85
DATA SHEET
SURFACE MOUNT MULTILAYER
CERAMIC CAPACITORS
Automotive grade
NP0/X7R
6.3 V TO 630 V
0.2 pF to 680nF
Product Specification – July 5, 2021 V.13
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
Automotive grade
NP0/X7R
6.3 V to 630 V
2
23
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
Automotive grade NP0/X7R series
chip capacitors with lead-free
terminations and used for
automotive equipments.
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
GLOBAL PART NUMBER
AC
XXXX X X XXX X
(1)
APPLICATIONS
All general purpose applications
Entertainment applications
Comfort / security applications
Information applications
(2) (3) (4)
B
(5)
X XXX
(6) (7)
(1) SIZE – INCH BASED (METRIC)
0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) /
1812 (4532)
(2) TOLERANCE
B = ± 0.1 pF
FEATURES
AEC-Q200 qualified
MSL class: MSL 1
AC series soldering is
compliant with J-STD-020D
High component and
equipment reliability
The capacitors are 100%
performed by automatic optical
inspection prior to taping.
C = ± 0.25 pF
D = ± 0.5 pF
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
M = ± 20%
(3) PACKING STYLE (SEE FIG. 9 FOR DETAIL)
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
(4) TC MATERIAL
NPO
X7R
(5) RATED VOLTAGE
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
0 = 100 V
A = 200 V
Y = 250 V
B = 500 V
Z = 630 V
(6) PROCESS
N = NP0
B = Class 2 MLCC
(7) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Jul. 05, 2021 V.13
3
NP0/X7R
Automotive grade
23
6.3 V to 630 V
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (Matte
Sn). The terminations are leadfree. A cross section of the
structure is shown in Fig.1.
terminations
electrodes
MLB457
Fig. 1 Surface mounted multilayer ceramic capacitor construction
ceramic material
OUTLINES
DIMENSION
Table 1 For outlines see fig. 2
TYPE
L1 (mm)
W (mm)
T (MM)
0201
0.6 ± 0.03
0.3± 0.03
0402
1.0 ± 0.05
0603
L2 / L3 (mm)
L4 (mm)
min.
max.
min.
0.3± 0.03
0.10
0.20
0.20
0.5 ± 0.05
0.5 ± 0.05
0.15
0.35
0.40
1.6 ± 0.10
0.8 ± 0.10
0.8 ± 0.10
0.20
0.60
0.40
2.0 ± 0.10
1.25 ± 0.10
0.25
0.75
0.70
2.0 ± 0.20
1.25 ± 0.20
3.2 ± 0.15
1.6 ± 0.15
3.2 ± 0.30
1.6 ± 0.20
0.25
0.75
1.40
3.2 ± 0.30
1.6 ± 0.30
3.2 ± 0.20
2.5 ± 0.20
3.2 ± 0.30
2.5 ± 0.20
0.25
0.75
1.40
3.2 ± 0.40
2.5 ± 0.30
2.5 ± 0.20
1808
4.5 ± 0.40
2.0 ± 0.30
1.25 ± 0.20
0.25
0.75
2.20
1812
4.5 ± 0.40
3.2 ± 0.30
0.25
0.75
2.20
0.25
0.75
3.40
0805
1206
1210
For dimension see Table 1
W
T
L2
L4
L1
L3
MBB211
0.6 ± 0.10
0.85 ± 0.10
1.25 ± 0.20
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
0.6 ± 0.10
0.85 ± 0.10
1.25 ± 0.20
1.6 ± 0.20
1.6 ± 0.30
0.85 ± 0.10
1.25 ± 0.20
1.6 ± 0.20
2.0 ± 0.20
0.85 ± 0.10
1.25 ± 0.20
1.60 ± 0.20
2020
5.7 ± 0.40
5.0 ± 0.30
0.85
0.10
2.0 ±±0.20
1.25 ± 0.20
1.25 ± 0.20
1.6 ± 0.20
1.6 ± 0.20
www.yageo.com
Jul. 05, 2021 V.13
4
Automotive grade
CAPACITANCE RANGE & THICKNESS FOR NP0
Table 2 Sizes from 0201 to 0805
0201
0402
0603
CAP.
25 V / 50 V
NP0/X7R
6.3 V to 630 V
23
0805
50 V
50 V
100 V
250 V
50 V
100 V
250V
0.2 pF
0.3± 0.03
0.47 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.56 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.68 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.82 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.0 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.5 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.8 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.7 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.3 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.9 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
4.7 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
5.6 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
6.8 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
8.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
10 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
12 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
15 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
18 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
22 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
27 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
33 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
39 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
47 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
56 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
68 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
82 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
100 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-12 series is on request
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
5
23
Table 3 Sizes from 0402 to 0805 (continued)
CAP.
0402
0603
50 V
50 V
100 V
250 V
0805
50 V
100 V
250 V
120 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
150 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
180 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
220 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
270 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
330 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
390 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
470 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
560 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
680 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
820 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.0 nF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.2 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
1.5 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
1.8 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
2.2 nF
0.8± 0.1
0.8± 0.1
1.25± 0.2
1.25± 0.2
2.7 nF
1.25± 0.2
1.25± 0.2
3.3 nF
1.25± 0.2
1.25± 0.2
3.9 nF
1.25± 0.2
1.25± 0.2
4.7 nF
1.25± 0.2
1.25± 0.2
5.6 nF
1.25± 0.2
1.25± 0.2
6.8 nF
1.25± 0.2
1.25± 0.2
8.2 nF
1.25± 0.2
1.25± 0.2
10 nF
1.25± 0.2
1.25± 0.2
NOTE
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
6
23
Table 4 Sizes from 1206 to 1210
CAP.
1210
1206
50 V
100 V
250 V
500 V
630 V
10 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
12 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
15 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
18 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
22 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
27 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
33 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
39 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
47 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
56 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
68 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
50 V
100 V
250 V
500 V
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
82 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
100 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
120 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
150 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
180 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
220 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
270 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
330 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
390 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
470 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
560 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
680 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
820 pF
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.0 nF
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.2 nF
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.5 nF
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.8 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.2 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.7 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
NOTE
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
7
23
CAPACITANCE RANGE & THICKNESS FOR X7R
Table 5 Sizes from 0201 to 0603
CAP.
0201
25V
0603
0402
50 V
10V
16 V
25 V
50 V
100 V
10V
16 V
25 V
50 V
100 V
1.0 nF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.5 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.2 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.3 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
4.7 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
6.8 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
10 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
15 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
22 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
33 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
47 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
68 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
100 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
150 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
220 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
330 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
470 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
680 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
100 pF 0.3± 0.03 0.3± 0.03
150 pF 0.3± 0.03 0.3± 0.03
220 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
330 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
470 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
680 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
NOTE
2. Capacitance value of non E-6 series is on request
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
8
23
Table 6
Size 0805
0805
CAP.
10 V
16 V
25 V
50 V
100 V
250 V
500 V
1.0 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.5 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
2.2 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
3.3 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
4.7 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
6.8 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
10 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
15 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
22 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
33 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
47 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
68 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
330 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
470 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
680 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
1.25± 0.2
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
NOTE
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
9
23
6.3 V to 630 V
Table 7 Size 1206
1206
CAP.
6.3 V
10V
16V
25V
50 V
100 V
250 V
500 V
630 V
1 nF
1.25± 0.2
1.25± 0.2
2.2 nF
1.25± 0.2
1.25± 0.2
4.7 nF
1.25± 0.2
1.25± 0.2
10 nF
1.25± 0.2
1.25± 0.2
22 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
33 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
47 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
68 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.60± 0.2
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.60± 0.2
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
330 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
1.60± 0.2
470 nF
1.00± 0.1
1.00± 0.1
1.00± 0.1
1.00± 0.1
1.60± 0.2
1.60± 0.2
680 nF
1.15± 0.1
1.15± 0.1
1.15± 0.1
1.60± 0.2
1.60± 0.2
1.60± 0.2
Table 8
Size 1210
CAP.
1812
1210
6.3V
10 V
16 V
25 V
50V
100 V
250 V
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
330 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
2.0± 0.2
470 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
680 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
50V
100V
2.0± 0.2
1.60± 0.2
1.60± 0.2
2.0± 0.2
1.60± 0.2
1.60± 0.2
NOTE
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
10
23
THICKNESS CLASSES AND PACKING QUANTITY
Table 9
SIZE CODE
THICKNESS
CLASSIFICATION
PACKING CODE
7 INCH
13 INCH
QUANTITY PER REEL
TAPE WIDTH
Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
0201
0.3 ± 0.03 mm
R
P
8 mm
15,000
50,000
0402
0.5 ± 0.05 mm
R
P
8 mm
10,000
50,000
0603
0.8 ± 0.1 mm
R
P
8 mm
4,000
15,000
0.6 ± 0.1 mm
R
P
8 mm
4,000
20,000
0.85 ± 0.1 mm
R
P
8 mm
4,000
15,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
0.6 ± 0.1 mm
R
P
8 mm
4,000
20,000
0.85 ± 0.1 mm
R
P
8 mm
4,000
15,000
1.0/1.15 ± 0.1 mm
K
F
8 mm
3,000
10,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
0.85 ± 0.1 mm
K
F
8 mm
4,000
10,000
1.15 ± 0.1 mm
K
F
8 mm
3,000
10,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
2.0 ± 0.2 mm
K
8 mm
2,000
2.5 ± 0.2 mm
K
8 mm
1,000
0.6 / 0.85± 0.1 mm
K
12 mm
2,000
1.15± 0.1 mm
K
12 mm
1,000
1.25± 0.2 mm
K
12 mm
1,000
1.6 ± 0.2 mm
K
12 mm
2,000
0805
1206
1210
1812
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
11
23
6.3 V to 630 V
PAPER/PE TAPE SPECIFICATION
P0
D0
T
P2
E
F
cover tape
W
B0
K0
A0
P1
MBG251-1
Fig. 3 Paper/PE tape
Table 10 Dimensions of paper/PE tape for relevant chip size; see Fig.3
SIZE
Unit: mm
SYMBOL
CODE A0
B0
W
E
F
P0
(1)
P1
P2
Ø D0
K0
T
0.38 ± 0.05
(0.47 / 0.55)±0.10
0201
0.39 ± 0.06 0.70 ± 0.06
8.0 ± 0.20
1.75 ± 0.1
3.50 ± 0.05 4.0 ± 0.05
2.0 ± 0.05
2.0 ± 0.05
1.55 ± 0.03
0402
0.70 ± 0.15 1.21 ± 0.12
8.0 ± 0.20
1.75 ± 0.1
2.0 ± 0.05
2.0 ± 0.05
1.50 +0.1 /-0 (0.75 / 0.60)±0.10
(0.85 / 0.70)±0.10
0603
1.05 ± 0.14 1.86 ± 0.13
8.0 ± 0.20
1.75 ± 0.1
3.50 ± 0.05 4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10
(1.15 / 1.05 / 0.85)±0.10
0805
1.50 ± 0.15 2.26 ± 0.20
8.0 ± 0.20
1.75 ± 0.1
4.0 ± 0.10
2.0 ± 0.05
1206
1.90 ± 0.15 3.50 ± 0.20
8.0 ± 0.20
1.75 ± 0.1
4.0 ± 0.10
2.0 ± 0.05
1.50 +0.1 /-0 (0.95 / 0.75)±0.10
(1.05 / 0.85)± 0.10
NOTE
1. P0 pitch tolerance over any 10 pitches is 0.2 mm
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
12
23
6.3 V to 630 V
BLISTER TAPE SPECIFICATION
P0
D0
K0
P2
E
F
cover tape
W
B0
A0
T2
SCM015
D1
P1
K0: so chosen that the orientation of the component
cannot change
For W = 8 mm: T2 = 3.5 mm max.
For W = 12 mm: T2 = 6.5 mm max.
direction of unreeling
Fig. 4 Blister tape
Table 11 Dimensions of blister tape for relevant chip size; see Fig.4
SYMBOL
SIZE
A0
B0
CODE
Unit: mm
K0
W
E
F
Min. Max. Min. Max. Min. Max.
Ø D0
Ø D1
P0
(2)
P1
P2
T2
Min.
Min. Max.
0805
1.29
1.65
2.09
2.60
1.25
1.62
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
1.5 +0.1/-0.0 1 +0.1/-0.0
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.30
1.67
1206
1.65
2.12
3.30
3.75
1.22
2.15
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.27
2.20
1210
2.55
3.02
3.31
3.88
0.97
2.92
8.1 ± 0.20
1.75 ± 0.1
3.5 ± 0.05
4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.02
2.97
1808
2.05
2.55
4.80
5.45
1.30
2.45
12.1 ± 0.20
1.75 ± 0.1
5.5 ± 0.05
1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10
4.0 ± 0.10
2.0 ± 0.05
1.35
2.50
1812
3.35
3.75
4.70
5.33
0.70
2.40
12.1 ± 0.20
1.75 ± 0.1
5.5 ± 0.05
8.0 ± 0.10
2.0 ± 0.05
0.75
2.45
NOTE
1. Typical capacitor displacement in pocket
2. P0 pitch tolerance over any 10 pitches is ±0.2 mm
www.yageo.com
Jul. 05, 2021 V.13
Automotive grade
NP0/X7R
6.3 V to 630 V
13
23
REEL SPECIFICATION
W2
C
N
A
HBK039
W1
Fig. 5 Reel
Table12 Reel dimensions; see Fig.5
TAPE WIDTH
SYMBOL
Unit: mm
A
N
C
W1
W2max.
8 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
9.4 ± 1.5
14.4
8 (Ø 330 mm/13")
330 ± 1.0
100 ± 1.0
13 +0.50/-0.20
9.0 ± 0.2
14.4
12 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
13.4 ± 1.5
18.4
P ROPERTIES OF REEL
Material: polystyrene
Surface resistance:
