SMT POWER INDUCTORS
Shielded Drum Core - PL91XX Series
Ruggedized
Height: 0.248 inches (6.3mm) Max
Footprint: 0.413 inches x 0.413 inches (10.5mm x 10.5mm) Max
Inductance Range: 0.96µH to 879µH
Current Rating: up to 10.5A
Moisture Sensitivity Level: 1
Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C
Part
Numbers
PL9101
PL9102
PL9103
PL9104
PL9105
PL9106
PL9107
PL9108
PL9109
PL9110
PL9111
PL9112
PL9113
PL9114
PL9115
PL9116
PL9117
PL9118
PL9119
PL9120
PL9121
PL9122
PL9123
PL9124
PL9125
PL9126
PL9127
PL9128
PL9129
PL9130
PL9131
PL9132
Inductance
@Irated
(µH TYP)
Irated2(A)
0.96
1.52
2.34
3.27
4.39
5.54
6.73
8.19
9.90
13.4
15.4
17.6
22.5
28.5
31.4
38.4
48.3
55.9
67.6
86.1
103
121
149
186
224
279
335
398
464
563
681
879
10.5
9.5
7.8
6.7
5.6
5.2
5.0
4.6
4.2
3.6
3.4
3.2
2.8
2.5
2.4
2.2
1.9
1.8
1.7
1.4
1.3
1.2
1.1
1.00
0.91
0.82
0.72
0.68
0.63
0.57
0.52
0.46
Inductance
DCR (mΩ)
TYP
3.2
3.9
5.5
7.7
11
12.6
14
16
31
35
47
53
55
76
87
95
133
175
192
216
242
318
370
520
571
638
844
943
1054
1418
MAX
4.5
5.5
7.8
11
15.6
18
27
30
40
45
62
70
75
100
110
120
178
230
253
280
310
400
460
690
760
850
1060
1200
1550
1750
*Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts.
Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9101 becomes PL9101T).
Saturation3
Heating4Current
Current
@0ADC
(µH) (A) @25°C
(A)
1.0*
1.8*
2.7*
3.9*
5.1*
6.8*
8.2*
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1000
12.7
10.1
8.4
7.2
6.3
5.6
5.1
4.6
4.2
3.6
3.4
3.2
2.8
2.5
2.4
2.2
1.9
1.8
1.7
1.4
1.3
1.2
1.1
1.0
0.91
0.82
0.72
0.68
0.63
0.57
0.52
0.46
10.5
9.5
7.8
6.7
5.6
5.2
5
4.8
4.3
4
3.4
3.2
2.8
2.6
2.5
2.2
2.1
2
1.7
1.5
1.4
1.3
1.2
1.05
0.96
0.84
0.8
0.77
0.66
0.63
0.6
0.5
NOTES FROM TABLE: (See back page)
Electrical Schematic
Mechanical
.004/0.10MAX
.413[10.50]
MAX
NOTE: Pin 3 and Pin 4 are for
mechanical connection only.
1
.421
[10.70]
TYP
.287 .142
[7.30] [3.60]
TYP TYP
.248[6.30]
MAX
www.inrcore.com
.287[7.30]TYP
.421[10.70] TYP
M121. E (07/20)
SMT POWER INDUCTORS
Ruggedized
Notes for tables:
4. The heating current is the DC current, which causes the temperature of
the part to increase
1. Temperature of the component (ambient plus temperature rise) must be by approximately 40°C. This current is determined by extending the
within specified operating temperature range.
terminals of the component with 30mm length 28 gauge buss wires and
2. The rated current as listed is either the saturation current or the heating
applying the current to the device for 30 minutes. The temperature is
current depending on which value is lower.
measured by placing the thermo-couple between the winding and the
3. The saturation current is the current which causes the inductance to drop shield.
to 75% of its initial inductance at zero bias. This current is determined 5. In high volt*time applications, additional heating in the component can
by placing the component at room ambient (25°C), and applying a
occur due to core losses in the inductor which may necessitate derating
short duration pulse current (to eliminate self-heating effects) to the
the current in order to limit the temperature rise of the compo-nent. In
component.
order to determine the approximate total loss (or temperature rise) for a
given application, both copper losses and core losses should be taken into
account.
2
www.inrcore.com
M121. E (07/20)
SMT POWER INDUCTORS
Ruggedized
For More Information
Global Sales Representatives and Lo cations:
http://www.inrcore.com
iNRCORE,LLC
311 Sinclair Road Bristol,
PA 19007-6812 U.S.A
Tel: + 1.215.781.6400
Fax: +1.215.7816430
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names
mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved.
3
www.inrcore.com
M121. E (07/20)
很抱歉,暂时无法提供与“PL9132”相匹配的价格&库存,您可以联系我们找货
