SCB75F-151
SCB75F-151
    SIGNAL
    非标准
    固定电感器 Nonstandard 150µH ±10% 680mA 900mΩ
SCB75F-151 数据手册
SCB75F SMD POWER INDUCTORS XXX MARKING ● Features DC Resistance (Ω MAX) (2) (1) 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 23m 28m 32m 38m 49m 60m 70m 80m 90m 0.10 0.12 0.14 0.18 0.21 0.25 0.29 0.34 0.46 0.55 0.67 0.90 1.05 1.35 1.55 2.05 2.30 2.60 2.88 2.56 2.36 2.16 1.88 1.68 1.56 1.44 1.36 1.28 1.17 1.07 1.00 0.91 0.84 0.72 0.66 0.58 0.51 0.42 0.37 0.35 0.29 0.28 0.23 0.215 0.195 BS 1.0 1.5 2.2 3.3 4.7 6.8 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 O SCB75F-1R0 SCB75F-1R5 SCB75F-2R2 SCB75F-3R3 SCB75F-4R7 SCB75F-6R8 SCB75F-100 SCB75F-120 SCB75F-150 SCB75F-180 SCB75F-220 SCB75F-270 SCB75F-330 SCB75F-390 SCB75F-470 SCB75F-560 SCB75F-680 SCB75F-820 SCB75F-101 SCB75F-121 SCB75F-151 SCB75F-181 SCB75F-221 SCB75F-271 SCB75F-331 SCB75F-391 SCB75F-471 Saturation Temperature (3) (4) Current Current (A) (A) 5.50 5.00 4.20 3.80 3.50 3.24 2.70 2.50 2.30 2.10 1.90 1.70 1.55 1.40 1.30 1.22 1.14 1.00 0.85 0.78 0.68 0.60 0.50 0.47 0.44 0.41 0.38 SCB75F decrease bycur current BCB75F I Inductance nduct ance decr ease by r ent 1000 471 Inductance (µH)uH) I nduct ance( Inductance Test (uH) Frequency O Part Number 100 390 10 1 0. 1 10 100 1R0 100000 10000 1000 DC cur r ent (mA) ( mA) DC current BCB75F Temper Temperature at ur e r i se byrise cur by r entcurrent SCB75F Temperature Tem per at ur eriser i°C se ℃ ELECTRICAL CHARACTERISTICS LE TE 1. Open frame construction 2 Excellent Power Density 3 Engineered to Provide High Efficiency 80 70 471 60 390 50 1R0 40 30 20 10 0 1000 2000 3000 4000 5000 6000 7000 8000 9000 DC cur ent ( m(mA) A) DCrcurrent (1). Inductance tolerance for 1.0uH~3.3uH: ±30%, for 4.7uH~100uH: ±20%, for 120uH~470uH: ±10%. Tested at 0.25V, 0ADC and 25℃. (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 10% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 96 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCB75F-151
1. 物料型号:文档列出了多种型号的SCB75F电感器,包括1.0uH至470uH的不同电感值。
2. 器件简介:电感器采用开放式框架结构,具有出色的功率密度和高效率。
3. 引脚分配:文档没有明确提供引脚分配信息,但通常SMD电感器有明确的引脚定义用于电路连接。
4. 参数特性:提供了电感器的电气特性,包括电感值、测试频率、最大直流电阻(DCR)、饱和电流和在特定条件下的电流和温度特性。
5. 功能详解:文档中包含了电感值随直流电流变化的图表,以及电感器随电流变化导致的温度上升图表。
6. 应用信息:文档提到可以根据请求提供定制版本,但没有具体说明应用领域。
7. 封装信息:文档没有提供详细的封装信息,但提到了“QUANTITY PER REEL & PACKING INFORMATION”,暗示了包装和卷装数量信息的可用性。
8. 其他:文档最后提供了制造商Signal Transformer的联系信息,包括地址、免费电话、电话、传真以及电子邮件地址。
SCB75F-151 价格&库存
很抱歉,暂时无法提供与“SCB75F-151”相匹配的价格&库存,您可以联系我们找货
