Technical Data 4111
Effective August 2017
Supersedes March 2007
UP2C
UNI-PAC™ drum core power inductors
Applications
Desktop computer
Workstations/servers
DVD Players
Portable power devices
Base stations
Industrial power supplies
Output filter chokes
Test equipment instrumentation
Environmental data
Product features
Miniature surface mount design with rugged
case to eliminate core breakage
Inductance range from 0.470 uH to 1000 uH
Current range up to 18.6 A peak
Meets UL94V-0 flammability standard
Ferrite core material
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Technical Data 4111
UP2C
Product specifications
Part
Number
Inductance
µH
(rated)
0.470
1.0
1.5
2.2
3.3
4.7
6.8
10.0
15.0
22.0
33.0
47.0
68.0
100.0
150.0
220.0
330.0
470.0
680.0
1000.0
UP2C-R47-R
UP2C-1R0-R
UP2C-1R5-R
UP2C-2R2-R
UP2C-3R3-R
UP2C-4R7-R
UP2C-6R8-R
UP2C-100-R
UP2C-150-R
UP2C-220-R
UP2C-330-R
UP2C-470-R
UP2C-680-R
UP2C-101-R
UP2C-151-R
UP2C-221-R
UP2C-331-R
UP2C-471-R
UP2C-681-R
UP2C-102-R
OCL(1)
µH±20%
I RMS(2)
(A)
I SAT(3)
(A)
0.48
1.03
1.45
2.00
3.30
4.41
7.16
10.56
15.97
22.33
32.11
47.90
65.03
97.85
141.9
207.8
318.2
470.8
689.7
1080.0
12.2
9.80
8.10
7.50
5.90
5.62
4.42
3.61
3.17
2.61
2.16
1.77
1.57
1.26
1.04
0.82
0.67
0.56
0.46
0.38
18.6
11.8
10.0
8.67
6.84
6.20
4.82
3.94
3.17
2.65
2.20
1.83
1.53
1.24
1.02
0.85
0.70
0.58
0.48
0.40
DCR(4)
mΩ
typ.
2.5
3.9
5.6
6.6
10.5
11.7
18.0
28.3
36.9
54.0
79.7
118.5
151.7
233.1
351.4
545.0
824.3
1191.4
1774.2
2657.1
Volts(5)
µs
(typ)
4.15
7.0
8.3
9.6
12.1
13.4
17.3
21.1
26.2
31.3
37.7
45.4
54.3
67.1
81.2
97.8
120
144
173
209
(4) DCR limits +20 °C.
(5) Applied volt-time product (V-us) across the inductor. This value
represents the applied v-us at 300 kHz necessary to generate a core
loss equal to 10% of the total losses for a 40 °C temperature rise.
Notes: (1) Open Circuit Inductance Test Parameters: 100 kHz, .250 Vrms, 0.0 Adc.
(2) RMS current for an approximate ∆T of 40 °C without core loss, at an
ambient temperature of +85 ˚C.
(3) Peak current for approximately 30% rolloff @ +20 °C.
Dimensions-mm
TOP VIEW
FRONT VIEW
PCB PAD LAYOUT
5.2
12.90
Max.
1
UP2C
xxx
wwllyy R
SIDE VIEW
1
SCHEMATIC
7.37
2.79
3.0ref
9.40
Max.
2.92
2
2
COMPONENT VIEW
2.5max*
see note A
(A) 2.5mm max is width of copper at seating plane. The width above the seating
plane may exceed 2.5mm.
Dimensions in Millimeters.
wwllyy = (date code) R = revision level
xxx = Inductance value per family chart
Do not route traces or vias underneath the inductor
Packaging information-mm
4.0
1.5 dia
+0.1/-0.0
2.0
1.5 dia
min
A
1.7
1
11.5
24.0
+/-0.3
B0
ACTUAL SIZE
UNIPAC 2C
2
Ao=9.50mm
Bo=13.0mm
Ko=5.7mm
2
K0
SECTION A-A
www.eaton.com/electronics
A
A0
12.0
User direction of feed
Supplied in tape and reel packaging, 900 parts per reel
UP2C
Technical Data 4111
Inductance characteristics
Core loss
I RMS DERATING WITH CORE LOSS
50
60
70
Hz
10
0K
50
0K
Hz
30
0K
Hz
0K
Hz
Hz
80
1M
% of Losses from Irms (maximum)
92
94
95
96
97
98
99
10
40
50 60
80
100
200
300
400 500 600
800 1000
% of Applied Volt-µ-seconds
3
UP2C
Technical Data 4111
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4111
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“UP2C-2R2-R”相匹配的价格&库存,您可以联系我们找货
