SCRH104-181
SCRH104-181
    SIGNAL
    非标准
    固定电感器 Nonstandard 180µH ±20% 720mA 840mΩ
SCRH104-181 数据手册
SCRH104 SMD POWER INDUCTORS XXX MARKING ● Features 1. Magnetically shielded construction 2 Excellent Power Density 3 Engineered to Provide High Efficiency ELECTRICAL CHARACTERISTICS (2) (1) SCRH104-1R0 SCRH104-1R5 SCRH104-2R2 SCRH104-3R3 SCRH104-4R7 SCRH104-6R8 SCRH104-100 SCRH104-120 SCRH104-150 SCRH104-180 SCRH104-220 SCRH104-270 SCRH104-330 SCRH104-390 SCRH104-470 SCRH104-560 SCRH104-680 SCRH104-820 SCRH104-101 SCRH104-121 SCRH104-151 SCRH104-181 SCRH104-221 SCRH104-271 SCRH104-331 SCRH104-391 SCRH104-471 1.0 1.5 2.2 3.3 4.7 6.8 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 DC Resistance (Ω MAX) 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 100KHZ 14m 17m 24m 29m 32m 44m 50m 54m 69m 84m 94m 0.11 0.15 0.17 0.21 0.23 0.29 0.36 0.41 0.45 0.64 0.84 0.86 1.07 1.37 1.55 1.74 Saturation(3) Temperature (4) Current Current (A) (A) 8.50 8.00 7.50 7.00 6.00 5.00 2.40 2.25 2.00 1.80 1.65 1.45 1.35 1.20 1.10 1.00 0.93 0.84 0.76 0.70 0.63 0.57 0.52 0.47 0.43 0.39 0.36 7.00 5.80 5.20 4.68 4.22 3.60 3.40 3.00 2.70 2.40 2.16 1.95 1.76 1.59 1.52 1.40 1.17 1.06 0.96 0.87 0.79 0.72 0.65 0.59 0.54 0.49 0.44 SCRH104 decrease BCRH104 I Inductance nduct ance decr ease bybycurcurrent r ent 1000 I nduct ance( Inductance (µH)uH) Inductance Test (uH) Frequency 471 100 470 10 1 1R0 0. 1 10 100 10000 1000 100000 DC curcurrent r ent ( m(mA) A) DC SCRH104 Temperature rise BCRH104 Tem per at ur e r i se byby curcurrent r ent Temperature riser °C Tem per at ur e i se ℃ Part Number 80 70 60 471 50 470 1R0 40 30 20 10 0 1000 2000 3000 4000 5000 6000 DC DC cur current r ent ( m A) (mA) 7000 8000 9000 (1). Inductance tolerance for 1.0uH~6.8uH: ±30%, for 10uH~470uH: ±20%. Tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 25% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 125 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCRH104-181
物料型号:SCRH104 器件简介:SMD POWER INDUCTORS(表面贴装功率电感器) 引脚分配:文档中未提供引脚分配信息 参数特性:包括电感值、测试频率、最大直流电阻、饱和电流和温度上升电流等 功能详解:文档中未提供功能详解 应用信息:文档中未提供应用信息 封装信息:文档中未提供封装信息
具体参数特性如下: - 电感值范围:1.0uH至470uH - 测试频率:100kHz - 最大直流电阻:14mΩ至0.41Ω - 饱和电流:8.50A至0.36A - 温度上升电流:7.00A至0.84A
SCRH104-181 价格&库存
很抱歉,暂时无法提供与“SCRH104-181”相匹配的价格&库存,您可以联系我们找货
