2SC4226
NPN Silicon Epitaxial Planar Transistor
FEATURES
z
Low noise.
z
High gain.
z
Power dissipation.(PC=150mW)
APPLICATIONS
z
High frequency low noise amplifier.
SOT-323
ORDERING INFORMATION
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Symbol
Parameter
Value
Units
VCBO
Collector-Base Voltage
V
VCEO
Collector-Emitter Voltage
12
V
VEBO
Emitter-Base Voltage
3
V
IC
Collector Current -Continuous
100
mA
PC
Collector Dissipation
150
mW
Tj,Tstg
Junction and Storage Temperature
-65 to +150
www.slkormicro.com
1
2SC4226
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Symbol
Test conditions
MIN
Collector-base breakdown voltage
V(BR)CBO
IC=100μA,IE=0
V
Collector-emitter breakdown
voltage
V(BR)CEO
IC=1mA,IB=0
12
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100μA,IC=0
3
V
Collector cut-off current
ICBO
VCB=10V,IE=0
1.0
μA
Emitter cut-off current
IEBO
VEB=1V,IC=0
1.0
μA
DC current gain
hFE
VCE=3V,IC=7mA
Feed back capacitance
Cre
VCE=3V,IE=0mA,f=1MHz
Transition frequency
fT
VCE=3V, IE=7mA
Noise Figure
NF
VCE=3V,IC=7mA,f=1GHz
40
3.0
TYP
MAX
110
250
0.7
1.5
4.5
1.2
hFE
2.5
R23
R24
R25
40-80
70-140
125-250
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
www.slkormicro.com
2
pF
GHz
CLASSIFICANTION OF hFE
Marking
UNIT
dB
2SC4226
www.slkormicro.com
3
2SC4226
PACKAGE OUTLINE
Plastic surface mounted package
SOT-323
Dim
Min
Max
A
1.8
2.2
B
1.15
1.35
C
1.0Typical
D
0.15
0.35
E
0.25
0.40
G
1.2
1.4
H
0.02
0.1
J
K
0.1Typical
2.2
2.4
All Dimensions in mm
www.slkormicro.com
4
很抱歉,暂时无法提供与“2SC4226 R24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28383
- 100+0.22681
- 600+0.19830
- 1200+0.19533
- 3000+0.17691
