RS721
10MHz, Rail-to-Rail I/O
CMOS Operational Amplifier
FEATURES
DESCRIPTION
HIGH GAIN BANDWIDTH:10MHz
RAIL-TO-RAIL INPUT AND OUTPUT
1mV Typical Vos
INPUT VOLTAGE RANGE: -0.1V to +5.6V
with Vs = 5.5V
SUPPLY RANGE: +2.5V to +5.5V
SPECIFIED UP TO +125°C
MicroSIZE
The RS721 offer low voltage operation and rail-to-rail
input and output, as well as excellent speed/power
consumption ratio, providing an excellent bandwidth
(10MHz) and slew rate of 7V/us. The op-amps are
unity gain stable and feature an ultra-low input bias
current.
The devices are ideal for sensor interfaces, active
filters and portable applications. The RS721 is
specified at the full temperature range of −40°C to
+125°C under single supplies of 2.5V to 5.5V or dual
power supplies of ±1.25V to ±2.75V.
PACKAGES: SOT353(SC70-5)
APPLICATIONS
SENSORS
PHOTODIODE AMPLIFICATION
ACTIVE FILTERS
TEST EQUIPMENT
DRIVING A/D CONVERTERS
PIN CONFIGURATIONS
RS721
OUT
1
V-
2
+IN
3
5
V+
4
-IN
SOT353(SC70-5)
REV B.1
1
www.run-ic.com
RS721
ABSOLUTE MAXIMUM RATINGS (1)
Supply Voltage, V+ to V-...............................................7.0V
Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V
Current (2)…………………....…..... ±10mA
Storage Temperature ……….…………… −65°C to +150°C
Operating Temperature ……….………… −40°C to +125°C
Junction Temperature................................................150°C
Package Thermal Resistance @ TA = +25°C
SOT23-5, SOT23-6………………….………………200°C/W
MSOP-10, SOIC-8 …………………….…………... 150°C/W
SOIC-14, TSSOP-14……….….….….…..…………100°C/W
Lead Temperature (Soldering, 10s) ……………........260°C
ESD Susceptibility
HBM …......................................................................3000V
MM ……………………….........………………...……….200V
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance
degradation to complete device failure. Precision
integrated circuits may be more susceptible to
damage because very small parametric changes
could cause the device not to meet its published
specifications.
(1) Stresses above these ratings may cause permanent damage. Exposure to
absolute maximum conditions for extended periods may degrade device
reliability. These are stress ratings only, and functional operation of the
device at these or any other conditions beyond those specified is not
implied.
(2) Input terminals are diode-clamped to the power-supply rails. Input
signals that can swing more than 0.5V beyond the supply rails should
be current-limited to 10mA or less.
PACKAGE/ORDERING INFORMATION
PRODUCT
ORDERING NUMBER
RS721
RS721XC5
TEMPERATURE
RANGE
-40℃~125℃
PACKAGE LEAD
SOT353(SC70-5)
2
PACKAGE
MARKING
RS721
PACKAGE OPTION
Tape and Reel,3000
www.run-ic.com
RS721
ELECTRICAL CHARACTERISTICS
(At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.)
PARAMETER
CONDITIONS
RS721
TJ
MIN
TYP
MAX
UNIT
5.5
V
1.15
1.55
mA
POWER SUPPLY
Vs
IQ
25°C
Operating Voltage Range
Quiescent Current/Amplifier
PSRR Power-Supply Rejection Ratio
2.5
25°C
25°C
Vs= 2.5V to 5.5V
Vcm =(V-)+0.5V –40°C to 125°C
77
90
dB
68
INPUT
Vos Input Offset Voltage
Vcm=2.5V
Vos TC Input Offset Voltage Average Drift -40°C to 125°C
IB
Input Bias Current
Ios
Input Offset Current
Vcm
Common-Mode Voltage Range
CMRR Common-Mode Rejection Ratio
25°C
±1
±3
2.6
mV
uV/°C
25°C
1
10
pA
25°C
1
10
pA
5.6
V
Vs=5.5V
25°C
-0.1
Vs = 5.5V, Vcm
=-0.1V to 4V
25°C
77
–40°C to 125°C
70
Vs = 5.5V, Vcm
= -0.1V to 5.6V
25°C
63
–40°C to 125°C
60
RL =2KΩ, Vo =
0.15V to 4.85V
25°C
96
–40°C to 125°C
75
90
80
dB
OUTPUT
AOL
Open-Loop Voltage Gain
RL = 2KΩ
RL = 10kΩ
100
110
dB
77
25°C
25°C
52
7
mV
25°C
150
mA
Slew Rate
Gain-Bandwidth Product
25°C
7
V/us
25°C
10
MHz
Phase Margin
25°C
62
0.2
us
0.35
us
Output Swing From Rail
Iout
25°C
RL = 10kΩ, Vo =
0.05V to 4.95V
–40°C to 125°C
105
Output Short-Circuit Current
FREQUENCY RESPONSE
SR
GBP
Φm
ts
Settling Time, 0.1%
Overload Recovery Time
VIN • Gain ≥ Vs
NOISE
en
Input-Referred Voltage Noise
f = 1 kHz
25°C
9.5
nV/√Hz
f = 10 kHz
25°C
6.5
nV/√Hz
3
www.run-ic.com
RS721
TYPICAL CHARACTERISTICS
At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted.
COMMON−MODE REJECTION RATIO vs
FREQUENCY
OPEN−LOOP GAIN AND PHASE vs FREQUENCY
120
160
Gain
120
100
60
80
40
60
CMRR(dB)
Phase
80
Phase Margin (°)
Open-Loop Gain(dB)
100
120
140
80
60
40
1K
100K
10M
1
1K
INPUT VOLTAGE NOISE
SPECTRAL DENSITY vs FREQUENCY
POWER−SUPPLY REJECTION RATIO vs
FREQUENCY
10K
120
PSRR(dB)
100
10
80
60
40
1
100
1K
10K
100K
1
10
Frequency(Hz)
100
1K
10K
Frequency(KHz) Vs=5V
QUIESCENT CURRENT vs TEMPERATURE
1.3
1.6
1.5
Quiescent Current(mA)
100
100
Voltage Noise (nV/√Hz)
10
Frequency(Hz)
1.4
1.3
1.2
1.1
1
0.9
1.2
1.1
1
0.9
0.8
0.8
-40 -20
20 40 60 80 100 120 140
Temperature(℃) Vs=2.7V
4
Temperature(℃) Vs=5V
www.run-ic.com
RS721
INPUT BIAS CURRENT vs TEMPERATURE
SMALL−SIGNAL STEP RESPONSE
CL=100PF
1K
50mV/div
Input Bias Current(pA)
10K
100
10
1
0.1
-40 -20
60
200ns/div
80 100 120 140
Temperature(℃)
POSITIVE OVERLOAD RECOVERY
CL=100PF
200mV/div
LARGE−SIGNAL STEP RESPONSE
0V
1V/div
VIN
VS=±2.5V
G=-100
1V/div
VOUT
0V
400ns/div
500ns/DIV
VIN
0V
200mV/div
NEGATIVE OVERLOAD RECOVERY
1V/div
0V
VOUT
VS=±2.5V
G=-100
500ns/div
5
www.run-ic.com
RS721
PACKAGE OUTLINE DIMENSIONS
SOT353 (SC70-5)
D
1.30
b
1.9
E
E1
0.75
Pin1
Index Area
0.65
0.4
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
c
θ
L
A1
Symbol
Dimensions In Millimeters
L1
Dimensions In Inches
Min
Max
Min
Max
A
0.900
1.100
0.035
0.043
A1
0.000
0.100
0.000
0.004
A2
0.900
1.000
0.035
0.039
b
0.150
0.350
0.006
0.014
c
0.080
0.150
0.003
0.006
D
2.000
2.200
0.079
0.087
E
1.150
1.350
0.045
0.053
E1
2.150
2.450
0.085
0.096
e
0.650(BSC)
0.026(BSC)
e1
1.300(BSC)
0.051(BSC)
L
0.260
L1
θ
0.460
0.010
0.525
0°
0.018
0.021
8°
6
0°
8°
www.run-ic.com
很抱歉,暂时无法提供与“RS721XC5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.76210
- 10+2.72067
- 600+2.69346
- 1200+2.63959
- 3000+2.56040
- 国内价格
- 5+3.01320
- 50+2.24640
- 150+1.92240
- 500+1.51200
