Technical Data 4128
Effective August 2017
Supersedes March 2007
SD3114
Low profile metalized shielded drum core power inductors
Applications
SMD Device
Environmental data
Product features
3.1 mm x 3.1 mm x 1.4 mm shielded drum core
Ferrite core material
Inductance range from 1.0 uH to 330 uH
Current range from 2.59 A to 0.106 A
Frequency range up to 4 MHz
Mobile phones,
Digital cameras
Media players
Small LCD displays
LED driver and LED flash circuits
Hard disk drives
LCD Backlighting
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
SD3114
Technical Data 4128
Product specifications
Part Number
SD3114-1R0-R
SD3114-1R5-R
SD3114-2R2-R
SD3114-3R3-R
SD3114-4R7-R
SD3114-6R8-R
SD3114-8R2-R
SD3114-100-R
SD3114-150-R
SD3114-220-R
SD3114-330-R
SD3114-470-R
SD3114-680-R
SD3114-820-R
SD3114-101-R
SD3114-151-R
SD3114-221-R
SD3114-331-R
Rated
Inductance
(µH)
1.0
1.5
2.2
3.3
4.7
6.8
8.2
10.0
15.0
22.0
33.0
47.0
68.0
82.0
100.0
150.0
220.0
330.0
OCL (1)
(µH)
Part
Marking
Designator
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
1.16+/-30%
1.44+/-30%
2.12+/-30%
3.36+/-30%
4.90+/-30%
6.72+/-30%
8.10+/-30%
10.4+/-30%
14.9+/-20%
22.5+/-20%
33.1+/-20%
47.5+/-20%
68.6+/-20%
81.8+/-20%
101.1+/-20%
149.0+/-20%
220.9+/-20%
329.5+/-20%
(1) Open Circuit Inductance Test Parameters: 100 kHz, 0.1Vrms, 0.0 Adc.
(2) Irms: DC current for an approximate DT of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and
proximity of other heat generating components will affect the temperature rise. It
is recommended that the temperature of the part not exceed +125 °C under
worst case operating conditions verified in the end application.
Irms (2)
(A)
Isat (3)
(A)
1.60
1.39
1.17
0.95
0.77
0.71
0.68
0.57
0.48
0.43
0.35
0.280
0.239
0.227
0.213
0.172
0.140
0.113
2.35
2.11
1.74
1.38
1.14
0.98
0.89
0.78
0.66
0.53
0.44
0.37
0.305
0.280
0.252
0.207
0.170
0.139
DCR (Ω)
typ. @
+20 °C
0.058
0.077
0.110
0.167
0.251
0.296
0.329
0.458
0.650
0.821
1.23
1.86
2.62
2.91
3.30
5.07
7.67
11.78
K-factor
(4)
98
79
67
54
45
37
34
30
25
21
17
14
12
11
10
8
6
5
(3) Isat Amperes peak for approximately 30% rolloff (@ +20 °C)
(4) K-factor: Used to determine B p-p for core loss (see graph).
B p-p = K*L*∆I, B p-p(mT), K: (K factor from table), L: (Inductance in uH),
∆(Peak to peak ripple current in Amps).
Dimensions- mm
BOTTOM VIEW
TOP VIEW
RECOMMENDED PCB LAYOUT
2.40
Pin #1 indicator
3.1 max.
1.40
Marking
3.7 max
XX X
0.70
3.1 max.
1.2 typical
SCHEMATI C
1
SIDE VIEW
1.4 max
2
Part Marking:
3 Digit Marking: (1st digit: Indicates inductance value per letter in Part Marking Designator); (2nd digit: Bi-weekly production date code); (3rd digit: Last digit of the year produced).
Do not route traces or vias underneath the inductor
Packaging information- mm
Parts packaged on 13" Diameter reel,
4,100 parts per reel.
1.2 Dia
min.
1.5 Dia.
+0.1/-0.0
2.00 ¡À
1.75
A
Bo
1
B1
10.25
5.50
2
3.2
3.2
A
A1
Ao
8.0
A o = 3.9 mm
A 1 = 0.93 mm
Bo = 3.60 mm
B1 = 1.25 mm
K o = 1.60 mm
2
www.eaton.com/electronics
Direction of feed
12.0
+/-0.3
SD3114
Technical Data 4128
Temperature rise vs total loss loss
Temp. Rise (° C)
90
80
70
60
50
40
30
0. 1
0. 15
0. 2
0. 25
0. 3
0. 35
0. 4
0. 45
Total Loss (W)
Core loss vs Bp-p
10
1 MH z
1
50 0kH z
3 00 k H z
20 0kH z
0 .1
C ore Lo ss (W)
10 0kH z
5 0kH z
0 .01
0.0 01
0 .00 01
0 .000 01
0.0 000 01
1
10
10 0
10 0 0
B p-p (mT )
Inductance characteristics
OCL vs. Isat
120%
110%
100%
90%
% of L initial
80%
70%
-40°C
60%
50%
25°C
40%
30%
85°C
20%
10%
0%
0%
10%
20%
30%
40%
50%
60%
70%
80%
90%
100% 110% 120% 130%
3
SD3114
Technical Data 4128
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Compan . Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant inju y to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4128
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD3114-4R7-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4100+15.985794100+2.07740
- 国内价格 香港价格
- 1+26.108821+3.39291
- 10+21.4672610+2.78973
- 100+17.65364100+2.29414
- 1000+16.080691000+2.08973
