - (*)Connect to exposed pad to V Ver.3 http://www.njr.com/ -1- NJU77230/NJU77231/NJU77232 ■BLOCK DIAGRAM V+ -INPUT OUTPUT +INPUT V- ■PRODUCT NAME INFORMATION NJU77230 F (TE1) Part Number ■ORDERING INFORMATION PART PACKAGE OUTLINE NUMBER NJU77230F SOT-23-5 NJU77230F3 SC-88A NJU77231F SOT-23-5 NJU77231F3 SC-88A NJU77231KG1 DFN6-G1 NJU77232RB1 MSOP8(TVSP8) NJU77232KU1 DFN8-U1 RoHS yes yes yes yes yes yes yes Package Taping Form HALOGENFREE yes yes yes yes yes yes yes TERMINAL FINISH Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi MARKING 1H F1 1J F2 77231 77232 77232 WEIGHT (mg) 15 7.5 15 7.5 3.5 18 5.3 MOQ (pcs) 3,000 3,000 3,000 3,000 3,000 2,000 3,000 ■ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage (1,2) Input Voltage (2) Input Current (3) Differential Input Voltage (1) Output Terminal Input Voltage Power Dissipation(Ta=25℃) (4) SOT-23-5 (4) SC-88A (5) DFN6-G1 (4) MSOP8(TVSP8) (5) DFN8-U1 Junction Temperature Storage Temperature Range SYMBOL + V -V VIN IIN VID Vo PD Tjmax Tstg RATINGS 7 + V - 0.3 to V + 0.3 10 ±7 + V - 0.3 to V + 0.3 (2-layer / 4-layer) 480 / 650 360 / 490 330 / 1200 510 / 680 450 / 1200 +150 - 55 to +150 UNIT V V mA V V mW °C °C (1) Voltage values are limited at 7V. (2) Input voltages outside the supply voltage will be clamped by ESD protection diodes. If the input voltage exceeds the supply voltage, the input current must be limited 10mA or less by using a restriction resistance. (3) Differential voltage is the voltage difference between +INPUT and - INPUT. For supply voltage less than +7V, the absolute maximum rating is equal to the supply voltage. (4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers FR4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers FR4), internal Cu area: 74.2 x 74.2mm (5) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) *For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5 Ver.3 http://www.njr.com/ -2- NJU77230/NJU77231/NJU77232 ■THERMAL CHARACTERISTICS PARAMETER SYMBOL Junction-to-ambient thermal resistance (6) SOT-23-5 (6) SC-88A (7) DFN6-G1 (6) MSOP8(TVSP8) (7) DFN8-U1 Junction-to-Top of package characterization parameter (6) SOT-23-5 (6) SC-88A (7) DFN6-G1 (6) MSOP8(TVSP8) (7) DFN8-U1 VALUE (2-layer / 4-layer) 259 / 193 352 / 256 381 / 106 244 / 185 278 / 107 (2-layer/ 4-layer) 67 / 58 91 / 73 64 / 26 51 / 45 42 / 25 θja ψjt UNIT °C /W °C /W (6) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers FR4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers FR4), internal Cu area: 74.2 x 74.2mm (7) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) *For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) ■POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 2-Layer 700 4-Layer 1400 Power Dissipation PD [mW] Power Dissipation PD [mW] MSOP8(TVSP8) 600 SOT-23-5 500 DFN8-U1(ESON8-U1) 400 SC-88A 300 200 DFN6-G1(ESON6-G1) 100 1200 DFN6-G1(ESON6-G1) DFN8-U1(ESON8-U1) 1000 MSOP8(TVSP8) 800 SOT-23-5 600 400 SC-88A 200 0 0 0 25 50 75 100 125 Ambient Temperature Ta [ºC] 0 150 25 50 75 100 125 Ambient Temperature Ta [ºC] 150 ■RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Single Supply Dual Supply Operating Ambient Temperature Ver.3 SYMBOL + - V -V + V /V Topr RATINGS UNIT +1.8 to +5.5 ±0.9 to ±2.75 - 40 to +125 V http://www.njr.com/ °C -3- NJU77230/NJU77231/NJU77232 ■ELECTRICAL CHARACTERISTICS ●DC CHARACTERISTICS (Unless otherwise specified, V+=3V, V-=0V, RL=OPEN, Ta=25℃) PARAMETER Supply Current (per comparator) SYMBOL TEST CONDITION VID=100mV,Vcom=0V VID=100mV,Vcom=3V VCOM=0V VCOM=3V ISUPPLY MIN. - - - - - - TYP. 6 9 1 1 1 1 MAX. 10 14 6 7 - - UNIT µA µA mV mV pA pA Input Offset Voltage VIO Input Offset Current Input Bias Current Common Mode Input Voltage Range Open-Loop Voltage Gain Common Mode Rejection Ratio IIO IB VICM CMR≥50dB 0 - 3 V Av CMR - 50 100 70 - - dB dB Supply Voltage Rejection Ratio SVR 65 85 - dB High-level Output Voltage Low-level Output Voltage VOH VOL RL=5.1kΩ VICM=0 to 3V VCOM=0V, + V =1.8 to 5.5V ISOURCE=3mA ISINK=3mA 2.7 - 2.8 0.2 - 0.3 V V ●SWITCHING CHARACTERISTICS + - (Unless otherwise specified,V =+3V, V =0V, Ta=25℃, CL=15pF, RL=5.1kΩ) SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT tPLH Overdrive=100mV 780 ns - - tPHL Overdrive =100mV 480 ns - - tTLH Overdrive =100mV 20 ns - - tTHL Overdrive =100mV 11 ns - - PARAMETER Propagation Delay Low to High Propagation Delay High to Low Output Signal Rising Time Output Signal Falling Time ■TIMING WAVEFORM Over Drive INPUT Over Drive V IN V OH OUTPUT V OL 90% 90% 50% 50% 10% 10% tTHL tTLH tPLH Ver.3 http://www.njr.com/ tPHL -4- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS Supply Current per Comparator vs. Supply Voltage V- =0V, VCOM=0V, VID=100mV, RL=OPEN 18 16 14 12 Ta=125ºC Ta=25ºC 10 8 6 4 2 V- =0V, VCOM=V+, VID=100mV, RL=OPEN 20 Supply Current per Comparator [μA] 20 Supply Current per Comparator [μA] Supply Current per Comparator vs. Supply Voltage Ta=-40ºC 0 18 16 14 Ta=25ºC 12 10 8 6 4 Ta=-40ºC 2 0 0 1 2 3 4 5 Supply Voltage V+[V] 6 7 0 Supply Current per Comparator vs. Temperature Supply Current per Comparator [μA] Supply Current per Comparator [μA] 16 14 V+=1.8V V+=3V V+=5.5V 10 8 6 4 2 0 6 7 18 16 V+=1.8V V+=5.5V V+=3V 14 12 10 8 6 4 2 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 20 V- =0V, VID=100mV, RL=OPEN 18 16 14 12 Ta=25ºC Ta=125ºC 10 8 6 4 2 V+=3V, V- =0V, VID=100mV, RL=OPEN 20 Supply Current per Comparator [μA] V+=3V, 0 25 50 75 100 125 150 Ambient Temperature [ºC] Supply Current per Comparator vs. Temperature Supply Current per Comparator vs. Common-Mode Input Voltage Supply Current per Comparator [μA] 2 3 4 5 Supply Voltage V+ [V] V- =0V, VCOM=V+, VID=100mV, RL=OPEN 20 18 12 1 Supply Current per Comparator vs. Temperature V- =0V, VCOM=0V, VID=100mV, RL=OPEN 20 Ta=-40ºC 18 16 14 VCOM=3V 12 10 8 6 4 VCOM=0V 2 VCOM=1.5V 0 0 0 Ver.3 Ta=125ºC 0.5 1 1.5 2 2.5 Common-Mode Input Voltage [V] 3 -50 http://www.njr.com/ -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -5- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS Input Offset Voltage vs. Temperature Input Offset Voltage vs. Temperature V- =0V , VCOM=0V 5 4 3 Input Offset Voltage [mV] 4 Input Offset Voltage [mV] V- =0V , VCOM=V+, 5 V+=5.5V 2 1 0 -1 V+=1.8V V+=3V -2 -3 3 2 V+=1.8V 1 0 -1 -2 -3 -4 -4 -5 -5 -50 -25 -50 0 25 50 75 100 125 150 Ambient Temperature [ºC] -25 Input offset voltage vs. temperature 2 Input Offset Voltage [mV] Input Offset Voltage [mV] V+=3V, V-=0V, VCOM=V+ 3 1 0 -1 -2 -3 2 1 0 -1 -2 -3 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 V- =0V, VCOM=0V 5 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Offset Voltage vs. Supply Voltage Input Offset Voltage vs. Supply Voltage V- =0V, VCOM=V+ 5 4 4 3 Ta=25ºC 2 Input Offset Voltage [mV] Input Offset Voltage [mV] 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input offset voltage vs. temperature V+=3V, V-=0V, VCOM=0V, 3 Ta=125ºC 1 0 -1 -2 Ta=-40ºC -3 3 2 Ta=125ºC 1 0 -1 -2 Ta=25ºC -3 Ta=-40ºC -4 -4 -5 -5 1 Ver.3 V+=5.5V V+=3V 2 3 4 5 Supply Voltage V+ [V] 6 1 http://www.njr.com/ 2 3 4 Supply Voltage V+ [V] 5 6 -6- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage 5 4 4 3 3 2 Ta=125ºC Ta=25ºC 1 0 -1 -2 Ta=-40ºC -3 V+=3V, V- =0V 5 Input Offset Voltage [mV] Input Offset Voltage [mV] Input Offset Voltage vs. Common-Mode Input Voltage V+=1.8V, V- =0V -4 2 Ta=125ºC 1 Ta=25ºC 0 -1 -2 Ta=-40ºC -3 -4 -5 -5 0 0.3 0.6 0.9 1.2 1.5 Common-Mode Input Voltage [V] 1.8 0 0.5 1 1.5 2 2.5 Common-Mode Input Voltage [V] 3 Input Offset Voltage vs. Common-Mode Input Voltage 5 V+=5.5V, V- =0V Input Offset Voltage [mV] 4 3 2 Ta=125ºC 1 0 -1 -2 Ta=25ºC Ta=-40ºC -3 -4 -5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 Common-Mode Input Voltage [V] Ver.3 http://www.njr.com/ -7- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS SVR vs. Temperature 140 V+=3V, V- =0V, RL=5.1kΩ 140 120 Open-Loop Voltage Gain [dB] Supply Voltage Rejection Ratio [dB] Open-Loop Voltage Gain vs. Temperature V+=1.8V to 5.5V, V- =0V, VCOM=0V 100 80 60 40 20 0 120 100 80 60 40 20 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 CMR vs. Temperature 100 Input Bias Current [nA] Common-Mode Rejection Ratio [dB] VCOM=V+/2, V- =0V 100 80 60 40 20 0 10 V+=5.5V 1 V+=3V V+=1.8V 0.1 0.01 0.001 -50 Ver.3 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Bias Current vs. Temperature V+=3V, V- =0V, VICM=0V to 3V 120 -25 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] 25 http://www.njr.com/ 50 75 100 125 Ambient Temperature [ºC] 150 -8- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS Output Voltage vs. Temperature Output Voltage vs. Output Current V+=1.8V, V- =0V, VID=100mV 1.8 ISOURCE 1.6 1.6 Ta=-40ºC VOH 1.4 Output Voltage [V] 1.4 Output Voltage [V] V+=1.8V, V- =0V, VID=100mV, Iout=3mA 1.8 1.2 1 Ta=125ºC Ta=25ºC 0.8 0.6 ISINK 0.4 1.2 1 0.8 0.6 0.4 VOL 0.2 0.2 0 0 0 3 6 9 Output Current [mA] -50 12 -25 Output Voltage vs. Output Current Output Voltage vs. Temperature V+=3V, V- =0V, VID=100mV 3 0 25 50 75 100 125 150 Ambient Temperature [ºC] V+=3V, V-=0V, VID=100mV, Iout=3mA 3 Ta=-40ºC VOH 2.5 Output Voltage [V] Output Voltage [V 2.5 2 1.5 Ta=125ºC Ta=25ºC 1 0.5 2 1.5 1 0.5 VOL 0 0 0 3 6 9 12 15 18 21 24 27 30 Output Current [mA] -50 -25 Output Voltage vs. Output Current 5 4.5 4.5 4 4 Output Voltage [V] Output Voltage [V] 5 3.5 3 Ta=125ºC 2.5 Ta=25ºC V+=5.5V, V- =0V, VID=100mV, Iout=3mA 5.5 Ta=-40ºC 2 1.5 VOH 3.5 3 2.5 2 1.5 1 1 0.5 0.5 VOL 0 0 0 Ver.3 Output Voltage vs. Temperature V+=5.5V, V- =0V, VID=100mV 5.5 0 25 50 75 100 125 150 Ambient Temperature [ºC] 3 6 9 12 15 18 21 24 27 30 Output Current [mA] -50 -25 http://www.njr.com/ 0 25 50 75 100 125 150 Ambient Temperature [ºC] -9- NJU77230/NJU77231/NJU77232 ■TYPICAL CHARACTERISTICS Propagation Delay Low to High vs. Temperature V- =0V, overdrive=100mV, RL=5.1kΩ, CL=15pF V+=5.5V 1.4 1.2 1 V+=3V 0.8 V+=1.8V 0.6 V- =0V, overdrive=100mV, RL=5.1kΩ, CL=15pF 0.7 Propagation Delay High to Low [μs] 1.6 Propagation Delay Low to High [μs] Propagation Delay High to Low vs. Temperature 0.4 0.2 0 V+=5.5V 0.6 0.5 0.4 V+=1.8V 0.3 V+=3V 0.2 0.1 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 Output Signal Rising Time vs. Temperature V+=5.5V 50 40 V+=1.8V 30 20 V+=3V 10 V- =0V, overdrive=100mV, RL=5.1kΩ, CL=15pF 25 Output Signal Falling Time [ns] Output Signal Rising Time [ns] 60 0 20 V+=1.8V 15 V+=5.5V 10 V+=3V 5 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 -25 V+=3V,V- =0V, RL=5.1kΩ, CL=15pF 5 INPUT:0.2V/div Overdrive=50mV Overdrive=20mV 0.6 Overdrive=100mV 0.4 4 0.2 3.5 3 2.5 0 Overdrive=100mV Overdrive=50mV 5 4.5 4 -0.2 3 -0.4 2.5 0 2 1.5 -1 0 -0.5 0 0.5 1 1.5 500ns/div 2 2.5 3 0.2 3.5 -0.8 OUTPUT:0.5V/div 0.4 Overdrive=100mV Overdrive=50mV Overdrive=20mV -0.6 Overdrive=20mV 0.6 INPUT:0.2V/div 2 0.5 Ver.3 V+=3V,V- =0V, RL=5.1kΩ, CL=15pF 1.5 1 0 25 50 75 100 125 150 Ambient Temperature [ºC] Response time(Fall) Response time(Rise) 4.5 0 25 50 75 100 125 150 Ambient Temperature [ºC] Output Signal Falling Time vs. Temperature V- =0V, overdrive=100mV, RL=5.1kΩ, CL=15pF 70 -25 -0.2 Overdrive=100mV Overdrive=50mV Overdrive=20mV -0.4 -0.6 -0.8 1 -1.2 0.5 -1.4 0 -1 -1.2 OUTPUT:0.5V/div -1.4 -0.5 http://www.njr.com/ 0 0.5 1 1.5 500ns/div 2 2.5 3 - 10 - NJU77230/NJU77231/NJU77232 ■TYPICAL TEST CIRCUIT ●Supply Current (ISUPPLY) + ・V =3V,V-=0V,Vcom=0V, VID=100mV + ・V =3V,V-=0V,Vcom=3V, VID=100mV V+ A V ID V COM ●High-level Output Voltage (VOH) + ・V =3V,V-=0V,ISOURCE=3mA,VID=100mV ●Low-level Output Voltage (VOL) + ・V =3V,V-=0V,ISINK=3mA,VID=100mV V+ V+ ISOURCE V V ISINK VID VID ●Propagation Delay (tPLH, tPHL),Output Signal Rising Time (tTLH),Output Signal Falling Time (tTHL) + ・V =3V,V-=0V,VCOM=0V,RL=5.1kΩ,CL=15pF,Over drive=100mV Input Wave Form (Rise Measurement) V+ Over Drive VCOM 100mV V IN VCOM CL Input Wave Form (Fall Measurement) RL 100mV VCOM Over Drive Ver.3 http://www.njr.com/ - 11 - NJU77230/NJU77231/NJU77232 ■APPLICATION NOTE ・Input Voltage Exceeding the Supply Voltage Inputs of the NJU77230/ NJU77231/ NJU77232 are protected by ESD diodes (shown in Figure1) that will conduct if the input voltages exceed the power supplies by more than approximately 300mV. Momentary voltages greater than 300mV beyond the power supply, inputs can be tolerated if the current is limited to 10mA. Figure2 is easily accomplished with an input resistor. If the input voltage exceeds the supply voltage, the input current must be limited 10mA or less by using a restriction resistance (RLIMIT) as shown in figure2. V+ +INPUT OUTPUT -INPUT V- Figure1. Simplified Schematic Current Limit 10mA V+ Vin Vout RLIMIT VFigure2. Input Current Protection for Voltages exceeding the Supply Voltage. ・Bypass Capacitor It is advised to add a bypass capacitor between the supply voltage and ground as close as possible to device. Ver.3 http://www.njr.com/ - 12 - NJU77230/NJU77231/NJU77232 ・ EMIRR(EMI Rejection Ratio) Definition EMIRR is a parameter indicating the EMI robustness of an OP-Amp. The definition of EMIRR is given by the following a formula (1). We can grasp the tolerance of the RF signal by measuring an RF signal and offset voltage shift quantity. EMIRR=20∙log⁡( VRF_PEAK ) |∆VIO | ・・・(1) VRF_PEAK :RF Signal Amplitude [ VP ] ΔVIO :Input offset voltage shift quantity [ V ] Offset voltage shift is small so that a value of EMIRR is big. And it understands that the tolerance for the RF signal is high. In addition, about the input offset voltage shift with the RF signal,there is the thinking that influence applied to the input terminal is dominant. Therefore, generally the EMIRR becomes value that applied an RF signal to +INPUT terminal. EMIRR vs. Frequency V+=3V, V-=0V, VREF=1.5V, VRF_PEAK=100mVPP, 120 EMIRR [dB] 100 80 60 40 20 0 100M 1G Frequency [Hz] 10G Figure3. EMIRR vs. Frequency *For details, refer to " Application Note for EMI Immunity" in our HP: http://www.njr.com/ Ver.3 http://www.njr.com/ - 13 - NJU77230/NJU77231/NJU77232 SOT-23-5 Unit: mm ■PACKAGE DIMENSIONS 2.9 ±0.2 0 ~15 ° 1.9 ±0.2 4 0.6 2.8 ±0.2 1.6 +0.2 -0.1 0.2 5 2 1 3 0.1 0.95 ±0.1 +0.1 -0.03 0.4 ±0.1 0.1 0.1max 1.1 ±0.1 0.6max ■EXAMPLE OF SOLDER PADS DIMENSIONS 2.4 1.0 0.7 0.95 Ver.3 0.95 http://www.njr.com/ - 14 - NJU77230/NJU77231/NJU77232 SC-88A Unit: mm 0.425 ±0.2 ■PACKAGE DIMENSIONS 2.0 ± 0.2 1.3 ± 0.2 5 2 (0.245) 2.1 ±0.2 1.25 ±0.1 0.23 +0.1 -0.03 4 3 0.425 ±0.2 1 0.13 +0.1 -0.05 0 ~ 10 ° +0.05 -0.15 0.95 0.05 ±0.05 0.9 ±0.1 +0.2 0.2 -0.1 0.65 ± 0.07 0.1 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 1.9 0.8 0.3 0.65 Ver.3 0.65 http://www.njr.com/ - 15 - NJU77230/NJU77231/NJU77232 DFN6-G1(ESON6-G1) Unit: mm ■EXAMPLE OF SOLDER PADS DIMENSIONS ■PACKAGE DIMENSIONS 0.10 M 1.28 A S 0.28 0.397 ± 0.030 1.8 0.62 0.10 1.14 S 0.075 +0.01 0.01 -0.008 S M 1.60 ± 0.05 S B 0.31 1.60 ± 0.05 0.05 S A 1.20 +0.06 -0.04 C0 .2 0.5 0.5 0.26 +0.06 -0.04 Ver.3 +0.06 0.21-0.04 3- R0 .2 +0.06 0.68 -0.04 B φ0.05 M S AB http://www.njr.com/ - 16 - NJU77230/NJU77231/NJU77232 MSOP8(TVSP8)MEET JEDEC MO-187-DA/ thin type Unit: mm ■PACKAGE DIMENSIONS 2.9 ±0.1 1 0.55 ±0.1 4.0 ±0.2 5 2.8 ±0.1 8 0 ~10゚ 4 0.127 +0.05 -0.03 0.65 0.08 0.2 ±0.05 0.05 M 0.1 ±0.05 1.0max 0.475 ±0.1 ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3.5 1.0 0.23 1.95 Ver.3 http://www.njr.com/ - 17 - NJU77230/NJU77231/NJU77232 DFN8-U1(ESON8-U1) Unit: mm ■PACKAGE DIMENSIONS ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.28 0.5 2.20 1.02 2.0 ±0.05 0.31 2.0 ±0.05 0.075 0.01 +0.010 -0.008 S 0.397 ±0.03 1.54 1.78 S S 0.05 A 0.21 -0.04 +0.06 1.6 +0.06 -0.04 0.25 C0 .3 3- R0 .3 1.08 -0.04 +0.06 B 0.5 0.26 +0.06 -0.04 Ver.3 φ 0.05 M S AB http://www.njr.com/ - 18 - NJU77230/NJU77231/NJU77232 SOT-23-5 ■ PACKING SPEC Unit: mm TAPING DIMENSIONS SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 Feed direction P0 φD0 T B W1 W F E P2 A P1 K0 φD1 T2 DIMENSION 3.3±0.1 3.2±0.1 1.55 1.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.82 1.5±0.1 8.0±0.3 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1MAX REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.3 http://www.njr.com/ - 19 - NJU77230/NJU77231/NJU77232 SC-88A Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed direction P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A P1 T2 φD1 DIMENSION 2.3±0.1 2.5±0.1 1.55±0.05 1.05±0.05 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.3±0.1 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION φ180±1 φ 60±1 φ 13±0.2 φ 21±0.8 2±0.5 9±0.5 1.2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Drawing direction Empty tape Device attaching tape more than 20pitch 3000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.3 http://www.njr.com/ - 20 - NJU77230/NJU77231/NJU77232 DFN6-G1(ESON6-G1) ■ PACKING SPEC Unit: mm TAPING DIMENSIONS Feed direction φD0 P0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F E P2 A φD1 P1 T2 DIMENSION 1.85±0.05 1.85±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION 0 φ180 -1.5 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel Empty tape Covering tape more than 25 pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.3 http://www.njr.com/ - 21 - NJU77230/NJU77231/NJU77232 MSOP8(TVSP8)MEET JEDEC MO-187-DA/thin type Unit: mm ■PACKING SPEC TAPING DIMENSIONS Feed direction P2 P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 B W1 W F E T A φD1 P1 T2 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 1.75 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 C SYMBOL A B C D E W W1 A B D E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction more than 20pitch Devices 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.3 http://www.njr.com/ - 22 - NJU77230/NJU77231/NJU77232 DFN8-U1(ESON8-U1) Unit: mm ■PACKING SPEC TAPING DIMENSIONS Feed direct ion P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 T B W1 W F E P2 K0 A T2 φ D1 P1 DIMENSION 2.25±0.05 2.25±0.05 1.5 +0.1 0 0.5±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 2.0±0.05 0.25±0.05 1.00±0.07 0.65±0.05 8.0±0.2 5.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E B A D C DIMENSION 0 φ180 -1.5 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 9 +0.3 0 1.2 W TAPING STATE Insert direction Sealing with covering tape (TE3) Feed direction Empty tape Devices more than 40 pitch 3000pcs/reel Empty tape Covering tape more than 25 pitch reel more than 1 round PACKING STATE Label Label Put a reel into a box Ver.3 http://www.njr.com/ - 23 - NJU77230/NJU77231/NJU77232 ■RECOMMENDED MOUNTING METHOD *Recommended reflow soldering procedure f 260℃ e 230℃ 220℃ d 180℃ 150℃ Room Temp. a b a:Temperature ramping rate b:Pre-heating temperature time c:Temperature ramp rate d:220℃ or higher time e:230℃ or higher time f:Peak temperature g:Temperature ramping rate c g : 1 to 4℃/s : 150 to 180℃ : 60 to 120s : 1 to 4℃/s : Shorter than 60s : Shorter than 40s : Lower than 260℃ : 1 to 6℃/s *The temperature indicates at the surface of mold package. ■REVISION HISTORY Ver.3 Date Revision Changes 2016/11/30 Ver.0 First edition 2017/5/24 Ver.1 Added information of NJU77232. 2017/10/12 Ver.2 Changed GENERAL DESCRIPTION and APPLICATION 2017/11/10 Ver.3 Corrected ELECTRICAL CHARACTERISTICS http://www.njr.com/ - 24 - NJU77230/NJU77231/NJU77232 [ CAUTION ] 1. New JRC strives to produce reliable and high quality semiconductors. New JRC's semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of New JRC's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. 3. To ensure the highest levels of reliability, New JRC products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. New JRC offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact New JRC's Sale's Office if you are uncertain about the products listed in this catalog. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in the catalog may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment. Aerospace Equipment Equipment Used in the Deep sea Power Generator Control Equipment (Nuclear, Steam, Hydraulic) Life Maintenance Medical Equipment Fire Alarm/Intruder Detector Vehicle Control Equipment (airplane, railroad, ship, etc.) Various Safety devices 7. New JRC's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this catalog. Failure to employ New JRC products in the proper applications can lead to deterioration, destruction or failure of the products. New JRC shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of its products. Products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. 8. Warning for handling Gallium and Arsenic(GaAs) Products (Applying to GaAs MMIC, Photo Reflector). This Products uses Gallium(Ga) and Arsenic(As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed, please follow the related regulation and do not mix this with general industrial waste or household waste. 9. The product specifications and descriptions listed in this catalog are subject to change at any time, without notice. Ver.3 http://www.njr.com/ - 25 -
NJU77232RB1-TE1 价格&库存
很抱歉,暂时无法提供与“NJU77232RB1-TE1”相匹配的价格&库存,您可以联系我们找货
