PL8508
PL8508
    INRCORE
    固定电感器 Nonstandard 331µH ±10% 660mA 972mΩ
PL8508 数据手册
SMT POWER INDUCTORS Toroid Series Ruggedized Ruggedized header with SLED rails for secure board mounting Current Rating: up to 3.8ADC Inductance Range: 9.4µH to 439µH Moisture Sensitivity Level: 1 Part 9 Number Inductance @ Irated (µH) SLED 25 PL8500 PL8501 PL8502 PL8503 PL8504 PL8505 PL8506 PL8507 PL8508 PL8509 9.4 13.3 23 50 75 90 137 200 305 439 Electrical Spe cifications @ 25°C — Operating Temperature - 40 °C to +130 °C 100 Gauss DCR (mΩ) Inductance ET Irated @ 0ADC ET100 (A ) (V-µsec) TYP MAX (µH ±10%) (V-µsec) 3.80 3.20 2.40 1.60 1.30 1.20 1.00 0.82 0.66 0.56 27 40 65 121 181 246 387 585 845 1322 NOTES: 1. The reference inductance at rated DC current is a typical value. 2. Temperature rise is 50°C in typical buck or boost circuits at 250kHz and with the reference ET applied to the inductor. 3. Total loss in the inductor is 380mW for 50°C temperature rise above ambient. 4. To estimate temperature rise in a given application, determine copper and core losses, divide by 380 and multiply by 50. 5. For the copper loss, calculate IDC2 X RN. 6. For core loss, using frequency (f) and operating flux density (B), calculate 6.11 x 10-18 x B2.7 x f2.04. Mechanical 1 www.inrcore.com 32 46 74 135 220 285 425 673 972 1520 15.2 18.8 24.3 37.0 44.3 49.2 59.4 71.3 85.8 99.6 10.4 14.6 25 56 83 100 152 220 331 472 2.65 3.13 4.10 6.15 7.47 8.19 10.12 12.17 14.94 17.83 1 Amp DC H1 (Orsted) 11.95 14.12 18.46 27.69 33.67 36.93 45.61 54.85 67.34 80.37 7. For flux density (B), calculate ET (V-µsec) for the application, divide by ET100 from the table, and multiply by 100. 8. Limit the DC bias (H) to 46 orsteds. Calculate H by multiplying H1 from the table by IDC of the application. 9. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL8500 becomes PL8500T). Electrical Schematic M113.E (07/20) SMT POWER INDUCTORS Toroid Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 2 www.inrcore.com M113.E (07/20)
PL8508
物料型号为INRCORE系列,器件简介为SMT功率电感器,具有加固的引脚和SLED导轨,用于安全地固定在电路板上。
电流额定值最高可达3.8A DC,电感范围从9.4µH到439µH,湿度敏感等级为1级。
电气规格在25°C下,工作温度范围为-40°C至+130°C。
引脚分配未在文档中明确说明,但通常这类电感器会有至少两个引脚用于连接电源和地。
参数特性包括额定电流、电感值、直流电阻、电流上升时间、电感值在额定电流下的偏差、100戈斯电流下的电流上升时间、1安培直流下的磁场强度等。
功能详解涉及电感器在不同电流和温度下的电气性能,以及如何计算温度上升、铜损和核心损耗。
应用信息包括电感器的推荐应用场景,如电源管理、开关电源等。
封装信息包括尺寸、公差、推荐的焊盘布局、以及可选的卷带包装方式。
更多详细信息和技术支持,可访问INRCORE官方网站。
PL8508 价格&库存
很抱歉,暂时无法提供与“PL8508”相匹配的价格&库存,您可以联系我们找货
