SL52B THRU SL510B
Reverse Voltage - 20 to 100 Volts
Forward Current - 5.0 Ampere
LOW FORWARD VOLTAGE SCHOTTKY BARRIER DIODES
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.155(3.95)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.05)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.098(2.45)
0.080(2.00)
0.062(1.55)
0.030(0.75)
0.008(0.203)MAX.
Mechanical Data
0.224(5.60)
0.196(4.90)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003ounce, 0.093 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
SL52B
MDD
SL53B
MDD
SL54B
MDD
SL55B
MDD
SL56B
VRRM
21
30
40
28
40
50
35
50
60
42
60
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=90℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
VRMS
VDC
V
V
V
A
IFSM
100
A
Maximum DC reverse current
at rated DCblocking voltage
IR
Typical thermal resistance (NOTE 3)
100
70
100
5.0
VF
Typical junction capacitance (NOTE 2)
80
56
80
UNITS
I(AV)
Maximum instantaneous forward voltage at 5.0A
TA=25℃
TA=125℃
MDD
MDD
SL58B SL510B
0.45
0.50
0.5
20.0
0.70
V
0.2
10.0
mA
CJ
200
pF
RJA
68.0
℃/W
-55 to +150
Operating junction and storage temperature range TJ,TSTG
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2025A3
Page :1
SL52B THRU SL510B
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
1.0
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
80
60
40
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SL52B-SL54B
SL55B-SL56B
SL58B-SL510B
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.9
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2025A3
Page :2
SL52B THRU SL510B
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
340*350*40
330
CARTON
SIZE
(mm)
370*370*370
CARTON
(pcs)
48 ,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2025A3
Page :3
很抱歉,暂时无法提供与“SL54B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.21669
- 10+0.94784
- 30+0.83276
- 100+0.68896
- 600+0.62499
- 1200+0.58663
