PL9409T
PL9409T
    INRCORE
    SMD-4P,10.4x10.4mm
    固定电感器 Nonstandard 10µH ±20% 2.7A 42.9mΩ
PL9409T 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL94XX Series Ruggedized Height: 0.132 inches (3.35mm) Max Footprint: 0.410 inches x 0.410 inches (10.4mm x 10.4mm) Max Inductance Range: 0.67µH to 325µH Current Rating: up to 7.00A Moisture Sensitivity Level: 1 Part Numbers PL9401 PL9402 PL9403 PL9404 PL9405 PL9406 PL9407 PL9408 PL9409 PL9410 PL9411 PL9412 PL9413 PL9414 PL9415 PL9416 PL9417 PL9418 PL9419 PL9420 PL9421 PL9422 Electrical Specifications @ 25 °C — Operating Inductance Irated 2 DCR (mΩ) @Irated (A) TYP (µH TYP) 0.67 7.00 3.4 1.3 6.10 4.9 2.1 5.70 8.0 3.1 4.80 12.0 4.5 4.10 16.3 5.8 3.60 19.4 7.0 3.30 21.4 9.4 3.00 30.4 11 2.70 33.0 12 2.40 37.0 15 2.25 48.3 24 1.85 63.8 35 1.40 93 48 1.25 139 55 1.15 154 64 1.05 207 88 0.94 235 106 0.88 265 129 0.80 354 157 0.70 404 238 0.58 620 325 0.45 888 Temperature - 5 5 °C to +130 °C Inductance Saturation 3 @0ADC Current MAX (µH) 4.4 6.4 10.4 15.6 21.2 25.2 27.8 39.5 42.9 50.0 65.2 86.1 126 188 208 279 317 358 478 545 837 1199 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9401 becomes PL9401T). Mechanical 1 www.inrcore.com 0.68* 1.5* 2.2* 3.3* 4.7* 6.2* 6.8* 8.2* 10 12 15 22 33 47 56 68 82 100 120 150 220 330 (A) @25°C Heating 4 Current 7.00 6.10 5.70 4.80 4.10 3.60 3.30 3.00 2.70 2.40 2.25 1.85 1.40 1.25 1.15 1.05 0.94 0.88 0.80 0.70 0.58 0.45 (A) 13.00 9.30 7.40 5.90 5.00 4.50 4.15 3.50 3.25 2.85 2.65 2.25 1.85 1.45 1.35 1.20 1.08 1.00 0.93 0.83 0.75 0.73 NOTES FROM TABLE: (See back page) Electrical Schematic M123.E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL94XX Series Ruggedized Notes from Tables 4. The heating current is the DC current, which causes the temperature of the part to increase by approximately 40°C. This current is determined by extending the terminals of the component with 30mm length 28 gauge buss wires and applying the current to the device for 30 minutes. The temperature is measured by placing the thermo-couple between the winding and the shield. 5. In high volt*time applications, additional heating in the component can occur due to core losses in the inductor which may necessitate derating the current in order to limit the temperature rise of the compo-nent. In order to determine the approximate total loss (or temperature rise) for a given application, both copper losses and core losses should be taken into account. 1. Temperature of the component (ambient plus temperature rise) must be within specified operating temperature range. 2. The rated current as listed is either the saturation current or the heating current depending on which value is lower. 3. The saturation current is the current which causes the inductance to drop to 75% of its initial inductance at zero bias. This current is determined by placing the component at room ambient (25°C), and applying a short duration pulse current (to eliminate self-heating effects) to the component. TAPE & REEL LAYOUT Schematic 1 1 .177 Ø4,50 2 .421 10,70 Percentage of the intitial inductance .154 3,90 3 PL94XX 1 1 4 3 Date Code Country of Origin 2 .421 10,70 PL94XX 3 4 PL94XX Date Code Country of Origin Date Code Country of Origin 2 2 .630 16,00 .945 ± .012 24.00 ± 0,30 4 USER DIRECTION OF FEED Inductance vs. Current Characteristics 120% 100% 80% 60% 40% 20% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Normalized Isat 2 www.inrcore.com M123.E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL94XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M123.E (07/20)
PL9409T 价格&库存
很抱歉,暂时无法提供与“PL9409T”相匹配的价格&库存,您可以联系我们找货
