PL9121
PL9121
    INRCORE
    固定电感器 Nonstandard 120µH ±20% 1.3A 253mΩ
PL9121 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL91XX Series Ruggedized Height: 0.248 inches (6.3mm) Max Footprint: 0.413 inches x 0.413 inches (10.5mm x 10.5mm) Max Inductance Range: 0.96µH to 879µH Current Rating: up to 10.5A Moisture Sensitivity Level: 1 Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C Part Numbers PL9101 PL9102 PL9103 PL9104 PL9105 PL9106 PL9107 PL9108 PL9109 PL9110 PL9111 PL9112 PL9113 PL9114 PL9115 PL9116 PL9117 PL9118 PL9119 PL9120 PL9121 PL9122 PL9123 PL9124 PL9125 PL9126 PL9127 PL9128 PL9129 PL9130 PL9131 PL9132 Inductance @Irated (µH TYP) Irated2(A) 0.96 1.52 2.34 3.27 4.39 5.54 6.73 8.19 9.90 13.4 15.4 17.6 22.5 28.5 31.4 38.4 48.3 55.9 67.6 86.1 103 121 149 186 224 279 335 398 464 563 681 879 10.5 9.5 7.8 6.7 5.6 5.2 5.0 4.6 4.2 3.6 3.4 3.2 2.8 2.5 2.4 2.2 1.9 1.8 1.7 1.4 1.3 1.2 1.1 1.00 0.91 0.82 0.72 0.68 0.63 0.57 0.52 0.46 Inductance DCR (mΩ) TYP 3.2 3.9 5.5 7.7 11 12.6 14 16 20 22 31 35 47 53 55 76 87 95 133 175 192 216 242 318 370 520 571 638 844 943 1054 1418 MAX 4.5 5.5 7.8 11 15.6 18 20 22 27 30 40 45 62 70 75 100 110 120 178 230 253 280 310 400 460 690 760 850 1060 1200 1550 1750 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9101 becomes PL9101T). Saturation3 Heating4Current Current @0ADC (µH) (A) @25°C (A) 1.0* 1.8* 2.7* 3.9* 5.1* 6.8* 8.2* 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 12.7 10.1 8.4 7.2 6.3 5.6 5.1 4.6 4.2 3.6 3.4 3.2 2.8 2.5 2.4 2.2 1.9 1.8 1.7 1.4 1.3 1.2 1.1 1.0 0.91 0.82 0.72 0.68 0.63 0.57 0.52 0.46 10.5 9.5 7.8 6.7 5.6 5.2 5 4.8 4.3 4 3.4 3.2 2.8 2.6 2.5 2.2 2.1 2 1.7 1.5 1.4 1.3 1.2 1.05 0.96 0.84 0.8 0.77 0.66 0.63 0.6 0.5 NOTES FROM TABLE: (See back page) Electrical Schematic Mechanical .004/0.10MAX .413[10.50] MAX NOTE: Pin 3 and Pin 4 are for mechanical connection only. 1 .421 [10.70] TYP .287 .142 [7.30] [3.60] TYP TYP .248[6.30] MAX www.inrcore.com .287[7.30]TYP .421[10.70] TYP M121. E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL91XX Series Ruggedized Notes for tables: 4. The heating current is the DC current, which causes the temperature of the part to increase 1. Temperature of the component (ambient plus temperature rise) must be by approximately 40°C. This current is determined by extending the within specified operating temperature range. terminals of the component with 30mm length 28 gauge buss wires and 2. The rated current as listed is either the saturation current or the heating applying the current to the device for 30 minutes. The temperature is current depending on which value is lower. measured by placing the thermo-couple between the winding and the 3. The saturation current is the current which causes the inductance to drop shield. to 75% of its initial inductance at zero bias. This current is determined 5. In high volt*time applications, additional heating in the component can by placing the component at room ambient (25°C), and applying a occur due to core losses in the inductor which may necessitate derating short duration pulse current (to eliminate self-heating effects) to the the current in order to limit the temperature rise of the compo-nent. In component. order to determine the approximate total loss (or temperature rise) for a given application, both copper losses and core losses should be taken into account. 2 www.inrcore.com M121. E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL91XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M121. E (07/20)
PL9121 价格&库存
很抱歉,暂时无法提供与“PL9121”相匹配的价格&库存,您可以联系我们找货
