SMT POWER INDUCTORS
Shielded Drum Core - PL92XX Series
Ruggedized
Height: 0.201 inches (5.1mm) Max
Footprint: 0.413 inches x 0.413 inches (10.5mm x 10.5mm) Max
Inductance Range: 0.95µH to 890µH
Current Rating: up to 8.7A
Moisture Sensitivity Level: 1
Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C
Part
Numbers
PL9201
PL9202
PL9203
PL9204
PL9205
PL9206
PL9207
PL9208
PL9209
PL9210
PL9211
PL9212
PL9213
PL9214
PL9215
PL9216
PL9217
PL9218
PL9219
PL9220
PL9221
PL9222
PL9223
PL9224
PL9225
PL9226
PL9227
PL9228
PL9229
PL9230
PL9231
PL9232
Inductance @Irated
(µH TYP)
0.95
1.55
2.32
3.24
4.26
5.64
7.17
9.3
10.8
13.4
17.5
19.4
24.2
30.6
38.5
46.1
53.2
63.1
76.6
88
112
135
132
198
237
296
355
445
495
610
702
890
Irated 2
(A)
8.7
7.4
6.6
5.5
5.1
4.4
4.2
3.6
3.3
3.0
2.7
2.6
2.2
2.1
1.8
1.7
1.6
1.45
1.36
1.29
1.07
1.02
0.87
0.82
0.78
0.66
0.58
0.54
0.53
0.49
0.43
0.40
Inductance@0ADC
DCR (mΩ)
TYP
4.0
5.5
6.9
10.0
11.7
15.6
17.5
23
27
34
40
43
61
69
93
104
119
147
165
184
264
294
328
450
502
691
916
1037
1095
1220
1656
1885
MAX
5.7
7.9
10.0
14.5
16.5
22
25
35
37
47
58
67
79
94
126
140
157
202
232
270
316
456
497
681
775
955
1087
1403
1623
1824
2355
2850
(µH)
1.0*
1.6*
2.7*
3.6*
4.5*
6.0*
7.6*
10
12
15
18
22
27
33
39
47
56
68.0
82.0
100.0
120.0
150.0
180.0
220.0
270
330
390
470
560
680
820
1000
Saturation 3Current
(A) @25°C
11
8.8
7.3
6.3
5.5
4.9
4.4
4.0
3.7
3.4
2.9
2.8
2.4
2.2
2.0
1.8
1.7
1.6
1.4
1.3
1.2
1.05
0.96
0.86
0.79
0.71
0.66
0.59
0.54
0.49
0.45
0.41
Heating 4
Current (A)
8.7
7.4
6.6
5.5
5.1
4.4
4.2
3.6
3.3
3.0
2.7
2.6
2.2
2.1
1.8
1.7
1.6
1.45
1.36
1.29
1.07
1.02
0.87
0.82
0.78
0.66
0.58
0.54
0.53
0.50
0.43
0.40
*Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts.
Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9201 becomes PL9201T).
Notes from Tables
1. Temperature of the component (ambient plus temperature rise)
must be within specified operating temperature range.
2. The rated current as listed is either the saturation current or the
heating current depending on which value is lower.
3. The saturation current is the current which causes the inductance
to drop to 75% of its initial inductance at zero bias. This current is
determined by placing the component at room ambient (25°C),
and applying a short duration pulse current (to eliminate
self-heating effects) to the component.
1
www.inrcore.com
4. The heating current is the DC current, which causes the temperature of the
part to increase by approximately 40°C. This current is determined by
extending the terminals of the component with 30mm length 28 gauge buss
wires and applying the current to the device for 30 minutes. The temperature is
measured by placing the thermo-couple between the winding and the shield.
5. In high volt*time applications, additional heating in the component can occur
due to core losses in the inductor which may necessitate derating the current in
order to limit the temperature rise of the compo-nent. In order to determine the
approximate total loss (or temperature rise) for a given application, both copper
losses and core losses should be taken into account.
M122.E(07/20)
SMT POWER INDUCTORS
Ruggedized
Electrical Schematic
Mechanical
TAPE & REEL LAYOUT
Schematic
1
1
.161
Ø4,10
2
.421
10,70
3
Percentage of the intitial inductance�
.209
5,30
1
1
4
PL92XX
3
PL92XX
3
4
PL92XX
Date Code
Countr y of Or igin
Date Code
Countr y of Or igin
Date Code
Countr y of Or igin
2
2
2
.421
10,70
.630
16,00
.945 ± .012
24.00 ± 0,30
4
USER DIRECTION
OF FEED
Inductance vs. Current Characteristics
120%
100%
80%
60%
40%
20%
0%
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Normalized Isat
2
www.inrcore.com
M122.E(07/20)
SMT POWER INDUCTORS
Ruggedized
For More Information
Global Sales Representatives and Lo cations:
http://www.inrcore.com
iNRCORE,LLC
311 Sinclair Road Bristol,
PA 19007-6812 U.S.A
Tel: + 1.215.781.6400
Fax: +1.215.7816430
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names
mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved.
3
www.inrcore.com
M122.E(07/20)
很抱歉,暂时无法提供与“PL9201T”相匹配的价格&库存,您可以联系我们找货
