Technical Data 4147
Effective April 2016
Supersedes March 2007
DR1040
Shielded power inductors
Applications
LED/LCD backlighting
High definition televisions (HDTV)
Server and desktop power supplies
Portable electronics
Graphics cards and battery powered systems
Point-of-load (POL) modules
Printers and peripherals
Environmental Data
Description
Shielded drum core
Inductance range from 1.4 μH to 323 μH
Current range from 0.52 A to 10 A
10.5 mm x 10.3 mm footprint surface mount
package in a 4.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
DR1040
Technical Data 4147
Product Specifications
OCL1
(μH) ±30%
Irms2
(A)
Isat2
(A)
DCR (mΩ)
typical
@ 20°C
DCR (mΩ)
maximum
@ 20°C
K-factor4
DR1040-1R5-R
1.35
6.5
10
6.0
8.1
15.5
DR1040-2R5-R
2.4
6.1
7.8
7.0
9.0
12.0
DR1040-3R8-R
3.6
5.5
6.4
9.6
13
9.9
DR1040-5R2-R
5.2
5.4
5.5
14
17
8.3
DR1040-7R0-R
6.8
4.5
4.8
17
DR1040-8R2-R
8.1
3.98
4.6
24
29
6.4
DR1040-100-R
9.6
3.8
4.4
26
35
5.7
DR1040-150-R
14.9
3.1
3.6
37
50
4.7
DR1040-220-R
21.1 ±20%
2.5
2.9
54
73
4.0
DR1040-330-R
32.6
2.2
2.45
69
93
3.3
DR1040-470-R
45.8
1.9
2.1
95
128
2.8
DR1040-680-R
65.3
1.42
1.65
152
183
2.3
DR1040-820-R
87
1.29
1.47
214
260
2.0
DR1040-101-R
101
1.25
1.35
225
304
1.9
DR1040-151-R
148
0.85
1.15
356
430
1.6
DR1040-221-R
216
0.70
0.92
530
640
1.3
DR1040-331-R
323
0.52
0.70
810
1090
1.0
Part Number
5
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 ºC
2. Irms: DC current for an approximate temperature rise of 30 ºC without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125 ºC under worst case operating
conditions verified in the end application.
3. Isat: Peak current for approximately 35% rolloff @ +25 ºC
4. K-factor: K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (mT), K:
(K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps)..
5. Part Number Definition: DR1040-xxx-R
DR1040 = Product code and size
-xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: inductance value in uH. R = decimal point. If no R is present then last character equals number of zeroes.
wwlly = date code, R = revision level
Do not route traces or vias underneath the inductor
2
www.eaton.com/elx
DR1040
Technical Data 4147
Packaging information (mm)
Supplied in tape and reel packaging , 850 parts per 13” diameter reel
Temperature rise vs. total loss
Temperature Rise ( )
120
100
80
60
40
0.4
0.6
0.8
1
1.2
Total Loss (W)
www.eaton.com/elx
3
DR1040
Technical Data 4147
Core loss vs. Bp-p
1 MHz
10
500 kHz
300 kHz
200 kHz
100 kHz
Core Loss (W)
1
0.1
0.01
0.001
1
10
Bp-p (mT)
100
1000
Inductance characteristics
%OCL vs. Isat
120%
100%
% of OCL
80%
60%
40%
-40 °C
+25 °C
+85 °C
20%
0%
0%
20%
40%
60%
80%
% of Isat
4
www.eaton.com/elx
100%
120%
140%
160%
DR1040
Technical Data 4147
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“DR1040-820-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 850+4.79691850+0.62037
- 1700+4.552261700+0.58873
- 2550+4.438672550+0.57404
- 4250+4.281394250+0.55370
- 5950+4.194025950+0.54240
- 8500+4.106648500+0.53110
- 21250+3.9056821250+0.50511
- 国内价格
- 850+4.45462
- 1700+4.23183
- 2550+4.12043
- 4250+3.98149
- 5950+3.89764
- 8500+3.81380
- 21250+3.62814
