Technical Data 10296
Effective October 2017
Supersedes August 2014
HCMA1707
Automotive grade
High current power inductors
Applications
Product features
Body electronics
• Central body control module
Headlamps, tai lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system
Car black box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
AEC-Q200 qualified
Digital instrument cluster
High current carrying capacity
In-vehicle infotainment (IVI) and navigation
Magnetically shielded, low EMI
Frequency range up to 1 MHz
Chassis and safety electronics
• Airbag control unit
Inductance range from 1.5 μH to 68 μH
Electronic stability control system (ESC)
Current range from 5.2 A to 40 A
Electric parking brake
17.5 mm x 17.2 mm footprint surface mount
package in a 7.0 mm height
Electronic Power Steering (EPS)
Iron powder core material
Anti-Lock Braking System (ABS)
Environmental Data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCMA1707
Automotive grade high current power inductors
Product Specifications
OCL1
±20%
(µH)
FLL min.2
(µH)
HCMA1707-1R5-R
1.5
HCMA1707-2R2-R
2.2
Part Number6
DCR (mΩ)
@ +20 °C
(typical)
DCR (mΩ)
@ +20 °C
(maximum)
K-factor5
40
1.85
2.15
124
34
2.15
2.50
103
Irms3
(A)
Isat4
(A)
0.96
40
1.41
37
HCMA1707-4R7-R
4.7
3.01
27
24
4.12
4.72
76
HCMA1707-6R8-R
6.8
4.35
6.55
7.55
60
HCMA1707-8R2-R
8.2
5.25
16
8.70
55
HCMA1707-100-R
10
6.40
14
18
9.30
10
47
HCMA1707-150-R
15
9.60
12
13
14.5
15.5
43
HCMA1707-220-R
22
14.1
9.5
11
21
23
37
HCMA1707-330-R
33
21.1
9.0
10
35
37
28
HCMA1707-470-R
47
30.1
6.8
7.5
41
47
25
HCMA1707-680-R
68
43.5
5.2
6.5
74
85
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc,
+25 °C.
2. Full Load Inductance (FLL): Test parameters: 100 kHz, 0.25 Vrms, Isat, +25 °C.
3. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I.
Bp-p :(Gauss), K: (K-factor from table), L: (Inductance in μH), ∆I (Peak to peak
ripple current in amps).
6. Part Number Definition: HCMA1707-yyy-R
- HCMA1707 = Product code and siz
yyy= Inductance value in uH, R = decimal point,
if no R is present then third character = number of zeros.
- “-R” suffix = RoHS compliant
4.. Isat : Peak current for approximately 20% rolloff at +25 °C.
Dimensions (mm)
HCMA1707
XXX
wwllyy R
a
b
DCR measured between point “a” and point “b”
2
www.eaton.com/electronics
All soldering surfaces coplanar within 0.10 millimeters.
Part marking: HCMA1707; A = Automotive grade, XXX = initial inductance in µH, R = decimal point;
if no R is present, last digit equals number of zeros.
wwllyy = date code, R = revision level
Color: Grey
Do not route traces or vias underneath the inductor
HCMA1707
Packaging information (mm)
HCMA1707
XXX
wwllyy R
Supplied in tape and reel packaging , 350 parts per 13” diameter reel
Temperature rise vs. total loss
50
Temperature Rise (˚C)
40
30
0.5
1.0
1.5
Total Loss ( W)
2.0
2.5
3
HCMA1707
Core loss vs. Bp-p
10000.0
500K
300K
200K
100K
50K
25K
Core Loss (mW)
1000.0
100.0
10.0
1.0
1000
100
10000
Bp-p (Gauss)
Inductance characteristics
HCMA1707 -2R2-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCMA1707 -1R5-R
80%
70%
60%
70%
60%
50%
50%
40%
Idc (A)
4
80%
40
50
60
70
40%
Idc (A)
40
50
60
70
HCMA1707
HCMA1707 -6R8-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCMA1707 -4R7-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
30
5
10
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
30
30
HCMA1707 -100-R
HCMA1707 -8R2-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
5
10
HCMA1707 -220-R
HCMA1707 -150-R
110%
100%
100%
90%
90%
% of OCL
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
4
15
Idc (A)
Idc (A)
% of OCL
15
Idc (A)
Idc (A)
40%
6
8
10
Idc (A)
12
14
16
18
4
6
8
10
12
14
16
18
Idc (A)
5
HCMA1707
HCMA1707-470-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCMA1707-330-R
80%
70%
60%
50%
50%
6
4
2
40%
10
12
14
16
18
HCMA1707-680-R
110%
100%
90%
80%
70%
60%
50%
40%
4
6
Idc (A)
4
6
Idc (A)
Idc (A)
% of OCL
70%
60%
40%
6
80%
8
10
12
14
8
10
12
14
HCMA1707
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCMA1707-330-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.214431+3.52019
- 10+22.3560110+2.89175
- 25+20.6842525+2.67551
- 50+19.5001550+2.52235
- 100+18.38678100+2.37833
- 国内价格 香港价格
- 350+16.53519350+2.13883
- 700+15.59374700+2.01705
- 1050+15.068851050+1.94916
- 1750+14.433141750+1.86693
- 2450+14.029722450+1.81475
- 3500+13.685383500+1.77021
- 国内价格 香港价格
- 144+63.94742144+8.27160
