SS22B THRU SS2200B
Reverse Voltage - 20 to 200 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
DO-214AA/SMB
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
Built-in strain relief,ideal for automated placement
0.185(4.70)
0.160(4.06)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.220(5.59)
0.200(5.08)
Case: JEDEC DO-214AA/SMB molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.003 ounce, 0.093 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
VRRM
VRMS
VDC
SS22
SS23
SS24
SS25
SS26
SS28
SS210
MDD
SS22B
MDD
SS23B
MDD
SS24B
MDD
SS25B
MDD
SS26B
MDD
SS28B
MDD
SS210B
MDD
SS2150B
MDD
SS2200B
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
I(AV)
SS2150
SS2200
2.0
UNITS
V
V
V
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 2.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
45
55
0.55
0.70
0.85
A
0.95
0.5
IR
0.3
5.0
3.0
CJ
220
V
mA
110
pF
Typical thermal resistance (NOTE 2)
RJA
60
℃/W
Operating junction temperature range
TJ
-50 to +125
TSTG
-50 to +150
Storage temperature range
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS22B THRU SS2200B
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 F
Fo
or w a r d C
Cu
ur r e n t D
De
er a t i n g C
Cu
ur v e
10 4
T J =75°C
10
2
10
1
SS22B~SS26B
10 0
60
80
Fig.4 Typical Junction Capacitance
T J =25°C
10
1.0
SS22B ~ SS25B
SS26B
SS28B/SS210B
SS2150B/SS2200B
0.1
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS22B~SS26B
SS28B~SS2200B
10
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
60
SS22B-SS26B
SS28B-SS2200B
50
40
30
1000
1.8
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
Junction Capacitance (pF)
T J =25°C
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
SS28B~SS2200B
T J =25°C
Case Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS22B THRU SS2200B
Packing information
unit:mm
P0
P1
Item
Symbol
Tolerance
SMB
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 50
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Unit (inch)
Symbol
Unit (mm)
A
2.8
0.110
B
0.094
C
2.4
4.6
0.181
D
2.2
0.086
E
7.0
0.276
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS24B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63940
- 200+0.21275
- 1500+0.13340
- 3000+0.10580
- 国内价格
- 20+0.18747
- 300+0.14933
- 1200+0.12834
- 国内价格
- 20+0.22508
- 200+0.17734
- 600+0.15077
- 3000+0.12550
- 9000+0.11178
- 21000+0.10433
